Ana içeriğe geç
Logitech MX Ergo Battery Replacement
Adriana Zwink
Adriana Zwink ve 2 diğer katkıda bulunanlar
En son November 29, 2023 tarihinde güncellendi
20 - 30 dakika
Orta
Öne Çıkan Kılavuzlar
Use this guide to replace the battery in a Logitech MX Ergo.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Logitech MX Ergo Battery Replacement, Power off the mouse: adım 1, 3 resimden 1. Logitech MX Ergo Battery Replacement, Power off the mouse: adım 1, 3 resimden 2. Logitech MX Ergo Battery Replacement, Power off the mouse: adım 1, 3 resimden 3.
    • Before you begin, flip the mouse's power switch into the OFF position.
  2. Logitech MX Ergo Battery Replacement, Remove the cover: adım 2, 2 resimden 1. Logitech MX Ergo Battery Replacement, Remove the cover: adım 2, 2 resimden 2.
    • Remove the magnetic cover by pulling it away from the bottom mouse half.
  3. Logitech MX Ergo Battery Replacement, Remove the case screws: adım 3, 1 resimden 1.
    • Use a Torx T6 screwdriver to remove the six 5.7 mm-long screws securing the two halves of the mouse together.
    My mx ergo had T5 screws not T6
    Jacob Beaman - Yanıt
  4. Logitech MX Ergo Battery Replacement, Remove the trackball: adım 4, 3 resimden 1. Logitech MX Ergo Battery Replacement, Remove the trackball: adım 4, 3 resimden 2. Logitech MX Ergo Battery Replacement, Remove the trackball: adım 4, 3 resimden 3.
    • Insert a spudger into the hole on the bottom of the mouse, located under the trackball.
    • Use the spudger to push the trackball out of its recess.
    • Remove the trackball.
  5. Logitech MX Ergo Battery Replacement, Unhinge the plastic clips: adım 5, 3 resimden 1. Logitech MX Ergo Battery Replacement, Unhinge the plastic clips: adım 5, 3 resimden 2. Logitech MX Ergo Battery Replacement, Unhinge the plastic clips: adım 5, 3 resimden 3.
    • There are clips all around the perimeter of the mouse case holding the two halves together.
    • Insert an opening pick into the gap on the right side of the mouse.
    • Rotate the opening pick about 30 degrees to unhinge the plastic clip.
  6. Logitech MX Ergo Battery Replacement: adım 6, 2 resimden 1. Logitech MX Ergo Battery Replacement: adım 6, 2 resimden 2.
    • Slide the opening pick to the lower right side of the mouse.
  7. Logitech MX Ergo Battery Replacement: adım 7, 2 resimden 1. Logitech MX Ergo Battery Replacement: adım 7, 2 resimden 2.
    • Slide the opening pick to the bottom side of the mouse.
    • Rotate the opening pick about 30 degrees to unhinge the plastic clip on the bottom end of the mouse.
  8. Logitech MX Ergo Battery Replacement: adım 8, 2 resimden 1. Logitech MX Ergo Battery Replacement: adım 8, 2 resimden 2.
    • Slide the opening pick to the center of the left side next to the recess of the trackball.
    • Rotate the opening pick to unhinge the remaining plastic clip.
  9. Logitech MX Ergo Battery Replacement, Create access: adım 9, 3 resimden 1. Logitech MX Ergo Battery Replacement, Create access: adım 9, 3 resimden 2. Logitech MX Ergo Battery Replacement, Create access: adım 9, 3 resimden 3.
    • Don't completely separate the two halves yet—they're still tethered together by a delicate cable.
    • For better access, place the top half of the mouse to the left of the lower half of the mouse.
  10. Logitech MX Ergo Battery Replacement, Disconnect the interconnect cable: adım 10, 2 resimden 1. Logitech MX Ergo Battery Replacement, Disconnect the interconnect cable: adım 10, 2 resimden 2.
    • Use the pointed end of a spudger to gently lift the left side of the black sliding lock on the interconnect cable socket until it stops.
  11. Logitech MX Ergo Battery Replacement: adım 11, 2 resimden 1. Logitech MX Ergo Battery Replacement: adım 11, 2 resimden 2.
    • Use the pointed end of a spudger to gently lift the right side of the black sliding lock on the interconnect cable socket until it stops and the cable is no longer locked in.
  12. Logitech MX Ergo Battery Replacement, Remove the top half of the mouse: adım 12, 3 resimden 1. Logitech MX Ergo Battery Replacement, Remove the top half of the mouse: adım 12, 3 resimden 2. Logitech MX Ergo Battery Replacement, Remove the top half of the mouse: adım 12, 3 resimden 3.
    • Remove the top half of the mouse.
  13. Logitech MX Ergo Battery Replacement, Disconnect the battery: adım 13, 2 resimden 1. Logitech MX Ergo Battery Replacement, Disconnect the battery: adım 13, 2 resimden 2.
    • Use the pointed end of a spudger to push the battery connector up and out of its socket.
  14. Logitech MX Ergo Battery Replacement, Pry out the battery: adım 14, 3 resimden 1. Logitech MX Ergo Battery Replacement, Pry out the battery: adım 14, 3 resimden 2. Logitech MX Ergo Battery Replacement, Pry out the battery: adım 14, 3 resimden 3.
    • Insert the long edge of an opening pick between the battery and its housing at the side opposite the battery cable.
    • Push the opening pick under the battery and lift up to pry the battery off of its housing.
    • Make sure you push underneath the battery and not into it. Don't bend or deform the battery.
  15. Logitech MX Ergo Battery Replacement, Lift out the battery: adım 15, 2 resimden 1. Logitech MX Ergo Battery Replacement, Lift out the battery: adım 15, 2 resimden 2.
    • Use you fingers to lift the battery out of its housing.
  16. Logitech MX Ergo Battery Replacement, Remove the battery: adım 16, 2 resimden 1. Logitech MX Ergo Battery Replacement, Remove the battery: adım 16, 2 resimden 2.
    • Use your fingers to carefully pull the cable out of the socket.
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • It is likely you can reuse the old adhesive with the new battery. If you wish to replace the adhesive instead, remove the old adhesive and wipe away any adhesive residue with a lint-free cloth and high-concentration isopropyl alcohol.
    • Follow this guide to install new precut adhesive.
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
15 farklı kişi bu kılavuzu tamamladı.
Adriana Zwink
56.909 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.807 adet Kılavuz yazıldı
7Kılavuz Yorumları
This guide is fantastic! It was super easy to fix! Thanks!
Corey Trueman - Yanıt
Thank you for this !! Visited this site before for other tutorials you guys are great. This was easy to follow worked good for me.
DJSan - Yanıt
Its a very thorough explinations and guide except the most important point.
Where to buy the new replacement battery.
Jacob Bornman - Yanıt
Those are very well-done instructions. The new battery installation went very well. Thanks for the help.
Lyle Ellingson - Yanıt
hi where did you buy the battery?
Yanna -
If you do a google search on Logitech 533-00121 battery you will find suppliers
David Gaguine - Yanıt
An easier way to separate the two halves of the case: After removing the ball in Step 4 of the above Guide, (1) hold the case in your right hand, with the power switch forward and facing left, the concave ball recess facing up and to your right, and the edge of your right thumb firmly grasping the right edge of the rim around the ball recess (the rim is on the upper half of the case and protrudes a bit from the ball recess, so you can get a tight grip on it; the ball recess is on the lower half and is separate from the rim); (2) insert a sturdy rod into the hole that you used to remove the ball (e.g., the shaft of a Phillips-head screwdriver); (3) while holding the rim with your thumb as described in (1), gently but firmly twist the sturdy rod downward to pry the two halves of the case apart; (4) as described in Step 9 of the Guide, the two halves are connected by a cable, so as they separate be careful to keep them close to each other to prevent damage ; and (5) continue with Steps 9 through 16 of the Guide.
ebiznez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 37
Son 30 gün: 300
Her zaman: 15,490
