Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. MacBook Pro 13" Retina Display Early 2015 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. MacBook Pro 13" Retina Display Early 2015 Teardown, MacBook Pro 13" Retina Display Early 2015 Teardown: adım 1, 3 resimden 1. MacBook Pro 13" Retina Display Early 2015 Teardown, MacBook Pro 13" Retina Display Early 2015 Teardown: adım 1, 3 resimden 2. MacBook Pro 13" Retina Display Early 2015 Teardown, MacBook Pro 13" Retina Display Early 2015 Teardown: adım 1, 3 resimden 3.
    • Behold, the new Retina! We've done this dance before with Apple's 13-inch professional laptop, but something's changed. Oooh that trackpad!
    • Let's see what technical marvels this magic box has to offer:
    • 13.3-inch, 2560-by-1600 pixel (227 ppi) Retina display
    • 2.7 or 2.9 GHz dual-core Intel Core i5 processor (Optional 3.1 GHz dual-core Intel Core i7 processor available)
    • 8 GB or 16 GB of 1866 MHz LPDDR3 onboard memory
    • 128 GB, 256 GB, 512 GB, or 1 TB flash storage
    • Intel Iris Graphics 6100
    • Thunderbolt 2, USB 3.0, and full size HDMI I/O
    its configurable up to a 3.1GHz dual core i7. The i5 can turbo to 3.3GHz, but thats it :P
    [deleted] - Yanıt
    if you look at benchmarks, youll find the i7 isnt that much stronger than the 2.7 i5, so for most people it isnt really worth getting. (think about the added heat as well)
    bcredeur97 -
    Hey Guys, ready to do the 15" macbook pro from 2015?
    mcrugg - Yanıt
  2. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 2, 2 resimden 1. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 2, 2 resimden 2.
    • A quick look at the bottom panel reveals no surprises—this machine shares the A1502 designation with the late 2013 Macbook Pro.
    • Let's take a peek at the ports:
    • On the right side, this MacBook is equipped with an SDXC card slot, HDMI port, and a USB 3 port.
    • To the left (to the left), we have a MagSafe 2 port, two Thunderbolt 2 ports, another USB 3.0 port, a headphone jack, and dual microphones (plus everything we own, in a box).
  3. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 3, 3 resimden 1. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 3, 3 resimden 2. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 3, 3 resimden 3.
    • Let the reveal commence. Drumroll, please!
    • It looks like this MacBook Pro inherited the single fan gene from its predecessor... among other things.
    • Actually, the only immediate difference we note is the trackpad cable, newly slung over the top of the battery. Other than that, it's very similar to the Late 2013 version (last image).
    • We'll have to cut a bit deeper to get to the good stuff.
  4. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 4, 3 resimden 1. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 4, 3 resimden 2. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 4, 3 resimden 3.
    • Is Apple actually beckoning us in? The warning text on the battery that we've seen in the MacBook Pro 13" Retina Display Late 2013 Teardown (center) has disappeared. Well then, let's dig in!
    • Okay, maybe just relocated... But spoilers! We're not removing the battery just yet.
    • The mystery of the Force Touch trackpad unfolds layer by layer as we first remove its cable.
    • Apple leaves us with enticing instructions for this trackpad: "Press a little deeper, do a lot more." Okay, Apple, if you insist!
    This trackpad cable is proving to be the last straw for me. Not a month off warranty, the keyboard and trackpad on my MBP stopped responding and replacing this poorly-located cable was the only fix. Three months later, I'm having the same problem, albeit intermittently, and I'm probably going to have to replace it yet again. It's not acceptable that this fancy product is sold as a pro-level machine. Frankly, Apple's new engineering ethos is an embarrassment and an insult to the industry, and yet when I look into the competition, I see much the same: fancy products designed to last just beyond the standard warranty. And don't get me started on port adapters. Such a shame.
    mapercortesia - Yanıt
    To any of you possibly reading this and in any way invested in this cable issue, I did indeed replace the cable back in August (2016) and the machine worked properly until this last week of December (2016) when the problem returned. I'll either have to replace it yet again or move on to a new machine.
    mapercortesia -
    Thanks for providing me another incidence of this cable being the culprit in what seems to be a frequently reported bug on this particular model of the MacBook pro.
    dramitkrsharma -
    Hi mapercortesia - can you please let https://appelissues.net/ know about the issue and please cite this compendium that is collecting as much information about the issue: http://a1502-2015-macbook-pro-13-trackpa...
    software developer -
    I'm having the same intermittent trackpad and keyboard issue for the last few weeks. I've narrowed it down to the cable based on feedback from people like yourself and would love to know where you procured your replacement cable from (and the part number if you happen to know it).
    dramitkrsharma - Yanıt
    Hello! I ordered the IPD Trackpad Flex Cable (Item CMP-5726-UTW0) from Command Mac Parts.
    mapercortesia -
    Last update for anyone affected by this issue: this is fundamentally a design flaw. Temperature fluctuations cause the extremely small points of contact between each end of the cable and its respective connector to disengage. Unless the cable itself is truly kaput, reseating it often resolves the problem, but only temporarily. Allowing the machine to adjust to room temperature (after carrying it around outside in colder weather, for example) may also get the keyboard and trackpad working again. Tapping on the case beneath the spacebar, at the base of the trackpad or underneath the trackpad can also get the components working properly. But, again, this is not a permanent solution. I'm not sure if there is a permanent solution. And since carrying an external keyboard and mouse around with me is preposterous (imagine someone sitting in a cafè with a keyboard on their keyboard), I'm not going to deal with this anymore. It will be a long time before I consider purchasing another Apple product.
    Hey mapercortesia. I actually paid Apple to replace the cable. I tried to replace it myself with one off eBay and it worked except for haptic feedback / clicking.
    I can’t work on a crippled device so I took it to Apple immediately. I didn’t bother to check if others had the haptic feedback issue with replacement cable, but that is indeed the case. And there’s 2 part numbers for the cable (one is a revised one that Apple tries to remedy the issue with - but still fails).
    Under Australia Consumer Law Guarantee a product must be of acceptable quality free from defect and fit for purpose (e.g. you can use keyboard & mouse). This trackpad cable is, as you say, a design flaw and not durable and fails that test. However this law only applies for products with a reasonable lifetime expectancy. Apple in Australia uses only two factors on deciding reasonable lifetime: (1) when the fault happened and (2) the age of the product.
    Apple says: “your laptop is 4 years old, which is 12 months older than expected lifetime”.
    Here is an actively maintained compendium of this issue: http://a1502-2015-macbook-pro-13-trackpa...
    I urge anyone having this issue please contact https://appleissues.net/ and let them know that this is a widespread well known issue that Apple has not acknowledged and link to above.
    software developer - Yanıt
  5. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 5, 2 resimden 1. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 5, 2 resimden 2.
    • Operation: Battery Extraction is underway! Since we've seen retinas before, we've got a bit of an eye-dea how to proceed, but you aren't going to hear it since the speakers are out next.
    • Where once there were four screws holding the battery frame in place (perhaps superfluously, with all of the adhesive used), there are now four rubber stoppers.
    • The previous gen's adhesive seemed plenty strong—so, is Apple poofing away these screws because they weren't ever needed, or because they aren't needed now? Perhaps a stronger adhesive made these screws unnecessary? We shudder at the thought.
  6. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 6, 2 resimden 1. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    iOpener
    $17.99
    • If it's a battle you want, Apple, it's a battle you'll get. As the old Klingon proverb says, today is a good day to die trying to unseat a battery.
    • Armed with our trusted tools, iOpener and plastic card, we begin heating and prying the battery, taking care not to puncture anything with "potential for fire or burning."
  7. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 7, 2 resimden 1. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 7, 2 resimden 2.
    • These components are putting up an orchestrated effort to avoid our eyes. We use our plastic opening tool to nudge the trackpad control board out of our way, but not remove it...
    • Apple decided to solder the largest cables onto the trackpad board, meaning we'll have to just flip it out of the way for now. Y U NO ZIF, Apple?
    • The new trackpad board has some interesting ICs:
    • ST Microelectronics 32F103 ARM Cortex-M based microcontroller
    • Broadcom BCM5976 touch screen controller
    • This is the same lil' guy found in the iPhone 5s as well as the iPad Air.
    你好,这个板子能买到吗?
    孟令涛 - Yanıt
  8. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 8, 3 resimden 1. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 8, 3 resimden 2. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 8, 3 resimden 3.
    • Arrrgh. We begin the arduous process of carding this underaged battery for substance abuse. In our view, adhesive should be a controlled substance, and only used responsibly.
    • We know Apple can do better, since we've seen it, like, yesterday.
    • The central cells seem tougher to remove than in in years gone by. Maybe we're just weaker.
    • Peeling back the battery reveals... gunk. Either Apple doesn't think you need to replace this battery, or someone accidentally dipped it in tar.
    Tar video is unavailable :(
    No Reply - Yanıt
    Tar video is gone :(
    No Reply - Yanıt
    What was the tar video *of*? <shoot[V]-foot[N.DO]-self[PRO.GEN] copyright rant> Some obscure scene in an obscure movie that would have actually served to advertise the movie to people who read iFixit? Wow - an opportunity for a movie company to perhaps *make money* from “copyright infringement” - *what a concept*!
    jimwitte - Yanıt
  9. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 9, 3 resimden 1. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 9, 3 resimden 2. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 9, 3 resimden 3.
    • We performed a battery of procedures in order to remove this 74.9-watt-hour array of lithium-polymer cells.
    • Apple claims that this new 11.42 V, 74.9 Whr battery provides up to 10 hours of web browsing and up to 12 hours of video playback.
    • For the Late 2013 model, we got 71.8 Whr—so we're up a whole 4% capacity, for an extra 11% runtime. We're gonna chalk the rest of the boost up to the Broadwell architecture's efficiency gains.
    • The Dell XPS 13, however, manages an HD screen and an (alleged) 11 hours of run time on a 52 Wh battery.
    • This familiar Retina denizen, the Texas Instruments BQ20Z451 Gas Gauge IC, measures battery life.
    • This IC should be similar to the older BQ20Z45, or its replacement, the BQ20Z45-R1.
    Not sure if anyone here knows this off the top of their head (or if anyone will read it..), but I assume the BQ20Z451 is based around a coulomb counter. How much energy is “wasted” by the CC in the process of measuring?
    jimwitte - Yanıt
  10. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 10, 3 resimden 1. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 10, 3 resimden 2. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 10, 3 resimden 3.
    • Here it is, folks—the all-new Force Touch trackpad. To put it to the test, we bring in our littlest employee, Gus the Ewok Cavapoo, to investigate.
    • Thusfar, Gus is unimpressed. (Maybe he's not pressing hard enough?)
    • You can't judge a trackpad by its cover, so we remove the 10 screws securing it.
    • We're trying not to judge it; at least it's not adhesive. But the sight of 10 more screws in the trackpad underneath the cover makes us groan. Just how much force is in this trackpad?
  11. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 11, 1 resimden 1.
    • The Force is with us. Well, the Force Touch trackpad that is.
    • Hinted at as far back as 2007, we finally have our hands on the Taptic Engine, which provides the haptic feedback for the Force Touch.
    • Confused? Let's break these ridiculous rhymes down. Haptic feedback is just a fancy way of saying that the trackpad will use vibration and pressure to let you know what's happening. "Taptic Engine" is Apple's term for the underlying electromagnet that makes it shake, rattle, and roll.
    • Tl;dr: Rumble Pak.
    Any chance this is compatible with an older 13" rMBP or 15" rMBP?
    Shrivatsa Somany - Yanıt
    Does the force touch track pad fit into a 2013 MBP?
    jantheiss - Yanıt
  12. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 12, 1 resimden 1.
    • At their event on Monday, Apple showed us some incredible renders of the new MacBook's cutting-edge Force Touch trackpad.
    • We were expecting the MacBook Pro to receive the same trackpad—but this looks somewhat different, with a full lower panel and four springy mounts.
    • Not that we're criticizing—there's certainly a big difference between retrofitting technology into an existing laptop like the MacBook Pro, and a ground-up design like the MacBook. But we'll be excitedly looking for the differences when we get our hands on the MacBook.
  13. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 13, 3 resimden 1. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 13, 3 resimden 2. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 13, 3 resimden 3.
    • Let's take a gander under the hood of the Taptic Engine, shall we?
    • The rubber we hoped to simply cut open needed to be cut away chunk by chunk.
    • Finally, the coils are free! Well, bare at least.
    • Force Touch looks to be a clever application of a technology that dates back a ways—the year 1824, to be exact.
    • Made of wire coils surrounding a ferromagnetic core, the electromagnet in the Force Touch Trackpad is used to create the vibrational feedback you feel.
    • We're guessing that the four separate coils here are used to vary the feedback given to the user. Turning different sets of the four coils on and off varies the strength and direction of the vibration, and how it feels to your finger.
  14. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 14, 1 resimden 1.
    • Let's continue unraveling the secrets of the trackpad, starting with the coils—we were hoping to find some evidence of linear oscillators in the taptic engine, but it looks like it's just a series of electromagnets.
    • The magnets rapidly push and pull against a metal rail mounted beneath the trackpad, to create a tiny "buzz" of feedback with each click (and a second buzz for a "force click").
    • So that explains the buzzing, but what about the sensing?
    • A patent issued last year hints that the Force Touch might utilize strain gauges to measure pressure on its surface.
    • We're going to just have to crack this bad boy the rest of the way open to see if that's the case.
    I'll give you big kudos if you can wind that coil back up and have it work again.
    cityzen - Yanıt
    Patent applications related to that trackpad were published in the end of 2013, under an unknown applicant name: Yknots Industries LLC, in Delaware... See for example http://www.google.com/patents/WO20131883..., http://www.google.com/patents/WO20131656..., among others. Once those worldwide patent applications enter in national phases (such as US), they become assigned to Apple Inc.
    Does Apple create fake company entities to conceal its published patent applications?
    Doc Godo - Yanıt
    Wouldn’t that be at least some counterproductive to Apple, in terms of it’s valuation regarding patents that they have but don’t/haven’t/don’t-ever-intend-to-use? Of course, that assumes that anyone *cares* about that, unless “Time Apple” *really* screws up, it goes back 20 years and manages to drop to a few cents and become a takeover target.
    But if Apple decided to license those (hypothetical) “never intend to use” patents.. Or to let them be used in ways that Apple would never actually *do* (because it was too complicated for “the simple folk” in terms of industrial/UX design").
    jimwitte - Yanıt
  15. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 15, 3 resimden 1. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 15, 3 resimden 2. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 15, 3 resimden 3.
    • Removing the trackpad from the bracket requires slicing through four pads of glue.
    • With the pad splayed open, we get our first look at the pressure sensors.
    • And popping the sensor bracket under a microscope, we get a second, closer look.
    • Based on the wiggly pattern of traces stuck to the metal tabs, we're pretty sure the magic pressure sensors in the new Force Touch trackpad are tiny strain gauges. Mounted on flexing metal supports, they detect the amount of flex on each—and based on that, the force from above.
    • This works in conjunction with the traditional capacitive touchpad up top, to pinpoint where you're applying force.
    • Be sure to check out our in-depth video analysis of the Force Touch trackpad!
  16. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 16, 3 resimden 1. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 16, 3 resimden 2. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 16, 3 resimden 3.
    • This looks familiar... The all-new and twice-as-fast flash memory has the exact same ICs as the one found in our recent teardown of the MacBook Air 13":
    • Samsung S4LN058A01 PCIe 3.0 x4 AHCI flash controller
    • Samsung K4E4E324ED 512 MB LPDDR3 DRAM
    • 8 x Samsung K9LDGY8S1D-XCK0 16 GB flash storage (128 GB total)
    • Just like its MacBook Air brother, this SSD benchmarks at significantly faster speeds than the previous generation.
    So will I be able to order their proprietary SSD from Apple and then be able to upgrade? Will they (Apple) do the upgrade for a charge (albeit a very steep charge)? Say 128 to 512? Surely third parties will as well once warranty goes out on the model..
    chrisdublynn - Yanıt
    I would wait at the moment. There is one website that sell the SSD but at a ludicrous price. You can check eBay for the drive, but make sure it's for your apple macbook pro.
    Mit Amin -
    Hi everyone I just wanna know, can I upgrade my SSD card on the MacBook Pro retina early 2015 ? Thank you for your answer
    paulwood94 - Yanıt
  17. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 17, 2 resimden 1. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 17, 2 resimden 2.
    • This MacBook loses its cool, and moments later the logic board flips out.
    • Not to worry—we've got this under control. Apart from that metastasizing blob of thermal paste, this looks like our old friend from teardowns of yore: same form factor, same removal procedure.
    Why is the thermal pipe not touching the GPU die?
    Jack - Yanıt
    The thermal pipe contact surface does cover the combined CPU+GPU die completely, so no problem there (though it looks like there's an awful lot of thermal paste on iFixits device...).
    The part I think you're looking at (clean with no thermal paste and too far from the thermal pipe contact surface to be covered by it) is the PCH die, which apparently doesn't put off enough heat to matter.
    Speculating, if they HAD extended the thermal pipe contact surface to the PCH, it would almost certainly have transferred some of the heat coming off the CPU+GPU die over to the PCH, which in addition to being counterproductive, might be something the PCH can't handle :)
    Steve -
  18. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 18, 1 resimden 1.
    • We forgot our IC decoder ring, but no matter—a lot of these chips look very familiar:
    • Intel SR26K Dual-Core i5-5257U Processor with Intel Iris Graphics 6100
    • SK Hynix H9CCNNNBLTALAR LPDDR-SDRAM
    • Cirrus 4208-CRZ Two-Channel Low Power HD Audio Codec
    • Intel DSL5520 Thunderbolt 2 Controller
    • Texas Instruments TI 58872D
    • 2 x Fairchild Semiconductor DE46SY
  19. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 19, 1 resimden 1.
    • More familiar friends! These are the ICs that bespangle the back of the lobo:
    • SK Hynix H5TC4G63AFR 4 Gb (512 MB) DDR3 SDRAM
    • Texas Instruments/Stellaris LM4FS1EH SMC controller
    • Broadcom BCM15700A2, appears to be a wireless networking chipset
    • Texas Instruments HD3SS213 DisplayPort Differential Switch
    • Windbond 25064FVIQ
    • Linear Technology LT3957 and Intersil 958 26AHRZ
    • Texas Instruments TPS51980 and SMSC EMC1704-2
    On the “Linear Technology LT3957 and Intersil 958 26AHRZ” and “Texas Instruments TPS51980 and SMSC EMC1704-2”, which one is which?
    Meow meow - Yanıt
  20. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 20, 3 resimden 1. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 20, 3 resimden 2. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 20, 3 resimden 3.
    • The I/O board looks unchanged, but what about the onboard chips? Looks like some of them have swapped sides:
    • Parade Technology PS8401A HDMI Jitter Cleaning Repeater
    • Genesys Logic GL3219 SDXC Card Reader Controller
    • NXP Semiconductors PCA9501 8-bit I/O Expander with an On-Board 2-kbit EEPROM
    Has apple really not changed to the now 4 year old SD4.0 standard for SDXCcards? this is a 5 year old part yes? Max throughput 104MB/s?
    jimmyjimjim - Yanıt
  21. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 21, 2 resimden 1. MacBook Pro 13" Retina Display Early 2015 Teardown: adım 21, 2 resimden 2.
    • MacBook Pro with Retina Display 13" Early 2015 Repairability Score: 1 out of 10 (10 is easiest to repair)
    • Proprietary pentalobe screws continue to make opening the device unnecessarily difficult.
    • The battery assembly is entirely, and very solidly, glued into the case, thus complicating replacement. Additionally, the battery covers the screws holding the trackpad in place, meaning it's impossible to replace the trackpad without first removing the battery.
    • The Retina display is a fused unit with no separate, protective glass. If anything ever fails inside the display, the entire ($$$) assembly will need to be replaced.
    • The RAM is soldered to the logic board. Pay for the upgrade now, or be stuck with 8 GB forever. There is no chance of upgrade.
    • The proprietary PCIe SSD still isn't a standard drive. Cross your fingers for future compatible drives; for now, you're stuck with what you've got.
    This repairability score seems particularly harsh to me. Pentalobe screws - so? You get a tool and you can open it easily. Battery replacement - yes, difficult, but possible, especially with the guides provided here. SSD - easily available so that comment is overly harsh. I'd give it a 3 or 4. To me, "repairability" is the ability to be repaired, not so much a commentary on how difficult it is. Several components can be replaced, so that's good.
    David - Yanıt
    Como siempre, iFixit cumple. Excelente guía de sustitución de batería, en mi caso.
    Dos pentalobe, secador de cabello, tarjetas plásticas en desuso y paciencia, mucha paciencia. ¡Éxito!
    Se me terminó la alegría al pretender ampliar la memoria RAM. ¡No se puede! (¡¡¡¿¿¿ >:( ???!!!). Muy MAL por Apple.
    Luis Miguel Hierro Martínez - Yanıt
52Kılavuz Yorumları
How are the SSDs propriotery? They are just a M.2 SSD available in most places! The Samsung ones are just harder to get.
theodorlas - Yanıt
They appear to be M.2 but they aren't. If you look closely to the connector you can spot some differences.
Andre Fonseca -
It's the same as in the old Macbook Retina. A Proprietary connector, it's a modified SATA3 connector. Every macbook aberration has even its own form factor. So upgradability will be not possible that easy.
ydar -
I would edit the part "Pay for the upgrade now, or be stuck with 8 GB forever. There is no chance of upgrade."
It should rather say "There is no chance of upgrade FOR THE ORDINARY PEOPLE OUT THERE."
I don't know how skilled at soldering technicians you have in the US, but from where I come from (Czech Republic), I work with a guy who can do wonders, and that includes upgrading, usually the 2012 15" Retina Macbooks Pro from 8GB Ram to 16GB ram.
And if there's something this guy can't do, then he has his Polish friends who can resurrect computers that 99.9% technicians out there would consider unrepairable, dead, useless weight.
I wish I had their skills. I guess there's a long way ahead of me
Marhowl - Yanıt
Actually he is correct. The 2012 15" retina has the RAM soldered to the board. The 2012 15" without the retina display does have removable RAM chips. So yes upgrading the 2012 Retina does take some pretty good soldering skills. Here is an image of the 2012 15" Retina motherboard
https://d3nevzfk7ii3be.cloudfront.net/ig...
gverrault -
Hi, i am in germany and I want to open the laptop and clean it for coffee spill. are there technicians like you said in germany? it would be much help
krishna -
Hi, are there any technicians like that in germany? i want help in cleaning my mac which got coffee spilled over
krishna -
I think the PCIe 3.0 SSD is not a good reason to give this a 1 score. First off, it's smaller. And then it's super fast, has less protocol overhead and can virtually be upgraded with any future PCIe compatible SSD provided Apple builds the support required inside OS X.
brokenthorn - Yanıt
Noooooooop. This is not a standard M.2 SSD. It's got a proprietary connector.
mikeswelch -
I'd like a comparison with the old trackpad to see how it compares. Check overall volume,part volume, part location, height of system and parts, all weights... Maybe edge sealing around the pad...
The point being that I want to know how much does this actually gain or loose. That new Lenovo is about 15% lighter when compared to the new macbook so I'm curious where the weight is coming from.
fastm3driver - Yanıt
This means if I have a mid-2014 13" Retina and I buy a new 2015 13" Retina I can't swap the SSD? I was hoping I could, I have a 1TB model now, I'd like to move my SSD into a new 13" Retina.
KarmicJustice - Yanıt
you may actually be able to... no word on it yet however
bcredeur97 -
Does the Force Touch trackpad have the same connection and mounts as the old Macbook Pro trackpad? Thinking about retrofits here.
xcorlett - Yanıt
Great teardown as usual. "Proprietary" was the beginning of the end for IBM - anybody remember the PS2? Apple is getting cocky and not caring about its customer base the way Microsoft did in the 90s - which led to its irrelevancy of today. Not letting your customers upgrade their SSD down the road is simply cruel, like a doctor telling a patient s/he will only get one battery for the pacemaker. It will come back to bite Apple, as history has proven many times. Anybody remember Apple being close to bankruptcy in the late nineties?
TonyInMontreal - Yanıt
yep and lets not even mention the terrible quality of the iPhone 6 and 6+, they are either out of touch or simply dont care
Roger -
Any chance you can retrofit the force track pad to a late 2013 retina macbook pro?
huecobros - Yanıt
do you want to be the first to try it? xD
bcredeur97 -
Hi guys, I have a 128 GB Macbook Retina Early 2015. I would like to have a 500 GB SSD. Is this possible without the warranty going void?
siva - Yanıt
hi guys.. wishes from abu dhabi
i have macbook pro retina 13" late 2012.. is it possible to upgrade its ssd ?
Sulaiman Nissar - Yanıt
I did it on a MacBookPro Early 2011, be sure of compatibility.
Riccardo Mereu -
I knew when Steve Jobs died that Apple would not be able to carry on satisfying customers. It only took a couple of generations of the Macbook to alienate the customer. The many changes are not for us, they're for Apple. Old trick - planned obsolescence. If you cannot upgrade the device you have to buy a new one sooner. Great for Apple - bad for customer. But wait, what if customer no longer buys them? I refuse to buy any computer that I cannot upgrade. And I know I'm not the only one. History is repeating itself. No Jobs = bad decisions at Apple. Sell your stock boys, this time he ain't commin' back!
Cave Dave - Yanıt
Sorry to break it to you but Steve Jobs was the one who first decided Apple should take the closed system approach way back in the 1980's with the introduction of the Macintosh, he wasn't quite the hero of the company he appears.
Ben -
What do you exactly need 1 Tb of internal storage for? I have a 128 Gb model and a removable 1 Tb external solid state drive that was £50. Im studying for a masters in mechanical engineering here in England and the macbook is perfect. Its solid as a brick, reliable and stable. Compared to the surface book its cheap.
I have a monster gaming rig the size of a fridge for home use.
Its a tool, you don't perform surgery with a sledgehammer. I would recommend the pro to anyone. Apart from gamers.
Steve - Yanıt
Where did you get a 1TB external SSD for £50?
aldrinjtauro -
I'm planning tobuy retina macbook pro 2015 13inch
I hAVE SOME DOUBTS
1.Whether ram is soldered or ram upgradable
2. Many people facing problems strains on retina display
3. We can manuallu updgrade ssd in this model
4. whehter it is best for CATIA,ANSYS,SOLID WORKS working environment
chidella jayachand - Yanıt
If you are doing advanced video editing then even then the 13" is good. I use Adobe Audition and Adobe After Effects with it and it doesn't lag. But the 15" has a dedicated graphics card, that might be better for you if you do 3D modelling as it is more powerful. It is also quad core as opposed to dual core.
AdamA -
OMG was I the only one who loved hearing her say the names of all the components? haha! Great tear down guys!
Daniel Scott - Yanıt
Hi, where is the reed switch/hall sensor that let the macbook goes in stop mode when you close the lid?
Nagus - Yanıt
I really wish you guys had taken off the keyboard backing to show that it is now held in place by rivets, not screws. Wasted 3 hours getting it apart, realizing I couldn't replace the keyboard then putting it back together still broken. Not angry at iFixit. !#^&@@ off at Apple for this blatant disregard to repair-ability.
jerbil24 - Yanıt
Hello, I would like to know if it is possible to remove the motherboard without removing the heatsink. Can anyone help me?
Riccardo Mereu - Yanıt
'Maybe' but it's not a best practice. The fan on the 13" has a panel that extends far beneath the heatsink. And the tiny ribbon cable that connects the fan to the logic board is very difficult to unplug with the heatsink attached. If you can manage to unplug the ribbon cable without remove the heatsink, then yes.
Jacob -
Even though the battery is a monster to remove is replacement plausible?
RikoTiko - Yanıt
Hey RikoTiko! Lucky for you we created a product for replacing Retina batteries with adhesive remover, making this job way easier! We have the adhesive remover kit here, and a battery replacement kit here, for use with this guide. Since this requires such a specialized solution, the repairability score still stands, despite being plausible. =)
Sam Goldheart -
Well, now I understand (yea, right!) why you guys make the big bucks right out of puberty. So, here’s my question: To begin with, it is now April 2018 and I’m asking about a 2015, 13” 2.9, I5 Retina MB Pro with the 6100 graphics that’s going bad (which should really inspire another blog altogether about why the !&&* Adderrall wasn’t available in the 80s when I clearly needed it), and therefore i’ve been offered this otherwise perfect condition laptop for a song. So, how much will this repair cost, and is there someone in the Washington, D.C. area capable of performing same while I wait, hopefully without being bent over toooo far? Only a day or two to decide … HEEELP!!
s'
Phil - Yanıt
Is the processor soldered to the system board in this model??
SAR - Yanıt
Yes...Don't know if there's ever been a macbook with an upgradeable processor...that's typically been reserved for their desktops.
Jacob -
could i upgrade my MacBook pro 13” early 2015 from 8 ram to 16 ??
Abdullah Alnaqbi - Yanıt
Not you, but somebody! Check them out: https://iboffrcc.com/
Jacob -
Is there a Processor Upgrade i can Get?? And how do i replace it?? Is it Soldered on??
The i5 is not enough for me!
preston.douglas3 - Yanıt
To you and @yourtechy: you can’t upgrade, it’s soldered straight to the board. That’s the norm with laptops unfortunately!
Jeff Suovanen -
Sure there is! Is it feasible for you to do or economic for you to pay for someone else to do? Nope! Check out Dosdude1 on youtube...You are likely limited to dual core 4th gen cpu's due to the TDP constraints of the 13" laptop though.
Jacob -
Do we have to replace keyboard and trackpad also only to replace the battery?Because my battery has failed.
Chaitanya Pohnerkar - Yanıt
I have 2015 model a1502 macbooc pro, retina and hard drive crashed. Can I fix myself? Local applestore is almost asking half price of macbook. What SSD can fit this model.
Greg - Yanıt
@gogababa I think this is the guide you’re looking for. It includes a link to some compatible parts. They are pricey, but far less than half the retail cost of the machine.
Jeff Suovanen -
Hi, on Step 17 theres a black tape like thing around the CPU that came off during one of my repairs.
There seems to be a lot of confusing stuff on the internet (and during my calls to repair shops) about that.
Is it a thermal pad or kaptom tape? Where can I get the replacement?
Very much appreciated.
Amit Shakya - Yanıt
Great question...no one knows! Check out the discussion here: Tape over processor and GPU?
Jacob -
Hello,
I would like to know if thé LCD Screen is the same on 2014 and 2015?
thank you!
Roger - Yanıt
See this link for all your MacBook interchangeability needs!
https://logi.wiki/index.php/MacBook_LCD_...
Jacob -
what is the screw type and size for heatsink and ssd? i need to buy new one because old one are stripped.
rick - Yanıt
Ouch! Marhowl. Ourada plunge-tore a stake into your rectum
nialldooley - Yanıt
I feel like this score (as well as others) deserve a revisit. I am a moderately seasoned technician and I have gutted an entire 13 and 15 inch retina MacBook Pro. What are the main differences from the unibody's?
1. Proprietary SSD (alleviated via a cheap adapter)
2. Soldered RAM (the biggest bummer; but still possible to upgrade and I HAVE: see REWA and iBoff RCC)
3. Riveted Keyboard (Another bummer, but not that impossible to replace; and after replacing? You can use screws!)
4. Adhesive for the battery (I removed both 13/15 batteries WITHOUT heat or adhesive dissolver; I did need to remove the 15 Logic Board, so that is certainly a time consuming repair)
5. The screen assemblies are basically all one unit, any issue means you are replacing the whole thing for most people (but even on the unibodies...who was replacing individual components on these screens? That's crazy risky)
Other than that? Everything is just screws and connectors...borderline identical to unbody's. 1/10? Give me a break...
Jacob - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 37
Son 7 gün: 230
Son 30 gün: 1,231
Her zaman: 837,785
