Ana içeriğe geç
Google Pixel 6 Pro Battery Replacement
Neye ihtiyacın var
  1. Google Pixel 6 Pro Battery Replacement, Safety precautions: adım 1, 2 resimden 1. Google Pixel 6 Pro Battery Replacement, Safety precautions: adım 1, 2 resimden 2.
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
    Please, how can I turn it off when screen is broken?
    Thubbe - Yanıt
  2. Google Pixel 6 Pro Battery Replacement, Anti-Clamp instructions: adım 2, 3 resimden 1. Google Pixel 6 Pro Battery Replacement, Anti-Clamp instructions: adım 2, 3 resimden 2. Google Pixel 6 Pro Battery Replacement, Anti-Clamp instructions: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. Google Pixel 6 Pro Battery Replacement: adım 3, 3 resimden 1. Google Pixel 6 Pro Battery Replacement: adım 3, 3 resimden 2. Google Pixel 6 Pro Battery Replacement: adım 3, 3 resimden 3.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  4. Google Pixel 6 Pro Battery Replacement: adım 4, 3 resimden 1. Google Pixel 6 Pro Battery Replacement: adım 4, 3 resimden 2. Google Pixel 6 Pro Battery Replacement: adım 4, 3 resimden 3.
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  5. Google Pixel 6 Pro Battery Replacement, Loosen the display adhesive: adım 5, 1 resimden 1.
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    Do you think that removing the SIM card, also will be a wise step? I'm pretty sure that heating the SIM card is not a good idea.
    Emil Teofanov - Yanıt
    The SIM is probably no more sensitive than the rest of the phone.
    ScottMcNay - Yanıt
    What does "be sure to have replacement adhesives for both the rear glass and the screen." I only had one it didn't mention another one?
    alberte - Yanıt
    I didn't have the replacement adhesive for rear glass nor the 2 sided tape they talk about when putting it back together. It's Sunday, so I don't expect an answer. I decided to go ahead and work up until that point
    StlrFan -
  6. Google Pixel 6 Pro Battery Replacement, Insert an opening pick: adım 6, 3 resimden 1. Google Pixel 6 Pro Battery Replacement, Insert an opening pick: adım 6, 3 resimden 2. Google Pixel 6 Pro Battery Replacement, Insert an opening pick: adım 6, 3 resimden 3.
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the screen.
    • Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
    • Insert an opening pick into the gap between the screen frame and the phone assembly.
    • Make sure to insert your opening pick in the right position to avoid separating the screen from its safety frame instead of the phone assembly.
    • Slide the opening pick to the bottom left corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  7. Google Pixel 6 Pro Battery Replacement, Slice the adhesive: adım 7, 2 resimden 1. Google Pixel 6 Pro Battery Replacement, Slice the adhesive: adım 7, 2 resimden 2.
    • Insert a second opening pick at the bottom edge and slide it to the bottom right corner of the screen to slice the adhesive.
  8. Google Pixel 6 Pro Battery Replacement: adım 8, 3 resimden 1. Google Pixel 6 Pro Battery Replacement: adım 8, 3 resimden 2. Google Pixel 6 Pro Battery Replacement: adım 8, 3 resimden 3.
    • The screen of the Google Pixel 6 Pro is not only held in place by adhesive but also small plastic pins. In case your opening pick gets blocked during the screen removal procedure it means you inserted your pick too deep underneath the screen. Only insert the tip of the opening pick (~3-4 mm) when slicing the display adhesive.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  9. Google Pixel 6 Pro Battery Replacement: adım 9, 2 resimden 1. Google Pixel 6 Pro Battery Replacement: adım 9, 2 resimden 2.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2-3 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  10. Google Pixel 6 Pro Battery Replacement: adım 10, 2 resimden 1. Google Pixel 6 Pro Battery Replacement: adım 10, 2 resimden 2.
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly.
  11. Google Pixel 6 Pro Battery Replacement, Open up the phone assembly: adım 11, 3 resimden 1. Google Pixel 6 Pro Battery Replacement, Open up the phone assembly: adım 11, 3 resimden 2. Google Pixel 6 Pro Battery Replacement, Open up the phone assembly: adım 11, 3 resimden 3.
    • Avoid straining the display cable during the following procedure.
    • Carefully fold the screen to the left side of the phone assembly like you would open the front cover of a book.
    I don't know if it's an earlier or later design, but I am combining 2 phones (1 crushed glass but operational into the casing of one that quit functioning but has good glass) and on both, the ribbon cable for the LCD is a tiny bit too short to fold out flat like this. If you are working on one like mine, extreme care must be taken while holding the LCD up while simultaneously trying to plug the cable back into that very small recessed socket. Almost like you need 3 hands or robot fingers...
    Stephen P. Thurman - Yanıt
    I also felt that the cable was too short to fully open like a book, however it is possible that the hinge side of my screen was still pressed in to the adhesive and I did not properly open the screen or I was being overly cautious. Be careful on first approach either way.
    Nick Harris - Yanıt
  12. Google Pixel 6 Pro Battery Replacement, Unfasten the display bracket screw: adım 12, 1 resimden 1.
    Magnetic Project Mat
    $19.95
    • While the Pixel 6 Pro uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx T3 screwdriver to remove the 2.0 mm-long 3IP Torx Plus screw securing the display cable metal bracket.
    I don't know if it's an earlier or later design, but I am combining 2 phones (1 crushed glass but operational into the casing of one that quit functioning but has good glass), and on both, the metal holder plate shown here is simply spring connected and that 2mm screw is instead slightly off to the side as part of the aluminum bracket's screws.
    Does anyone know the exact dimensions/specifications of this screw? I've misplaced mine and need to find a replacement.
    Alternatively, what are the chances the display cable might come loose if I install the display bracket without screwing it in? I would expect there's not too much clearance between the bracket and the display, so it should still mostly hold in place once the display is installed.
    Chris Gutkowski - Yanıt
  13. Google Pixel 6 Pro Battery Replacement, Remove the display cable bracket: adım 13, 2 resimden 1. Google Pixel 6 Pro Battery Replacement, Remove the display cable bracket: adım 13, 2 resimden 2.
    • Use a pair of tweezers to remove the metal bracket sitting on top of the display cable connector.
    • Make sure to keep this component to reinstall it during reassembly.
  14. Google Pixel 6 Pro Battery Replacement, Disconnect the display cable: adım 14, 2 resimden 1. Google Pixel 6 Pro Battery Replacement, Disconnect the display cable: adım 14, 2 resimden 2.
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
    Reconnecting the display port cable was the longest part of my first repair. It helped when I carefully folded the ribbon connector at each end to get the most length out of it and bent it into the proper shape to hover just right over the small port. I lightly bent the cable back at the base and at the connector end.
    This connector feels delicate, so it definitely made me take my time and be cautious. The snap is unmistakable, but be careful afterward as you're on a short leash again. I folded the new screen closed like a book and snapped it into place easily.
    Nick Harris - Yanıt
  15. Google Pixel 6 Pro Battery Replacement, Screen information: adım 15, 1 resimden 1.
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  16. Google Pixel 6 Pro Battery Replacement, Remove the screen: adım 16, 2 resimden 1. Google Pixel 6 Pro Battery Replacement, Remove the screen: adım 16, 2 resimden 2.
    • Remove the screen.
    • During reassembly:
    • If you replaced the screen, check the screen's front-facing camera hole and sensor cutout for any protective liners. Remove these liners before you close the phone up.
    • Remember to reinstall the display cable bracket.
    • This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide in case you're using a pre-cut adhesive card.
    • If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
    Before reassembly, clean around the edge of where the screen was, to remove any debris that may have been captured.
    ScottMcNay - Yanıt
    After reassembly, the fingerprint sensor appears to be a common issue with new screens:
    * Go to https://pixelrepair.withgoogle.com/udfps on a computer.
    * If using Windows, click the help link to install the USB software. After installing, restart the computer and return to https://pixelrepair.withgoogle.com/udfps.
    * Follow the steps given to install the fingerprint calibration software.
    * Restart the phone.
    ScottMcNay - Yanıt
    "Be sure to remove all adhesive liners from your replacement screen. Check the selfie camera recess and make sure you've removed the liner there."
    A photo with blue highlight square would've been helpful here...also it's very easy to miss this instruction as you'd be on the adhesive page...
    alberte - Yanıt
    I did take the selfie camera liner this is a bad problem
    Austin Curtis -
    This is very true. I only realized after turning on my phone the next day that the film blocking the front camera is still there. I had to re-open the screen to remove that black film, which was not obvious at all. I only opened the upper half to remove the film, hopefully the adhesive is not compromised too much...
    Esmerando Escoto -
    All went well except for the adhesive. It was simply too small so when Iaid it down it was fine on one side as well as the top and bottom, but the other side required me to pull it over. As it is quite sticky, it bunched up. I cut out part of it and used my own double-sided tape to secure part of it. Otherwise, it was great. Thanks to those who made special note of the cover on the selfie camera window, and the procedure to set up the new fingerprint scanner.
    Arnold Bosman - Yanıt
    They do not highlight the part that needs to be removed from the new screen, this should be added as the part looks and feels like it is a part of the new screen and removing it could break the new screen. So make sure you remove the selfie screen camera cover even if it looks and feels like there is not one there, it's there.
    Nick Harris - Yanıt
    I ordered Google Pixel 6 pro- fix kit in IFIXIT. I followed the steps mentioned in the repair guide. During repair the finger print symbol is blinking in the screen. I thought it would get set when i do re calibration as mentioned in repair guide but it did not worked. It displays " Can´t use finger print sensor Visit a repair provider or g.co/pixel/fingerprintunlock". Does anyone have same problem??
    Surendra Reddy Velagala - Yanıt
    You have to go to that link and you can re calibrate the new finger print scanner by logging into your account and approving it.
    dot Ducky -
    New Finger Print Reader
    Boot into fast boot and connect your pixel to your pc
    On your PC go to pixelrepair.withgoogle.com/udfps
    Follow the Prompts
    dot Ducky -
    Replacement process went smoothly. I reattached the screen after seating the connector. No sign its working. Just black blank screen. However text and notification sounds still coming through. Even receiving calls. etc on que. I know the phone works, just not the screen.
    I figure maybe I didnt seat the connector all the way so I break the adhesive liner (figuring I'll buy another and apply again) and this time I clip in the connector for sure. Still nothing on the screen.
    What can I do? Is the screen defective?
    If phone is working should I see the display after the connector is seated but the phone still open? Or does the screen need to be seated all the way in the case to turn on? The screen does not display anything in either state by the way...
    As an aside, your instructions are so detailed until the point where the screen needs to connect and seat. It would helpful to get more pointers for this final step...
    Chobby - Yanıt
    It's so frustrating that paper instructions are not included considering I'm about to pull the screen off my phone. It's also very frustrating that I have to load and read multiple sub instructions in the middle of the main instructions, just include all instructions in one booklet and include the booklet in the kit.
    Jeremiah Miller - Yanıt
  17. Google Pixel 6 Pro Battery Replacement, Loosen the graphite film adhesive: adım 17, 1 resimden 1.
    • Apply a heated iOpener or a heat gun to the rear glass to loosen the adhesive underneath the graphite films on top of the battery. Apply the iOpener for at least two minutes.
    • Don't apply heat directly onto the battery. It is susceptible to heat damage and could cause a thermal event.
    This seems contradictory: the step basically says to heat the graphite film through the battery (from below) instead of heating the graphite film itself, and then says "don't heat the battery directly". Sounds like a thermometer test is needed.
    ScottMcNay - Yanıt
  18. Google Pixel 6 Pro Battery Replacement, Remove the graphite film: adım 18, 3 resimden 1. Google Pixel 6 Pro Battery Replacement, Remove the graphite film: adım 18, 3 resimden 2. Google Pixel 6 Pro Battery Replacement, Remove the graphite film: adım 18, 3 resimden 3.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the bottom edge of the battery and the motherboard shield.
    • Remove the graphite film.
    The film delaminates easily, so be careful.
    If you are using an iFixit replacement battery, it comes with replacement graphite film for the bottom and left.
    ScottMcNay - Yanıt
    so do you need this film?? if it is damaged, can you use some sort of tape, or does it have to be this graphite film?
    Michael Carton - Yanıt
  19. Google Pixel 6 Pro Battery Replacement, Peel off the graphite film: adım 19, 2 resimden 1. Google Pixel 6 Pro Battery Replacement, Peel off the graphite film: adım 19, 2 resimden 2.
    • If you want to replace your battery it's enough to peel the bottom part of the graphite film off the battery. If you want to replace your rear camera you need to remove it completely. In case you only want to replace the earpiece speaker or the front facing camera, you can leave it in its place.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the top right corner of the battery.
    • Fold the graphite film in direction of the selfie camera to get free access to the battery.
    バッテリーとカメラユニットの間に隙間があります。そこからピンセットを差し込んでグラファイトフィルムを剥がすのが最も安全ですね。
    AKINORI HARADA - Yanıt
    It should be highlighted that this graphite film does not have a replacement and so should only be peeled back. I know it says peel vs. remove in the title, but going through people (myself as an example) might not read the title portion.
    genericuser256 - Yanıt
  20. Google Pixel 6 Pro Battery Replacement, Remove the graphite film: adım 20, 3 resimden 1. Google Pixel 6 Pro Battery Replacement, Remove the graphite film: adım 20, 3 resimden 2. Google Pixel 6 Pro Battery Replacement, Remove the graphite film: adım 20, 3 resimden 3.
    • If the graphite film becomes hard to peel off, it has most likely cooled down. Reapply your iOpener or heat gun to the rear glass for 1-2 minutes to reheat it.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the left edge of the battery and the motherboard shield.
  21. Google Pixel 6 Pro Battery Replacement, Unfasten the charging port bracket screws: adım 21, 1 resimden 1.
    • Use a Torx T3 screwdriver to remove the two 5.1 mm-long 3IP Torx Plus screws securing the charging port metal bracket.
    Use the Torx T3...
    (slight reminder that it's the same bit as used already)
    ScottMcNay - Yanıt
  22. Google Pixel 6 Pro Battery Replacement, Remove the charging port bracket: adım 22, 2 resimden 1. Google Pixel 6 Pro Battery Replacement, Remove the charging port bracket: adım 22, 2 resimden 2.
    • Use a pair of tweezers to remove the charging port bracket.
  23. Google Pixel 6 Pro Battery Replacement, Unfasten the motherboard cover screws: adım 23, 1 resimden 1.
    • Use a Torx T3 screwdriver to remove the five 5.1 mm-long 3IP Torx Plus screws securing the motherboard cover.
    Use the Torx T3...
    ScottMcNay - Yanıt
  24. Google Pixel 6 Pro Battery Replacement, Remove the motherboard cover: adım 24, 2 resimden 1. Google Pixel 6 Pro Battery Replacement, Remove the motherboard cover: adım 24, 2 resimden 2.
    • Use a pair of tweezers or your fingers to carefully remove the motherboard cover.
  25. Google Pixel 6 Pro Battery Replacement, Disconnect the battery cable: adım 25, 2 resimden 1. Google Pixel 6 Pro Battery Replacement, Disconnect the battery cable: adım 25, 2 resimden 2.
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    On some models, there is another cable, which crosses the battery (which accounts for the odd diagonal shape of the upper-left graphite film), which also needs to be removed.
    ScottMcNay - Yanıt
  26. Google Pixel 6 Pro Battery Replacement, Apply high concentration isopropyl alcohol: adım 26, 2 resimden 1. Google Pixel 6 Pro Battery Replacement, Apply high concentration isopropyl alcohol: adım 26, 2 resimden 2.
    • There's only adhesive underneath the top and bottom areas of the battery and not underneath the center. The see-through plastic strip around the center of the battery is not especially useful during the removal procedure. Feel free to remove it for easier handling by opening its adhesive seal and pulling it out from underneath the battery.
    • Bring your phone assembly to an ~45° angle.
    • This helps to spread the isopropyl alcohol evenly in the following step. You can hold the phone in one hand and apply the alcohol with the other or secure your suction handle to the rear glass and use its handle as a stand for your phone.
    • Apply a few drops of high concentration (over 90%) isopropyl alcohol into the gap between the motherboard and the top left and bottom left corner of the battery.
    At least in Germany, the battery replacement kit does not come with the isopropyl alcohol included, only a pipette is included. Perhaps for legal reasons, not sure. I had a bottle at hand but that might not be the case for everyone.
    Patrick - Yanıt
  27. Google Pixel 6 Pro Battery Replacement, Insert an opening pick: adım 27, 3 resimden 1. Google Pixel 6 Pro Battery Replacement, Insert an opening pick: adım 27, 3 resimden 2. Google Pixel 6 Pro Battery Replacement, Insert an opening pick: adım 27, 3 resimden 3.
    • Insert an opening pick into the gap between the top right corner of the battery and the midframe.
    • Use your opening pick to pry up the battery by tilting your pick downwards and widen the gap between battery and the midframe.
  28. Google Pixel 6 Pro Battery Replacement, Widen the gap: adım 28, 2 resimden 1. Google Pixel 6 Pro Battery Replacement, Widen the gap: adım 28, 2 resimden 2.
    • Work your way along the right edge of the battery and widen the gap between battery and midframe until you have enough space to insert a plastic card.
    Typo: "Work you".
    ScottMcNay - Yanıt
  29. Google Pixel 6 Pro Battery Replacement, Insert a plastic card: adım 29, 3 resimden 1. Google Pixel 6 Pro Battery Replacement, Insert a plastic card: adım 29, 3 resimden 2. Google Pixel 6 Pro Battery Replacement, Insert a plastic card: adım 29, 3 resimden 3.
    Plastic Cards
    $2.99
    • If you can't manage to remove the battery by only using high concentration isopropyl alcohol (over 90%) you can try a combination with heat. In this case prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath the battery.
    • Insert a plastic card underneath the right edge of the battery.
    • Slide the plastic card along the right edge of the battery to separate it from the midframe.
    • Use your plastic card to pry up the battery.
  30. Google Pixel 6 Pro Battery Replacement, Remove the battery: adım 30, 2 resimden 1. Google Pixel 6 Pro Battery Replacement, Remove the battery: adım 30, 2 resimden 2.
    • Peel the battery off the remaining adhesive.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
    • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
20 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
232.089 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.840 adet Kılavuz yazıldı
9Kılavuz Yorumları
White flickering screen after battery replacement. I checked all the connections and it seemed that they were all right.
Svitlana Kennedy - Yanıt
Same AF, got to take it back apart and try to reconnect my screen
James Hatch -
I found an important and critical piece missing in this guide. In steps 6 through 10 your goal is to get the screen separate from the phone chassis. While they do mention to be sensitive around the front camera the guide doesn't mention that you also need to be sensitive around the left-side center of the phone as well. This is where the screen cable connects to the motherboard. I wouldn't even put a pick or tool anywhere near that area. I didn't put too much pressure or anything but it looks like I somehow hit that cable while removing the screen. I don't see any damage to the cable or the screen but when I turn the phone on my screen now outputs several always on bright pink and green lines running through it indicating something went wrong here. So I went from replacing the battery to having to replace the screen too. Between the cost of the new battery and a new screen it probably would've been cheaper to just buy another used Pixel 6 Pro.
Dan - Yanıt
Sorry, I have a question, did you change the screen?
RICCC -
I went through this process successfully; Several notes;
1. As Dan Mentions, careful of the screen cable, but also be careful of the alignment pins top left and bottom right of the screen - they block the insertion of the pry picks.
2. A hair dryer (750W) on low speed, high heat, works a charm and is much faster and easier than the iOpener.
3. There's an additional wiring ribbon cutting across the battery from top middle to left-middle. It can be easily disconnected, but it isn't shown on the pictures, nor mentioned in the instructions.
4. When you've reconnected the screen wiring ribbon, it says "Don't touch the screen as it needs to calibrate." Mine did nothing. It just turned on and presented the login screen. I used my fingerprint and the device worked. So I powered off and proceeded to affix the screen to the adhesives.
5. Once everything was assembled, I powered on and the finger print reader stopped working (was undetectable). There is a solution to this, but it really should be in this Guide.
Marc Aniballi - Yanıt
@5. And what is the solution to the finger print reader not working? Could you please just link to it?
Update, it's mentioned in the respective comment: https://de.ifixit.com/Anleitung/Google+P...
quak -
Was replacing the screen, decided I might as well replace the battery while I was at it. That seems to be working fine (including fingerprint sensor) but now the loudspeaker sounds like it's underwater. Not sure how that happened. 😞
Andrew - Yanıt
I actually just ran into the same issue! I've ordered another set of adhesive and replacement graphite stickers. Going to see if I can figure out what's up.
Kyle -
Now after popping the new screen off, I seem to have damaged the new screen and the speaker is just hosed. I think I've botched this whole project. :(
Kyle -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 48
Son 7 gün: 323
Son 30 gün: 1,359
Her zaman: 49,759
