Ana içeriğe geç
iPhone 12 Pro Max Battery Replacement
Neye ihtiyacın var
  1. iPhone 12 Pro Max Battery Replacement, Remove the pentalobe screws: adım 1, 1 resimden 1.
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    FixBot'a Sor
    Yorum Ekle
  2. iPhone 12 Pro Max Battery Replacement, Mark your opening picks: adım 2, 3 resimden 1. iPhone 12 Pro Max Battery Replacement, Mark your opening picks: adım 2, 3 resimden 2. iPhone 12 Pro Max Battery Replacement, Mark your opening picks: adım 2, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    FixBot'a Sor
    Yorum Ekle
  3. iPhone 12 Pro Max Battery Replacement, Tape over any cracks: adım 3, 3 resimden 1. iPhone 12 Pro Max Battery Replacement, Tape over any cracks: adım 3, 3 resimden 2. iPhone 12 Pro Max Battery Replacement, Tape over any cracks: adım 3, 3 resimden 3.
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    FixBot'a Sor
    Yorum Ekle
  4. iPhone 12 Pro Max Battery Replacement, Anti-Clamp instructions: adım 4, 3 resimden 1. iPhone 12 Pro Max Battery Replacement, Anti-Clamp instructions: adım 4, 3 resimden 2. iPhone 12 Pro Max Battery Replacement, Anti-Clamp instructions: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    FixBot'a Sor
    Yorum Ekle
  5. iPhone 12 Pro Max Battery Replacement: adım 5, 3 resimden 1. iPhone 12 Pro Max Battery Replacement: adım 5, 3 resimden 2. iPhone 12 Pro Max Battery Replacement: adım 5, 3 resimden 3.
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    FixBot'a Sor
    Yorum Ekle
  6. iPhone 12 Pro Max Battery Replacement: adım 6, 3 resimden 1. iPhone 12 Pro Max Battery Replacement: adım 6, 3 resimden 2. iPhone 12 Pro Max Battery Replacement: adım 6, 3 resimden 3.
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    FixBot'a Sor
    Yorum Ekle
  7. iPhone 12 Pro Max Battery Replacement, Heat the bottom edge: adım 7, 1 resimden 1.
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
    FixBot'a Sor
    Yorum Ekle
  8. iPhone 12 Pro Max Battery Replacement, Apply a suction cup: adım 8, 2 resimden 1. iPhone 12 Pro Max Battery Replacement, Apply a suction cup: adım 8, 2 resimden 2.
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the very edge of the glass.
    FixBot'a Sor
    Yorum Ekle
  9. iPhone 12 Pro Max Battery Replacement, Lift the screen slightly: adım 9, 3 resimden 1. iPhone 12 Pro Max Battery Replacement, Lift the screen slightly: adım 9, 3 resimden 2. iPhone 12 Pro Max Battery Replacement, Lift the screen slightly: adım 9, 3 resimden 3.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick at a steep angle into the gap.
    • Make sure to insert the opening pick under the thick plastic bezel to avoid damaging your screen. You should see a visual gap, and the pick shouldn't catch on anything. If you can't see the gap, you'll need to pull the screen up more.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    FixBot'a Sor
    Yorum Ekle
  10. iPhone 12 Pro Max Battery Replacement, Separate the bottom edge adhesive: adım 10, 3 resimden 1. iPhone 12 Pro Max Battery Replacement, Separate the bottom edge adhesive: adım 10, 3 resimden 2. iPhone 12 Pro Max Battery Replacement, Separate the bottom edge adhesive: adım 10, 3 resimden 3.
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    FixBot'a Sor
    Yorum Ekle
  11. iPhone 12 Pro Max Battery Replacement, Heat the right edge: adım 11, 2 resimden 1. iPhone 12 Pro Max Battery Replacement, Heat the right edge: adım 11, 2 resimden 2.
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
    FixBot'a Sor
    Yorum Ekle
  12. iPhone 12 Pro Max Battery Replacement: adım 12, 3 resimden 1. iPhone 12 Pro Max Battery Replacement: adım 12, 3 resimden 2. iPhone 12 Pro Max Battery Replacement: adım 12, 3 resimden 3.
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
    FixBot'a Sor
    Yorum Ekle
  13. iPhone 12 Pro Max Battery Replacement, Heat the top edge: adım 13, 1 resimden 1.
    • Use a hair dryer to heat the top edge of the iPhone until the screen is slightly too hot to touch.
    FixBot'a Sor
    Yorum Ekle
  14. iPhone 12 Pro Max Battery Replacement, Separate the top adhesive: adım 14, 3 resimden 1. iPhone 12 Pro Max Battery Replacement, Separate the top adhesive: adım 14, 3 resimden 2. iPhone 12 Pro Max Battery Replacement, Separate the top adhesive: adım 14, 3 resimden 3.
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
    FixBot'a Sor
    Yorum Ekle
  15. iPhone 12 Pro Max Battery Replacement, Heat the left edge: adım 15, 2 resimden 1. iPhone 12 Pro Max Battery Replacement, Heat the left edge: adım 15, 2 resimden 2.
    • Use a hair dryer to heat the left edge of the iPhone until the screen is slightly too hot to touch.
    FixBot'a Sor
    Yorum Ekle
  16. iPhone 12 Pro Max Battery Replacement, Separate the left adhesive: adım 16, 3 resimden 1. iPhone 12 Pro Max Battery Replacement, Separate the left adhesive: adım 16, 3 resimden 2. iPhone 12 Pro Max Battery Replacement, Separate the left adhesive: adım 16, 3 resimden 3.
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
    • If you're having trouble separating the adhesive, reheat the left edge.
    FixBot'a Sor
    Yorum Ekle
  17. iPhone 12 Pro Max Battery Replacement, Open the iPhone: adım 17, 3 resimden 1. iPhone 12 Pro Max Battery Replacement, Open the iPhone: adım 17, 3 resimden 2. iPhone 12 Pro Max Battery Replacement, Open the iPhone: adım 17, 3 resimden 3.
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    FixBot'a Sor
    Yorum Ekle
  18. iPhone 12 Pro Max Battery Replacement, Unscrew the battery and display connector cover: adım 18, 1 resimden 1.
    Magnetic Project Mat
    $19.95
    • Remove four 1.1 mm-long Y000 screws securing the battery and display connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    FixBot'a Sor
    Yorum Ekle
  19. iPhone 12 Pro Max Battery Replacement, Remove the battery and display connector cover: adım 19, 1 resimden 1.
    • Remove the battery and display connector cover.
    FixBot'a Sor
    Yorum Ekle
  20. iPhone 12 Pro Max Battery Replacement, Disconnect the battery: adım 20, 2 resimden 1. iPhone 12 Pro Max Battery Replacement, Disconnect the battery: adım 20, 2 resimden 2.
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    FixBot'a Sor
    Yorum Ekle
  21. iPhone 12 Pro Max Battery Replacement, Disconnect the display cable: adım 21, 2 resimden 1. iPhone 12 Pro Max Battery Replacement, Disconnect the display cable: adım 21, 2 resimden 2.
    • Use a spudger or a fingernail to disconnect the display cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    FixBot'a Sor
    Yorum Ekle
  22. iPhone 12 Pro Max Battery Replacement, Unscrew the front sensor connector cover: adım 22, 1 resimden 1.
    • Use a Y000 driver to remove the four 1.1 mm-long screws securing the front sensor connector cover.
    FixBot'a Sor
    Yorum Ekle
  23. iPhone 12 Pro Max Battery Replacement, Remove the front sensor connector cover: adım 23, 3 resimden 1. iPhone 12 Pro Max Battery Replacement, Remove the front sensor connector cover: adım 23, 3 resimden 2. iPhone 12 Pro Max Battery Replacement, Remove the front sensor connector cover: adım 23, 3 resimden 3.
    • Swing the cover up from the left until the small clip on the right unhooks.
    • Remove the cover.
    • During reassembly, insert the clip on the right edge into its slot first, then hinge the rest of the cover into place.
    FixBot'a Sor
    Yorum Ekle
  24. iPhone 12 Pro Max Battery Replacement, Disconnect the front sensors: adım 24, 2 resimden 1. iPhone 12 Pro Max Battery Replacement, Disconnect the front sensors: adım 24, 2 resimden 2.
    • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
    FixBot'a Sor
    Yorum Ekle
  25. iPhone 12 Pro Max Battery Replacement, Remove the display assembly: adım 25, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  26. iPhone 12 Pro Max Battery Replacement, Unscrew the loudspeaker: adım 26, 1 resimden 1.
    • Use a Phillips driver to remove the four 1.4 mm screws securing the loudspeaker.
    FixBot'a Sor
    Yorum Ekle
  27. iPhone 12 Pro Max Battery Replacement, Remove the loudspeaker: adım 27, 3 resimden 1. iPhone 12 Pro Max Battery Replacement, Remove the loudspeaker: adım 27, 3 resimden 2. iPhone 12 Pro Max Battery Replacement, Remove the loudspeaker: adım 27, 3 resimden 3.
    • Slowly lift the loudspeaker out of its recess while gently peeling it off of its adhesive strip. Reapply this strip to the new loudspeaker.
    • Remove the loudspeaker.
    FixBot'a Sor
    Yorum Ekle
  28. iPhone 12 Pro Max Battery Replacement, Remove the Taptic Engine plastic cover: adım 28, 1 resimden 1.
    • Use a Phillips driver to remove the 1.4 mm screw securing the Taptic Engine plastic cover.
    FixBot'a Sor
    Yorum Ekle
  29. iPhone 12 Pro Max Battery Replacement: adım 29, 1 resimden 1.
    • Remove the plastic cover
    FixBot'a Sor
    Yorum Ekle
  30. iPhone 12 Pro Max Battery Replacement, Remove the Taptic Engine: adım 30, 2 resimden 1. iPhone 12 Pro Max Battery Replacement, Remove the Taptic Engine: adım 30, 2 resimden 2.
    • Use the point of a spudger to pry the Taptic Engine connector straight up and out of its socket.
    FixBot'a Sor
    Yorum Ekle
  31. iPhone 12 Pro Max Battery Replacement: adım 31, 1 resimden 1.
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the three screws securing the Taptic Engine:
    • Two 2.8 mm standoff screws
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    • One 1.6 mm Phillips screw
    FixBot'a Sor
    Yorum Ekle
  32. iPhone 12 Pro Max Battery Replacement, Remove the Taptic Engine: adım 32, 3 resimden 1. iPhone 12 Pro Max Battery Replacement, Remove the Taptic Engine: adım 32, 3 resimden 2. iPhone 12 Pro Max Battery Replacement, Remove the Taptic Engine: adım 32, 3 resimden 3.
    • Remove the Taptic Engine.
    • If you are replacing the Taptic Engine, remove the adhesive strip and transfer it to the new Taptic Engine before beginning reassembly.
    FixBot'a Sor
    Yorum Ekle
  33. iPhone 12 Pro Max Battery Replacement, Locate the adhesive strips: adım 33, 1 resimden 1.
    • The battery is secured to the rear case with four pieces of stretch-release adhesive—two on the bottom edge of the battery, and two on the top edge.
    • Each piece of adhesive has a black pull-tab at the end, which is lightly adhered to the edge of the battery.
    • In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. These "command-strip" style adhesives lose their stick when stretched, so you can remove the battery with ease.
    • If the strips break, don't panic! They don't always work as intended. Keep reading for tips on removing broken strips.
    FixBot'a Sor
    Yorum Ekle
  34. iPhone 12 Pro Max Battery Replacement, Remove the stretch-release adhesive: adım 34, 2 resimden 1. iPhone 12 Pro Max Battery Replacement, Remove the stretch-release adhesive: adım 34, 2 resimden 2.
    • Peel down the first battery adhesive pull-tab to un-stick it from the bottom edge of the battery.
    • Space is tight around some parts of the battery. It may help to slide an opening pick between the battery and its adhesive to help separate the adhesive.
    • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
    FixBot'a Sor
    Yorum Ekle
  35. iPhone 12 Pro Max Battery Replacement: adım 35, 2 resimden 1. iPhone 12 Pro Max Battery Replacement: adım 35, 2 resimden 2.
    • Peel down the second battery adhesive pull-tab to un-stick it from the bottom edge of the battery.
    FixBot'a Sor
    Yorum Ekle
  36. iPhone 12 Pro Max Battery Replacement: adım 36, 3 resimden 1. iPhone 12 Pro Max Battery Replacement: adım 36, 3 resimden 2. iPhone 12 Pro Max Battery Replacement: adım 36, 3 resimden 3.
    • Grab the first pull-tab with your fingers and slowly pull it away from the battery, toward the bottom of the iPhone.
    • Pull hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and un-stick from under the battery.
    • Don't press down on the battery. Hold the iPhone firmly by its sides.
    • Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling mainly in the middle or on one side.
    • Pull at a low angle so the strip doesn't snag on the edge of the battery.
    • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
    • If any of the adhesive strips break off underneath the battery and can't be retrieved, try to remove the other strips, and then proceed as instructed below.
    FixBot'a Sor
    Yorum Ekle
  37. iPhone 12 Pro Max Battery Replacement: adım 37, 3 resimden 1. iPhone 12 Pro Max Battery Replacement: adım 37, 3 resimden 2. iPhone 12 Pro Max Battery Replacement: adım 37, 3 resimden 3.
    • Grab the second pull-tab with your fingers and pull it away from the battery, toward the bottom of the iPhone.
    • Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
    • If the adhesive breaks off underneath the battery and can't be retrieved, continue with the next step.
    FixBot'a Sor
    Yorum Ekle
  38. iPhone 12 Pro Max Battery Replacement: adım 38, 3 resimden 1. iPhone 12 Pro Max Battery Replacement: adım 38, 3 resimden 2. iPhone 12 Pro Max Battery Replacement: adım 38, 3 resimden 3.
    • Peel up the two remaining battery adhesive pull-tabs to un-stick them from the top edge of the battery.
    • There's not a lot of space to grab these adhesive strips—using an opening pick to separate them from the battery before grabbing them with tweezers may help.
    FixBot'a Sor
    Yorum Ekle
  39. iPhone 12 Pro Max Battery Replacement: adım 39, 3 resimden 1. iPhone 12 Pro Max Battery Replacement: adım 39, 3 resimden 2. iPhone 12 Pro Max Battery Replacement: adım 39, 3 resimden 3.
    • Using the same procedure as before, pull the remaining two tabs, one at a time, to stretch and remove the remaining adhesive strip holding the battery in place. Try not to snag the adhesive on anything.
    • Be careful not to fling the battery from the iPhone as the final adhesive strip comes out.
    • If you removed all the adhesive strips successfully, skip the next step.
    • Otherwise, continue with the next step below.
    FixBot'a Sor
    Yorum Ekle
  40. iPhone 12 Pro Max Battery Replacement, How to remove a stuck battery: adım 40, 2 resimden 1. iPhone 12 Pro Max Battery Replacement, How to remove a stuck battery: adım 40, 2 resimden 2.
    • If you're still having trouble removing the battery, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use an opening pick or the flat end of a spudger to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    FixBot'a Sor
    Yorum Ekle
  41. iPhone 12 Pro Max Battery Replacement, Remove the battery: adım 41, 1 resimden 1.
    • Remove the battery.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • If your new battery didn't come with adhesive preinstalled, refer to this guide for help replacing the adhesive strips.
    • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
    FixBot'a Sor
    Yorum Ekle
Sonuç
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 Pro Max Answers community for help.
88 farklı kişi bu kılavuzu tamamladı.
Adam O'Camb
222.996 İtibar
416 adet Kılavuz yazıldı
13Kılavuz Yorumları
Will you ship to England from your us store I am after the battery
Glenn hinds - Yanıt Paylaş
Just an FYI. Seems like there's a solid chance that if you swap out the battery, your iPhone will not recognize the battery as an Apple certified one and will cease to receive any updates.
Daniel Pino - Yanıt Paylaş
100% chance, you can't make the message go away unless you have a BMS board reprogrammer
Zachary Rushworth - Yanıt Paylaş
How to solve that problem?
fakeelvis - Yanıt Paylaş
A mi hijo le partieron la pantalla y la parte de atrás de su teléfono. El mismo fue reparado, se cambiaron ambas partes la trasera y la pantalla frontal. A los días la batería se infló. Esto que lo pudo haber ocasionado? Es daño consecuencia de la reparación?
Inés Esber - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 132
Son 7 gün: 989
Son 30 gün: 4,178
Her zaman: 208,423
