Ana içeriğe geç
iPad 5 Wi-Fi Battery Replacement
Neye ihtiyacın var
  1. iPad 5 Wi-Fi Battery Replacement, Heat the left edge: adım 1, 1 resimden 1.
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. iPad 5 Wi-Fi Battery Replacement, Screen removal information: adım 2, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement, Screen removal information: adım 2, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement, Screen removal information: adım 2, 3 resimden 3.
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. iPad 5 Wi-Fi Battery Replacement, Anti-Clamp instructions: adım 3, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement, Anti-Clamp instructions: adım 3, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement, Anti-Clamp instructions: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad 5 Wi-Fi Battery Replacement: adım 4, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 4, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 4, 3 resimden 3.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad 5 Wi-Fi Battery Replacement: adım 5, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 5, 2 resimden 2.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad 5 Wi-Fi Battery Replacement, Insert an opening pick: adım 6, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement, Insert an opening pick: adım 6, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement, Insert an opening pick: adım 6, 3 resimden 3.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  7. iPad 5 Wi-Fi Battery Replacement, Separate the left adhesive: adım 7, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement, Separate the left adhesive: adım 7, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement, Separate the left adhesive: adım 7, 3 resimden 3.
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. iPad 5 Wi-Fi Battery Replacement: adım 8, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 8, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 8, 3 resimden 3.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. iPad 5 Wi-Fi Battery Replacement: adım 9, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 9, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 9, 3 resimden 3.
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. iPad 5 Wi-Fi Battery Replacement, Heat the top edge: adım 10, 1 resimden 1.
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
  11. iPad 5 Wi-Fi Battery Replacement, Separate the top left adhesive: adım 11, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement, Separate the top left adhesive: adım 11, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement, Separate the top left adhesive: adım 11, 3 resimden 3.
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
  12. iPad 5 Wi-Fi Battery Replacement, Separate the top adhesive: adım 12, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement, Separate the top adhesive: adım 12, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement, Separate the top adhesive: adım 12, 3 resimden 3.
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. iPad 5 Wi-Fi Battery Replacement: adım 13, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 13, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 13, 3 resimden 3.
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. iPad 5 Wi-Fi Battery Replacement: adım 14, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 14, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 14, 3 resimden 3.
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. iPad 5 Wi-Fi Battery Replacement, Heat the right edge: adım 15, 1 resimden 1.
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  16. iPad 5 Wi-Fi Battery Replacement, Separate the top right adhesive: adım 16, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement, Separate the top right adhesive: adım 16, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement, Separate the top right adhesive: adım 16, 3 resimden 3.
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  17. iPad 5 Wi-Fi Battery Replacement, Separate the right adhesive: adım 17, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement, Separate the right adhesive: adım 17, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement, Separate the right adhesive: adım 17, 3 resimden 3.
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
  18. iPad 5 Wi-Fi Battery Replacement, Heat the bottom edge: adım 18, 1 resimden 1.
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  19. iPad 5 Wi-Fi Battery Replacement, Separate the bottom left adhesive: adım 19, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement, Separate the bottom left adhesive: adım 19, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement, Separate the bottom left adhesive: adım 19, 3 resimden 3.
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the bottom-left corner before moving to the next step.
  20. iPad 5 Wi-Fi Battery Replacement, Separate the bottom adhesive: adım 20, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement, Separate the bottom adhesive: adım 20, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement, Separate the bottom adhesive: adım 20, 3 resimden 3.
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. iPad 5 Wi-Fi Battery Replacement: adım 21, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 21, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 21, 3 resimden 3.
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
  22. iPad 5 Wi-Fi Battery Replacement: adım 22, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 22, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 22, 3 resimden 3.
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. iPad 5 Wi-Fi Battery Replacement, Heat the right edge: adım 23, 1 resimden 1.
  24. iPad 5 Wi-Fi Battery Replacement: adım 24, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 24, 2 resimden 2.
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. iPad 5 Wi-Fi Battery Replacement: adım 25, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 25, 2 resimden 2.
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  26. iPad 5 Wi-Fi Battery Replacement, Separate the right adhesive: adım 26, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement, Separate the right adhesive: adım 26, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement, Separate the right adhesive: adım 26, 3 resimden 3.
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  27. iPad 5 Wi-Fi Battery Replacement: adım 27, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 27, 2 resimden 2.
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  28. iPad 5 Wi-Fi Battery Replacement, LCD: adım 28, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement, LCD: adım 28, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement, LCD: adım 28, 3 resimden 3.
    • Remove any tape obscuring the LCD screws.
  29. iPad 5 Wi-Fi Battery Replacement: adım 29, 1 resimden 1.
    • Remove the following Phillips screws securing the LCD.
    • Three 4.0 mm screws
    • One 4.8 mm screw
    Use the provided replace screen case's square compartments to place your screws into as you remove them. Really helpful and you likely won't mess up.
    Travis Dixon - Yanıt
    I tape a stripe of double sided tape on my workbench. You can place the screws on the tape on the location where the screw would be if it was in the screen assembly. In this step, your screws would be in the four corners of the tape stripe, with the longest screw (4,8mm) in the upper left corner. The other screws from the next steps can also be placed on the tape this way.
    Brecht Bocket - Yanıt
    **I believe you mean the “top Right corner” Is where the longer screw goes.. not left.
    Amanda Felske -
    ! went to Office World bought 4 packs of bluetac stuck them on a sheet of paper to give approximately size and shape of iPad put it in a flat cardboard box
    John Smith - Yanıt
    Where can I buy these screws please ?
    Anthony Roberts - Yanıt
  30. iPad 5 Wi-Fi Battery Replacement: adım 30, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 30, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 30, 3 resimden 3.
    • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
    • Lay the LCD on its face to allow access to the display cables.
    • Set the LCD down on a soft, clean, lint-free surface.
    Got a cracked screen from toddler stepping on the iPad. My repair went well, everything worked. Except I scratched the LCD. It seems to scratch easily.
    At this step, be careful when folding over the screen, as it may scratch on the aluminum frame (third picture). When they say “soft lint free surface” that is needed, specifically where the LCD meets the frame. Place a thin cloth like sunglass cleaning cloth over the edge of the frame.
    Cobus de Beer - Yanıt
    Thank you, very much, for this tip.
    rcrandall85 -
    At this step, possibly depending on date of manufacture, there may be black silicone present on/around the four screws that mount the display. It needs to be carefully scraped away and the two screw mount holes at the top of the screen pried up and away from the chassis. Between the chassis and the plastic portion of the mounting frame, there is a slim sheet of metal. Be sure to pry this off WITH the mounting frame. It is part of it. DO NOT try to separate it.
    rcrandall85 - Yanıt
  31. iPad 5 Wi-Fi Battery Replacement: adım 31, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 31, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 31, 3 resimden 3.
    Battery Blocker
    $3.99
    • Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board.
    • To reduce the risk of a short, you can insert a battery blocker or a modified opening pick to disconnect the battery.
    • Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage.
    • Slide the battery blocker underneath the battery connector area of the logic board, and leave it in place while you work.
    • If you are having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery.
    Not having the isolation pick, I used 2 thin guitar picks instead, which did the job fine.
    goodcyning - Yanıt
    I couldn't disconnect the battery connector - I applied some force, nothing happened and I was afraid of applying too much force - so I just left it connected and I was very careful not to short out any terminals with metal tools. I completed the repair without any other issues and the iPad now seems to be working fine.
    Peter Gray - Yanıt
    Mine was missing. Made one with scissors but still didn't do the trick. I just worked with the batteries still plugged in.
    Couldn’t get the battery terminal disconnected so I continued with repair. I didn’t short anything but now it won’t do anything. It worked before, just a cracked glass to replace. Any solutions?
    Tech-ER - Yanıt
    Why do you say you didn’t short anything? Your result would seem to suggest otherwise
    John Marx -
    I don’t know if it applies to the iPad Air, but I saw elsewhere in my researches in reference to a iPad mini (or was it an iPod mini?) that disconnecting the LCD and/or digitizer with the battery still connected will blow a “fuse” for the backlight. Might yours still be working, just with no screen illumination whatsoever? Dunno. Just a thought.
    It apparently can be repaired, but is no longer a DIY job.
    Tim -
    try lifting the board and not blocking the connector. If you block the connector there are pins that could be damaged.
    Bryan Cruse - Yanıt
    A replacement of the battery connector is required if pins are bent should you get power on or charge issue after battery disconnection. This can be replaced with the right tools and low melt solder to remove the connector and replace.
    Best method to disconnect battery is to carefully lift the logic board near the battery connector enough to slip a piece of thin plastic or paper between the batter connector and the logic board battery connector and pins.
    Failing to isolate battery so can result in blown back light or touch filters or diodes in backlight circuit.
    At the very least run down the battery flat prior to repair but you are really best to isolate battery.
    markduff - Yanıt
    From a repair point of view. This connector is a royal pain. For assembly it's great, well, nearly great.
    This connector is SOLDERED to the motherboard side. Never lever this on the motherboard side, I will call it the right hand side. It will break leaving it's soldered pins behind. Yes I did it.
    The pins, on the battery side of this connector, just rest on the batteries plated pads. They are kept under tension by the screw. It should be noted though that removal of the screw will not disconnect the connector pins from the battery pads. Natural tension is still present.
    I suggest strongly that you take a look at the battery connector online to see the nature of the pins and you will see that some are quite delicate.
    The tools purpose is to raise the battery side of the connector ; the left side, so there is some clearance between the pins and the batteries pads. If you have seen a picture of this connector then you will realise the potential of damage to this connector and will have a better idea of what to do.
    Biskwit2 - Yanıt
    Contd.
    Lifting the connector and simultaneously sliding a thin piece of card or plastic under the pins should be done carefully. In fact, to minimise damage I just slid it under ONE of the main battery pins, plus or minus, which are in the middle and quite robust compared with the tiddlers on the side of the connector.
    The second point, the battery and the motherboard have protection circuitry. When I broke my connector the battery dropped to 0.5V at the terminals. Connecting the charger, when all the connections were sound and not shorted raised it from the dead back to over 3.2V
    Biskwit2 - Yanıt
    I replaced the battery, and got things hooked backup. For the test, the screen came on, digitizer seemed to be functioning fine. But I couldn’t get it to charge. I used the i-fixit battery blocker by using my spooger to put a little up pressure on the board, and then sliding the blocker in. I don’t think I damaged the pins, but its possible. This is a friends ipad, and its obviously been dropped a few times. I started eye balling the charging port, it LOOKS ok, but looks can be deceiving. When plugged in, even trying different cables, the ipad is not showing the charging symbol. Some of the comments here seem to imply, if I damaged the battery connection pins, I would still get a charging symbol. My question is, if I damaged those battery connector pins, would the ipad show the charging icon or not? Should I be looking at replacing the charging port?
    Mike Lindsay - Yanıt
    If you gently use the plastic opening tool as shown in step 94 to lift the board slightly it makes it MUCH easier to slide the battery blocker in.
    Kevin - Yanıt
  32. iPad 5 Wi-Fi Battery Replacement: adım 32, 1 resimden 1.
    • Remove the three 1.4 mm Phillips screws from the display cable bracket.
    Be careful when re-installing screws on reassembly. I mistakenly put the longer screw from the battery connector in the outboard hole, and wound up twisting off the lug that is only lightly soldered to the metal below. Still have 2 screws and system seems to work fine.
    Brian Anderson - Yanıt
  33. iPad 5 Wi-Fi Battery Replacement: adım 33, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 33, 2 resimden 2.
    • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
    • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
    bough my digitizer from ebay and have everything done up to this step. The screwdriver the kit came with said to be a #000 but it stripped the screw on the plate... I have tried rubber bands, tape and paper to no avail...anyone got an idea on how to remove the screw. Also I am currently studying in St. Kitts and they lack some products found in the US.
    originalpaintballpanda2 - Yanıt
    I'm sure you've moved past this by now, but I've had some success with stripped screws using a comparable, if slightly larger flathead screwdriver. The screwdrivers that come in those kits tend to suck quite a lot... iFixit actually has a guide for stripped screws: How to Remove a Stripped Screw
    goodcyning -
    Does anyone know where I could purchase a replacement display cable bracket?
    gwarren - Yanıt
    Note:Be rly carefule with unplugin homebutton-connection.
    The plug-connection (Homebutton) is not similar to the plug connections the basic-plugs got.
    The homeputton-plug-connection is sensetiv and cant unplug easly.
    IPad - Yanıt
  34. iPad 5 Wi-Fi Battery Replacement: adım 34, 1 resimden 1.
    • Remove the LCD.
    Andddddd continue this iFix folks! It's not a matter of working backwards. Most people must have cracked screens and end up having to rip the screen off and won't have a chance to inspect connections.
    He is far from complete…..if lcd is being replaced its probably because top screen is busted too. He didn’t show anything about how to remove the cables for that.
    B. A. Computer Services - Yanıt
    If the battery blocking method is outdated and dangerous, why not show us the new, safer method? Just a thought.
    hdrjunkie - Yanıt
    There is a separate guide for replacing the outer glass ;)
    Gerald Bowen - Yanıt
  35. iPad 5 Wi-Fi Battery Replacement, Front Panel Assembly: adım 35, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement, Front Panel Assembly: adım 35, 2 resimden 2.
    • Remove any tape covering the home button ribbon cable connector.
    I totally skipped steps 39-98 I didn’t see any need to remove all these components and the logic board just to get the battery out. I gently pried up the board where the battery connector goes in, slipped it out, and slipped in the new one.
    Seth Childers - Yanıt
    That is a great tip. There is plenty of space inside the case to lever out the battery without taking out all of the components. I laid the iPad on top of a large bean bag, heated for 3 minutes in the microwave. After 4-5 minutes, I was able to lever out the battery with the spudger and the credit cards. It came out after a few minutes of careful levering and cramming the credit cards under the battery. I unscrewed the earphone connector and carefully taped it back to the iPad housing with paint tape to have more room to maneuver.
    Jonathan Koehler -
    I second this.
    Just be careful to make sure you don’t squish or tear any wires or anything else surrounding when you’re fighting with the batteries, and it’s still way easier than removing everything else in there first.
    I’ll add one bit, though. The hole in the battery connector that accepts the screw through the logic board also apparently slips over a pin in which the screw seats. I couldn’t see that. So when I got the last bit of battery adhesive to let go, the pin tore out the battery connector hole. Since I was replacing the battery, it wasn’t a problem, but did produce a little conductive piece that I had to fish out before putting anything back together. Wouldn’t want that little torn out piece running around in there to short something out later.
    Also, that pin will locate the battery correctly, so that in one of the last steps of reassembly, the battery connection screws together properly. Make sure you find it before the battery adhesive grabs on to the back of the case.
    Tim -
    Careful removing the tape. The home button has a zif connector and if you aren’t careful the tape can rip the zif flap right off. You might have to hold it down while you pull it off or pull the tape from a different direction to make sure you dont tear the zif tab off.
    Sarah Ybarra - Yanıt
  36. iPad 5 Wi-Fi Battery Replacement: adım 36, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 36, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 36, 3 resimden 3.
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable horizontally out of the ZIF connector.
    I got through the repair, only to have the new screen give me problems that I can not find solutions to any where. The digitizer is working on its own without my input, it will start apps, switch windows, etc. I have pulled up the new screen and checked my ribbons and cables seem to be fine. ANY IDEAS??
    Moses Roman - Yanıt
    Moses Roman
    Same exact problem that I have. I think it has something to do with the glass touching the ipad. Something like on the iPad mini, where you had to cover some areas beside the home button.
    I would love to see a real solution, as im stuck with unhappy customers and frustrated me :)
    Bilal Kinali - Yanıt
    I had mine replaced TWICE by a local repair shop. Soon noticed both times that the iPad would soon go haywire after a few minutes use with random clicks, ghost typing, opening apps, etc.
    The iPad Air's such a poor quality, un-durable product anyway. I only had my screen replaced in the first place because it cracked with no apparent drop or trauma and Apple wouldn't replace.
    daviddesignbristol - Yanıt
    I have also the same issue, does anyone know what the problem is?
    Please give us some feedback.
    Elektromic - Yanıt
    Have seen this with multiple repairs where the digitizer was replaced. In each case it was a problem with the digitizer cables where it gets tucked under the glass near the edge of the frame. Not yet sure if they are badly made digitizers or if the cable gets damaged trying to tuck it under frame during installation.
    RayM - Yanıt
    To avoid the digi sending the ipad crazy. In the same way you tape the copper/silver edges on the back of the glass for the iPad Mini. You tape all the way around, making sure not to dirty the protective cover when placing back down after taping one edge.
    Make sure all the metal surround is cover by tape, but careful not too go over the edges too much. It will be visible when using the device.
    Like i said earlier, the real skill is not too dirty the screen when lifting the protective sheet.
    Have fun!
    Josh - Yanıt
    Thanks man, I'll give it a try. Any idea what kind of tape should I buy?
    Luis Tamborrell -
    Kapton tape otherwise known as heat tape or polyamide tape
    Neil Davis -
    Just fitted the screen, the digitizer works, display all good but I had a message saying I could not use touch ID and the home button doesn’t work at all…is this expected?
    Paul Kelly - Yanıt
    I break the ZIF connector. Is tat touch connecter.?
    aiyathurai Aathee - Yanıt
    How do you take the ribbon cable off from the home button site???
    BP Thompson - Yanıt
    Pull the ribbon horizontally out, not up
    Rusty - Yanıt
  37. iPad 5 Wi-Fi Battery Replacement: adım 37, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 37, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 37, 3 resimden 3.
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
    What are those connectors for because i kinda half broke the left one on the screen on the glass frame and now the lcd wont turn on
    SuperCow_man - Yanıt
  38. iPad 5 Wi-Fi Battery Replacement: adım 38, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 38, 2 resimden 2.
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
    THIS PICTURE IS PERFECT AND PERTANANT TO THE NEXT STEP REGARDING “GHOST OR PHANTOM TOUCH” - See that foam around the edges? For some reason, the ifixit replacement digitizer doesn’t come with it (but it does come with new adhesive applied already.) With your screen, also purchase their “tesa tape” : Tesa 61395 Tape / 4 mm - it comes in different widths fyi. I choose 4mm as advised by a staff member.
    scottgogos - Yanıt
    On the replacement screen I received from you, the home screen ribbon cable does not fully seat inside the Zif connector like the original and will not lock in place as a result. It seems too fat. Any tips to make it work?
    Greg DeCelle - Yanıt
    I can’t think of any reason for that other than it’s the wrong display for your model, or it’s defective. Double-check the model very carefully and make sure you ordered/received a compatible part. If you ordered from iFixit, contact customer support directly for returns or exchanges. Good luck!
    Jeff Suovanen -
    I didn’t receive any of the two sided tape…I assume it needed to be ordered separately??
    So, when I removed the glass, the bottom cable tore and I have to replace it. The video is not as clear regarding replacement. The old button had a round rubber gasket but the new one does not. No inst. how to re-use it. I can’t attach and keep in place the new button.
    Michael Goss - Yanıt
    In a previous repair, i broke the zif, what you want to do is hold it down while removing the tape, otherwise it will pull the parts up with it.
    Since it was broke i put a piece of electrical tape on top for the pressure the zif would push down, then another piece from the screw hole to the bend in the cable, so it does not come loose when putting back together.
    Neil Rogers - Yanıt
  39. iPad 5 Wi-Fi Battery Replacement: adım 39, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 39, 2 resimden 2.
    Polyimide Tape
    $9.99
    • Remove the front panel assembly.
    • During reassembly, wipe any dust or fingerprints off of the inside of the front panel assembly to ensure a clean display.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
    In your conclusion, which doesn't have a comments area, you say to reverse the procedure - simple enough, BUT what about the sticky adhesive residue along the edges of the (a) the just-remove-glass (if re-using) and (b) along the 'inside' edges of the iPad chassis? Typically Apple says to remove the adhesive residue (careful) with alcohol wipes (lint free & 98% isopropyl). Thanks for the instructions!
    Joe Kazura - Yanıt
    the hardest part of this repair for me is actually aligning the ribbons (especially on the aftermarket version) so they don't jumble and cause the glass to mush away from the adhesive leaving a gap. Would would be very helpful to see how to fold the ribbon cables back on the aftermarket digitizers. They are slightly different than the originals, or at least they appear different. This repair is super useful but we could really use a step 44 because re-assembly has a sequence and a folding technique.
    TJ Hellmuth - Yanıt
    The ribbon cable is a little tricky to figure out. But if you look closely at the old ( Broken) screen you will see they stick to the underside of the screen thin the remaining ribbon slides down into the ipad between the display and ipads frame.
    I used a heat gun and suction cups to loosen screen.
    This was a very good ifix ii
    Rowell - Yanıt
    Reassemble huh? What about how to move the home button to the new panel?
    xsubguy - Yanıt
    This is what I need too!
    Sarah Ybarra -
    It is not as simple as reverse disassembly steps, the ribbon cables need to be tucked into the pocket on the side of the iPad. There is tape on them that has to adhere to the side of the digitizer too. Mine did not make it all the way down into the gap, and stuck on the other adhesive, now I have a gap by these two cables. To tuck these into this area is difficult at best. I now need to remove the glass, hoping it does not shatter and purchase more tape.
    Other than this the task was not bad.. BTW: YES People use the capton tape
    Randall Hooper - Yanıt
    I’ve read that people are putting glue at each corner. I haven’t figured out what glue. One person said Glue Dot 1” 16lb, another said rubber cement, 1 video shows 5 min epoxy… Heard that some sort of glue (not super glue) needs to be used to avoid the glass lifting later on. And to use 3m red tape along the edges. I’ve been searching for which glue because I still have an ipad air to do screen replacement on.
    tsolorio - Yanıt
    Would be helpful if the tape were listed in the master supplies for the guide. I got the whole kit overnighted, but then had to wait a week to get the tape from Amazon (since I wasn’t going to shell out another $50 for overnight shipping). Otherwise, it’d be nice to know if the displays through iFix it included the foam or not—mine didn’t.
    Micah Sledge - Yanıt
    Second the concern about the foam. I bought the full repair kit, but was surprised there wasn’t already polyimide tape on the digitizer or in the kit. At least mention that it needs to be purchased extra.
    Ronny Barlow - Yanıt
    @baron9 The displays we sell have the proper insulation and don’t require any tape. That note is more for folks who use our guides while buying the parts from somewhere else. (They tend to complain here, even though it’s the part that’s at fault, not the guide.) I’ve updated the instructions to try to make things a little more clear. Sorry about that!
    Jeff Suovanen -
    My digitizer kit from ifixit also looks like it is missing the polyimide tape on the digitizer. Can someone confirm that i do not need to get the tape with the original ifixit kit and just slap the digitizer on there?
    Alex -
    what is the difference between the right and left antenna?. My right antenna is damage and cant find a replacement. Can I use only the left one?
    Daniel C - Yanıt
    I did not realize that aftermarket screens (besides the one ifixit sells) do not come with adhesive strips. Well worth the time to figure out what kind of adhesive you’re going to use to re-adhere the glass before you begin. Stopping while you’re so close to the end of the repair (or having to open the ipad up again after the screen doesn’t stick back down) is slightly frustrating.
    Robert - Yanıt
    I used a b-7000. 48 h cure time.
    Jean masaoka -
    Thank you for your guide, it helped me fix my son’s iPad!
    Bill - Yanıt
    Just wanna say thank you. I replaced my LCD and digitizer today…. took a LOT longer to get that adhesive off than I expected. And the IOpener busted in my microwave despite following all directions (eg only 30 sec at a time, out for at least 10 min before reheating. So that sucked. Turns out the rice in a sock worked pretty well too.
    GC Mitts - Yanıt
    Regarding assembly: even with carefully tucking the ribbon cables down the side while reassembling, it’s still hard to get that area to stick down.
    Gary Wolfe - Yanıt
    Some advice when reassembling that I have learned in the hard way.
    One good hint is to those who buy replacement parts that are not exactly the original ones. Some of the parts come with a 3M adhesive tape on the tab of the flex cables (I guess original parts are already folded and glued). I would strongly recommend to be very careful when you try to glue it on the front panel and maybe watch a video on how to fold it properly, so as not to fold or pinch the flex cable on an unrepairable way. Also, some of the low cost parts come with a very strong protection sticker on the front glass. It is advisable that you peel off the sticker before reassembling the ipad in order to not end up ruining the glue that was supposed to hold the front panel .
    Jean masaoka - Yanıt
  40. iPad 5 Wi-Fi Battery Replacement, Right Antenna: adım 40, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement, Right Antenna: adım 40, 2 resimden 2.
    • Insert a spudger under the antenna cable closest to the edge of the iPad and lift upward to disconnect the antenna cable connector.
    Skip to the step 98 or even 100 if you just need to replace the power button - I think you should even consider this to replace volume buttons. I am fixing mine right now and screwed up the speaker cable. I did follow the instruction but totally missed the cable right below the tape. I proceeded further, but I just realized I didn't have to go through all the troubles. I wish ifixit.com can manage this type of direction clearly so that dis-assembly is minimum.
    msgfromside3 - Yanıt
    After you replace the Digitizer if you are getting random key presses it is likely to be because Kapton tape has not been applied to the edges of the digitizer. You need to cover the silver strip around the edge of the digitizer with kapton tape before reassembling. Works every time.
    Richard - Yanıt
    This is my first ipad and when the battery dies, it will be my last, way overrated and no options like memory cards or mini usb ports, and the battery thing is ridiculous,I wish I would have never bought this knowing this stuff , and way over priced.
    Gary - Yanıt
    It always helps to Google something before buying it. "iPad Air reviews" in Google would have saved you. I just find it funny how in this day and age, people STILL make "purchase mistakes" because they didn't take the time to research the several-hundred-dollar device they are about to commit to purchasing. You should have seen the amounts of research I did before buying my $1,399 Asus G751JY laptop. I'm absolutely pleased with it and am happy I don't deal with issues other people have. Just be weary, buddy. ALWAYS GOOGLE.
    Scott S -
    If you just want to replace the battery, skip to step 99. You can easily get to most sides of the battery without removing all other components. It worked for me. Good luck!
    Thomas Van den Dries - Yanıt
    I wish I read this comment. Would have saved me a lot of time.
    leo -
    I followed your piece of advice and went to step 99. My new battery works just fine without removing all those components including the logic board - thanks a lot!!
    Charlotte M -
    An important note - as per the comments lower down, you can skip ahead to step 95 (unsticking the battery) just fine if you're just changing the battery, but after you've unstuck the battery you will need to go back to step 88 and soften the logic board adhesive so you can pry it up about a cm and lift the battery terminal up and over the post to remove it. I didn't realise the post was there, and broke off a piece of the original battery terminal that got stuck under the logic board. This prevented a good connection with the new battery, and caused random restarts after I put everything back together until I realised and went back to recover it.
    Rory Condon -
    Don’t skip to 99 because you need to remove the logic board.
    Cesar Hernandez - Yanıt
    I have successfully replaced the Battery without removing any components other than the Screen Assembly and LCD. You can skip steps 44 thru 99 by using a spudger as a wedge to lift & hold the Logic Board high enough to lift the battery contact over the post that holds it in place… this will save you a lot of time and frustration and makes the repair sooo much easier.
    firestormmedia -
    My goal was to replace the battery. As some suggested I skipped some steps. I did Step 46 and left out 47 to 100. But I think Step 46 can be skipped too. iFixit probably does not recommend skipping these steps because it is riskier to bend the batteries and damage them. But if you work carefully enough and make sure the adhesive has been softened well, you should be fine. It was no problem for me. It saved me quite some time. (I will write a comment in Step 102 to help you get the batteries out without Steps 46-100.)
    marcelflueeler - Yanıt
  41. iPad 5 Wi-Fi Battery Replacement: adım 41, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 41, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 41, 3 resimden 3.
    • There are two large pieces of tape wrapped around the right antenna cable, securing it to the rear case.
    • Peel the tape up from the rear case.
    • While peeling the antenna tape up, leave it in place on the antenna cable to aid with reassembly.
    You may partially skip steps 46 to 100, as it is not really mandatory to remove all those parts in order to remove the logic board and the battery.
    Pierre-Aurélien - Yanıt
  42. iPad 5 Wi-Fi Battery Replacement: adım 42, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 42, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 42, 3 resimden 3.
    • The antenna cable is anchored to the speaker with a small metal bracket. The bracket is permanently crimped to the antenna and adhered to the speaker enclosure.
    • Carefully insert an opening pick between the speaker enclosure and the antenna cable bracket.
    • Slide the pick toward the home button to cut the adhesive.
    • Push the bracket away from the speaker until it clears the tape underneath.
    The pick was not thin enough but the razor worked.
    Moon & Snow - Yanıt
    In my view there is a few destructive steps here. I have been able to remove this entire assembly by lifting only the adhesive tape anchoring it to the back without touching this fine metal bracket as touched in in Step 46 & 63 or tearing the foam in Steps 48 & 65 on both the left & right sides. Remove the screws as in Step 47 & 57 and the one’s either side of the charging port in 64 & 71. Once removed, the only thing securing these to the rear is adhesive tape. Lift the tape and walk the units out by nudging them from side to side.
    Neil Cross - Yanıt
    Thanks. Made the whole next chunk much simpler :)
    Sarah Ybarra -
  43. iPad 5 Wi-Fi Battery Replacement: adım 43, 1 resimden 1.
    • Remove the following Phillips #000 screws securing the right antenna:
    • One 2.3 mm screw
    • Two 1.4 mm screws
    I would strongly advise not to follow this step and following ones: removing the 2 Wi-Fi antennas is not required for complete disassembly of the motherboard and battery, and you may potentially destroy your antennas: I scrupulously and foolishly followed this tutorial step by step and now I have severe Wi-Fi problems on my iPad because one of the 2 antennas has been damaged during the process (and by reading all the comments on this page you'll see that I'm not the only one to have this issue...).
    => As someone else already mentioned it in the comments, just skip most of these steps and go directly to something like step 79.
  44. iPad 5 Wi-Fi Battery Replacement: adım 44, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 44, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 44, 3 resimden 3.
    • Insert the flat end of a spudger between the antenna and the speaker assembly.
    • Slide the spudger toward the home button to cut the foam adhesive securing the antenna.
    Este paso es innecesario, ya que con solo quitar los tornillos es suficiente, no hace falta despegar la goma espuma que mantiene la antena de la bocina.
    Anthony Aguilar - Yanıt
    tout a fais il n'est pas nécessaire de décoller l'antenne du haut-parleur ! Il faut juste enlever les vis et continuer le démontage du haut-parleur en laissent l'antenne fixer a lui !!!
    dordetivan - Yanıt
    Faire de même pour le deuxième haut-parleur !
    dordetivan - Yanıt
  45. iPad 5 Wi-Fi Battery Replacement: adım 45, 1 resimden 1.
    • Remove the right antenna from the iPad.
  46. iPad 5 Wi-Fi Battery Replacement, Right Speaker: adım 46, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement, Right Speaker: adım 46, 2 resimden 2.
    • Insert a spudger under the left antenna cable and lift upward to disconnect the antenna cable connector.
  47. iPad 5 Wi-Fi Battery Replacement: adım 47, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 47, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 47, 3 resimden 3.
    • There are five pieces of tape wrapped around the left antenna cable covering the right speaker cable connector.
    • Fold the antenna cable out of the way.
    What can I do if I accidentally peel
    off the speaker ribbon from both
    speaker connecters? Can I get a replacement part?
    mike - Yanıt
    This step was not very well explained. It fails to mention the speaker cable attached on to the tape. This caused the speaker cable to be torn since it is so thoroughly attached to the tape. Guide made no mention that it was under there or that you should be careful about it. Not even the usual remove the tape gently they just tell you to rip it right off no problem. Not sure how this was missed when the guide was so thorough about this beforehand.
    Holden Bott - Yanıt
    Approx. 3/4 of an inch past the bend in the cabling underneath the tape lies the right speaker cable. Beyond this point proceed with extreme caution. Delicate cables and ZIF connectors underneath the tape will be torn or damaged if they aren't separated from the underside of the insulation tape first. Use fingernails or thin-edged tools.
    rcrandall85 - Yanıt
    An update to this would be nice. Will the Ipad work with a broken spaker cable? Is it possible to get replacement part? Maybe this step should be rewritten.
    Nathaniel Johnson - Yanıt
  48. iPad 5 Wi-Fi Battery Replacement: adım 48, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 48, 2 resimden 2.
    • A bend in the speaker cable makes it difficult to peel the tape up from the end.
    • Instead, grip the tape just under the speaker and peel it down, away from the edge of the case.
    • Be careful with your tweezers—only grab and peel the tape, and not the cable beneath.
  49. iPad 5 Wi-Fi Battery Replacement: adım 49, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 49, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 49, 3 resimden 3.
    • Peel the tape toward the home button to uncover the speaker cable connector.
  50. iPad 5 Wi-Fi Battery Replacement: adım 50, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 50, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 50, 3 resimden 3.
    • Use the pointed end of a spudger to flip up the retaining flap on the right speaker cable connector.
    • Slide the speaker cable straight out of its ZIF connector.
  51. iPad 5 Wi-Fi Battery Replacement: adım 51, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 51, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 51, 3 resimden 3.
    • Remove the tape holding the speaker to the rear case.
  52. iPad 5 Wi-Fi Battery Replacement: adım 52, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 52, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 52, 3 resimden 3.
    • Carefully peel the LCD buffer tape up off of the rear case.
  53. iPad 5 Wi-Fi Battery Replacement: adım 53, 1 resimden 1.
    • Remove the 2.2 mm Phillips #000 screw securing the speaker to the rear case.
  54. iPad 5 Wi-Fi Battery Replacement: adım 54, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 54, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 54, 3 resimden 3.
    • Insert a fingernail or the flat end of a spudger in the groove in the speaker housing, near the corner of the rear case.
    • Pull the speaker down, away from the corner of the case.
    It is really not necessary to remove either speakers for a logic board swap.
    sergeymkl - Yanıt
  55. iPad 5 Wi-Fi Battery Replacement: adım 55, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 55, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 55, 3 resimden 3.
    • Use a spudger to help pull the speaker out from under the edge of the rear case.
    • Remove the right speaker from the iPad.
    When did you remove the blocker after installing the battery blocker? No photos with blockers after this procedure.
    Prof.Sakamoto - Yanıt
  56. iPad 5 Wi-Fi Battery Replacement, Upper Component Cable Bracket: adım 56, 1 resimden 1.
    • Remove the three 1.4 mm Phillips #000 screws securing the upper component cable bracket.
  57. iPad 5 Wi-Fi Battery Replacement: adım 57, 1 resimden 1.
    • Remove the upper component cable bracket.
    • If you have the Wi-Fi/Cellular model, your iPad will look slightly different and will require the removal of two additional screws to access components covered by this bracket.
  58. iPad 5 Wi-Fi Battery Replacement, Logic Board: adım 58, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement, Logic Board: adım 58, 2 resimden 2.
    • There are two remaining pieces of tape securing the left antenna cable to the rear case.
  59. iPad 5 Wi-Fi Battery Replacement: adım 59, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 59, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 59, 3 resimden 3.
    • Push the bracket away from the speaker until it is clear of the tape underneath.
  60. iPad 5 Wi-Fi Battery Replacement: adım 60, 1 resimden 1.
    • Remove the following Phillips #000 screws:
    • Two 1.4 mm screws
    • One 2.3 mm screw
    I didn’t need to take the left antenna and speaker out. If you just get the wire and tape out of the way so you can unplug the speaker flex cables and take out the lightning connector, then you should still be able to get the logic board out. the left speaker isn’t in the way at all.
    Reed Deemer - Yanıt
  61. iPad 5 Wi-Fi Battery Replacement: adım 61, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 61, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 61, 3 resimden 3.
  62. iPad 5 Wi-Fi Battery Replacement: adım 62, 1 resimden 1.
    • Remove the left antenna from the iPad.
  63. iPad 5 Wi-Fi Battery Replacement: adım 63, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 63, 2 resimden 2.
    • Remove the tape covering the left speaker cable connector.
    Pulled out the connector doing this step. Best to hold down cable while pulling tape.
    doug - Yanıt
  64. iPad 5 Wi-Fi Battery Replacement: adım 64, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 64, 2 resimden 2.
    • Use the pointed end of a spudger to flip up the retaining flap on the left speaker cable connector.
  65. iPad 5 Wi-Fi Battery Replacement: adım 65, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 65, 2 resimden 2.
  66. iPad 5 Wi-Fi Battery Replacement: adım 66, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 66, 2 resimden 2.
  67. iPad 5 Wi-Fi Battery Replacement: adım 67, 1 resimden 1.
  68. iPad 5 Wi-Fi Battery Replacement: adım 68, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 68, 2 resimden 2.
    • Gently fold the left speaker ribbon cable up so that it will clear the battery when you slide the speaker enclosure out.
  69. iPad 5 Wi-Fi Battery Replacement: adım 69, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 69, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 69, 3 resimden 3.
  70. iPad 5 Wi-Fi Battery Replacement: adım 70, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 70, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 70, 3 resimden 3.
    • Remove the left speaker from the iPad.
  71. iPad 5 Wi-Fi Battery Replacement: adım 71, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 71, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 71, 3 resimden 3.
    • Use the flat end of a spudger to disconnect the front-facing camera connector from the logic board.
    • Pry up only on the connector—not on the socket itself.
    • Fold the front-facing camera cable out of the way.
    • There is a bit of conductive adhesive between the gold-colored cable contacts. Be sure to apply pressure to readhere these contacts during reassembly.
  72. iPad 5 Wi-Fi Battery Replacement: adım 72, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 72, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 72, 3 resimden 3.
    • Use the flat end of a spudger to disconnect the rear-facing camera connector from the logic board.
    • Fold the rear-facing camera cable out of the way.
  73. iPad 5 Wi-Fi Battery Replacement: adım 73, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 73, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 73, 3 resimden 3.
    • Use the flat end of a spudger to disconnect the headphone jack connector from the logic board.
    • Newer iPad units have a loop of tape connecting this connector to its socket on the the logic board. This tape must be cut in order to disconnect the headphone jack.
    • Fold the headphone jack cable out of the way.
    Note for others. On this connector, i have some tape keeping it down, it's rather difficult to remove without ripping it. So i ripped the tape to remove it.
    justin Booras - Yanıt
    "Ripping" the tape seems ill-advised. A sharp ceramic craft paper cutting knife or the very tip of a fine-tip Exacto blade work well. Once the tape is cut on one side, the blade slides through it like it's nothing. Zero force required.
    Be careful not to insert a blade too far or it may come into contact with conductive components.
    rcrandall85 - Yanıt
  74. iPad 5 Wi-Fi Battery Replacement: adım 74, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 74, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the microphone cable connector from the logic board.
  75. iPad 5 Wi-Fi Battery Replacement: adım 75, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 75, 2 resimden 2.
    • Remove any tape covering the upper button assembly cable connector.
  76. iPad 5 Wi-Fi Battery Replacement: adım 76, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 76, 2 resimden 2.
    • Use the pointed end of a spudger to flip up the retaining flap on the upper button assembly cable connector.
  77. iPad 5 Wi-Fi Battery Replacement: adım 77, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 77, 2 resimden 2.
    • Slide the upper button assembly cable straight out of its ZIF connector.
  78. iPad 5 Wi-Fi Battery Replacement: adım 78, 1 resimden 1.
    • Remove the two 3.3 mm Phillips #000 screws securing the Lightning port.
    • To find these screws, hold the iPad vertically and look down at the Lightning port.
    NOTE for others who might miss this: this picture is looking down, out the bottom of the iPad. There are four other screws near the lightning port, two for the speakers and two for the port. You see these four easily, looking down at the battery and motherboard. These two are additional to those, and perpendicular to them. Both pairs of lightning port screws, one set perpendicular to the other, must be removed.
    Bonnie Baxter - Yanıt
    Where did the battery blocker go? It was introduced in step 35. Nowhere has it been said it can be removed . . . yet it is now absent in this picture. I took it out when I got to steps 93-96.
    Randy Burgess - Yanıt
    Yes this is a deceptive image as the battery and connector strap seem to be missing. Hold your iPad vertically and look down at the lightning port and you’ll see these hidden screws.
    Rusty - Yanıt
    Thanks for your comment! I’ll add a note in the step.
    Arthur Shi -
  79. iPad 5 Wi-Fi Battery Replacement: adım 79, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 79, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 79, 3 resimden 3.
    • In the next steps, you will use an iOpener to apply heat to the rear case of the iPad to soften adhesive holding the logic board in place.
    • As you reheat and place the iOpener in each of the indicated locations, leave it in place for at least a minute to soften the adhesive through the rear case.
    • The adhesive is in the form of six pieces of black foam tape—refer to this step as you work at heating and prying to keep track of where each piece is located.
    Thread a piece of dental floss under the tip of the logic board. Be careful when rounding the corner not to snag any ribbon cables. This easily released the foam tape up to the battery connector.
    ROBERT MORELLA - Yanıt
    Les 2 images suivantes sont contradictoires. elles donnent l'impression de devoir enlever la carte mère.
    Humair - Yanıt
    @totoy Effectivement, cela peut-être perturbant, mais ces images servent de référence et expliquent où se trouvent les six morceaux d'adhésif qu'il va falloir décoller au cours des étapes suivantes pour retirer la carte mère.
    Claire Miesch -
  80. iPad 5 Wi-Fi Battery Replacement: adım 80, 1 resimden 1.
    • Place a heated iOpener over the rear-facing camera end of the iPad, and let it sit for at least a minute to soften the adhesive through the rear case.
    • More time won't hurt, but you may need to reheat your iOpener and reapply it if you leave it on the rear case for too long.
  81. iPad 5 Wi-Fi Battery Replacement: adım 81, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 81, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 81, 3 resimden 3.
    • As you complete the next few steps, prying adhesive securing the logic board in place, always start by testing gently to see if the adhesive is softened. If not, reheat the iOpener and reapply it to the back of the rear case.
    • Carefully insert an opening pick under the logic board, between the front-facing camera and the battery.
    • Slide the pick toward the front-facing camera connector, and stop at the bend in the logic board.
  82. iPad 5 Wi-Fi Battery Replacement: adım 82, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 82, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 82, 3 resimden 3.
    • Slide an opening pick under the logic board from the front-facing camera to the rear facing camera.
  83. iPad 5 Wi-Fi Battery Replacement: adım 83, 1 resimden 1.
    • Place a heated iOpener along the bottom edge of the iPad.
    • Again, let the iOpener sit for at least a minute to soften the adhesive through the rear case.
  84. iPad 5 Wi-Fi Battery Replacement: adım 84, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 84, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 84, 3 resimden 3.
    • The Lightning connector cable is stuck to the case with some adhesive. To detach the adhesive you will be sliding an opening pick between the cable and the case. Be very careful not to cut the Lightning connector cable itself.
    • Insert an opening pick under the Lightning cable where it meets the logic board.
    • Slide the pick down and around the bend in the cable.
  85. iPad 5 Wi-Fi Battery Replacement: adım 85, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 85, 2 resimden 2.
    • Continue to slide the opening pick under the cable, stopping before the cable bends to the Lightning connector.
    • Move slowly and carefully. If the opening pick does not slide easily, apply more heat and try again. If you use excessive force, you will likely slip and sever the Lightning connector cable.
  86. iPad 5 Wi-Fi Battery Replacement: adım 86, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 86, 2 resimden 2.
    • Finally, slide the opening pick between the battery and the Lightning connector itself to separate the last of the adhesive underneath the cable.
    There are two screws holding the lightning connector to the rear case, I didn’t see them in this guide. I recommend removing them before you attempt to remove the lightning connector, otherwise you’ll look like an idiot struggling with it for around 1/2 an hour like I just did.
    Will Young - Yanıt
    I had this problem too!!
    Jocelyn Hall -
    Will Young is correct. The two extra screws are horizontal - they are in addition to the vertical screws mentioned in step 82.
    @usablethought AFAIK there are only two screws securing the actual port to the chassis. You can tell by looking at the part—there are only two screw holes. Those additional screws can be left in place, as shown in the photos. At least, that was my experience. If you’re working on a different model, then of course you may need to improvise—the instructions are only for the model indicated.
    Jeff Suovanen -
  87. iPad 5 Wi-Fi Battery Replacement: adım 87, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 87, 2 resimden 2.
    • Pull the Lightning connector straight out of its recess in the rear case.
    there were two screws holding the lightening connector in place on my iPad
    Nate Czupinski - Yanıt
    Yep! In this guide those screws are removed in Step 82, but you can remove them at any point prior to taking out the Lightning connector.
    Jeff Suovanen -
    CAUTION - there are two ‘hidden’ screws holding the lightning port that face the battery. Hold the iPad vertically and look down to see them. I almost broke the cable trying to remove it thinking it was just stubborn adhesive. Yes its mentioned at Step 82 but its a confusing illustration and easily overlooked.
    Rusty - Yanıt
  88. iPad 5 Wi-Fi Battery Replacement: adım 88, 1 resimden 1.
    • Place a heated iOpener on the left side of the rear case, where the logic board is adhered.
    • Let the iOpener sit for at least a minute to soften the adhesive through the rear case.
  89. iPad 5 Wi-Fi Battery Replacement: adım 89, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 89, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 89, 3 resimden 3.
    • Insert a plastic opening tool in the rectangular gap in the upper area of the logic board, and pry the logic board up from the rear case.
    • While keeping the opening tool underneath the logic board, slide it down the length of the gap to free the upper end of the logic board from the adhesive.
  90. iPad 5 Wi-Fi Battery Replacement: adım 90, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 90, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 90, 3 resimden 3.
    • Pry up the logic board at the lower edge of the rectangular gap, near the EMI shield.
    • Lift the end of the logic board slowly. If you encounter significant resistance, stop prying and reapply the iOpener.
  91. iPad 5 Wi-Fi Battery Replacement: adım 91, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 91, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 91, 3 resimden 3.
    • Slide an opening pick under the logic board between it and the battery.
    • Slide the pick from the base to the center of the logic board to cut the adhesive.
    • Take care not to cut the battery with the opening pick; a punctured battery can be very dangerous. If you encounter resistance, reheat and reapply the iOpener.
  92. iPad 5 Wi-Fi Battery Replacement: adım 92, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 92, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 92, 3 resimden 3.
    • Slide the pick up the length of the logic board.
    • Once the adhesive has been cut, pry the battery side of the logic board upward off of the rear case.
    Don't touch the small components which are under the motherboard !!! If you do it your iPad is definitively dead.
    Easy Repair - Yanıt
  93. iPad 5 Wi-Fi Battery Replacement: adım 93, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 93, 2 resimden 2.
    • Continue to lift the logic board along the edge nearest the battery, until you can get an opening pick against the far edge of the logic board.
    • Cut any adhesive holding the outer edge of the logic board to the rear case.
  94. iPad 5 Wi-Fi Battery Replacement: adım 94, 1 resimden 1.
    • Remove the logic board from the iPad.
    Nice guide, thank you, very helpful. There would be no way to guess where the glue stripes are located and a couple of connectors are very difficult to spot. I don't see any need to remove the antennas and the speakers though, they are not really an obstacle to remove the board and can be left in place. The lightning connector is secured in place by two other two horizontal screws which are not shown in the guide.
    Thanks again !
    arbaman - Yanıt
    Technically, you are correct. But those screws are holding a bracket-like piece for the lightning connecter to screw into- which if you think about it, it wouldn't be considered apart of the lightning port (or at least that's what i think). Not trying to start an argument, as this comment is old, but yeah.
    Kaz -
    This is a bear of a job, and I wouldn’t have had any hope of completing it without this guide. THANK YOU for all your hard work!!!!
  95. iPad 5 Wi-Fi Battery Replacement, Battery: adım 95, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement, Battery: adım 95, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement, Battery: adım 95, 3 resimden 3.
    Bu adımda kullanılan alet:
    iFixit Adhesive Remover
    $19.99
    • The following steps instruct you to use heat to soften the glue securing the battery. A safer alternative is to inject a solvent, such as iFixit adhesive remover, between the battery and rear case to dissolve the adhesive.
    • Reheat the iOpener in the microwave for 30 seconds.
    • Remember to be careful not to overheat the iOpener during the repair procedure. Wait at least two minutes before reheating the iOpener, and never microwave it for more than 30 seconds.
    • Place the heated iOpener in the center of the back of the iPad. Let it sit there for 90 seconds to soften the battery adhesive.
    • Move the iOpener to the right (away from the rear-facing camera), and let the iOpener sit for another 90 seconds.
    • Finally, move the iOpener to the right-hand edge of the iPad for 90 seconds.
    • The iOpener may cool significantly between sittings—if it does, reheat for another 30 seconds between each position.
  96. iPad 5 Wi-Fi Battery Replacement: adım 96, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 96, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 96, 3 resimden 3.
    Plastic Cards
    $2.99
    • Throughout the following procedure, you'll be sliding thin plastic cards between the battery and rear case of the iPad, to separate the adhesive securing the battery. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
    • Insert a plastic card under the lower battery cell, at the lower right-hand corner.
    • If you encounter significant resistance, re-heat the iOpener and repeat the previous step to give the adhesive more time to soften.
    Did you skip Step 46 through 100, then this is for you: Because the logic board is still in, you will have less space to loosen the battery pack. Be extra careful not to bend it. Work from the sides that are more accessible like in Step 113 and slowly work your way underneath the battery pack to loosen it all over. As I was loosening the battery I had the heated iOpener underneath the part I was working on. This really helped a lot. And be patient. You do not want to force it.
    First of all, thanks @marcelflueeler and everyone else who gave advice on skipping ahead. This is definitely the way to go if you're just changing a battery! Once you've unstuck the battery you'll find you can't pull it out because it's stuck at the terminal though. Don't try and force it here! You'll need to return to step 88 and soften the logic board adhesive so you can pry it up about a cm, then you can lift the battery terminal up and over the locking post that's holding it in place. I didn't realise this and broke a piece of plastic off the old battery terminal, which got lodged under the logic board and prevented a good battery contact until I realised and retrieved it.
    Rory Condon -
  97. iPad 5 Wi-Fi Battery Replacement: adım 97, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 97, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 97, 3 resimden 3.
    • With the card roughly halfway inserted, slide it toward the top of the iPad, stopping before the battery contact post.
  98. iPad 5 Wi-Fi Battery Replacement: adım 98, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 98, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 98, 3 resimden 3.
    • Lift the card up from the rear case slightly to allow it to pass over the battery contact mounting post.
    • Slide the card from the center of the battery cells to the upper right corner of the battery.
  99. iPad 5 Wi-Fi Battery Replacement: adım 99, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 99, 2 resimden 2.
    • Place a second plastic card about halfway under the left hand battery cell to prevent it from readhering when you reapply the iOpener.
  100. iPad 5 Wi-Fi Battery Replacement: adım 100, 1 resimden 1.
    • Place an iOpener on the right side of the battery, opposite the cards, to loosen the adhesive.
  101. iPad 5 Wi-Fi Battery Replacement: adım 101, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 101, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 101, 3 resimden 3.
    • Slide the card around the lower right corner of the battery.
  102. iPad 5 Wi-Fi Battery Replacement: adım 102, 2 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 102, 2 resimden 2.
    • Slide the plastic card to the lower left corner of the battery.
  103. iPad 5 Wi-Fi Battery Replacement: adım 103, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 103, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 103, 3 resimden 3.
    • Press the card in further, breaking as much of the adhesive holding in the battery as you can.
    • Place the plastic card underneath the lower left corner of the battery.
  104. iPad 5 Wi-Fi Battery Replacement: adım 104, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 104, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 104, 3 resimden 3.
    • Slide the card around the upper right corner of the battery.
    • Be extremely careful to slide the card over the front-facing camera and headphone jack cables to avoid cutting them.
  105. iPad 5 Wi-Fi Battery Replacement: adım 105, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 105, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 105, 3 resimden 3.
    • Slide the plastic card to the upper left corner of the battery.
    • Be careful to slide the card over the front-facing camera and headphone jack cables to avoid cutting them.
  106. iPad 5 Wi-Fi Battery Replacement: adım 106, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 106, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 106, 3 resimden 3.
    • Place the plastic card underneath the upper left corner of the battery.
  107. iPad 5 Wi-Fi Battery Replacement: adım 107, 3 resimden 1. iPad 5 Wi-Fi Battery Replacement: adım 107, 3 resimden 2. iPad 5 Wi-Fi Battery Replacement: adım 107, 3 resimden 3.
    • Grip both cards firmly and twist them to lift the battery off of the rear case.
    • Remove the battery from the rear case.
    Finally done !
    Easy Repair - Yanıt
    Apple aren’t stupid are they
    bob - Yanıt
    It took me nearly 3hrs, but i finally made it. Thanks for the great instructions
    Oliver Wegen - Yanıt
    New battery installed. Battery wont charge. Any ideas?
    David F - Yanıt
    REASSEMBLY TIPS:
    The adhesive strips that come with the iFixit battery have no labels to say which goes where. Look at them carefully and one side has a blue protective cover that runs the length of each strip. This faces up and is to be removed at the last moment when you’re ready to stick the screen down permanently. One strip has a narrowed section in the long length to clear the glass touch screen cables, so stick this one down first to avoid mistakes.
    Before removing the protective strips, close the touch screen and boot the iPad. Test both cameras, wifi and speakers. (I found the rear facing camera connector hadn’t bedded properly which was easily fixed). Clean the screen and remove dust from LCD before bedding in touch screen.
    The iFixit site has updated battery calibration instructions which differ from the card packed with the battery:
    Charge it to 100% and keep charging it for at least 2 more hours.
    Then use your device until it shuts off due to low battery.
    Finally, charge it uninterrupted to 100%.
    Rusty - Yanıt
    Great tip to boot the iPad before removing the adhesive from the battery. There are quite a few comments here about faulty batteries. Fortunately, mine worked just fine.
    Jonathan Koehler -
    The iFixit battery replacement kit worked great! The repair guide is very good also. So glad I didn’t just try buying the battery. While testing everything after finishing the battery replacement, the digitizer, volume controls and the sleep button did not work. I was very happy when I went back in and found the cable connections had just come loose. My wife couldn’t believe I fixed her iPad.
    Randal Haufler - Yanıt
    The guide was pretty good but a few comments:
    I didn’t liked the iOpener that much. I used an heat gun with good temperature control instead.
    Any advice on how to remove the old glue residu would have been welcome. I used a combination of physical scraping and cleaning afterward with isopropyl alcohol.
    An extra guide on how to apply the new adhesive strips would also be nice.
    mlombaers - Yanıt
    Fixed!....The guide is very clear and well laid out. I also had issues with the iOpener not working, I needed more heat, used heat gun with temp control. Also used floss to remove the logic board. Would have appreciated more clearer instructions on adding the adhesive strips.....Thanks
    hzulu88 Zulander - Yanıt
    The iOpener is really bad. It isnt hot enough to keep the iPad that cools down to roomtemperature in a few seconds. I used an hair dryer which was also not warm enough but at least made it warm enough to create a gap where I was able to fit my pics under. Unfortunately my Digitizer still died. Battery works but I cannot turn off my iPad now lol
    Luca Steuer - Yanıt
    Very good guide to a very tedious project! Thank you for the detailed description of the digitizer separation. I didn’t sever any cables. The iOpener isn’t bad; it’s just too small. This project really requires the Anti-clamp, the acetone/isopropanol adhesive softener, and a heat gun that can be used at a low heat setting. I didn’t try a hair dryer, but I think that it might be too windy. Like other fixers,I skipped steps 47 thru 100 something and took my chances manhandling the battery. I opted to insulate the digitizer with Kapton tape. I only have a wide roll of Kapton, so I stuck it to the stiff plastic backing for the battery, then cut narrow strips and peeled them off the backing. Finally, I’d like to see a show of hands of the people who forgot to put in the four corner screws for the display. Maybe I’m the only one …
    Laetiporus - Yanıt
    I successfully replaced the battery in my A1954. But I stopped at step 40 and then I just pried the old battery with the plastic cards that came with the new battery and some isopropyl alcohol. Next step I pried the logic board upwards with a blue pick around the screw area. The board needs to flex upwards more than you're comfortable with in order to make room for the new battery connector to slide underneath the pick but over the screw hole underneath the logic board. I dint't really feel like gutting the entire housing of all the parts but I was risking damaging both the logic board and the new battery. So do it at your own risk.
    redishman - Yanıt
Sonuç
54 farklı kişi bu kılavuzu tamamladı.
Evan Noronha
226.382 İtibar
168 adet Kılavuz yazıldı
9Kılavuz Yorumları
Thank you for this guide Evan, worked a treat! Very happy client.
Tom
Tom Ward - Yanıt
Very nice information for the do it yourself person
Kerry Augustson - Yanıt
I finished it replaced the battery but TouchID is not working… sigh and do not have motivation to try again so going to leave it as is.
ztauseef - Yanıt
Buona giorno a tutti,
volevo chiedere perché smontare tutto il pad, quando dopo aver tolto lo schermo basterebbe scollare la batteria e sostituirla?
Grazie per la risposta
Luigi
Luigi - Yanıt
Thanks to this I successfully replaced the battery and glass on my iPad, great job.
Not Playing - Yanıt
I wish I read the comments in the first step! I didn't lose my patience with the iopener until removing the battery and finally broke out the hairdryer. I also have a 3D printer and one suggestion of using the heated bed would have been helpful. With the glue only slightly soft from the iopener more force was required. At some point I severed one of the speaker cables. I only moved the pick from the center out as the directions specified but I must have gotten under the longest speaker cable and when I hit the point of connection severing the cable was easy compared with the glue.
It is going to bug me a little how messy you have to leave the inside as everything is glued down to start. If I ever attempt this again, I'll probably pull out the hairdryer and try to remove the battery while leaving as many of the parts in place as possible. Apple should be ashamed for how difficult a battery replacement is, though. Tech companies tout being green but they are far from it in product design.
Christopher Duncan - Yanıt
Apart from the adhesive strips for the glass, is there a need to re-apply glue to the battery and other components? If so, is there a preferred glue for this, is there a particular glue that can be softened by heat?
Claude - Yanıt
this guide was very accurate, very nerve racking at the end (with the battery)
Philip - Yanıt
Lol, all this to change a battery. Apple products are hilariously anti-consumer
N Chr - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 25
Son 7 gün: 165
Son 30 gün: 682
Her zaman: 54,219
