Ana içeriğe geç
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Soru Tümünü görüntüle
What upgrades are possible in this system?
Is it possible to adapt a MacBook Pro mid 2012 logic board (and other parts maybe) in this system?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sadly Apple's laptops don't have removable chips (thin laptops tend not to). Here's a view of the logic board:
The larger green chip is the CPU
There are two models in the Mid 2012 (2.5 & 2.9 GHz) the only choice here is a logic board swap out if you have the lower end model within the series you could get the upper end model but it’s not enough benefit unless your logic board had died. Likewise, there is no newer logic board possible either as Apple completely redesigned the MacBook Pro in 2012 with the retina series. So upgrading is not possible to anything newer.
But! You do have some areas which you can gain performance!
To start with, I would bump the RAM up to 16 GB.
The next area would be the storage. Here you could swap out the HD with something bigger, I would go with a SSHD from Seagate as the best option here. The other option here is to take the big leap to a SSD. Just make sure you get one that has enough space. After you load it up you want to have 1/3 to 1/4 of the drive free more for the smaller SSD's.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
En Yararlı Yanıt
You can replace the Hard Drive in the MacBook with an SSD to speed up your system in terms of time of booting MacOS up and reduce time taken for loading applications:
MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement
You could use a dual-drive configuration to use a SSD as main drive and Hard Drive as secondary drive combo to have both lots of storage space and a fast loading MacBook:
Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive
You can upgrade the ram capacity of this MacBook to 16GB which iFixit sells 2x 8GB sticks here:
MacBook Pro 13" Unibody Mid 2012 RAM Replacement
MacBook Pro 13" Unibody Mid 2012 RAM Görseli
Kılavuz
Zorluk:
Kolay
15 - 30 minutes
MacBook Pro 13" Unibody Mid 2012 Hard Drive Görseli
Kılavuz
Zorluk:
Orta
30 - 45 minutes
MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive Görseli
Kılavuz
Zorluk:
Orta
10 - 30 minutes
Puan 3
Yorum Ekle
Yanıtını ekle
dany34 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 97
