Ana içeriğe geç
iPad 7 Battery Replacement
Neye ihtiyacın var
  1. iPad 7 Battery Replacement, Heat the left edge: adım 1, 1 resimden 1.
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. iPad 7 Battery Replacement, Screen removal information: adım 2, 3 resimden 1. iPad 7 Battery Replacement, Screen removal information: adım 2, 3 resimden 2. iPad 7 Battery Replacement, Screen removal information: adım 2, 3 resimden 3.
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. iPad 7 Battery Replacement, Anti-Clamp instructions: adım 3, 3 resimden 1. iPad 7 Battery Replacement, Anti-Clamp instructions: adım 3, 3 resimden 2. iPad 7 Battery Replacement, Anti-Clamp instructions: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad 7 Battery Replacement: adım 4, 3 resimden 1. iPad 7 Battery Replacement: adım 4, 3 resimden 2. iPad 7 Battery Replacement: adım 4, 3 resimden 3.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad 7 Battery Replacement: adım 5, 2 resimden 1. iPad 7 Battery Replacement: adım 5, 2 resimden 2.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad 7 Battery Replacement, Insert an opening pick: adım 6, 3 resimden 1. iPad 7 Battery Replacement, Insert an opening pick: adım 6, 3 resimden 2. iPad 7 Battery Replacement, Insert an opening pick: adım 6, 3 resimden 3.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  7. iPad 7 Battery Replacement, Separate the left adhesive: adım 7, 3 resimden 1. iPad 7 Battery Replacement, Separate the left adhesive: adım 7, 3 resimden 2. iPad 7 Battery Replacement, Separate the left adhesive: adım 7, 3 resimden 3.
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. iPad 7 Battery Replacement: adım 8, 3 resimden 1. iPad 7 Battery Replacement: adım 8, 3 resimden 2. iPad 7 Battery Replacement: adım 8, 3 resimden 3.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. iPad 7 Battery Replacement: adım 9, 3 resimden 1. iPad 7 Battery Replacement: adım 9, 3 resimden 2. iPad 7 Battery Replacement: adım 9, 3 resimden 3.
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. iPad 7 Battery Replacement, Heat the top edge: adım 10, 1 resimden 1.
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
  11. iPad 7 Battery Replacement, Separate the top left adhesive: adım 11, 3 resimden 1. iPad 7 Battery Replacement, Separate the top left adhesive: adım 11, 3 resimden 2. iPad 7 Battery Replacement, Separate the top left adhesive: adım 11, 3 resimden 3.
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
  12. iPad 7 Battery Replacement, Separate the top adhesive: adım 12, 3 resimden 1. iPad 7 Battery Replacement, Separate the top adhesive: adım 12, 3 resimden 2. iPad 7 Battery Replacement, Separate the top adhesive: adım 12, 3 resimden 3.
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. iPad 7 Battery Replacement: adım 13, 3 resimden 1. iPad 7 Battery Replacement: adım 13, 3 resimden 2. iPad 7 Battery Replacement: adım 13, 3 resimden 3.
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. iPad 7 Battery Replacement: adım 14, 3 resimden 1. iPad 7 Battery Replacement: adım 14, 3 resimden 2. iPad 7 Battery Replacement: adım 14, 3 resimden 3.
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. iPad 7 Battery Replacement, Heat the right edge: adım 15, 1 resimden 1.
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  16. iPad 7 Battery Replacement, Separate the top right adhesive: adım 16, 3 resimden 1. iPad 7 Battery Replacement, Separate the top right adhesive: adım 16, 3 resimden 2. iPad 7 Battery Replacement, Separate the top right adhesive: adım 16, 3 resimden 3.
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  17. iPad 7 Battery Replacement, Separate the right adhesive: adım 17, 3 resimden 1. iPad 7 Battery Replacement, Separate the right adhesive: adım 17, 3 resimden 2. iPad 7 Battery Replacement, Separate the right adhesive: adım 17, 3 resimden 3.
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
  18. iPad 7 Battery Replacement, Heat the bottom edge: adım 18, 1 resimden 1.
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  19. iPad 7 Battery Replacement, Separate the bottom left adhesive: adım 19, 3 resimden 1. iPad 7 Battery Replacement, Separate the bottom left adhesive: adım 19, 3 resimden 2. iPad 7 Battery Replacement, Separate the bottom left adhesive: adım 19, 3 resimden 3.
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the bottom-left corner before moving to the next step.
  20. iPad 7 Battery Replacement, Separate the bottom adhesive: adım 20, 3 resimden 1. iPad 7 Battery Replacement, Separate the bottom adhesive: adım 20, 3 resimden 2. iPad 7 Battery Replacement, Separate the bottom adhesive: adım 20, 3 resimden 3.
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. iPad 7 Battery Replacement: adım 21, 3 resimden 1. iPad 7 Battery Replacement: adım 21, 3 resimden 2. iPad 7 Battery Replacement: adım 21, 3 resimden 3.
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
  22. iPad 7 Battery Replacement: adım 22, 3 resimden 1. iPad 7 Battery Replacement: adım 22, 3 resimden 2. iPad 7 Battery Replacement: adım 22, 3 resimden 3.
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. iPad 7 Battery Replacement, Heat the right edge: adım 23, 1 resimden 1.
  24. iPad 7 Battery Replacement: adım 24, 2 resimden 1. iPad 7 Battery Replacement: adım 24, 2 resimden 2.
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. iPad 7 Battery Replacement: adım 25, 2 resimden 1. iPad 7 Battery Replacement: adım 25, 2 resimden 2.
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  26. iPad 7 Battery Replacement, Separate the right adhesive: adım 26, 3 resimden 1. iPad 7 Battery Replacement, Separate the right adhesive: adım 26, 3 resimden 2. iPad 7 Battery Replacement, Separate the right adhesive: adım 26, 3 resimden 3.
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  27. iPad 7 Battery Replacement: adım 27, 2 resimden 1. iPad 7 Battery Replacement: adım 27, 2 resimden 2.
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  28. iPad 7 Battery Replacement, Remove the LCD: adım 28, 2 resimden 1. iPad 7 Battery Replacement, Remove the LCD: adım 28, 2 resimden 2.
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the four 4.3 mm-long screws securing the LCD to the frame.
    • Remove any tape obscuring the LCD screws.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  29. iPad 7 Battery Replacement, Flip the LCD over: adım 29, 3 resimden 1. iPad 7 Battery Replacement, Flip the LCD over: adım 29, 3 resimden 2. iPad 7 Battery Replacement, Flip the LCD over: adım 29, 3 resimden 3.
    • Don't attempt to fully remove the LCD during this step, as it's still connected by several cables at the home button end.
    • Only lift the LCD from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the frame.
    • Lay the LCD down onto a clean, soft, lint-free surface to allow access to the display cables.
  30. iPad 7 Battery Replacement, Disconnect the battery: adım 30, 2 resimden 1. iPad 7 Battery Replacement, Disconnect the battery: adım 30, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 2.3 mm-long screw securing the battery connector to the logic board.
  31. iPad 7 Battery Replacement, Battery connector information: adım 31, 3 resimden 1. iPad 7 Battery Replacement, Battery connector information: adım 31, 3 resimden 2. iPad 7 Battery Replacement, Battery connector information: adım 31, 3 resimden 3.
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  32. iPad 7 Battery Replacement, Disconnect the battery: adım 32, 3 resimden 1. iPad 7 Battery Replacement, Disconnect the battery: adım 32, 3 resimden 2. iPad 7 Battery Replacement, Disconnect the battery: adım 32, 3 resimden 3.
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Ensure that the iFixit logo on the battery blocker is facing up.
    • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at about a 15 degree angle.
    • Leave the battery blocker in place as you work.
  33. iPad 7 Battery Replacement, Unfasten the display cable bracket: adım 33, 2 resimden 1. iPad 7 Battery Replacement, Unfasten the display cable bracket: adım 33, 2 resimden 2.
    • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the display cable bracket.
  34. iPad 7 Battery Replacement, Remove the display cable bracket: adım 34, 2 resimden 1. iPad 7 Battery Replacement, Remove the display cable bracket: adım 34, 2 resimden 2.
    • Remove the display cable bracket.
  35. iPad 7 Battery Replacement, Disconnect the LCD: adım 35, 2 resimden 1. iPad 7 Battery Replacement, Disconnect the LCD: adım 35, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the LCD cable by lifting straight up on the press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  36. iPad 7 Battery Replacement, Remove the LCD: adım 36, 2 resimden 1. iPad 7 Battery Replacement, Remove the LCD: adım 36, 2 resimden 2.
    • Remove the LCD completely and rest it face down on a clean, soft, lint-free surface.
  37. iPad 7 Battery Replacement, Disconnect the home button: adım 37, 2 resimden 1. iPad 7 Battery Replacement, Disconnect the home button: adım 37, 2 resimden 2.
    • Use a pair of tweezers to peel off the tape covering the home button cable ZIF connector.
  38. iPad 7 Battery Replacement: adım 38, 2 resimden 1. iPad 7 Battery Replacement: adım 38, 2 resimden 2.
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button cable ZIF connector.
  39. iPad 7 Battery Replacement: adım 39, 2 resimden 1. iPad 7 Battery Replacement: adım 39, 2 resimden 2.
    • Use a pair of tweezers to pull the home button ribbon cable straight out of the ZIF connector.
  40. iPad 7 Battery Replacement, Disconnect the display cables: adım 40, 3 resimden 1. iPad 7 Battery Replacement, Disconnect the display cables: adım 40, 3 resimden 2. iPad 7 Battery Replacement, Disconnect the display cables: adım 40, 3 resimden 3.
    • Use the flat end of a spudger to pry up and disconnect the two digitizer cable press connectors.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  41. iPad 7 Battery Replacement, Remove the vibration isolator: adım 41, 3 resimden 1. iPad 7 Battery Replacement, Remove the vibration isolator: adım 41, 3 resimden 2. iPad 7 Battery Replacement, Remove the vibration isolator: adım 41, 3 resimden 3.
    • Use the flat end of a spudger to pry up the vibration isolator near the bottom-right corner of the device.
    • Take care not to puncture or tear the home button ribbon cable.
    • Remove the vibration isolator.
  42. iPad 7 Battery Replacement: adım 42, 2 resimden 1. iPad 7 Battery Replacement: adım 42, 2 resimden 2.
    • The home button cable is secured with some light adhesive.
    • Use a pair of tweezers to peel the home button cable away from the frame.
  43. iPad 7 Battery Replacement, Remove the front panel assembly: adım 43, 3 resimden 1. iPad 7 Battery Replacement, Remove the front panel assembly: adım 43, 3 resimden 2. iPad 7 Battery Replacement, Remove the front panel assembly: adım 43, 3 resimden 3.
    Polyimide Tape
    $9.99
    • Remove the front panel assembly.
    • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
    • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
  44. iPad 7 Battery Replacement, Unfasten the upper component bracket: adım 44, 2 resimden 1. iPad 7 Battery Replacement, Unfasten the upper component bracket: adım 44, 2 resimden 2.
    • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the upper component bracket.
  45. iPad 7 Battery Replacement, Remove the upper component bracket: adım 45, 2 resimden 1. iPad 7 Battery Replacement, Remove the upper component bracket: adım 45, 2 resimden 2.
    • Use tweezers, or your fingers, to remove the upper component bracket from the frame.
  46. iPad 7 Battery Replacement, Disconnect the front camera: adım 46, 2 resimden 1. iPad 7 Battery Replacement, Disconnect the front camera: adım 46, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the front camera cable's press connector.
  47. iPad 7 Battery Replacement, Remove the front camera shell: adım 47, 2 resimden 1. iPad 7 Battery Replacement, Remove the front camera shell: adım 47, 2 resimden 2.
    • The front camera shell is lightly adhered to the frame.
    • Insert an opening pick between the front camera shell and the frame.
  48. iPad 7 Battery Replacement: adım 48, 3 resimden 1. iPad 7 Battery Replacement: adım 48, 3 resimden 2. iPad 7 Battery Replacement: adım 48, 3 resimden 3.
    • Slide the pick along the perimeter of the camera shell to separate the adhesive.
  49. iPad 7 Battery Replacement: adım 49, 3 resimden 1. iPad 7 Battery Replacement: adım 49, 3 resimden 2. iPad 7 Battery Replacement: adım 49, 3 resimden 3.
    • Pry up with the opening pick to separate the front camera shell from the frame.
    • Remove the front camera shell.
  50. iPad 7 Battery Replacement, Remove the front camera: adım 50, 3 resimden 1. iPad 7 Battery Replacement, Remove the front camera: adım 50, 3 resimden 2. iPad 7 Battery Replacement, Remove the front camera: adım 50, 3 resimden 3.
    • The front camera is mounted on microphone assembly with adhesive.
    • Insert a spudger between the front camera and the microphone assembly
    • Pry up to separate the front camera's adhesive.
    • Remove the front camera.
  51. iPad 7 Battery Replacement, Disconnect the headphone jack: adım 51, 2 resimden 1. iPad 7 Battery Replacement, Disconnect the headphone jack: adım 51, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the headphone jack by lifting straight up on the press connector.
  52. iPad 7 Battery Replacement: adım 52, 3 resimden 1. iPad 7 Battery Replacement: adım 52, 3 resimden 2. iPad 7 Battery Replacement: adım 52, 3 resimden 3.
    • Use your fingers to peel the headphone jack up from the frame and fold the cable out of the way.
  53. iPad 7 Battery Replacement, Disconnect the rear camera: adım 53, 2 resimden 1. iPad 7 Battery Replacement, Disconnect the rear camera: adım 53, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the rear camera by lifting straight up on the press connector.
  54. iPad 7 Battery Replacement, Disconnect the microphone assembly: adım 54, 2 resimden 1. iPad 7 Battery Replacement, Disconnect the microphone assembly: adım 54, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the microphone assembly by lifting straight up on the press connector.
  55. iPad 7 Battery Replacement, Disconnect the button control cable: adım 55, 2 resimden 1. iPad 7 Battery Replacement, Disconnect the button control cable: adım 55, 2 resimden 2.
  56. iPad 7 Battery Replacement: adım 56, 2 resimden 1. iPad 7 Battery Replacement: adım 56, 2 resimden 2.
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the button control cable ZIF connector.
  57. iPad 7 Battery Replacement: adım 57, 2 resimden 1. iPad 7 Battery Replacement: adım 57, 2 resimden 2.
    • Use a pair of tweezers to carefully pull the button control cable straight out of the ZIF connector.
  58. iPad 7 Battery Replacement, Disconnect the Smart Cover sensor: adım 58, 2 resimden 1. iPad 7 Battery Replacement, Disconnect the Smart Cover sensor: adım 58, 2 resimden 2.
    • Peel off any tape covering the Smart Cover sensor cable ZIF connector.
  59. iPad 7 Battery Replacement: adım 59, 2 resimden 1. iPad 7 Battery Replacement: adım 59, 2 resimden 2.
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the Smart Cover sensor cable ZIF connector.
  60. iPad 7 Battery Replacement: adım 60, 2 resimden 1. iPad 7 Battery Replacement: adım 60, 2 resimden 2.
    • Use a pair of tweezers to carefully pull the Smart Cover sensor cable straight out of the ZIF connector.
  61. iPad 7 Battery Replacement, Disconnect the antennas: adım 61, 3 resimden 1. iPad 7 Battery Replacement, Disconnect the antennas: adım 61, 3 resimden 2. iPad 7 Battery Replacement, Disconnect the antennas: adım 61, 3 resimden 3.
    • Use the tip of a spudger to pry up and disconnect the left antenna's coaxial cable.
    • Repeat for the right antenna's coaxial cable.
    • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  62. iPad 7 Battery Replacement: adım 62, 2 resimden 1. iPad 7 Battery Replacement: adım 62, 2 resimden 2.
    • Peel up the right antenna cable.
    • Grip the antenna cable by the cable itself and not at its connector. Pulling coaxial cables by their connectors can break them.
  63. iPad 7 Battery Replacement, Reposition the left antenna cable: adım 63, 3 resimden 1. iPad 7 Battery Replacement, Reposition the left antenna cable: adım 63, 3 resimden 2. iPad 7 Battery Replacement, Reposition the left antenna cable: adım 63, 3 resimden 3.
    • Peel the left antenna cable away from the frame, along the bottom edge of the iPad.
  64. iPad 7 Battery Replacement, Remove the vibration isolator: adım 64, 3 resimden 1. iPad 7 Battery Replacement, Remove the vibration isolator: adım 64, 3 resimden 2. iPad 7 Battery Replacement, Remove the vibration isolator: adım 64, 3 resimden 3.
    • Use the flat end of a spudger to pry up the vibration isolator at the bottom left corner of the iPad.
    • Use a pair of tweezers to remove the vibration isolator.
  65. iPad 7 Battery Replacement, Disconnect the speakers: adım 65, 3 resimden 1. iPad 7 Battery Replacement, Disconnect the speakers: adım 65, 3 resimden 2. iPad 7 Battery Replacement, Disconnect the speakers: adım 65, 3 resimden 3.
    • Use a pair of tweezers, or your fingers, to peel up the tape covering the speaker connectors.
  66. iPad 7 Battery Replacement: adım 66, 3 resimden 1. iPad 7 Battery Replacement: adım 66, 3 resimden 2. iPad 7 Battery Replacement: adım 66, 3 resimden 3.
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on both the left and right speaker cable ZIF connectors.
  67. iPad 7 Battery Replacement: adım 67, 3 resimden 1. iPad 7 Battery Replacement: adım 67, 3 resimden 2. iPad 7 Battery Replacement: adım 67, 3 resimden 3.
    • Use a pair of tweezers to carefully pull the left and right speaker cables straight out of their respective ZIF connectors.
  68. iPad 7 Battery Replacement, Disconnect the Smart Connector: adım 68, 2 resimden 1. iPad 7 Battery Replacement, Disconnect the Smart Connector: adım 68, 2 resimden 2.
    • Use the pointed end of a spudger to disconnect the Smart Connector coaxial cable by prying up as close to the connector as possible.
  69. iPad 7 Battery Replacement: adım 69, 2 resimden 1. iPad 7 Battery Replacement: adım 69, 2 resimden 2.
    • Use a spudger to pry up and disconnect the Smart Connector cable's connector.
  70. iPad 7 Battery Replacement: adım 70, 2 resimden 1. iPad 7 Battery Replacement: adım 70, 2 resimden 2.
    • Use a pair of tweezers to peel back the tape securing the Smart Connector cables to the frame.
  71. iPad 7 Battery Replacement, Reposition the Smart Connector cable: adım 71, 3 resimden 1. iPad 7 Battery Replacement, Reposition the Smart Connector cable: adım 71, 3 resimden 2. iPad 7 Battery Replacement, Reposition the Smart Connector cable: adım 71, 3 resimden 3.
    • Peel the Smart Connector cables away from the frame.
  72. iPad 7 Battery Replacement, Unfasten the charging port: adım 72, 2 resimden 1. iPad 7 Battery Replacement, Unfasten the charging port: adım 72, 2 resimden 2.
    • Use a Phillips screwdriver to remove the four screws securing the charging port to the frame:
    • Two 2.2 mm-long screws
    • Two 3.2 mm-long screws
  73. iPad 7 Battery Replacement, Soften the adhesive: adım 73, 3 resimden 1. iPad 7 Battery Replacement, Soften the adhesive: adım 73, 3 resimden 2. iPad 7 Battery Replacement, Soften the adhesive: adım 73, 3 resimden 3.
    • Heat an iOpener and apply it to the bottom, top, and logic board side of the iPad for thirty seconds in each location.
  74. iPad 7 Battery Replacement, Separate the charging port cable's adhesive: adım 74, 2 resimden 1. iPad 7 Battery Replacement, Separate the charging port cable's adhesive: adım 74, 2 resimden 2.
    • Insert an opening pick under the charging port cable near the logic board and slide it toward the charging port to slice the adhesive.
  75. iPad 7 Battery Replacement: adım 75, 3 resimden 1. iPad 7 Battery Replacement: adım 75, 3 resimden 2. iPad 7 Battery Replacement: adım 75, 3 resimden 3.
    • Insert an opening pick under the charging port cable near the charging port and slide it towards the logic board to cut the adhesive.
  76. iPad 7 Battery Replacement, Remove the charging port: adım 76, 2 resimden 1. iPad 7 Battery Replacement, Remove the charging port: adım 76, 2 resimden 2.
    • Pull the charging port out of its slot in the frame.
  77. iPad 7 Battery Replacement, Remove the logic board: adım 77, 3 resimden 1. iPad 7 Battery Replacement, Remove the logic board: adım 77, 3 resimden 2. iPad 7 Battery Replacement, Remove the logic board: adım 77, 3 resimden 3.
    • Insert an opening pick under the upper arm of the logic board and slide it toward the logic board to cut the adhesive securing it to the frame.
    • Leave the opening pick inserted to keep the adhesive from re-adhering.
  78. iPad 7 Battery Replacement: adım 78, 2 resimden 1. iPad 7 Battery Replacement: adım 78, 2 resimden 2.
    • Remove the battery blocker.
  79. iPad 7 Battery Replacement: adım 79, 2 resimden 1. iPad 7 Battery Replacement: adım 79, 2 resimden 2.
    • Insert an opening tool near the middle of the logic board and pry up with a slow and steady force to peel it away from the frame.
    • Bending or warping the logic board could lead to permanent damage. If the adhesive feels extra stubborn, apply more heat and try again.
    • If the logic board won't budge, slide an opening pick underneath the bottom edge of the logic board to slice some of the adhesive.
  80. iPad 7 Battery Replacement: adım 80, 2 resimden 1. iPad 7 Battery Replacement: adım 80, 2 resimden 2.
    Halberd Spudger
    $2.99
    • Use a halberd spudger or an opening pick to slice any remaining adhesive securing the logic board to the frame.
  81. iPad 7 Battery Replacement: adım 81, 2 resimden 1. iPad 7 Battery Replacement: adım 81, 2 resimden 2.
    Tesa 61395 Tape
    $8.95
    • Remove the logic board.
    • During reassembly, ensure that there are no ribbon cables stuck under the logic board before gluing it down.
    • During reassembly, apply strips of Tesa tape if the original adhesive is too mangled to be reused.
  82. iPad 7 Battery Replacement, Protect the other components: adım 82, 3 resimden 1. iPad 7 Battery Replacement, Protect the other components: adım 82, 3 resimden 2. iPad 7 Battery Replacement, Protect the other components: adım 82, 3 resimden 3.
    • Before removing the battery, it's important to protect the other components in the rear case by covering them with tape.
    • Cut a strip of painter's tape or scotch tape to the width of the iPad.
    • Press the bottom edge of the tape strip onto the rear case above the speakers and bottom antennas.
    • Run your finger along the bottom edge of tape strip to ensure a good seal.
    • Press the top edge of the tape strip over the bottom components to keep any cables from intruding on the battery removal.
  83. iPad 7 Battery Replacement: adım 83, 2 resimden 1. iPad 7 Battery Replacement: adım 83, 2 resimden 2.
    • Cover the upper components with a strip of tape.
  84. iPad 7 Battery Replacement, Protect your eyes and skin: adım 84, 2 resimden 1. iPad 7 Battery Replacement, Protect your eyes and skin: adım 84, 2 resimden 2.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover.
    • Do not wear contact lenses without eye protection.
    • Protective gloves are included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
  85. iPad 7 Battery Replacement, Open the adhesive remover: adım 85, 3 resimden 1. iPad 7 Battery Replacement, Open the adhesive remover: adım 85, 3 resimden 2. iPad 7 Battery Replacement, Open the adhesive remover: adım 85, 3 resimden 3.
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
  86. iPad 7 Battery Replacement, Adhesive location: adım 86, 2 resimden 1. iPad 7 Battery Replacement, Adhesive location: adım 86, 2 resimden 2.
    • The red boxes show the locations of the adhesive strips that secure the battery to the rear case.
  87. iPad 7 Battery Replacement, Apply adhesive remover: adım 87, 3 resimden 1. iPad 7 Battery Replacement, Apply adhesive remover: adım 87, 3 resimden 2. iPad 7 Battery Replacement, Apply adhesive remover: adım 87, 3 resimden 3.
    • Apply a few drops of adhesive remover or high-concentration isopropyl alcohol along the left edge of the battery.
  88. iPad 7 Battery Replacement: adım 88, 2 resimden 1. iPad 7 Battery Replacement: adım 88, 2 resimden 2.
    • Apply a few drops of adhesive remover or high-concentration isopropyl alcohol along the bottom edge of the battery.
  89. iPad 7 Battery Replacement: adım 89, 2 resimden 1. iPad 7 Battery Replacement: adım 89, 2 resimden 2.
    • Apply a few drops of adhesive remover or high-concentration isopropyl alcohol between the two battery cells.
  90. iPad 7 Battery Replacement: adım 90, 2 resimden 1. iPad 7 Battery Replacement: adım 90, 2 resimden 2.
    • Apply a few drops of adhesive remover or high-concentration isopropyl alcohol along the right edge of the battery.
  91. iPad 7 Battery Replacement: adım 91, 2 resimden 1. iPad 7 Battery Replacement: adım 91, 2 resimden 2.
    • Apply a few drops of adhesive remover or high-concentration isopropyl alcohol along the upper edge of the battery.
  92. iPad 7 Battery Replacement, Cut the adhesive on the right edge: adım 92, 2 resimden 1. iPad 7 Battery Replacement, Cut the adhesive on the right edge: adım 92, 2 resimden 2.
    Plastic Cards
    $2.99
    • Insert a plastic card at the bottom right corner of the battery.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • If at any point in this process the adhesive becomes very difficult to cut through, apply an iOpener to that area.
  93. iPad 7 Battery Replacement: adım 93, 3 resimden 1. iPad 7 Battery Replacement: adım 93, 3 resimden 2. iPad 7 Battery Replacement: adım 93, 3 resimden 3.
    • Slide the plastic card underneath the right edge to reach the center.
    • Insert the plastic card as far as you can under the battery to cut the adhesive.
    • Remove the plastic card.
  94. iPad 7 Battery Replacement: adım 94, 2 resimden 1. iPad 7 Battery Replacement: adım 94, 2 resimden 2.
    • Insert the plastic card below the battery connector as far as you can.
    • Leave the plastic card inserted.
  95. iPad 7 Battery Replacement: adım 95, 2 resimden 1. iPad 7 Battery Replacement: adım 95, 2 resimden 2.
    • Insert another plastic card above the battery connector as far as you can.
  96. iPad 7 Battery Replacement, Cut the adhesive on the bottom edge: adım 96, 2 resimden 1. iPad 7 Battery Replacement, Cut the adhesive on the bottom edge: adım 96, 2 resimden 2.
    • Remove the plastic card below the battery connector and insert it under the bottom edge of the battery.
  97. iPad 7 Battery Replacement: adım 97, 3 resimden 1. iPad 7 Battery Replacement: adım 97, 3 resimden 2. iPad 7 Battery Replacement: adım 97, 3 resimden 3.
    • Slide the plastic card along the bottom edge of the battery to cut the adhesive strip.
    • When you reach the left corner of the bottom edge, insert the plastic card as far as you can.
  98. iPad 7 Battery Replacement, Cut the adhesive on the upper edge: adım 98, 2 resimden 1. iPad 7 Battery Replacement, Cut the adhesive on the upper edge: adım 98, 2 resimden 2.
    • Remove the plastic card above the battery connector and insert it under the upper edge of the battery.
    • Slide the plastic card along the top edge of the battery to cut the adhesive strip.
    • If you're having trouble loosening the battery, apply some more adhesive remover, or apply a heated iOpener to the back case.
  99. iPad 7 Battery Replacement: adım 99, 2 resimden 1. iPad 7 Battery Replacement: adım 99, 2 resimden 2.
    • When you reach the left corner of the upper edge, insert the plastic card as far as you can.
  100. iPad 7 Battery Replacement, Cut the adhesive on the left edge: adım 100, 3 resimden 1. iPad 7 Battery Replacement, Cut the adhesive on the left edge: adım 100, 3 resimden 2. iPad 7 Battery Replacement, Cut the adhesive on the left edge: adım 100, 3 resimden 3.
    • Insert the plastic card under the upper left corner of the battery.
    • Slide the plastic card down towards the bottom of the iPad.
    • When you reach the center edge of the battery, insert the plastic card as far as you can to cut the central adhesive strip.
  101. iPad 7 Battery Replacement: adım 101, 2 resimden 1. iPad 7 Battery Replacement: adım 101, 2 resimden 2.
    • Insert the plastic card under the bottom left corner of the battery.
    • Slide the plastic card up towards the top of the iPad.
  102. iPad 7 Battery Replacement: adım 102, 2 resimden 1. iPad 7 Battery Replacement: adım 102, 2 resimden 2.
    • When you reach the center edge, insert the plastic card as far as you can to cut the central adhesive strip.
  103. iPad 7 Battery Replacement, Remove the battery: adım 103, 1 resimden 1.
    Tesa 61395 Tape
    $25.95
    • Remove the battery.
    • If you're still not able to remove the battery, repeat the process of cutting through the battery adhesive.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Remove the old battery adhesive from the rear case using tweezers and high concentration isopropyl alcohol with a lint-free cloth where needed.
    • If your battery doesn't come with preinstalled adhesive, use Tesa tape to reattach the battery to the rear case.
    • Before installing the new battery, test it by first reinserting the logic board, connecting the button control cable ZIF connector, and the LCD press connector. Then remove the battery blocker and reinstall the battery connector screw. Power on the device to ensure it still works. Go backwards through this step and then glue down the battery.
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 7 Answers community for help.
9 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
217.854 İtibar
1.087 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.991 adet Kılavuz yazıldı
1Rehber Yorum
amazing this tutorial is a life safer i hoped the pictures was GIF
سلام - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 188
Son 30 gün: 877
Her zaman: 18,476
