Ana içeriğe geç
iPhone 15 Logic Board Replacement
Neye ihtiyacın var
  1. iPhone 15 Logic Board Replacement, Prepare your phone for disassembly: adım 1, 2 resimden 1. iPhone 15 Logic Board Replacement, Prepare your phone for disassembly: adım 1, 2 resimden 2.
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Logic Board Replacement, Tape over any cracks: adım 2, 2 resimden 1. iPhone 15 Logic Board Replacement, Tape over any cracks: adım 2, 2 resimden 2.
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Logic Board Replacement, Mark your opening picks: adım 3, 3 resimden 1. iPhone 15 Logic Board Replacement, Mark your opening picks: adım 3, 3 resimden 2. iPhone 15 Logic Board Replacement, Mark your opening picks: adım 3, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 15 Logic Board Replacement, Remove the pentalobe screws: adım 4, 2 resimden 1. iPhone 15 Logic Board Replacement, Remove the pentalobe screws: adım 4, 2 resimden 2.
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  5. iPhone 15 Logic Board Replacement, Secure the back glass: adım 5, 3 resimden 1. iPhone 15 Logic Board Replacement, Secure the back glass: adım 5, 3 resimden 2. iPhone 15 Logic Board Replacement, Secure the back glass: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next four steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down four steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • The Anti-Clamp applies suction to both the screen and the back glass. To open the screen, you need to secure the back glass with tape. You can also check out the full instructions on how to use this tape.
    • Cut two strips of tape, apply them along the long edges of the phone, and fold them over the back glass to secure it.
  6. iPhone 15 Logic Board Replacement, Secure an Anti-Clamp: adım 6, 3 resimden 1. iPhone 15 Logic Board Replacement, Secure an Anti-Clamp: adım 6, 3 resimden 2. iPhone 15 Logic Board Replacement, Secure an Anti-Clamp: adım 6, 3 resimden 3.
    • Pull the Anti-Clamp's blue handle backward to unlock the arms.
    • With the screen facing up, slide the arms over the left edge of your phone, with one suction cup on the screen and the other on the back glass. Center the suction cups near the bottom edge.
    • Support your phone so it rests level while between the Anti-Clamp's arms—a small box works well.
    • Squeeze the cups together to create suction.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  7. iPhone 15 Logic Board Replacement, Create a gap under the screen: adım 7, 3 resimden 1. iPhone 15 Logic Board Replacement, Create a gap under the screen: adım 7, 3 resimden 2. iPhone 15 Logic Board Replacement, Create a gap under the screen: adım 7, 3 resimden 3.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle one full turn (360 degrees) or until the cups start to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they tend to slip, remove the Anti-Clamp and apply tape for the cups to stick to.
    • If you don't have tape, you may use your hands to clean the suction cups and warm them up to help them stick.
  8. iPhone 15 Logic Board Replacement, Insert an opening pick: adım 8, 3 resimden 1. iPhone 15 Logic Board Replacement, Insert an opening pick: adım 8, 3 resimden 2. iPhone 15 Logic Board Replacement, Insert an opening pick: adım 8, 3 resimden 3.
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    • Wait up to a minute for the adhesive to separate and a gap to form between the screen and the frame.
    • If a gap doesn't appear after one minute, apply more heat and rotate the handle a quarter turn. Let the Anti-Clamp and time do the work for you.
    • Insert an opening pick into the gap.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  9. iPhone 15 Logic Board Replacement, Heat the bottom edge: adım 9, 1 resimden 1.
  10. iPhone 15 Logic Board Replacement, Insert an opening pick: adım 10, 3 resimden 1. iPhone 15 Logic Board Replacement, Insert an opening pick: adım 10, 3 resimden 2. iPhone 15 Logic Board Replacement, Insert an opening pick: adım 10, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  11. iPhone 15 Logic Board Replacement, Screen information: adım 11, 1 resimden 1.
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone, one just above the mute switch, and the other about halfway between the volume down button and the bottom of the phone.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
  12. iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: adım 12, 3 resimden 1. iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: adım 12, 3 resimden 2. iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: adım 12, 3 resimden 3.
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  13. iPhone 15 Logic Board Replacement, Heat the right edge: adım 13, 1 resimden 1.
    • Heat the right edge of the screen until it's hot to the touch.
  14. iPhone 15 Logic Board Replacement, Position the opening pick: adım 14, 3 resimden 1. iPhone 15 Logic Board Replacement, Position the opening pick: adım 14, 3 resimden 2. iPhone 15 Logic Board Replacement, Position the opening pick: adım 14, 3 resimden 3.
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
  15. iPhone 15 Logic Board Replacement, Release the right clip: adım 15, 3 resimden 1. iPhone 15 Logic Board Replacement, Release the right clip: adım 15, 3 resimden 2. iPhone 15 Logic Board Replacement, Release the right clip: adım 15, 3 resimden 3.
    • Hold the pick with one hand and twist it to increase the gap between the screen and the frame and release the right clip.
    • Insert a second opening pick to the right of the first one.
  16. iPhone 15 Logic Board Replacement, Separate the right edge adhesive: adım 16, 3 resimden 1. iPhone 15 Logic Board Replacement, Separate the right edge adhesive: adım 16, 3 resimden 2. iPhone 15 Logic Board Replacement, Separate the right edge adhesive: adım 16, 3 resimden 3.
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
  17. iPhone 15 Logic Board Replacement, Heat the top edge: adım 17, 1 resimden 1.
    • Heat the top edge of the screen until it's hot to the touch.
  18. iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: adım 18, 3 resimden 1. iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: adım 18, 3 resimden 2. iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: adım 18, 3 resimden 3.
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Insert a third opening pick in the top right corner, just above the previous pick.
    • Slide your pick around the top right corner and along the top edge until you feel it stop against the top left screen clip.
  19. iPhone 15 Logic Board Replacement, Release the top edge clips: adım 19, 3 resimden 1. iPhone 15 Logic Board Replacement, Release the top edge clips: adım 19, 3 resimden 2. iPhone 15 Logic Board Replacement, Release the top edge clips: adım 19, 3 resimden 3.
    • Rotate your pick so its flat edge is under the screen.
    • Twist your pick to release the top left screen clip.
    • Slide your pick to the top left corner.
  20. iPhone 15 Logic Board Replacement, Heat the left edge: adım 20, 1 resimden 1.
    • Heat the left edge of the screen until it's hot to the touch.
  21. iPhone 15 Logic Board Replacement, Separate the left edge adhesive: adım 21, 3 resimden 1. iPhone 15 Logic Board Replacement, Separate the left edge adhesive: adım 21, 3 resimden 2. iPhone 15 Logic Board Replacement, Separate the left edge adhesive: adım 21, 3 resimden 3.
    • Don't insert your pick deeper than 3 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Slide your pick around the top left corner of the screen and along the left edge to release the clips and separate the adhesive securing it.
  22. iPhone 15 Logic Board Replacement, Swing open the screen: adım 22, 3 resimden 1. iPhone 15 Logic Board Replacement, Swing open the screen: adım 22, 3 resimden 2. iPhone 15 Logic Board Replacement, Swing open the screen: adım 22, 3 resimden 3.
    • Gently swing open the screen over the left edge of the phone.
    • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
  23. iPhone 15 Logic Board Replacement, Unfasten the front sensor connector cover: adım 23, 1 resimden 1.
    • Use a tri-point Y000 driver to remove the 0.9 mm-long screw securing the front sensor connector cover.
  24. iPhone 15 Logic Board Replacement, Remove the cover: adım 24, 3 resimden 1. iPhone 15 Logic Board Replacement, Remove the cover: adım 24, 3 resimden 2. iPhone 15 Logic Board Replacement, Remove the cover: adım 24, 3 resimden 3.
    • Use tweezers to lift the cover to a 90-degree angle.
    • Unhook the cover from its slot in the logic board.
    • Remove the cover.
    • During reassembly, insert the cover at a 90-degree angle to re-engage the hook before laying it flat against the press connector.
  25. iPhone 15 Logic Board Replacement, Disconnect the front sensor: adım 25, 2 resimden 1. iPhone 15 Logic Board Replacement, Disconnect the front sensor: adım 25, 2 resimden 2.
    • Use the tip of an opening pick to pry up and disconnect the front sensor press connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side.
  26. iPhone 15 Logic Board Replacement, Unfasten the screen connector cover: adım 26, 1 resimden 1.
    • Use your tri-point Y000 driver to remove the 0.9 mm screw securing the screen connector cover.
  27. iPhone 15 Logic Board Replacement, Remove the cover: adım 27, 2 resimden 1. iPhone 15 Logic Board Replacement, Remove the cover: adım 27, 2 resimden 2.
    • Use tweezers to lift the cover and unlatch it from its hook on the logic board.
    • Remove the cover.
  28. iPhone 15 Logic Board Replacement, Disconnect the screen: adım 28, 2 resimden 1. iPhone 15 Logic Board Replacement, Disconnect the screen: adım 28, 2 resimden 2.
    • Use the tip of an opening pick to pry up and disconnect the screen press connector.
  29. iPhone 15 Logic Board Replacement, Remove the screen: adım 29, 1 resimden 1.
    • Remove the screen.
    • During reassembly, use this guide to reapply adhesive and install your new screen.
    • Be careful not to damage any of the spring contacts as you clean the frame.
  30. iPhone 15 Logic Board Replacement, Flip your iPhone over: adım 30, 1 resimden 1.
    Microfiber Cleaning Cloths
    $3.99
    • Flip your phone over and lay it on a soft surface, such as a microfiber cloth, to protect its internals as you work.
  31. iPhone 15 Logic Board Replacement, Heat the bottom edge: adım 31, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
  32. iPhone 15 Logic Board Replacement, Insert an opening pick: adım 32, 3 resimden 1. iPhone 15 Logic Board Replacement, Insert an opening pick: adım 32, 3 resimden 2. iPhone 15 Logic Board Replacement, Insert an opening pick: adım 32, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
  33. iPhone 15 Logic Board Replacement, Back glass information: adım 33, 1 resimden 1.
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
  34. iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: adım 34, 3 resimden 1. iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: adım 34, 3 resimden 2. iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: adım 34, 3 resimden 3.
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
  35. iPhone 15 Logic Board Replacement, Heat the right edge: adım 35, 1 resimden 1.
    • Heat the right edge of the back glass until it's hot to the touch.
  36. iPhone 15 Logic Board Replacement, Separate the bottom right corner adhesive: adım 36, 3 resimden 1. iPhone 15 Logic Board Replacement, Separate the bottom right corner adhesive: adım 36, 3 resimden 2. iPhone 15 Logic Board Replacement, Separate the bottom right corner adhesive: adım 36, 3 resimden 3.
    • Don't insert your pick deeper than 7 mm along the right edge.
    • Rotate your pick around the bottom right corner and slide it to the volume down button or until you feel a hard stop at a large clip securing the back glass.
    • Don't slice past the volume buttons to avoid damaging the wireless charging cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  37. iPhone 15 Logic Board Replacement, Heat the left edge: adım 37, 1 resimden 1.
    • Heat the left edge of the back glass until it's hot to the touch.
  38. iPhone 15 Logic Board Replacement, Separate the left edge adhesive: adım 38, 3 resimden 1. iPhone 15 Logic Board Replacement, Separate the left edge adhesive: adım 38, 3 resimden 2. iPhone 15 Logic Board Replacement, Separate the left edge adhesive: adım 38, 3 resimden 3.
    • Along the left edge, don't insert your pick deeper than 5 mm.
    • Insert a second opening pick at the bottom edge.
    • Rotate the second pick around the bottom left corner.
    • Slide this pick up to the top left corner to separate the adhesive.
  39. iPhone 15 Logic Board Replacement, Heat the top edge: adım 39, 1 resimden 1.
    • Heat the top edge of the back glass until it's hot to the touch.
  40. iPhone 15 Logic Board Replacement, Separate the top edge adhesive: adım 40, 3 resimden 1. iPhone 15 Logic Board Replacement, Separate the top edge adhesive: adım 40, 3 resimden 2. iPhone 15 Logic Board Replacement, Separate the top edge adhesive: adım 40, 3 resimden 3.
    • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
    • You might hear and feel clicks as the top two clips release.
    • Leave this pick in place to prevent the adhesive from resealing.
  41. iPhone 15 Logic Board Replacement, Heat the top right corner: adım 41, 1 resimden 1.
    • Heat the top right corner of the back glass until it's hot to the touch.
  42. iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: adım 42, 3 resimden 1. iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: adım 42, 3 resimden 2. iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: adım 42, 3 resimden 3.
    • Don't insert your pick deeper than 4 mm along the right edge.
    • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
  43. iPhone 15 Logic Board Replacement, Swing open the back glass: adım 43, 3 resimden 1. iPhone 15 Logic Board Replacement, Swing open the back glass: adım 43, 3 resimden 2. iPhone 15 Logic Board Replacement, Swing open the back glass: adım 43, 3 resimden 3.
    • Gently swing open the back glass to the right of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a raised surface so it doesn't strain the cable.
  44. iPhone 15 Logic Board Replacement, Unfasten the lower connector cover: adım 44, 1 resimden 1.
    FixMat
    $36.95
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
  45. iPhone 15 Logic Board Replacement, Remove the lower connector cover: adım 45, 3 resimden 1. iPhone 15 Logic Board Replacement, Remove the lower connector cover: adım 45, 3 resimden 2. iPhone 15 Logic Board Replacement, Remove the lower connector cover: adım 45, 3 resimden 3.
    • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
    • Remove the cover.
    • During reassembly, latch the top edge of the cover onto its slot on the logic board before securing it with its screw.
  46. iPhone 15 Logic Board Replacement, Disconnect the battery: adım 46, 3 resimden 1. iPhone 15 Logic Board Replacement, Disconnect the battery: adım 46, 3 resimden 2. iPhone 15 Logic Board Replacement, Disconnect the battery: adım 46, 3 resimden 3.
    • Hold the back glass upright with one hand and rotate it just enough to reveal the battery press connector just below the volume buttons.
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
    • A plus and minus sign is printed on the head of this connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
  47. iPhone 15 Logic Board Replacement, Unfasten the middle connector cover: adım 47, 2 resimden 1. iPhone 15 Logic Board Replacement, Unfasten the middle connector cover: adım 47, 2 resimden 2.
    • Use your tri-point Y000 driver to remove the 0.9 mm-long screw securing the middle connector cover.
  48. iPhone 15 Logic Board Replacement, Remove the cover: adım 48, 3 resimden 1. iPhone 15 Logic Board Replacement, Remove the cover: adım 48, 3 resimden 2. iPhone 15 Logic Board Replacement, Remove the cover: adım 48, 3 resimden 3.
    • Use the flat end of a spudger or your finger to push the cover toward the bottom of the phone and unclip its top edge.
    • Remove the cover.
    • During reassembly, place the cover so its tab is just behind the clip on the logic board. Press down with one finger and slide the cover forward to engage the clip.
  49. iPhone 15 Logic Board Replacement, Disconnect the wireless charging coil: adım 49, 2 resimden 1. iPhone 15 Logic Board Replacement, Disconnect the wireless charging coil: adım 49, 2 resimden 2.
    • Use an opening pick to pry up and disconnect the wireless charging coil and NFC connector.
  50. iPhone 15 Logic Board Replacement, Remove the back glass: adım 50, 1 resimden 1.
    • Remove the back glass.
    • During reassembly:
    • This is a good point to test your repair before sealing up your phone. Temporarily reconnect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down and continue reassembly.
    • Use this guide to reapply adhesive and install your back glass.
  51. iPhone 15 Logic Board Replacement, Remove the upper connector cover: adım 51, 3 resimden 1. iPhone 15 Logic Board Replacement, Remove the upper connector cover: adım 51, 3 resimden 2. iPhone 15 Logic Board Replacement, Remove the upper connector cover: adım 51, 3 resimden 3.
    • Use your tri-point Y000 driver to remove the two 1.3 mm screws securing the upper connector cover.
    • Remove the cover.
  52. iPhone 15 Logic Board Replacement, Disconnect the front camera and sensors: adım 52, 3 resimden 1. iPhone 15 Logic Board Replacement, Disconnect the front camera and sensors: adım 52, 3 resimden 2. iPhone 15 Logic Board Replacement, Disconnect the front camera and sensors: adım 52, 3 resimden 3.
    • Use the tip of an opening pick to pry up and disconnect the antenna, front sensors, and front camera press connectors (three connectors in total).
  53. iPhone 15 Logic Board Replacement, Remove the front camera and sensors: adım 53, 2 resimden 1. iPhone 15 Logic Board Replacement, Remove the front camera and sensors: adım 53, 2 resimden 2.
    • Use tweezers or your fingers to pull the front camera and sensors out of their recess in the frame and remove them.
  54. iPhone 15 Logic Board Replacement, Disconnect the earpiece speaker: adım 54, 2 resimden 1. iPhone 15 Logic Board Replacement, Disconnect the earpiece speaker: adım 54, 2 resimden 2.
    • Use the tip of an opening pick to pry up and disconnect the earpiece speaker press connector.
  55. iPhone 15 Logic Board Replacement, Unfasten the earpiece speaker: adım 55, 1 resimden 1.
    • Use a Phillips #000 driver to remove the five screws securing the earpiece speaker:
    • Two 1.1 mm screws
    • Three 1.6 mm screws
  56. iPhone 15 Logic Board Replacement, Remove the earpiece speaker: adım 56, 3 resimden 1. iPhone 15 Logic Board Replacement, Remove the earpiece speaker: adım 56, 3 resimden 2. iPhone 15 Logic Board Replacement, Remove the earpiece speaker: adım 56, 3 resimden 3.
    • Use tweezers or your fingers to lift and pull the earpiece speaker away from the top of the phone to free the gasket from the frame.
    • Remove the earpiece speaker.
  57. iPhone 15 Logic Board Replacement, Separate the battery cable: adım 57, 3 resimden 1. iPhone 15 Logic Board Replacement, Separate the battery cable: adım 57, 3 resimden 2. iPhone 15 Logic Board Replacement, Separate the battery cable: adım 57, 3 resimden 3.
    • Light adhesive secures the battery cable to the logic board.
    • Slide an opening pick under the battery cable to separate it from the logic board.
    • Be careful not to crease the cable or dent the battery with your tool.
  58. iPhone 15 Logic Board Replacement, Disconnect the volume buttons: adım 58, 2 resimden 1. iPhone 15 Logic Board Replacement, Disconnect the volume buttons: adım 58, 2 resimden 2.
    • Use the tip of an opening pick to pry up and disconnect the volume buttons press connector.
  59. iPhone 15 Logic Board Replacement, Disconnect the power button: adım 59, 2 resimden 1. iPhone 15 Logic Board Replacement, Disconnect the power button: adım 59, 2 resimden 2.
    • Disconnect the power button press connector.
  60. iPhone 15 Logic Board Replacement, Disconnect the rear cameras and antenna: adım 60, 3 resimden 1. iPhone 15 Logic Board Replacement, Disconnect the rear cameras and antenna: adım 60, 3 resimden 2. iPhone 15 Logic Board Replacement, Disconnect the rear cameras and antenna: adım 60, 3 resimden 3.
    • Disconnect the rear cameras and antenna press connectors (three connectors in total).
  61. iPhone 15 Logic Board Replacement, Disconnect the eSIM, Taptic Engine, and charging port: adım 61, 3 resimden 1. iPhone 15 Logic Board Replacement, Disconnect the eSIM, Taptic Engine, and charging port: adım 61, 3 resimden 2. iPhone 15 Logic Board Replacement, Disconnect the eSIM, Taptic Engine, and charging port: adım 61, 3 resimden 3.
    • Disconnect the eSIM, Taptic Engine, and charging port press connectors (three connectors in total).
  62. iPhone 15 Logic Board Replacement, Unfasten the logic board: adım 62, 2 resimden 1. iPhone 15 Logic Board Replacement, Unfasten the logic board: adım 62, 2 resimden 2.
    Standoff Screwdriver for iPhones
    $5.49
    • Use your standoff driver to remove the five standoff screws securing the logic board:
    • One 2.9 mm screw
    • One 3.9 mm screw
    • Three 3.5 mm screws
    • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
  63. iPhone 15 Logic Board Replacement, Remove the logic board: adım 63, 3 resimden 1. iPhone 15 Logic Board Replacement, Remove the logic board: adım 63, 3 resimden 2. iPhone 15 Logic Board Replacement, Remove the logic board: adım 63, 3 resimden 3.
    • Grip the top edge of the logic board and gently pull it out from under the cables.
    • Remove the logic board.
    • During reassembly, make sure all nine press connectors (including the small volume buttons cable) are above the logic board.
Sonuç
To reassemble your phone, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Clay Eickemeyer
82.642 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.513 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 27
Son 7 gün: 179
Son 30 gün: 823
Her zaman: 7,330
