Giriş
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to remove or replace a worn battery in the Google Pixel 4 XL. If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Note: Some photos in this guide show the SIM card tray ejected from the phone. You don’t need to eject the SIM card tray for this procedure.
Caution: Google warns that disassembly of the front laser assembly could result in hazardous exposure to invisible infrared laser emissions. Read their safety warnings here.
Neye ihtiyacın var
Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
Insert the point of an opening pick into the gap.
Slide the opening pick across the bottom towards the left corner to slice the adhesive.
With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
Prepare an iOpener and apply it on the left edge of the phone for one minute.
Prepare an iOpener and apply it on the right edge of the phone for one minute.
Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
Do not try to pull the panel all the way off yet, as it is still connected to the phone.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Remove the four T3 Torx screws securing the battery connector shield:
One 1.8 mm screw
One 4.1 mm screw
One 4.4 mm shouldered screw
One 4.0 mm shouldered screw
Use a T3 Torx driver to remove the two 4.1 mm screws securing the back panel connector cover.
Bu adımda kullanılan alet:Tweezers$4.99
Use blunt tweezers to lift up the battery adhesive pull tabs so you can more easily grip them with your fingers.
Pull on the black pull tab at a shallow angle with steady force. When the adhesive grows long, roll it around a spudger and continue pulling.
Continue firmly pulling up on the adhesive strip with constant force, spinning the spudger every so often to keep the exposed section of the pull tab as short as possible.
Continue this process for each of the three pull tabs, until all are either out or have snapped in half.
If the battery tabs snapped during removal, insert an opening pick on the upper right edge of the battery, slicing the adhesive underneath.
Bu adımda kullanılan alet:Tesa 61395 Tape$5.99
Lift the battery up, away from the phone to remove it.
Remove any remaining adhesive from the battery well.
If you're using stretch release adhesive, apply them onto the battery. Otherwise, apply some double-sided tape, or pre-cut adhesive strips in the phone's battery well, being careful not to cover the charge port flex cable. Peel away any tape liners to expose the adhesive.
Temporarily re-connect the battery's connector to the motherboard socket. This ensures that the battery is properly positioned.
Lay the battery in place and press firmly.
Disconnect the battery connector from its motherboard socket and resume re-assembly.
For optimal performance, calibrate your newly installed battery after completing this guide.
96 farklı kişi bu kılavuzu tamamladı.
40Kılavuz Yorumları
Worked great, was tough pulling up the battery but other than that went super smoothly. thanks!!
Really comprehensive, helpful and well-written guide. I prefer to learn to fix things on my own, so this was immensely helpful and just what I needed. Thank you so much!
the adhesive pull tabs? there was no way to get them out as the hardware prevents you from pulling at the right angle. i went with softening the glue with a couple drops of alcohol and prying the battery up enough to get a guitar pick in and cut the rest.
Just finished changing the battery to my Pixel 4XL. Battery was slightly bloated (about 1mm) but still running great, at 104% after one year and a half. However, it suddenly stopped charging wirelessly, even from the original Pixel charger.
The kit was great, everything happened according to the instructions. Carefully cleaning the old adhesive took most of the time. I used lint-free wipes and a small syringe filled with Isopropyl alcohol 99.9% to drop the liquid over the adhesive strips in small sections, with the phone positioned vertically, so the alcohol didn’t get inside. Same for the rear cover [Regular rubbing alcohol does not work at all for this purpose] The alcohol really helped removing the old stretch release strips really fast. The connector of the new battery was slightly out of alignment, so I had to plug it first, with the battery leaning at a small angle, then seat the battery on the glue strips. Thank you, that was fun! :)
Great tutorial. I followed all the steps. And, even with the new battery, it's still stuck in 50%.
My phone took a dive in the pool. I love in Brazil, do I don't have Google technical support available, and due to battery mailing restrictions it took 6 months until I managed to receive a spare one.
Do you guys know what could I do?
Thanks
