2 TB SSD Hybrid 3.5" Hard Drive
  • 2 TB SSD Hybrid 3.5" Hard Drive / Part Only
Model #: ST2000DX002
$144,99
$144,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ürün Detayı
Açıklama
Açıklama
Replace or upgrade the hard drive in your compatible iMac with this part.
Not
To ensure compatibility with the 2009 and 2010 21.5" or 27" iMac, the replacement hard drive must be of the same brand as the original. The model number of the hard drive does not matter as long as the brand matches. 2011 and up iMacs cannot be supported by us.
Not
Works only in iMac G5s and Intel iMacs (excluding 2011 and up 21.5" and 27" models).
Uyumluluk
iMac G5 17" Model A1058
1.8 GHz (EMC No. 2055)
2 GHz
iMac G5 17" Model A1144
1.9 GHz
iMac G5 20" Model A1076
1.8 GHz
2 GHz
iMac G5 20" Model A1145
2.1 GHz
iMac Intel 17"
1.83 GHz (EMC No. 2104)
1.83 GHz (EMC No. 2110)
1.83 GHz (EMC No. 2124)
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2 GHz
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
iMac Intel 20" EMC 2266
2.66 GHz
iMac Intel 21.5" EMC 2308
EMC 2308 3.06 GHz
EMC 2308 3.33 GHz
iMac Intel 21.5" EMC 2389
EMC 2389 3.06 GHz
EMC 2389 3.2 GHz
EMC 2389 3.6 GHz
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2211)
3.06 GHz (EMC No. 2211)
iMac Intel 24" EMC 2267
2.66 GHz
2.93 GHz
3.06 GHz
iMac Intel 27" EMC 2309 and 2374
2.66 GHz (Late 2009)
2.8 GHz (Late 2009)
3.06 GHz (Late 2009)
3.33 GHz (Late 2009)
iMac Intel 27" EMC 2390
2.8 GHz (Mid 2010)
2.93 GHz (Mid 2010)
3.2 GHz (Mid 2010)
3.6 GHz (Mid 2010)
Power Mac G5
1.6 GHz
1.8 GHz (EMC No. 1969)
1.8 GHz (Late 2004)
1.8 GHz Dual (EMC No. 1969)
1.8 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 1969)
2.0 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 2023)
2.0 GHz Dual (EMC No. 2061)
2.3 GHz Dual (EMC No. 2023)
2.3 GHz Dual (EMC No. 2061)
2.5 GHz Dual (EMC No. 1969C)
2.5 GHz Quad
2.7 GHz Dual
13 cihaz daha göster
Onarım hikayeleri
Kullanıcı avatarı
patrickhonings's Story Photo #482516
patrickhonings's Story Photo #482515
Sorunum
HDD-failure
Tamirim
Slow tempo about an hour. No problems and no mistakes, thanks to the guide of Brittany McCrigler: iMac Intel 24" EMC 2134 and 2211 Hard Drive Replacement
Önerim
The only thing that I didn't follow, was step 11 "disconnect the LCD cable by pulling down". I disconnected it from the lcd-screen itsel . . .
Kullanıcı avatarı
Sorunum
I had a 1TB Seagate drive that was getting increasingly slower and was making an intermittent grinding noise while my Mac was asleep.
Tamirim
The repair guide was spot on!!! Be sure to read all of the comments with the associated steps, as they can be very insightful! From start to finish the repair took les . . .
Kullanıcı avatarı
Sorunum
2008 iMac was getting increasingly slow. No problems diagnosed—it was just getting old, taking ages to open applications—and driving me nuts. I was nervous about putting an SSD into my iMac—having to remove the screen, etc.—seemed a bit daunting.
Tamirim
Had the whole job done within an hour. So much . . .
Kullanıcı avatarı
Sorunum
After loading Yosemite and more and more documents and programs the imac mid 2010 worked in some parts to slow and with irregularities. So in a first step I doubled the RAM from 4 to 8 GB. The actual next step was to increase the storage capacity from a 0.5 HD to a 2 TB SSD Hybrid 3.5".
Tamirim
I worked me t . . .
Kullanıcı avatarı
Sorunum
S.MA.R.T read error would not let me upgrade to OS X Yosemite.
Tamirim
Repair was straight forward. I nearly ruined the Monitor Connection when I first removed the monitor to check the HDD, The instructions given on the guide are clear, I just misread them. Second time around I didn't remove the monitor.
Önerim
If y . . .
Kullanıcı avatarı
Sorunum
The problem was I listened to my computer experts in the repair business. Approximately 3 months after my warranty on IMAX ran out my computer completely shut down. Being most computer illiterate and needing it for my business I immediately took my IMAX into the computer experts, a high profile comp . . .
Daha fazla göster
