Giriş
Use this guide to replace a worn-out battery. If your battery is swollen, take appropriate precautions.
Neye ihtiyacın var
Videoya Genel Bakış
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Prying the battery connector off does not take much force. I did exactly what the guide suggested (walked it off back and forth) with the spudger without any problems. Just be very gentle, much like with anything inside laptops, they are very fragile and need to be worked with carefully. A+ instructions, battery replacement was a success.
Be patient on disconnecting this one. It worked for me step by step, little by little.
I used the nails of thumb and pointer finger simultaneously - worked pretty fine
I whittled down ends of two wooden strips to use, along with my fingernails to start with. I used halves of a wooden clothespin, but popsicle sticks should work too.
Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
I put some tape between the connector and socket while working on the drive.
That's a good tip
Anrothan -
Great tip, I did that too
One other note: The screw heads fit flush with the curvature of the case -- which means that they aren't exactly horizontal. In other words, they aren't perpendicular to the table that the computer is resting on. Don't try to force them straight in vertically, because you'll risk cross-threading them. (nearly ruined one screw hole myself!)
On my MacBook Pro, the connector seems to be an integral part of the battery.
I suspect it’s just like the special screwdriver required for seatbelts on cars – to discourage regular consumers from attempting repairs. Of course, this only encourages consumers to use the wrong tool to attempt to repairs
Dissambling my MacBookPro Premium Mid 2012 (i5-3210M 2.5Ghz) was easily, Careful with the screws, use screwdriver fitting exactly with the screws, you damage them very fast. Work very exactly, relaxed with time, consentration, good Tools and with feelings in your hands. Disconnect the Akku was easy if you take care, remove it to be safe, Two screws more, more space to work & haven`t to think about damaging someting. Apple use diffrent screws, you should have many difffrent scewdrivers. It is also good to clean everything inside, With time everything gets very dusty & dirty, don`t forget the sides and little fittings at the case. Use a pinsel, alcohol, soft peace stuff, it will look like new. If you have knowledge & experience, you can paint it in any colour or airbrushing for individualizing. You can also just polish it with a soft Politure (Sonax car Polish No1, NOT with wax or take an other light Politure you familiar & can do the job, A Laptop should serviced once a year, keeping it good working over years
First thing i do is open & cleanig everything inside,specially the cooling & fan, renew the thermal paste with an high quality product. Install the Nain System, clean up Bloatware and other unnecessary things, install standard software for daily use, additional change system components against better one (Edge to Firefox, Windows Media Player to VLC , an Office Suite and configuring everything for Data Protection, Privacy- & Indentety Protection, install Drivers from the component Manufactur (incedible effect, disable limitations, more functions, work better & faster, increasing performance, additional change the WiFi & Bluetooth Card to a better one a UMTS WWAN to an LTE Card, increase RAM with two Dual-Channel working SODIMMs, Use M2 or 2,5" SSD if no M2 Slot aviable) as System- and Software iDrive, a FAT32 formatted 32GB Partition to be safe of metaviruses comes with harmless downloads, and a big 2,5 HDD to store the user data. What does you guys think about this? Old Computer become a new life,
I livein Austria, near Vienna, if someone needs help or anything else, i would be glad to help. I always searching old or broken devices to bring them to new live. I also searching for spare parts, specilly a Bottom & Side Case and a 256GB or higher NGFF Storage Card for a Sony Vaio Tab 11 SVT1144HE (2014), some 14,1" Displays for a HP Probook 440G5 (2016), Elitebook MT 43 Mobile Thin Client, (2011), Dell Vostro 3460 (2012) Lenovo Thinkpad T440s (2014), and a Logic Board for an Lenovo Ideapad 330-15ARR (2017, damaged by Water i think) and a Logic Bord for an Alienware 17R4 with i7-6870HX & Nvidia 1080 (2018, CPU dead, maybe there is a repair Guide or workaround to bring it back to Life). I need always 8GB or 16GB DDR3 and DDR4 RAM Storage (perfectly two ident one for Dual-Channel use for Laptops, M2 SATA 6GB/s and NVMe PCIe SSDs 500GB or more and 2,5"SSD or HDD with 1TB or more and 3,5" HDD with 4GB or above. If you have some of this or other useful parts and doesn`t need them, please make me an offer, maybe
2
an change something you need. This is not a Business what i do, it`s more a Hobby with challenging new Excercices.. Thats the best Point. Plase forgive me as a Newbie this very long Post in the wrong Section, but if you are start writing you cannot stop.... But now i have to come to an end and would be happy if someone wants to get in contact. My E-Mail is: udontknowme@gmx.at (the adress name is just a notice against Big Data and for Privacy Protection!
Remove the following two screws:
One 5.6 mm Tri-point screw
One 13 mm Tri-point screw
Something isn’t right here. On my MacBook Pro, the connector is an integral part of the battery.
Verify that this is the correct guide for your specific model—if not, we’ve got guides for all the other models, too.
And which Apple “Genius” decided that a tri-wing screw would be just perfect for the job of holding the batter in place? Not smart for a genius.
These tri-point screws are Y0 size. You’re welcome :)
Thank you rossi
James -
The 13 mm Tri-point screw was very tricky to screw back into place. I had to make several attempts, unscrewing and realigning the battery to get it right. The rest of this fix was very easy, but this one screw was the hardest part.
As per Rossi Macri’s comment, I also observed for step 5 that both screws are Tri-point Y0 for my MacBook Pro 13 inch mid-2012 model.
For the Tri point 3 wings or however you call them. the proper Screwdriver is really to rcommend; I manageds it with a normal flat but very small screw- driver but it slightly "damages" the screws;(a four winged screwdriver does not grip enough);
So i recommend to buy the whole package with instruments; (i had all other instruments accept the Tripoint)
the screws themselves seem to be fragile
For putting them in again its better to start with longer one but dont fasten it tight keepit loose until the short one grips.. the tighten them but not too fast.
re Rossi Macri's comment posted nearly four years ago: when, if ever, is iFixit going to act in response? Just sloppy on their part, and infernally annoying to customers.
PS Otherwise their work is really
helpful. So small a thing.
Carefully peel the battery warning label off the upper case between the battery and the optical drive.
Probably to help you remove it? Not sure, but I used it along with the clear tab to pull the battery out. Worked pretty good.
One of the main thing is that it can weaken an already old battery which is never a good thing, especially if people try to remove the label using a pointy device and piercing the battery (can explode !). Also it is not useful to remove it and it allow tracking of old parts (recycle, dispose, …).
Cajuteq -
Use the attached plastic pull tab to remove the battery from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
My replacement battery came with a clear protective film that should be removed before installation. Be sure not to overlook the film on the bottom of the battery as it covers only a portion of that side and might be easy to overlook.
Do not over-tighten the bolts holding the battery in place. One of the tabs on the original battery was broken, presumably due to over-tightening.
The calibration suggestion given in this guide differs a bit from what iFIXIT sent with the battery. What came with the battery went like this…
For optimal performance, calibrate your newly installed battery. Drain battery below 10%, then charge it uninterrupted to 100%.
I recommend disregarding those instructions and following the steps in this article:
1. Charge it to 100%, and keep charging it for at least two more hours.
2. Unplug your laptop and use it normally to drain the battery.
3. Save your work when you see the low battery warning.
4. Keep your laptop on until it goes to sleep due to low battery.
5. Wait at least five hours, then charge your laptop uninterrupted to 100%.
It’s not dangerous (assuming you have put the back cover back on), though the computer will run slower. The charging assembly cannot supply as much amperage as the battery, so the processor will be throttled.
Oops, i missed step 5. Wait at least five hours, then charge your laptop uninterrupted to 100%. I charged it to 100% right after it went to sleep. It did seem slow to charge after that, so I reset the SMC. It now seems to be charging normally. I hope I did not damage by skipping that step.
@samomio I saw your reply about using the MacBook without a battery and how it will throttle the CPU since the charger will not supply the necessary power. What about a more powerful charger? Like there's an 85 watts charger that has the Magsafe 1 connector and all. Would that charger allow to use the device without it throttling?
782 farklı kişi bu kılavuzu tamamladı.
51Kılavuz Yorumları
I thought these batteries couldn't be replaced.
These batteries are built to the same spec as OEM (Apple)
They are just not "user friendly" to replace like most devices are, the price we pay for pretty devices.
This guide is excellent and now I know I need 1 more tool before I do this myself. I need that tri-wing screwdriver.
Clear, well written instructions, thank you! (But yes, a line about take off shoes and socks and ground yourself is helpful. )
Warning: if you have not used this MBP for a while, check how it does look like.
I kept mine for backwards compatibility (such as Rosetta and old FireWire). I cleaned up my drawer today.
See how it looked like today: http://666kb.com/i/do60coz0kn5z5txd5.jpg
The battery was most severely blown up, crashing the body shell. I’m glad it did not burn the house to ashes.
Wow! On your Picture we see the original battery from Apple! Yes?
Mario -
WOW! That's one spicy beef pillow
I just replaced my battery, and had no issues. Great instruction manual, and easy to do.
It happened to me too! i’ll try to calibrate the battery as apple says https://support.apple.com/es-es/HT1490
I replaced the battery, and it was very easy. The problem lies in fact that my laptop will only run for about 20 minutes then shuts down. I put the old battery back in and it is working fine. Is this a defective battery?
I have the same problem, posted above. Searched the web for possible solutions without success. Let me know if you’ve found one.
Same here. I am in the process of letting it die down from the first full charge and it does a hard shutdown every 20 minutes.
Looks like I might be having a similar issue. I’ve just received and installed a new battery from iFixit and the MacBook is shutting down abruptly anywhere from 5-30 minutes after switching to battery power. I’ve tried resetting PRAM/SMC/removing, checking connections and remove/replace the battery several times. This typically results in orange magsafe light, battery is detected correctly and it’s charging. Then after some time the magsafe the light goes green, battery is no longer charging and cononut battery shows NaN on battery capacitor indicator. I reinstalled the old battery and everything works fine - of course I have the original problem of diminished capacity which is why I replaced it. If several people are having similar issues I wonder if it’s a bad batch of batteries?
Colm -
Just installed the 2nd new iFixit battery. Exactly the same issue, abrupt shut down after approx. 20 mins. (Formatting the battery is a painful process...) Might be a faulty batch of batteries. From the earlier positive comments I guess this problem has been experienced recently, so, maybe Apple did something in Mojave?
Replaced the battery with this guide. Seemed to work at first, but the macbook sometimes suddenly switches off or doesn‘t start anymore. Resetting SMC/PRAM works only for a short time, bevore the Macbook does again what it wants. Any suggestions?
No suggestions. Seemingly many of us who made battery replacement experience the same. I’ve tried already two iFixit batteries. Same issues. Abrupt shutdown while on battery, battery reported N/A by the system, not charging while at e.g. 60%, etc. SMC solves the problems for 20-30 minutes only.
Hi folks of iFixit. I really like to fix things by myself, but it should work afterwards. So I immediately need an answer to the questions above. I have the same problems with a sudden shutdown after a short while even in process . That is really annoying in most of the times. The replacement is very easy, even with the good instruction, so pease give a statement.
I took contact to iFixit EU Support <eustore@ifixit.com>. I got a quick answer and after a short while I got another batterie. This batterie runs good for now, so I hope everything is fine now. So try to contact the support.
Very easy process. Thanks for the tips about the screw lining up with the bevels and noting that there are different screws that need to be returned in the same location they came from on the back!
Thanks for the guide, Daedalus Tested, Tek Approved!
The only thing you should mention is the size of the screw head, that would be helpful.
nach dem tausch des Akkus schaltet sich der Mac immer wieder plötzlich aus. Also er versetzt sich in den Ruhezustand. Jemand eine Idee wie man das beheben könnte?
Apparently, my local apple store is not able to replace the battery in my MBP from mid 2012. I asked them if it was possible to replace it by myself. They replied that the battery is attached to the keyboard, and that it therefore is not possible to replace it (since Apple do no longer provide parts for this model). Does anyone know anything about this? Should I buy the battery from iFixit and give it a try?
After replacing the battery and the Macbook Pro still doesn’t turn on, can I plug in the Macbook Pro to charge the battery?
Try and see if it charges. If it won’t, the issue is somewhere else, and i have an idea of what it could be.
I need A1322 or A1278 for Macbook Pro 13” 2012 mid?
Depends on your own model
I successfully installed the battery and my trackpad and keyboard were working fine for a minute and now the trackpad and keyboard doesnt respond.
please help!
Thank you for the tutorial. It helped me to take the swollen battery of my MacBook Pro out. Am now looking for a reliable new battery, would be happy to buy the iFixit battery listed on this page. However, my MacBook Pro (13” Unibody Mid 2012) was purchased in Asia (India) and works on a voltage of 220–240V. Will the iFixit battery work with that voltage? Would appreciate any response. Thanks in advance.
Yes, it will. MacBook Pros are designed to work on all electrical standards around the world, your charger will convert the AC power from the wall into the proper DC amperage and voltage for the computer.
Hi!
my battery came completly empty and once installed there are no signs of electricity.
it just doesnt work, it doesnt charge, once the computer turned on, it says the computer is running with the power adaptor.
i tries pluging in the old one and everything is fine. I charges the new one for two hours but it just doesnt work.
i bought the battery replacement for the 13 inch macbook pro 2012
Hi Nicolas,
If the battery is properly connected to the logic board, then you most likely received a bad battery. If you purchased it from iFixit, I would reach out to customer service at 1 (866) 613-4948 and they will send you a new one.
I replaced the battery as the instructions said. When the time to discharge came in, I just disconnected the power adaptor and the computer shutdown immediately.
It seems the battery is not able to power the device, although it got charge up to 100% . Does anyone encounter this problem? Is this a battery problem or maybe something extra I need to do?
of course I'll replace it as my 2012 Mac is capable of running Ventura. old battery is removed already, waiting for the mailman to bring the new battery later today. really nice guide, easy to follow, thanksies!! :)
Where did you order the battery replacement from?
The battery replacement was straightforward and easy. The only problem was in the "Long" battery hold down screw would not catch in reassembly. The screw threads had to be cleaned out of plastic. I had to use a watchmakers escapement file to file a taper to the end of the screw to allow it to feed into the threads and "catch." So far all is good.
Hello to all with battery charging problems on modern electronics, the charging systems are designed to not explode due to overcharging. They gauge the charge everytime they are connected, there is a chip on the battery and a chip on the item (does not matter what it is,cordless drill, computer, phone etc. etc.) it remembers the history of both, it will not charge the same battery ever again if a dangerous fault is detected . Best suggestion is common to most in the know, plug in and wait till 100%, disconnect and cool, run till flat, wait till some residual charge returns (or not), recharge to 100%, run till flat etc a number of times. This can work on brand new or most batteries as it is recalibrating what the computer thinks is the charge. Remember a computer is not as smart as a chicken, it can only do what it is told to do.
Hello,
Merci pour ce tuto <3
Je viens de faire mon changement de batterie avec celle-ci : https://www.amazon.fr/dp/B09HSHMBP1
Tout c'est bien passé, il faut a minima Essential Electronics Toolkit :)
Merci pour ton commentaire, je suis content pour toi ! La batterie d'Amazon est bien sûr un peu moins chère, mais je ne suis pas sûr qu'ils appliquent les mêmes normes de qualité que nous. Mais si elle fonctionne pour toi, c'est très bien !
How much weight can I save by removing the optical drive?
gunes314 - Yanıt
You can save a lot of weight if lets say your installing a solid state drive or putting in a second hard drive but if you know that you use the CD/DVD disc drive a lot then you might just want to leave the drive alone.
Marshall WahlstromHelgren -
Tip: Use one of those weekday pill holders to have a cheep way to store screws you remove and each day of the week can be for different sizes or parts. It has been handy to have (much less expensive than the magnetic mat.
Robert Wacker - Yanıt
Hello, where can I buy the screws I need in case I lose one of them?
taylornya - Yanıt
iFixit sells a kit: MacBook Pro Unibody Lower Case Screw Set
Darrell Johnson -
I have one stripped screw... How opening without drill it?! Any suggestions please?
rodrigosady - Yanıt
I also stripped a couple screws. I wasn’t able to open it up without drilling. After drilling the heads and removing the cover it was easy to hacksaw the tip and unscrew with a standard driver.
Michael Wilkens -
We have a guide for that!
How to Remove a Stripped Screw
Sam Omiotek -
My top tip - make sure you buy good quality Phillips screwdrivers and a magnetic holder. Cheap screwdrivers won’t get the screws undone safely. Without a magnetic holder you have no chance of getting the tiny crews in and out safely.
jeremyyoung - Yanıt
A good Phillips 00 is your friend here. Also, when reinserting the screws, gently start anticlockwise and you wil feel a click at the start of the thread. This tells you you’re in the right place and less likely to cross-thread through force in the wrong place.
Iain Boyd - Yanıt
I feel like these are 000 screws. Amazon sales describe them as such and my 000 screwdriver fits better
cam2000deluxe -
Before ordering a new Trackpad remove the existing battery and try clicking the Trackpad. If it clicks OK with the battery out the source of problem is likely a swollen battery, which should to be replaced even if it still works to some degree. From the side of the battery you will likely see the soft part of the battery bulging beyond the hard case.
Patrick Langvardt - Yanıt
That’s absolutely correct as I can testify. With the battery removed I also adjusted the T6 set screw that adjusts the sensitivity of the trackpad click, evidently someone had cranked mine down tighter than the factory setting.
Gary Register -
Le quatrième paragraphe dans les instructions en français n’est pas correct : ce ne sont pas les 2 petites vis, mais les 7 petites vis qui sont inclinées. Et les 3 grandes sont bien verticales.
Degeorges - Yanıt
Bonjour ! Merci de votre observation. J’ai corrigé la traduction. iFixit étant un wiki, n’hésitez pas à modifiez si vous remarquez une erreur :) Encore merci de votre attention et à bientôt !
Claire Miesch -
Tip: if you have a magnetic screw mat or similar, lay the macbook over the mat to make sure it catches any screws that may decide to fall of and hide under your table
Moritz - Yanıt
Funny, it's not her hands that are doing the close ups. :)
Cinemated Man - Yanıt
What's the difference between the shouldered and non shouldered screws? They look exactly the same to me.
MLNLRD - Yanıt
the shouldered screws have a space where the threading stops and the head of the screw begins. i don't think the newer screw kits include them. i've lost most of my shouldered screws but the non shouldered screws will work, too. you just need to adjust everything carefully because a shouldered screw will stick out of the case instead of fitting flush if it's in a non-shouldered hole.
postjosh -
There are bateries labeled as "A1322" but marked as "High Performance" and rated 76.56WH/11.6V. Also sold as replacement for the MacBook Pro 13" mid 2012 Model A1278. Does the different rating, in particular the voltage, is compatible? Does it really provides some extra "performance" in any actual way?
Thanks
locutus - Yanıt
does anyone know where to buy the shouldered 3.5mm screws? it looks like the current kit has substituted the non-shouldered version of the screw.
postjosh - Yanıt
here's a comparison picture:
shouldered vs non-shouldered
postjosh -
My screws were in a slightly different configuration -- my macbook has never been opened before so I'm not sure why my screws were different from the diagram here. Anyways, the three long screws were in the same position, then, clockwise from the right-middle screw, with s = shouldered and r = regular, I had: s, s, r, s, r, r, s.
Spencer Pennington - Yanıt
