Ana içeriğe geç
Valve Index Headset Head Strap Clip Replacement
Sam Omiotek
Sam Omiotek ve başka bir katkıda bulunan
En son October 18, 2023 tarihinde güncellendi
2 - 5 dakika
Kolay
Follow this guide to replace the head strap clip on a Valve Index VR headset.
Power off and unplug your Index before you begin your repair.
Neye ihtiyacın var
Parçalar
Aletler
  • Spudger
    Spudger
Daha fazlasını göster…
  1. Valve Index Headset Head Strap Clip Replacement, Remove the head strap clip: adım 1, 3 resimden 1. Valve Index Headset Head Strap Clip Replacement, Remove the head strap clip: adım 1, 3 resimden 2. Valve Index Headset Head Strap Clip Replacement, Remove the head strap clip: adım 1, 3 resimden 3.
    • Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
    • Pry up on the head strap clip until it is unclipped from the head strap.
    • To reinstall, first locate the recesses on the head strap for mounting the clip. Next, align the clip with the recesses, verify the tether cable is threaded through the clip, then simply press the clip back into place.
    Do you sell replacement clips?
    TomCatT - Yanıt
    I didn't really see the need to unclip this or do the next step so I skipped it. It seems easy enough to unplug the cable while it's still attached to these, so unless you're really concerned about the cable bending a little more than it already does it seems unnecessary.
    Stephen Smith - Yanıt
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
3 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
84.642 İtibar
290 adet Kılavuz yazıldı
7 Yorum
Why are these clips so expensive? At $39.99 it's like someone mashed an extra 9 when putting in the price, the face gasket which is much larger, uses more material and is more robust costs less than half, even the power adapters are $5 cheaper.
Dor - Yanıt
Seems that the price has been corrected to $4.99
Dor -
Yeah. The price is seriously insane! Two smaller zipties fit through that opening just fine and cost me pennies and work better than that cheap plastic clip.
Joshua Dworsky - Yanıt
Maybe i might have a older verison of the index because the larger clip piece on the top doesnt even clip in
Brent - Yanıt
scratch that you need to put the SMALLER side in last which is was this post doesnt say :)
Brent - Yanıt
Don't bother buying a clip, just buy some zipties. I bought 2 clips and they both only lasted 2 weeks. The plastic they use is to weak for long term use.
trollking321 - Yanıt
Are these things ever in stock? I've been waiting for them to be in stock fort weeks. I can't imagine that too many people need them so why are they always sold out?
Bryan Flood - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 30
Son 30 gün: 108
Her zaman: 8,604
