Ana içeriğe geç
iPhone 6s Rear Case Replacement
Neye ihtiyacın var
  1. iPhone 6s Rear Case Replacement, Pentalobe Screws: adım 1, 1 resimden 1.
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.
    FixBot'a Sor
    Yorum Ekle
  2. iPhone 6s Rear Case Replacement, Anti-Clamp instructions: adım 2, 3 resimden 1. iPhone 6s Rear Case Replacement, Anti-Clamp instructions: adım 2, 3 resimden 2. iPhone 6s Rear Case Replacement, Anti-Clamp instructions: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    FixBot'a Sor
    Yorum Ekle
  3. iPhone 6s Rear Case Replacement: adım 3, 3 resimden 1. iPhone 6s Rear Case Replacement: adım 3, 3 resimden 2. iPhone 6s Rear Case Replacement: adım 3, 3 resimden 3.
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    FixBot'a Sor
    Yorum Ekle
  4. iPhone 6s Rear Case Replacement, Opening Procedure: adım 4, 1 resimden 1.
    Clampy - Anti-Clamp
    $24.95
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
    FixBot'a Sor
    Yorum Ekle
  5. iPhone 6s Rear Case Replacement: adım 5, 1 resimden 1.
    • Opening the display on the 6s separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • Take care not to place the suction cup over the home button.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    FixBot'a Sor
    Yorum Ekle
  6. iPhone 6s Rear Case Replacement: adım 6, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 6, 2 resimden 2.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
    • If you have any trouble, heat the front of the iPhone using an iOpener, hair dryer, or heat gun until it's slightly too hot to touch. This will help soften the adhesive securing the edges of the display.
    FixBot'a Sor
    Yorum Ekle
  7. iPhone 6s Rear Case Replacement: adım 7, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 7, 2 resimden 2.
    • There is a notch on the underside of the display, just above the headphone jack. This is the safest place to begin prying the phone open.
    • Place the flat edge of a spudger into the gap between the screen and rear case, directly above the headphone jack.
    FixBot'a Sor
    Yorum Ekle
  8. iPhone 6s Rear Case Replacement: adım 8, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 8, 2 resimden 2.
    • Twist the spudger to widen the gap between the front panel assembly and the rest of the phone.
    FixBot'a Sor
    Yorum Ekle
  9. iPhone 6s Rear Case Replacement: adım 9, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 9, 2 resimden 2.
    • Insert the flat end of the spudger on the left side of the phone, between the display assembly and rear case.
    • Slide the spudger up the side of the phone to separate the adhesive and pop the clips free.
    FixBot'a Sor
    Yorum Ekle
  10. iPhone 6s Rear Case Replacement: adım 10, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 10, 2 resimden 2.
    • Remove the spudger and reinsert it on the bottom edge, where you pried the phone open.
    • Slide the spudger to the right, along the bottom edge of the phone.
    FixBot'a Sor
    Yorum Ekle
  11. iPhone 6s Rear Case Replacement: adım 11, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 11, 2 resimden 2.
    • Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone.
    FixBot'a Sor
    Yorum Ekle
  12. iPhone 6s Rear Case Replacement: adım 12, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 12, 2 resimden 2.
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90º, as it is still connected at the top by three cables that may break if stretched.
    FixBot'a Sor
    Yorum Ekle
  13. iPhone 6s Rear Case Replacement: adım 13, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 13, 2 resimden 2.
    • Pull up on the nub on the top side of the suction cup to remove it from the front panel.
    FixBot'a Sor
    Yorum Ekle
  14. iPhone 6s Rear Case Replacement: adım 14, 3 resimden 1. iPhone 6s Rear Case Replacement: adım 14, 3 resimden 2. iPhone 6s Rear Case Replacement: adım 14, 3 resimden 3.
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
    • During reassembly, pause here if you wish to replace the adhesive around the edges of the display.
    • During reassembly, the camera end of the screen body needs to hook under the edge of the body. The hooks of the screen frame need to be under the rim of the main body and snugged toward the camera end to easily close the cover and have it properly clip.
    • These hooks are not really a proper hinge but clasps that need to be under the rim of the main phone frame/edge!! This way the screen easily will return to its closed state nicely gently snapping into place.
    • During reassembly, reverse order for getting the screen clipped back in means pressing along the right side top to bottom corner. Then the left.
    FixBot'a Sor
    Yorum Ekle
  15. iPhone 6s Rear Case Replacement, Battery Connector: adım 15, 1 resimden 1.
    Magnetic Project Mat
    $19.95
    • Remove two Phillips screws securing the battery connector bracket, of the following lengths:
    • One 2.9 mm screw
    • One 2.2 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    FixBot'a Sor
    Yorum Ekle
  16. iPhone 6s Rear Case Replacement: adım 16, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 16, 2 resimden 2.
    • Remove the battery connector bracket from the iPhone.
    FixBot'a Sor
    Yorum Ekle
  17. iPhone 6s Rear Case Replacement: adım 17, 3 resimden 1. iPhone 6s Rear Case Replacement: adım 17, 3 resimden 2. iPhone 6s Rear Case Replacement: adım 17, 3 resimden 3.
    • Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
    FixBot'a Sor
    Yorum Ekle
  18. iPhone 6s Rear Case Replacement: adım 18, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 18, 2 resimden 2.
    • Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
    FixBot'a Sor
    Yorum Ekle
  19. iPhone 6s Rear Case Replacement, Unfasten the display cable bracket: adım 19, 1 resimden 1.
    • Remove the following four Phillips screws securing the display cable bracket:
    • Three 1.2 mm screws
    • One 2.8 mm screw
    FixBot'a Sor
    Yorum Ekle
  20. iPhone 6s Rear Case Replacement: adım 20, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 20, 2 resimden 2.
    • Remove the display cable bracket.
    FixBot'a Sor
    Yorum Ekle
  21. iPhone 6s Rear Case Replacement: adım 21, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 21, 2 resimden 2.
    • Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  22. iPhone 6s Rear Case Replacement: adım 22, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 22, 2 resimden 2.
    • Disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
    FixBot'a Sor
    Yorum Ekle
  23. iPhone 6s Rear Case Replacement: adım 23, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 23, 2 resimden 2.
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the display cable by prying it straight up from its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  24. iPhone 6s Rear Case Replacement: adım 24, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  25. iPhone 6s Rear Case Replacement, Rear Camera: adım 25, 2 resimden 1. iPhone 6s Rear Case Replacement, Rear Camera: adım 25, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the rear camera from its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  26. iPhone 6s Rear Case Replacement: adım 26, 1 resimden 1.
    • Remove the following two Phillips screws over the rear camera bracket:
    • One 1.6 mm screw
    • One 2.0 mm screw
    FixBot'a Sor
    Yorum Ekle
  27. iPhone 6s Rear Case Replacement: adım 27, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 27, 2 resimden 2.
    • Remove the camera bracket.
    FixBot'a Sor
    Yorum Ekle
  28. iPhone 6s Rear Case Replacement: adım 28, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 28, 2 resimden 2.
    • Insert a spudger to the side of the camera, between the rear case and the camera module.
    • Gently pry up on the camera to nudge it out from its housing.
    FixBot'a Sor
    Yorum Ekle
  29. iPhone 6s Rear Case Replacement: adım 29, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 29, 2 resimden 2.
    • Remove the camera.
    FixBot'a Sor
    Yorum Ekle
  30. iPhone 6s Rear Case Replacement, SIM Tray: adım 30, 2 resimden 1. iPhone 6s Rear Case Replacement, SIM Tray: adım 30, 2 resimden 2.
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force.
    FixBot'a Sor
    Yorum Ekle
  31. iPhone 6s Rear Case Replacement: adım 31, 1 resimden 1.
    • Remove the SIM Card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    FixBot'a Sor
    Yorum Ekle
  32. iPhone 6s Rear Case Replacement, Logic Board: adım 32, 1 resimden 1.
    • Remove the two 2.3 mm Phillips screws securing the upper component cable connector bracket.
    FixBot'a Sor
    Yorum Ekle
  33. iPhone 6s Rear Case Replacement: adım 33, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 33, 2 resimden 2.
    • Remove the upper component cable connector bracket.
    FixBot'a Sor
    Yorum Ekle
  34. iPhone 6s Rear Case Replacement: adım 34, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 34, 2 resimden 2.
    • Remove the following five Phillips screws securing the top left Wi-Fi antenna:
    • Two 1.5mm screws
    • One 2.3 mm screw
    • One 1.9 mm screw
    • One 2.0 mm screw
    FixBot'a Sor
    Yorum Ekle
  35. iPhone 6s Rear Case Replacement: adım 35, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 35, 2 resimden 2.
    • Remove the top left Wi-Fi antenna.
    FixBot'a Sor
    Yorum Ekle
  36. iPhone 6s Rear Case Replacement: adım 36, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 36, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the audio control cable from its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  37. iPhone 6s Rear Case Replacement: adım 37, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 37, 2 resimden 2.
    • Use the pointed tip of a spudger to disconnect the antenna cable from its socket on the upper right corner of the logic board.
    FixBot'a Sor
    Yorum Ekle
  38. iPhone 6s Rear Case Replacement: adım 38, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 38, 2 resimden 2.
    • Use the pointed tip of a spudger to disconnect the antenna cable from its socket on the lower left corner of the logic board.
    FixBot'a Sor
    Yorum Ekle
  39. iPhone 6s Rear Case Replacement: adım 39, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 39, 2 resimden 2.
    • Insert the flat end of a spudger underneath the Lightning connector ribbon cable. Lift up to disconnect it from its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  40. iPhone 6s Rear Case Replacement: adım 40, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 40, 2 resimden 2.
    • Gently pull up on the antenna cable to de-route it from the two clips on the right side of the logic board.
    FixBot'a Sor
    Yorum Ekle
  41. iPhone 6s Rear Case Replacement: adım 41, 1 resimden 1.
    • Remove the 1.3 mm Phillips screw securing the NFC bracket to the logic board.
    FixBot'a Sor
    Yorum Ekle
  42. iPhone 6s Rear Case Replacement: adım 42, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 42, 2 resimden 2.
    • Remove the NFC bracket.
    FixBot'a Sor
    Yorum Ekle
  43. iPhone 6s Rear Case Replacement: adım 43, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 43, 2 resimden 2.
    • Remove the following two Phillips screws:
    • One 2.5 mm screw at the top of the logic board
    • One 1.4 mm screw set into the upper edge of the rear case
    FixBot'a Sor
    Yorum Ekle
  44. iPhone 6s Rear Case Replacement: adım 44, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 44, 2 resimden 2.
    • Remove the plastic clip.
    FixBot'a Sor
    Yorum Ekle
  45. iPhone 6s Rear Case Replacement: adım 45, 1 resimden 1.
    • Remove the final three screws securing the logic board to the rear case:
    • One 1.9 mm Phillips screw
    • One 2.5 mm hex nut
    • One 1.8 mm Phillips screw
    FixBot'a Sor
    Yorum Ekle
  46. iPhone 6s Rear Case Replacement: adım 46, 3 resimden 1. iPhone 6s Rear Case Replacement: adım 46, 3 resimden 2. iPhone 6s Rear Case Replacement: adım 46, 3 resimden 3.
    • Insert an opening pick below the lower edge of the logic board, between the board and the loudspeaker.
    • Use the opening pick to gently lift the logic board out of its housing.
    • Remove the logic board.
    FixBot'a Sor
    Yorum Ekle
  47. iPhone 6s Rear Case Replacement, Upper Component Cable: adım 47, 2 resimden 1. iPhone 6s Rear Case Replacement, Upper Component Cable: adım 47, 2 resimden 2.
    • Remove the two 1.5 mm Phillips screws holding the Taptic Engine in place.
    • Remove the Taptic Engine.
    FixBot'a Sor
    Yorum Ekle
  48. iPhone 6s Rear Case Replacement: adım 48, 3 resimden 1. iPhone 6s Rear Case Replacement: adım 48, 3 resimden 2. iPhone 6s Rear Case Replacement: adım 48, 3 resimden 3.
    • Use tweezers to peel up the tips of the battery adhesive strips at the lower edge of the battery.
    FixBot'a Sor
    Yorum Ekle
  49. iPhone 6s Rear Case Replacement: adım 49, 3 resimden 1. iPhone 6s Rear Case Replacement: adım 49, 3 resimden 2. iPhone 6s Rear Case Replacement: adım 49, 3 resimden 3.
    • Try not to wrinkle the strips during this procedure—they will become very difficult to deal with and will not straighten out again.
    • Pull one of the adhesive strips straight out, towards the bottom of the iPhone.
    • For best results, pull the strip at a 60º angle or less.
    • The strip will stretch to many times its original length. Continue to pull steadily, re-grabbing the strip closer to the iPhone if necessary.
    • Continue pulling until the strip is fully removed.
    • If the battery adhesive tabs break off at any point during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
    • If one of the adhesive strips breaks under the battery during this procedure, and cannot be retrieved, remove the remaining strip, and then skip to Step 48.
    FixBot'a Sor
    Yorum Ekle
  50. iPhone 6s Rear Case Replacement: adım 50, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 50, 2 resimden 2.
    • Repeat the previous step for the second adhesive strip.
    • Use one hand to hold down the battery as you remove the second strip, or the strip may fling the battery from the phone once it separates from the rear case.
    FixBot'a Sor
    Yorum Ekle
  51. iPhone 6s Rear Case Replacement: adım 51, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 51, 2 resimden 2.
    Plastic Cards
    $2.99
    • If you successfully removed all three adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
    • Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
    • After about a minute, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
    FixBot'a Sor
    Yorum Ekle
  52. iPhone 6s Rear Case Replacement: adım 52, 1 resimden 1.
    • Remove the battery.
    • When installing the battery, refer to this guide to replace your battery's adhesive strips.
    FixBot'a Sor
    Yorum Ekle
  53. iPhone 6s Rear Case Replacement: adım 53, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 53, 2 resimden 2.
    • Remove the single 1.3 mm Phillips screw securing the flash bracket.
    • Remove the flash bracket.
    FixBot'a Sor
    Yorum Ekle
  54. iPhone 6s Rear Case Replacement: adım 54, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 54, 2 resimden 2.
    • Use the flat end of a spudger to lift the flash out of its housing in the rear case.
    FixBot'a Sor
    Yorum Ekle
  55. iPhone 6s Rear Case Replacement: adım 55, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 55, 2 resimden 2.
    • Remove the following five Phillips screws:
    • Two 2.5 mm screws set into the left edge of the rear case
    • One 2.1 mm Phillips #000 screw set into the left edge of the rear case
    • Two 2.1 mm screws set into the right edge of the rear case
    • If you overtighten these screws during reassembly, your power and volume buttons may not click properly. Check the clicking action on each button before you continue with reassembly.
    FixBot'a Sor
    Yorum Ekle
  56. iPhone 6s Rear Case Replacement: adım 56, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 56, 2 resimden 2.
    • Use the pointed tip of a spudger to gently separate the microphone from the rear case.
    FixBot'a Sor
    Yorum Ekle
  57. iPhone 6s Rear Case Replacement: adım 57, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 57, 2 resimden 2.
    • Slide an opening pick between the upper component cable and the rear case.
    • Gently separate the cable from the rear case.
    FixBot'a Sor
    Yorum Ekle
  58. iPhone 6s Rear Case Replacement: adım 58, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 58, 2 resimden 2.
    • Continue pushing the opening pick under the cable until it fully separates from the rear case.
    FixBot'a Sor
    Yorum Ekle
  59. iPhone 6s Rear Case Replacement: adım 59, 1 resimden 1.
    • Remove the upper component cable assembly.
    FixBot'a Sor
    Yorum Ekle
  60. iPhone 6s Rear Case Replacement: adım 60, 3 resimden 1. iPhone 6s Rear Case Replacement: adım 60, 3 resimden 2. iPhone 6s Rear Case Replacement: adım 60, 3 resimden 3.
    • If your replacement part did not come with the mute switch cover, you will need to remove the switch cover and transfer It.
    • Use the flat end of the spudger to press down and hold the old bracket firmly in place.
    • Use tweezers or your fingers to carefully rock the switch cover such that the switch cover pins swing out of their clips.
    • Lift the switch cover straight up.
    • To install the mute switch cover onto the new upper cable assembly, reverse the steps.
    • The pins are supposed to rest near the clip opening. Do no attempt to force the pins far into the clips. The switch cover will be held securely in place once you screw the bracket back onto the case.
    • The switch cover goes on in only one orientation. If you are having a hard time getting the switch cover onto the new part, try toggling the switch so that the black protruding lever is in a different position.
    • Before reassembling the phone, check all switches and buttons to see if they physically work.
    FixBot'a Sor
    Yorum Ekle
  61. iPhone 6s Rear Case Replacement, Volume Control Button Covers: adım 61, 3 resimden 1. iPhone 6s Rear Case Replacement, Volume Control Button Covers: adım 61, 3 resimden 2. iPhone 6s Rear Case Replacement, Volume Control Button Covers: adım 61, 3 resimden 3.
    • Grasp the metal bar behind either of the two volume control button covers, and pull the button cover out of its housing in the rear case.
    • Repeat for the second volume control button cover.
    • Check for proper orientation when reinstalling the button covers. The metal bar should swing downward, towards the rear case of the iPhone.
    FixBot'a Sor
    Yorum Ekle
  62. iPhone 6s Rear Case Replacement, Power Button Cover: adım 62, 2 resimden 1. iPhone 6s Rear Case Replacement, Power Button Cover: adım 62, 2 resimden 2.
    • Grasp the metal bar on the back of the power button cover.
    • Remove the power button cover.
    • Check for proper orientation when reinstalling the button cover. The metal bar should swing downward, towards the rear case of the iPhone.
    FixBot'a Sor
    Yorum Ekle
  63. iPhone 6s Rear Case Replacement, Rear Case: adım 63, 3 resimden 1. iPhone 6s Rear Case Replacement, Rear Case: adım 63, 3 resimden 2. iPhone 6s Rear Case Replacement, Rear Case: adım 63, 3 resimden 3.
    • Deroute the antenna cable from its rubber sleeve on the right edge of the rear case.
    FixBot'a Sor
    Yorum Ekle
  64. iPhone 6s Rear Case Replacement: adım 64, 1 resimden 1.
    • Remove the antenna cable from the metal clip on the right edge of the rear case.
    FixBot'a Sor
    Yorum Ekle
  65. iPhone 6s Rear Case Replacement: adım 65, 1 resimden 1.
    • Remove the following five Phillips screws securing the speaker to the rear case:
    • Two 2.6 mm screws
    • Two 2.3 mm screws
    • One 3.0 mm screw
    FixBot'a Sor
    Yorum Ekle
  66. iPhone 6s Rear Case Replacement: adım 66, 3 resimden 1. iPhone 6s Rear Case Replacement: adım 66, 3 resimden 2. iPhone 6s Rear Case Replacement: adım 66, 3 resimden 3.
    • Use your fingers to lift the speaker out of its housing in the rear case.
    • Remove the speaker assembly.
    FixBot'a Sor
    Yorum Ekle
  67. iPhone 6s Rear Case Replacement: adım 67, 1 resimden 1.
    • Remove the following eight Phillips screws:
    • Two 2.9 mm screws securing the headphone jack
    • One 3.7 mm screw securing the microphone bracket
    • Two 1.3 mm screws on the lower edge of the iPhone
    • Two 1.9 mm screws on either side of the Lighting connector
    • One 3.0 mm screw to the left of the connector
    FixBot'a Sor
    Yorum Ekle
  68. iPhone 6s Rear Case Replacement: adım 68, 1 resimden 1.
    • Remove the plastic microphone bracket.
    FixBot'a Sor
    Yorum Ekle
  69. iPhone 6s Rear Case Replacement: adım 69, 3 resimden 1. iPhone 6s Rear Case Replacement: adım 69, 3 resimden 2. iPhone 6s Rear Case Replacement: adım 69, 3 resimden 3.
    • Insert an opening pick between the Lightning connector assembly and the rear case to begin breaking up the adhesive holding the flex cable in place.
    FixBot'a Sor
    Yorum Ekle
  70. iPhone 6s Rear Case Replacement: adım 70, 3 resimden 1. iPhone 6s Rear Case Replacement: adım 70, 3 resimden 2. iPhone 6s Rear Case Replacement: adım 70, 3 resimden 3.
    • Use the flat end of a spudger to continue separating the Lightning connector assembly from the rear case.
    FixBot'a Sor
    Yorum Ekle
  71. iPhone 6s Rear Case Replacement: adım 71, 2 resimden 1. iPhone 6s Rear Case Replacement: adım 71, 2 resimden 2.
    • Use the tip of a spudger to separate the two microphones from the lower edge of the rear case.
    FixBot'a Sor
    Yorum Ekle
  72. iPhone 6s Rear Case Replacement: adım 72, 1 resimden 1.
    • Remove the Lightning connector and headphone jack assembly.
    FixBot'a Sor
    Yorum Ekle
  73. iPhone 6s Rear Case Replacement: adım 73, 1 resimden 1.
    • Only the rear case remains.
    FixBot'a Sor
    Yorum Ekle
Sonuç
92 farklı kişi bu kılavuzu tamamladı.
Evan Noronha
229.541 İtibar
168 adet Kılavuz yazıldı
9Kılavuz Yorumları
I can't get the phillips 000 screw out on step 52, now it's become too hollow within to open. What do I do?
Anun Azganun - Yanıt Paylaş
Stripped screws are the worst! We have a guide on how to remove stripped screws that you may find helpful. Remember to maintain lots of pressure on the screw and stop applying force and try a different method if the bit is still slipping.
Evan Noronha - Yanıt Paylaş
Every thing works fine except I have no sound, either on speakerphone or normally. Did I break the upper component cable? I've checked all the plug connections and they seem ok.
John Lesnik - Yanıt Paylaş
I have no sound at all from the normal speaker or in speakerphone mode. I have good cellular and Wi-Fi connections and the phone sees to work perfectly otherwise. The battery charges fine through the Lightning connector. Can't use it as a phone though! Did I break the upper component cable in the disassembly? Any other ideas?
Before I start.. many steps involve pulling flex cables away from adhesive films lining the case. If my replacement back has no such adhesive films, or they are no longer sticky, what's the impact? Will I have a phone that buzzes and resonates when on speakerphone?
Handy - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 34
Son 30 gün: 141
Her zaman: 103,394
