Ana içeriğe geç
Samsung Galaxy A53 5G Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy A53 5G Battery Replacement, Heat the back cover: adım 1, 1 resimden 1.
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy A53 5G Battery Replacement, Insert an opening pick: adım 2, 2 resimden 1. Samsung Galaxy A53 5G Battery Replacement, Insert an opening pick: adım 2, 2 resimden 2.
    • Secure a suction handle to the right edge of the back cover, as close to the edge as possible.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  3. Samsung Galaxy A53 5G Battery Replacement, Slice the adhesive: adım 3, 3 resimden 1. Samsung Galaxy A53 5G Battery Replacement, Slice the adhesive: adım 3, 3 resimden 2. Samsung Galaxy A53 5G Battery Replacement, Slice the adhesive: adım 3, 3 resimden 3.
    • Slide the opening pick to the top right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Samsung Galaxy A53 5G Battery Replacement, Slice the adhesive: adım 4, 3 resimden 1. Samsung Galaxy A53 5G Battery Replacement, Slice the adhesive: adım 4, 3 resimden 2. Samsung Galaxy A53 5G Battery Replacement, Slice the adhesive: adım 4, 3 resimden 3.
    • Insert a second opening pick at the top right edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  5. Samsung Galaxy A53 5G Battery Replacement: adım 5, 3 resimden 1. Samsung Galaxy A53 5G Battery Replacement: adım 5, 3 resimden 2. Samsung Galaxy A53 5G Battery Replacement: adım 5, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the bottom edge of your phone to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy A53 5G Battery Replacement: adım 6, 3 resimden 1. Samsung Galaxy A53 5G Battery Replacement: adım 6, 3 resimden 2. Samsung Galaxy A53 5G Battery Replacement: adım 6, 3 resimden 3.
    • Insert a fourth opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  7. Samsung Galaxy A53 5G Battery Replacement: adım 7, 2 resimden 1. Samsung Galaxy A53 5G Battery Replacement: adım 7, 2 resimden 2.
    • Insert a fifth opening pick at the top left corner.
    • Slide the opening pick along the top edge of the back cover to slice the remaining adhesive.
  8. Samsung Galaxy A53 5G Battery Replacement, Remove the back cover: adım 8, 1 resimden 1.
    • Remove the back cover.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. Samsung Galaxy A53 5G Battery Replacement, Unscrew the motherboard cover: adım 9, 1 resimden 1.
    • Use a Phillips screwdriver to remove the eight 3.9 mm-long screws securing the motherboard cover.
  10. Samsung Galaxy A53 5G Battery Replacement, Pry up the motherboard cover: adım 10, 3 resimden 1. Samsung Galaxy A53 5G Battery Replacement, Pry up the motherboard cover: adım 10, 3 resimden 2. Samsung Galaxy A53 5G Battery Replacement, Pry up the motherboard cover: adım 10, 3 resimden 3.
    • Insert the flat end of an spudger into the gap between the frame and the motherboard cover on the right edge.
    • Use the spudger to pry up the motherboard cover.
  11. Samsung Galaxy A53 5G Battery Replacement, Remove the motherboard cover: adım 11, 1 resimden 1.
    • Remove the motherboard cover.
  12. Samsung Galaxy A53 5G Battery Replacement, Disconnect the battery cable: adım 12, 2 resimden 1. Samsung Galaxy A53 5G Battery Replacement, Disconnect the battery cable: adım 12, 2 resimden 2.
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  13. Samsung Galaxy A53 5G Battery Replacement, Unfasten the loudspeaker screws: adım 13, 1 resimden 1.
    • Use a Phillips screwdriver to remove the seven 3.9 mm-long screws securing the loudspeaker assembly.
  14. Samsung Galaxy A53 5G Battery Replacement, Remove the loudspeaker: adım 14, 3 resimden 1. Samsung Galaxy A53 5G Battery Replacement, Remove the loudspeaker: adım 14, 3 resimden 2. Samsung Galaxy A53 5G Battery Replacement, Remove the loudspeaker: adım 14, 3 resimden 3.
    • Insert the flat end of a spudger into the gap between the right edge of the loudspeaker assembly and the midframe.
    • Use your spudger to pry up the loudspeaker assembly.
    • Remove the loudspeaker assembly.
  15. Samsung Galaxy A53 5G Battery Replacement, Disconnect the interconnect cable: adım 15, 2 resimden 1. Samsung Galaxy A53 5G Battery Replacement, Disconnect the interconnect cable: adım 15, 2 resimden 2.
    • Use a spudger to disconnect the interconnect cable from the motherboard by prying the connector straight up from its socket.
  16. Samsung Galaxy A53 5G Battery Replacement, Disconnect the interconnect cable: adım 16, 3 resimden 1. Samsung Galaxy A53 5G Battery Replacement, Disconnect the interconnect cable: adım 16, 3 resimden 2. Samsung Galaxy A53 5G Battery Replacement, Disconnect the interconnect cable: adım 16, 3 resimden 3.
    • Use a spudger to disconnect the interconnect cable from the daughterboard by prying the two connectors straight up from their sockets.
  17. Samsung Galaxy A53 5G Battery Replacement, Remove the interconnect cable: adım 17, 1 resimden 1.
    • Remove the interconnect cable.
  18. Samsung Galaxy A53 5G Battery Replacement, Loosen the battery adhesive: adım 18, 1 resimden 1.
    • Apply a heated iOpener to the screen to loosen the adhesive underneath the battery. Apply the iOpener for at least five minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    • Do not apply heat directly onto the battery as doing so is a potential safety hazard.
  19. Samsung Galaxy A53 5G Battery Replacement, Insert a plastic card: adım 19, 3 resimden 1. Samsung Galaxy A53 5G Battery Replacement, Insert a plastic card: adım 19, 3 resimden 2. Samsung Galaxy A53 5G Battery Replacement, Insert a plastic card: adım 19, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Insert a plastic card into the gap between the bottom edge of the battery and the frame.
    • Use the plastic card to slice the adhesive underneath the battery and pry it up.
    • The battery adhesive of the Samsung Galaxy A53 5G is strong. If you can't manage to remove the battery by only using your iOpener, you can apply a few drops of high concentration isopropyl alcohol (over 90%) into the gaps between the battery and the midframe.
    • If you're using isopropyl alcohol let the alcohol penetrate the battery adhesive for at least two minutes before attempting to remove the battery.
  20. Samsung Galaxy A53 5G Battery Replacement, Remove the battery: adım 20, 1 resimden 1.
    • Remove the battery.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
    • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
15 farklı kişi bu kılavuzu tamamladı.
Adriana Zwink
56.777 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.656 adet Kılavuz yazıldı
1Rehber Yorum
Thanks 🙏 👍
Peter Q. - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 195
Son 30 gün: 962
Her zaman: 22,650
