Giriş
Use this guide to replace the battery in your MacBook Air 2022 (M2).
This repair requires replacement adhesive.
Neye ihtiyacın var
Power off your MacBook Air and unplug all cables.
Close the display and flip the laptop upside down. Keep the lid closed until you've physically disconnected the battery.
Use a P5 Pentalobe driver to remove the four 6.4 mm screws securing the lower case:
Two screws with a short threaded portion near the hinges
Two screws with a long threaded portion near the front of the MacBook
Apply a suction handle to the center of the lower case's front edge.
Pull up on the suction handle with strong, steady force to create a small gap between the lower case and the frame.
Insert an opening pick into the gap.
Slide the pick to the bottom right corner to release the first clip.
Slide the pick around the corner and up the right edge to release the next two clips.
Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
Remove the lower case.
Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
Once the lower case is flush with the frame, press down firmly along the perimeter to engage the four snapping clips.
Use a T3 Torx driver to remove the two 1.5 mm screws securing the battery connector cover.
Use an opening pick to pry up and disconnect the battery connector.
Use a T3 Torx driver to remove the two 1.5 mm screws securing the trackpad cable cover.
Use a spudger or your fingers to move the trackpad cable cover out of the way so you can access the press connector underneath.
Use the pointed end of a spudger to pry up and disconnect the trackpad cable press connector.
Peel up and remove the foam pad from the lower display cable cover to reveal a hidden screw.
Use a T3 Torx driver to remove the fourteen 1.5 mm screws securing the various cable covers.
Use the pointed end of a spudger to pry up and disconnect both display cable press connectors.
Remove the nine screws securing the logic board:
Three 3.8 mm T5 Torx screws
One 3.6 mm T5 Torx screw
Two 3.4 mm T5 Torx screws
One 3.1 mm T5 Torx screw
Two 2.7 mm T3 Torx screws
Grip the right side of the logic board and slide it towards the trackpad until it clears the overhangs near the speakers.
Remove the logic board.
Right speaker cable
Trackpad cable
Display cables and microphone array cable
Antenna cables
Battery cable
Left speaker cable
USB-C and MagSafe cables
Reposition the trackpad cable over the bottom edge of the MacBook so it's out of the way of the battery.
Use a T5 Torx driver to remove the two 4.5 mm screws securing the upper edges of the battery tray.
Use a T3 Torx driver to remove the four screws securing the center of the battery tray.
Four on the bottom left corner
Four on the bottom right corner
Use a pair of tweezers to peel up the black pull tab on one of the stretch-release adhesive strips until you can grip it with your fingers.
Pull the strip out from under the battery at a shallow angle. Go very slow and use steady force, giving the strip plenty of time to stretch and unstick itself from under the battery tray.
Pull the adhesive strip until it’s completely freed from underneath the battery tray.
Repeat for the seven remaining adhesive strips.
Apply a few drops of high concentration (greater than 90%) isopropyl alcohol between the edge of the frame and the battery where any adhesive strips remain.
Wait one minute for the isopropyl alcohol to soften the adhesive.
Insert a plastic card underneath the battery's metal tray.
Push the plastic card underneath the metal tray and slide it back and forth to slice the remaining adhesive. You may need to lift the battery cell to reach the adhesive.
Remove the battery assembly.
Remove any remaining adhesive strips with tweezers or your fingers.
Clean up the adhesive residue with a few drops of isopropyl alcohol and a lint-free or microfiber cloth.
Before removing any adhesive liners, place the battery in its recess and make sure it fits.
If your replacement battery comes with adhesive, remove the plastic liners and firmly press each cell into place.
If your replacement battery doesn't come with adhesive, secure it with stretch-release adhesive.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
For optimal performance, calibrate your newly installed battery after completing this guide.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
6 farklı kişi bu kılavuzu tamamladı.
8 Yorum
Is is really necessary to remove the motherboard?
Looking at all the photos, it seems to me like the battery should be clear for removal after disconnecting it and the trackpad cable, leaving the motherboard (and all of its other connectors) in-place. So what am I missing here?
Hi! The logic board is removed first because the battery cable runs underneath it and is adhered to the frame.
It is not necessary to remove the motherboard. The battery cable runs underneath the logicboard, but is not adhere to it. You can slide it out once the battery is loose.
just1ed -
I lost the screws to my battery cover. Is there any way to replace them? Should i tape the cover on for now? Please help!
Can someone verify this and see if it does really need to e removed?
"It is not necessary to remove the motherboard. The battery cable runs underneath the logicboard, but is not adhere to it. You can slide it out once the battery is loose."
