Ana içeriğe geç
Google Pixel 4 Battery Replacement
Neye ihtiyacın var
  1. Google Pixel 4 Battery Replacement, Heat the back panel glass: adım 1, 1 resimden 1.
    • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Google Pixel 4 Battery Replacement, Apply a suction cup: adım 2, 2 resimden 1. Google Pixel 4 Battery Replacement, Apply a suction cup: adım 2, 2 resimden 2.
    • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
  3. Google Pixel 4 Battery Replacement, Insert an opening pick: adım 3, 2 resimden 1. Google Pixel 4 Battery Replacement, Insert an opening pick: adım 3, 2 resimden 2.
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  4. Google Pixel 4 Battery Replacement, Begin to slice the adhesive: adım 4, 3 resimden 1. Google Pixel 4 Battery Replacement, Begin to slice the adhesive: adım 4, 3 resimden 2. Google Pixel 4 Battery Replacement, Begin to slice the adhesive: adım 4, 3 resimden 3.
    • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
    • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  5. Google Pixel 4 Battery Replacement, Slice the lefthand-side adhesive: adım 5, 1 resimden 1.
    • Prepare an iOpener and apply it on the left edge of the phone for one minute.
  6. Google Pixel 4 Battery Replacement: adım 6, 2 resimden 1. Google Pixel 4 Battery Replacement: adım 6, 2 resimden 2.
    • Insert a second opening pick underneath the back panel directly over the charge port.
    • Slide the opening pick to the bottom left corner of the phone.
  7. Google Pixel 4 Battery Replacement: adım 7, 2 resimden 1. Google Pixel 4 Battery Replacement: adım 7, 2 resimden 2.
    • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
  8. Google Pixel 4 Battery Replacement, Slice righthand-side adhesive: adım 8, 1 resimden 1.
    • Prepare an iOpener and apply it on the right edge of the phone for one minute.
  9. Google Pixel 4 Battery Replacement: adım 9, 3 resimden 1. Google Pixel 4 Battery Replacement: adım 9, 3 resimden 2. Google Pixel 4 Battery Replacement: adım 9, 3 resimden 3.
    • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
    • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
    • Stop when you reach the top right corner, and leave the pick inserted.
  10. Google Pixel 4 Battery Replacement, Slice the top-side adhesive: adım 10, 2 resimden 1. Google Pixel 4 Battery Replacement, Slice the top-side adhesive: adım 10, 2 resimden 2.
    • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
  11. Google Pixel 4 Battery Replacement, Lift up the back panel: adım 11, 3 resimden 1. Google Pixel 4 Battery Replacement, Lift up the back panel: adım 11, 3 resimden 2. Google Pixel 4 Battery Replacement, Lift up the back panel: adım 11, 3 resimden 3.
    • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
    • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
  12. Google Pixel 4 Battery Replacement: adım 12, 2 resimden 1. Google Pixel 4 Battery Replacement: adım 12, 2 resimden 2.
    • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
    • During reassembly, this is a good point to power on your phone and test all functions before re-sealing the back panel. Be sure to power your phone back down completely before you continue working.
  13. Google Pixel 4 Battery Replacement, Disconnect the battery: adım 13, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Remove the five T3 Torx screws securing the battery connector shield:
    • Four 4.0 mm screws
    • One 2.1 mm screw
  14. Google Pixel 4 Battery Replacement: adım 14, 2 resimden 1. Google Pixel 4 Battery Replacement: adım 14, 2 resimden 2.
    • Use a pair of tweezers to remove the battery connector shield.
  15. Google Pixel 4 Battery Replacement: adım 15, 2 resimden 1. Google Pixel 4 Battery Replacement: adım 15, 2 resimden 2.
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  16. Google Pixel 4 Battery Replacement: adım 16, 2 resimden 1. Google Pixel 4 Battery Replacement: adım 16, 2 resimden 2.
    • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
  17. Google Pixel 4 Battery Replacement, Disconnect the back panel connector: adım 17, 1 resimden 1.
    • Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
  18. Google Pixel 4 Battery Replacement: adım 18, 2 resimden 1. Google Pixel 4 Battery Replacement: adım 18, 2 resimden 2.
    • Use a pair of tweezers to remove the back panel connector cover.
  19. Google Pixel 4 Battery Replacement: adım 19, 2 resimden 1. Google Pixel 4 Battery Replacement: adım 19, 2 resimden 2.
    • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
  20. Google Pixel 4 Battery Replacement, Remove the back panel: adım 20, 1 resimden 1.
    • Remove the back panel.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
    • Follow this guide if you are using a pre-cut adhesive card.
  21. Google Pixel 4 Battery Replacement, Remove the adhesive strips: adım 21, 3 resimden 1. Google Pixel 4 Battery Replacement, Remove the adhesive strips: adım 21, 3 resimden 2. Google Pixel 4 Battery Replacement, Remove the adhesive strips: adım 21, 3 resimden 3.
    • Pull on the yellow pull tab of the adhesive strip with steady force.
    • If the adhesive becomes hard to pull, you can roll it around a spudger and continue pulling.
    • Continue firmly pulling up on the adhesive strip with constant force. If you're using a spudger, spin it every so often to keep the exposed section of the pull tab as short as possible.
    • This may take a lot of force.
    • These adhesive pull tabs are very prone to snapping in half during this process. Pull as slowly as possible.
    • If the adhesive pull tabs are not stretching, fill a plastic dropper or syringe with high concentration (>90%) isopropyl alcohol and apply a few drops under the left edge of the battery. Give the alcohol a minute to weaken the battery adhesive.
    • Continue this process for each of the three pull tabs, until all are either out or have snapped in half.
  22. Google Pixel 4 Battery Replacement, Remove the battery: adım 22, 2 resimden 1. Google Pixel 4 Battery Replacement, Remove the battery: adım 22, 2 resimden 2.
    • If the battery tabs snapped during removal, insert an opening pick on the upper right edge of the battery, slicing the adhesive underneath.
    • Even if you successfully removed all three adhesive pull tabs, using an opening pick to dislodge the battery may be helpful.
    • Don't insert the opening pick on or anywhere below the grip sensor cable, as the pick can damage the charge port flex cable located underneath the battery.
  23. Google Pixel 4 Battery Replacement: adım 23, 2 resimden 1. Google Pixel 4 Battery Replacement: adım 23, 2 resimden 2.
    Tesa 61395 Tape
    $8.95
    • Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
    • Lift the battery up and away from the phone to remove it. You may need to peel the battery away from any leftover adhesive tabs.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off with a lint-free cloth or allow it to air dry before installing your battery.
    • To install a replacement battery:
    • If you're using stretch release adhesive, apply them onto the battery. Otherwise, apply some double-sided tape, or pre-cut adhesive strips in the phone's battery well, being careful not to cover the charge port flex cable. Peel away any tape liners to expose the adhesive.
    • Temporarily re-connect the battery's connector to the motherboard socket. This ensures that the battery is properly positioned.
    • Lay the battery in place and press firmly.
    • Disconnect the battery connector from its motherboard socket and resume re-assembly.
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
64 farklı kişi bu kılavuzu tamamladı.
Carsten Frauenheim
157.639 İtibar
439 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.971 adet Kılavuz yazıldı
32Kılavuz Yorumları
If you are gonna sell me your tool kit at least supply a *!&$!&$^ T3 Tork bit to complete the job.
Nicholas Smyth - Yanıt
Hi Nicholas,
The iFixit kit should definitely have a T3 bit. Please contact our customer support and we will get the issue resolved!
Arthur Shi -
When you put it back together do you need to reheat the adhesive?
Keith P - Yanıt
Hey Keith,
When putting the phone back together and reinstalling the back panel, we recommend removing the old adhesive and installing new adhesive. The Pixel 4’s back panel adhesive can be found here, and a guide on how to install it can be found here!
If you’d like to reuse your old adhesive, try removing any large uneven chunks, reheat the adhesive, and press the back panel back into place.
Carsten Frauenheim -
Does the kit include replacement battery adhesive strips? I don’t recall seeing it in mine.
Nikki Chan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 23
Son 7 gün: 146
Son 30 gün: 796
Her zaman: 91,647
