Ana içeriğe geç
iPhone 7 Plus Screen Replacement
Neye ihtiyacın var
Videoya Genel Bakış
    1. iPhone 7 Plus Screen Replacement, Pentalobe Screws: adım 1, 1 resimden 1.
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone (using a P2 screw bit, if you have a set of bits).
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 7 Plus Screen Replacement, Mark your opening picks: adım 2, 3 resimden 1. iPhone 7 Plus Screen Replacement, Mark your opening picks: adım 2, 3 resimden 2. iPhone 7 Plus Screen Replacement, Mark your opening picks: adım 2, 3 resimden 3.
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 7 Plus Screen Replacement, Anti-Clamp instructions: adım 3, 3 resimden 1. iPhone 7 Plus Screen Replacement, Anti-Clamp instructions: adım 3, 3 resimden 2. iPhone 7 Plus Screen Replacement, Anti-Clamp instructions: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      FixBot'a Sor
      Yorum Ekle
    2. iPhone 7 Plus Screen Replacement: adım 4, 3 resimden 1. iPhone 7 Plus Screen Replacement: adım 4, 3 resimden 2. iPhone 7 Plus Screen Replacement: adım 4, 3 resimden 3.
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      FixBot'a Sor
      Yorum Ekle
    3. iPhone 7 Plus Screen Replacement: adım 5, 2 resimden 1. iPhone 7 Plus Screen Replacement: adım 5, 2 resimden 2.
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      FixBot'a Sor
      Yorum Ekle
    4. iPhone 7 Plus Screen Replacement, Heat the display: adım 6, 1 resimden 1.
      • The next three steps show how to separate the screen using a suction cup.
      • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
      • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
      FixBot'a Sor
      Yorum Ekle
    5. iPhone 7 Plus Screen Replacement, Separate the display: adım 7, 2 resimden 1. iPhone 7 Plus Screen Replacement, Separate the display: adım 7, 2 resimden 2.
      • Apply a suction cup to the lower half of the front panel, just above the home button.
      • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
      FixBot'a Sor
      Yorum Ekle
    6. iPhone 7 Plus Screen Replacement: adım 8, 3 resimden 1. iPhone 7 Plus Screen Replacement: adım 8, 3 resimden 2. iPhone 7 Plus Screen Replacement: adım 8, 3 resimden 3.
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      FixBot'a Sor
      Yorum Ekle
    7. iPhone 7 Plus Screen Replacement: adım 9, 3 resimden 1. iPhone 7 Plus Screen Replacement: adım 9, 3 resimden 2. iPhone 7 Plus Screen Replacement: adım 9, 3 resimden 3.
      • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
      • Stop near the top left corner of the display.
      • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
      FixBot'a Sor
      Yorum Ekle
    8. iPhone 7 Plus Screen Replacement, Screen information: adım 10, 1 resimden 1.
      • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
      FixBot'a Sor
      Yorum Ekle
    9. iPhone 7 Plus Screen Replacement: adım 11, 3 resimden 1. iPhone 7 Plus Screen Replacement: adım 11, 3 resimden 2. iPhone 7 Plus Screen Replacement: adım 11, 3 resimden 3.
      • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      FixBot'a Sor
      Yorum Ekle
    10. iPhone 7 Plus Screen Replacement: adım 12, 2 resimden 1. iPhone 7 Plus Screen Replacement: adım 12, 2 resimden 2.
      • Gently pull up on the suction cup to lift up the bottom edge of the display.
      • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
      • Pull on the small nub on the suction cup to remove it from the front panel.
      FixBot'a Sor
      Yorum Ekle
    11. iPhone 7 Plus Screen Replacement: adım 13, 3 resimden 1. iPhone 7 Plus Screen Replacement: adım 13, 3 resimden 2. iPhone 7 Plus Screen Replacement: adım 13, 3 resimden 3.
      • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
      FixBot'a Sor
      Yorum Ekle
    12. iPhone 7 Plus Screen Replacement: adım 14, 2 resimden 1. iPhone 7 Plus Screen Replacement: adım 14, 2 resimden 2.
      • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
      FixBot'a Sor
      Yorum Ekle
    13. iPhone 7 Plus Screen Replacement: adım 15, 3 resimden 1. iPhone 7 Plus Screen Replacement: adım 15, 3 resimden 2. iPhone 7 Plus Screen Replacement: adım 15, 3 resimden 3.
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 7 Plus Screen Replacement, Battery Disconnection: adım 16, 1 resimden 1.
      • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
      • Three 1.2 mm screws
      • One 2.6 mm screw
      FixBot'a Sor
      Yorum Ekle
    2. iPhone 7 Plus Screen Replacement: adım 17, 2 resimden 1. iPhone 7 Plus Screen Replacement: adım 17, 2 resimden 2.
      • Remove the lower display cable bracket.
      FixBot'a Sor
      Yorum Ekle
    3. iPhone 7 Plus Screen Replacement: adım 18, 3 resimden 1. iPhone 7 Plus Screen Replacement: adım 18, 3 resimden 2. iPhone 7 Plus Screen Replacement: adım 18, 3 resimden 3.
      • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
      • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 7 Plus Screen Replacement, Display Assembly: adım 19, 3 resimden 1. iPhone 7 Plus Screen Replacement, Display Assembly: adım 19, 3 resimden 2. iPhone 7 Plus Screen Replacement, Display Assembly: adım 19, 3 resimden 3.
      • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
      • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
      • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
      • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
      FixBot'a Sor
      Yorum Ekle
    2. iPhone 7 Plus Screen Replacement: adım 20, 3 resimden 1. iPhone 7 Plus Screen Replacement: adım 20, 3 resimden 2. iPhone 7 Plus Screen Replacement: adım 20, 3 resimden 3.
      • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
      • One 1.3 mm screw
      • Two 1.0 mm screws
      • Remove the bracket.
      FixBot'a Sor
      Yorum Ekle
    3. iPhone 7 Plus Screen Replacement: adım 21, 2 resimden 1. iPhone 7 Plus Screen Replacement: adım 21, 2 resimden 2.
      • Disconnect the front panel sensor assembly connector from its socket on the logic board.
      • This press connector should also be reconnected one end at a time to minimize the risk of bending.
      FixBot'a Sor
      Yorum Ekle
    4. iPhone 7 Plus Screen Replacement: adım 22, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 7 Plus Screen Replacement, Home/Touch ID Sensor: adım 23, 1 resimden 1.
      • Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
      • One 1.1 mm screw
      • Three 1.3 mm screws
      • During reassembly, be careful not to overtighten these screws, or your home button may not work.
      FixBot'a Sor
      Yorum Ekle
    2. iPhone 7 Plus Screen Replacement: adım 24, 1 resimden 1.
      • Remove the bracket that secures the home/Touch ID sensor.
      FixBot'a Sor
      Yorum Ekle
    3. iPhone 7 Plus Screen Replacement: adım 25, 3 resimden 1. iPhone 7 Plus Screen Replacement: adım 25, 3 resimden 2. iPhone 7 Plus Screen Replacement: adım 25, 3 resimden 3.
      FixBot'a Sor
      Yorum Ekle
    4. iPhone 7 Plus Screen Replacement: adım 26, 2 resimden 1. iPhone 7 Plus Screen Replacement: adım 26, 2 resimden 2.
      • Carefully pry up the underlying connector and move it out of the way of the home/Touch ID cable.
      • It's very easy to damage your iPhone during this step. Work slowly and take care where you pry with your tool. If you damage the Touch ID hardware, it can only be replaced by Apple.
      • If the connector doesn't pry up easily, use a hair dryer or iOpener to heat and soften the adhesive securing the connector, and then try again.
      • Don't try to detach the connector completely—simply flip it up slightly so that the underlying home/Touch ID sensor cable can be removed.
      FixBot'a Sor
      Yorum Ekle
    5. iPhone 7 Plus Screen Replacement: adım 27, 1 resimden 1.
      • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
      • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
      FixBot'a Sor
      Yorum Ekle
    6. iPhone 7 Plus Screen Replacement: adım 28, 3 resimden 1. iPhone 7 Plus Screen Replacement: adım 28, 3 resimden 2. iPhone 7 Plus Screen Replacement: adım 28, 3 resimden 3.
      • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
      FixBot'a Sor
      Yorum Ekle
    7. iPhone 7 Plus Screen Replacement: adım 29, 1 resimden 1.
      • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
      • To reinstall, first feed the cable through the hole in the front of the display.
      • Your replacement part may come with an extra Y000 screw already installed right of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
      • Follow this guide to install replacement display adhesive on your screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
628 farklı kişi bu kılavuzu tamamladı.
Paige Reisman
24.175 İtibar
15 adet Kılavuz yazıldı
60Kılavuz Yorumları
Only the glass is broken on my screen. I don't need a new digitizer. Is there a way to just replace the glass? Seems like that would be much cheaper. Thanks!
Justin Brockbank - Yanıt Paylaş
Unfortunately, by the nature of the technology, cracked glass likely means your digitizer is out of commission (does touch still register on the cracked screen?). Below that is the LCD, and that might not be broken (if the image is fine, then the LCD is likely fine). The problem is that these components are VERY VERY difficult to separate. This makes the individual replacements a nightmare. I hate to say anything is impossible, but separating these components will feel impossible without expensive tools and extensive knowledge. It will also likely end in a mess of broken components. When there is a will, there is a way. But the separation project will demand a lot of will.
Scott Havard - Yanıt Paylaş
Our store is having trouble with the earpiece speaker working after screen repair on just the 7 Plus, not with the 7. We have tried different techniques and still get figure what we are doing wrong. Has anyone else had this problem and know the solution?
Joe Cox - Yanıt Paylaş
My earpiece speaker also won't work with new screen... this is frustrating. Any solution
Ben - Yanıt Paylaş
There are some connections for the earpiece speaker that can be a little tricky to get properly connected during reassembly. If you look at the third photo in step 22 of the iPhone 7 Plus teardown you can see four copper pads on the cable, and four protruding copper connections on the speaker. For starters, make sure that these are all clean. When reassembling, make sure that the metal pads on the cable firmly touch the metal pins on the speaker. These are actually electrical connections, and are a little tougher to seat properly because they don't snap in like press or ZIF connectors. If the metal is all lined up and pressed against each other, then electricity should be flowing and sound should result! If the earpiece speaker was not removed and this guide was followed as is, it is most likely an issue with the connectors in step 19 of this guide.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 35
Son 7 gün: 231
Son 30 gün: 891
Her zaman: 655,430
