Ana içeriğe geç
Nintendo Switch Digitizer Replacement
Neye ihtiyacın var
  1. Nintendo Switch Digitizer Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 1. Nintendo Switch Digitizer Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 2. Nintendo Switch Digitizer Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 3.
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo Switch Digitizer Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 1. Nintendo Switch Digitizer Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 2. Nintendo Switch Digitizer Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 3.
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo Switch Digitizer Replacement, Remove the back-side screws: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
    • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
    • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo Switch Digitizer Replacement, Remove the top and bottom screws: adım 4, 2 resimden 1. Nintendo Switch Digitizer Replacement, Remove the top and bottom screws: adım 4, 2 resimden 2.
    • Use a JIS 00 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
    • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo Switch Digitizer Replacement, Remove the center side screws: adım 5, 2 resimden 1. Nintendo Switch Digitizer Replacement, Remove the center side screws: adım 5, 2 resimden 2.
    • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
    FixBot'a Sor
    Yorum Ekle
  6. Nintendo Switch Digitizer Replacement: adım 6, 2 resimden 1. Nintendo Switch Digitizer Replacement: adım 6, 2 resimden 2.
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
    FixBot'a Sor
    Yorum Ekle
  7. Nintendo Switch Digitizer Replacement, Remove the kickstand well screw: adım 7, 1 resimden 1.
    • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
    FixBot'a Sor
    Yorum Ekle
  8. Nintendo Switch Digitizer Replacement, Remove the rear panel: adım 8, 3 resimden 1. Nintendo Switch Digitizer Replacement, Remove the rear panel: adım 8, 3 resimden 2. Nintendo Switch Digitizer Replacement, Remove the rear panel: adım 8, 3 resimden 3.
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel straight up from the bottom of the device and remove it.
    • Don't tilt it upwards while opening or else you risk breaking the plastic tabs on the top edge of the panel.
    FixBot'a Sor
    Yorum Ekle
  9. Nintendo Switch Digitizer Replacement, Remove the microSD card reader: adım 9, 1 resimden 1.
    • Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
    FixBot'a Sor
    Yorum Ekle
  10. Nintendo Switch Digitizer Replacement: adım 10, 2 resimden 1. Nintendo Switch Digitizer Replacement: adım 10, 2 resimden 2.
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, remove the foam pad before connecting the press connector to the motherboard. Set the foam pad back in place after you verify it's connected.
    FixBot'a Sor
    Yorum Ekle
  11. Nintendo Switch Digitizer Replacement, Remove the shield plate: adım 11, 1 resimden 1.
    • Use a JIS 00 driver to remove the six 3 mm screws securing the shield plate to the device.
    FixBot'a Sor
    Yorum Ekle
  12. Nintendo Switch Digitizer Replacement: adım 12, 2 resimden 1. Nintendo Switch Digitizer Replacement: adım 12, 2 resimden 2.
    • If the console doesn't have this foam, skip this step.
    • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
    • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
    FixBot'a Sor
    Yorum Ekle
  13. Nintendo Switch Digitizer Replacement: adım 13, 3 resimden 1. Nintendo Switch Digitizer Replacement: adım 13, 3 resimden 2. Nintendo Switch Digitizer Replacement: adım 13, 3 resimden 3.
    iFixit Thermal Putty
    $9.95
    • Insert a spudger underneath the shield plate along the edge of the device.
    • Pry up to lift the shield plate and remove it from the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
    • During reassembly, if you don't have replacement thermal compound, use the flat end of a spudger to distribute the old compound evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate.
    • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
    FixBot'a Sor
    Yorum Ekle
  14. Nintendo Switch Digitizer Replacement, Disconnect the battery: adım 14, 2 resimden 1. Nintendo Switch Digitizer Replacement, Disconnect the battery: adım 14, 2 resimden 2.
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  15. Nintendo Switch Digitizer Replacement, Remove the heat sink: adım 15, 1 resimden 1.
    • Use a JIS 00 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  16. Bu adımda kullanılan alet:
    iFixit Adhesive Remover
    $19.99
    • Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    • The foam is really delicate and tears easily. Use the following technique to peel the foam:
    • If you have some, dip the point of a spudger in adhesive remover or isopropyl alcohol (90% or greater).
    • Insert the point of a spudger underneath a part of the foam that isn't stuck to anything.
    • Press the top of the foam with your finger to hold it in place.
    • Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
    FixBot'a Sor
    Yorum Ekle
  17. Nintendo Switch Digitizer Replacement: adım 17, 3 resimden 1. Nintendo Switch Digitizer Replacement: adım 17, 3 resimden 2. Nintendo Switch Digitizer Replacement: adım 17, 3 resimden 3.
    • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly. Don't reuse the old thermal paste.
    • Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
    FixBot'a Sor
    Yorum Ekle
  18. Nintendo Switch Digitizer Replacement, Remove the headphone jack and game card reader: adım 18, 2 resimden 1. Nintendo Switch Digitizer Replacement, Remove the headphone jack and game card reader: adım 18, 2 resimden 2.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  19. Nintendo Switch Digitizer Replacement: adım 19, 2 resimden 1. Nintendo Switch Digitizer Replacement: adım 19, 2 resimden 2.
    • Use a pair of tweezers to slide the digitizer cable horizontally out of its connector on the game card reader board.
    • Before inserting the cable during reassembly, make sure the ZIF connector locking flap is flipped up.
    • With the cable parallel to the board, gently slide it into its connector.
    • Don't force the cable into the connector. If it doesn't insert, ensure the locking flap is flipped up, reposition the cable, and try again.
    • If your touchscreen doesn't work after the repair but your Game Card reader does, make sure this cable is properly inserted. If your Game Card reader also doesn't work, check the Game Card connector in the next step instead.
    FixBot'a Sor
    Yorum Ekle
  20. Nintendo Switch Digitizer Replacement: adım 20, 2 resimden 1. Nintendo Switch Digitizer Replacement: adım 20, 2 resimden 2.
    • Use the point of a spudger to pry the headphone jack and game card reader connector straight up to disconnect it from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    • If the touch screen doesn't work and/or game cards aren't detected after reassembly, you might have not fully reconnected this press connector. Carefully disconnect it and try again.
    FixBot'a Sor
    Yorum Ekle
  21. Nintendo Switch Digitizer Replacement: adım 21, 1 resimden 1.
    • Use a JIS 00 driver to remove the three 3.1 mm screws securing the headphone jack and game card reader board to the device.
    FixBot'a Sor
    Yorum Ekle
  22. Nintendo Switch Digitizer Replacement: adım 22, 2 resimden 1. Nintendo Switch Digitizer Replacement: adım 22, 2 resimden 2.
    • Use a pair of tweezers or your fingers to remove the headphone jack bracket.
    FixBot'a Sor
    Yorum Ekle
  23. Nintendo Switch Digitizer Replacement: adım 23, 2 resimden 1. Nintendo Switch Digitizer Replacement: adım 23, 2 resimden 2.
    • Use a pair of tweezers or your fingers to remove the headphone jack and game card reader board.
    FixBot'a Sor
    Yorum Ekle
  24. Nintendo Switch Digitizer Replacement, Screen: adım 24, 2 resimden 1. Nintendo Switch Digitizer Replacement, Screen: adım 24, 2 resimden 2.
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the LCD ribbon cable ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  25. Nintendo Switch Digitizer Replacement: adım 25, 2 resimden 1. Nintendo Switch Digitizer Replacement: adım 25, 2 resimden 2.
    • Use a pair of tweezers to pull the ribbon cable straight out of its connector on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  26. Nintendo Switch Digitizer Replacement: adım 26, 2 resimden 1. Nintendo Switch Digitizer Replacement: adım 26, 2 resimden 2.
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the smaller LCD ribbon cable ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  27. Nintendo Switch Digitizer Replacement: adım 27, 2 resimden 1. Nintendo Switch Digitizer Replacement: adım 27, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  28. Nintendo Switch Digitizer Replacement: adım 28, 1 resimden 1.
    • Heat an iOpener and apply it to the bottom edge of the screen for around two minutes to to help soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device—the display and internal battery are both susceptible to heat damage.
    FixBot'a Sor
    Yorum Ekle
  29. Nintendo Switch Digitizer Replacement: adım 29, 3 resimden 1. Nintendo Switch Digitizer Replacement: adım 29, 3 resimden 2. Nintendo Switch Digitizer Replacement: adım 29, 3 resimden 3.
    • Apply a suction cup to the bottom-left corner of the screen.
    • Pull up on the suction up with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Insert the point of an opening pick into the gap, making sure to only insert the pick about 5 mm.
    FixBot'a Sor
    Yorum Ekle
  30. Nintendo Switch Digitizer Replacement: adım 30, 3 resimden 1. Nintendo Switch Digitizer Replacement: adım 30, 3 resimden 2. Nintendo Switch Digitizer Replacement: adım 30, 3 resimden 3.
    • Slide the opening pick along the bottom edge of the screen to slice the adhesive.
    • Leave the pick inserted to prevent the adhesive from re-adhering to the frame.
    FixBot'a Sor
    Yorum Ekle
  31. Nintendo Switch Digitizer Replacement: adım 31, 3 resimden 1. Nintendo Switch Digitizer Replacement: adım 31, 3 resimden 2. Nintendo Switch Digitizer Replacement: adım 31, 3 resimden 3.
    • Insert a second opening pick into the gap to the left of the first pick.
    • Slide the opening pick back towards the left side of the device.
    • Leave the opening pick inserted.
    FixBot'a Sor
    Yorum Ekle
  32. Nintendo Switch Digitizer Replacement: adım 32, 1 resimden 1.
    • Heat the left edge of the screen for around two minutes to help soften the adhesive.
    FixBot'a Sor
    Yorum Ekle
  33. Nintendo Switch Digitizer Replacement: adım 33, 3 resimden 1. Nintendo Switch Digitizer Replacement: adım 33, 3 resimden 2. Nintendo Switch Digitizer Replacement: adım 33, 3 resimden 3.
    • Continue sliding the opening pick around the bottom-left corner to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  34. Nintendo Switch Digitizer Replacement: adım 34, 2 resimden 1. Nintendo Switch Digitizer Replacement: adım 34, 2 resimden 2.
    • Continue sliding the opening pick along the left edge of the screen to slice to adhesive.
    FixBot'a Sor
    Yorum Ekle
  35. Nintendo Switch Digitizer Replacement: adım 35, 1 resimden 1.
    • Heat the top edge of the screen for around two minutes to help soften the adhesive.
    FixBot'a Sor
    Yorum Ekle
  36. Nintendo Switch Digitizer Replacement: adım 36, 3 resimden 1. Nintendo Switch Digitizer Replacement: adım 36, 3 resimden 2. Nintendo Switch Digitizer Replacement: adım 36, 3 resimden 3.
    • Continue sliding the opening pick around the top-left corner of the screen to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  37. Nintendo Switch Digitizer Replacement: adım 37, 3 resimden 1. Nintendo Switch Digitizer Replacement: adım 37, 3 resimden 2. Nintendo Switch Digitizer Replacement: adım 37, 3 resimden 3.
    • Continue sliding the opening pick along the top edge of the screen to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  38. Nintendo Switch Digitizer Replacement: adım 38, 3 resimden 1. Nintendo Switch Digitizer Replacement: adım 38, 3 resimden 2. Nintendo Switch Digitizer Replacement: adım 38, 3 resimden 3.
    • Heat the right edge of the screen for around two minutes to help soften the adhesive.
    • Place the flat end of a spudger into the gap along the left edge of the screen.
    • Carefully and slowly lift the left edge of the screen, opening it like a book.
    FixBot'a Sor
    Yorum Ekle
  39. Nintendo Switch Digitizer Replacement: adım 39, 3 resimden 1. Nintendo Switch Digitizer Replacement: adım 39, 3 resimden 2. Nintendo Switch Digitizer Replacement: adım 39, 3 resimden 3.
    • Lift the right edge of the screen straight off the device, threading the ribbon cables through the frame as you do so.
    • Take care not to snag any of the ribbon cables on the frame as you remove the screen.
    • You can reuse the screen adhesive if it is still sticky. Otherwise, replace the adhesive with double-sided tape such as Tesa tape.
    FixBot'a Sor
    Yorum Ekle
  40. Nintendo Switch Digitizer Replacement, Separate the LCD panel and digitizer: adım 40, 1 resimden 1.
    • Heat the top edge of the screen assembly for around two minutes to help soften the adhesive holding the LCD panel to the digitizer.
    FixBot'a Sor
    Yorum Ekle
  41. Nintendo Switch Digitizer Replacement: adım 41, 3 resimden 1. Nintendo Switch Digitizer Replacement: adım 41, 3 resimden 2. Nintendo Switch Digitizer Replacement: adım 41, 3 resimden 3.
    • Turn the screen assembly over.
    • Insert an opening pick in between the LCD panel and the digitizer at the top-left corner.
    • It doesn't matter how deep you insert the opening pick, but about 5 mm is enough to slice through all the adhesive.
    • You can slightly bend the digitizer to create a wider gap, but take care not to bend it too far to cause damage to the digitizer if you're reusing it.
    • Slide the opening pick along the top edge of the screen assembly to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  42. Nintendo Switch Digitizer Replacement: adım 42, 3 resimden 1. Nintendo Switch Digitizer Replacement: adım 42, 3 resimden 2. Nintendo Switch Digitizer Replacement: adım 42, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
  43. Nintendo Switch Digitizer Replacement: adım 43, 1 resimden 1.
    • Heat the left edge of the screen assembly for around two minutes to help soften the adhesive.
    FixBot'a Sor
    Yorum Ekle
  44. Nintendo Switch Digitizer Replacement: adım 44, 2 resimden 1. Nintendo Switch Digitizer Replacement: adım 44, 2 resimden 2.
    • Insert and slide the opening pick along the left edge of the screen assembly to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  45. Nintendo Switch Digitizer Replacement: adım 45, 3 resimden 1. Nintendo Switch Digitizer Replacement: adım 45, 3 resimden 2. Nintendo Switch Digitizer Replacement: adım 45, 3 resimden 3.
    • Continue sliding the opening pick around the bottom-left corner of the screen assembly to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  46. Nintendo Switch Digitizer Replacement: adım 46, 1 resimden 1.
    • Heat the bottom edge of the screen assembly for around two minutes to help soften the adhesive.
    FixBot'a Sor
    Yorum Ekle
  47. Nintendo Switch Digitizer Replacement: adım 47, 3 resimden 1. Nintendo Switch Digitizer Replacement: adım 47, 3 resimden 2. Nintendo Switch Digitizer Replacement: adım 47, 3 resimden 3.
    • Continue sliding the opening pick along the bottom edge to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  48. Nintendo Switch Digitizer Replacement: adım 48, 1 resimden 1.
    • Heat the right edge of the screen assembly for around two minutes to help soften the adhesive.
    FixBot'a Sor
    Yorum Ekle
  49. Nintendo Switch Digitizer Replacement: adım 49, 2 resimden 1. Nintendo Switch Digitizer Replacement: adım 49, 2 resimden 2.
    • Insert the flat end of a spudger in between the LCD panel and the digitizer along the left edge of the screen assembly.
    • Carefully and slowly lift up the left side of the LCD panel, opening it like a book.
    FixBot'a Sor
    Yorum Ekle
  50. Nintendo Switch Digitizer Replacement: adım 50, 3 resimden 1. Nintendo Switch Digitizer Replacement: adım 50, 3 resimden 2. Nintendo Switch Digitizer Replacement: adım 50, 3 resimden 3.
    • Continue lifting the LCD panel away from the digitizer to separate the two components.
    • The LCD ribbon cable is slightly adhered to the digitizer. If it doesn't remove easily, apply more heat to that area and try again.
    FixBot'a Sor
    Yorum Ekle
  51. Nintendo Switch Digitizer Replacement, Digitizer: adım 51, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
If your new digitizer doesn’t work properly after you boot up the device, turn it back off and disconnect and reconnect the battery connector.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
36 farklı kişi bu kılavuzu tamamladı.
Craig Lloyd
42.948 İtibar
82 adet Kılavuz yazıldı
16Kılavuz Yorumları
Are Digitizers from original models (HAC-001) and revision models (HAC-001-(01)) compatible?
I don’t mean switch lite but the revision with the longer lasting battery.
GBG HNM - Yanıt Paylaş
Yes, the digitizer is compatible with both models!
Craig Lloyd - Yanıt Paylaş
No .
Daan Van Horssen - Yanıt Paylaş
The ribbon cable for the digitizer is too short and cannot plug in to the connecter on the game card reader. Any ideas what the issue could be? im using a custom housing for it
Daniel - Yanıt Paylaş
there should be a slit on the front housing where the ribbon cable goes straight through to the back. pay attention at where it comes out of on step 39
Ricardo Ortega - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 40
Son 7 gün: 212
Son 30 gün: 1,167
Her zaman: 86,351
