Giriş
Use this guide to remove or replace the battery on your Xiaomi Redmi Note 8 Pro.
If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
Neye ihtiyacın var
Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a small gap between the rear glass and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner of your phone.
Slide the opening pick along the left edge of your phone to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Carefully lift to rear glass upwards whilst pressing down the camera cover with a finger.
Remove the rear glass.
Insert the pointed end of a spudger into the gap next to the fingerprint connector cover.
Use the spudger to pry up the connector cover by tilting the spudger downwards. This might require some force.
Use a spudger to disconnect the fingerprint reader cable by prying the connector straight up from its socket.
Use a Phillips screwdriver to remove the ten 3.9 mm-long screws securing the motherboard cover.
Slide an opening pick underneath the black foil covering the battery and interconnect cable.
Use the opening pick to carefully separate the black foil from the battery and the interconnect cable.
Insert the tip of an opening pick underneath the bottom right corner of the motherboard cover.
Slide the opening pick along the right edge of the motherboard cover to unhinge the plastic clips and pry it up.
Insert the opening pick underneath the top edge of the motherboard cover and pry it up.
Remove the motherboard cover.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
Carefully slide an opening pick underneath the black foil covering the battery and the loudspeaker assembly to loosen its adhesive.
Remove the black protective foil.
Fold the interconnect flex cable towards the charging port in order to get free access to both battery pull tabs.
Grab the first pull-tab with a pair of tweezers or your fingers and slowly pull it away from the battery and towards the bottom edge of your phone.
Pull hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and un-stick from under the battery.
Don't press down on the battery. Hold the phone firmly by its sides.
Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling mainly in the middle or on one side.
Pull at a low angle so the strip doesn't snag on the edge of the battery.
If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
Repeat the previous pull-tab removal procedure on the second pull-tab.
Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
Wait about one minute for the alcohol solution to weaken the adhesive.
Use the flat end of a spudger to gently lift the battery.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
20 farklı kişi bu kılavuzu tamamladı.
2 Yorum
очень интересно, но лучше отнести в сервис. не на себя же потом пенять..
the isopropanol seeped into my screen, shoot.
