Ana içeriğe geç
Google Pixel 7 Battery Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch ve 6 diğer katkıda bulunanlar
En son July 10, 2024 tarihinde güncellendi
1 - 2 saat
Orta
Öne Çıkan Kılavuzlar
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the battery in your Google Pixel 7.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Caution: The Pixel 7 contains class 1 lasers. Disassembly could result in exposure to invisible infrared laser emissions.
Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
You'll need replacement adhesive in order to complete this repair.
Neye ihtiyacın var
Tamir Seti
Bu kit, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
  1. Google Pixel 7 Battery Replacement, Safety precautions: adım 1, 2 resimden 1. Google Pixel 7 Battery Replacement, Safety precautions: adım 1, 2 resimden 2.
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
    i replaced my pixel 7 screen, I noticed that my proximity sensor is no longer working, I have tried to calibrate it using 3rd part apps and it ddisnt work,i tried using developer settings to switch the proximity sensor and i also updated my android version...all these didnt work
    Ian - Yanıt
    If you can't power down your device because the screen is cracked (in my case, the AMOLED didn't light up at all anymore) and the touch is broken, you can also press power, volume up, and volume down all at the same time for 20-30 seconds. This will actually power off the phone, and not restart it (for that, you would hold the power button and volume up for a while).
    Max - Yanıt
  2. Google Pixel 7 Battery Replacement, Screen removal information: adım 2, 3 resimden 1. Google Pixel 7 Battery Replacement, Screen removal information: adım 2, 3 resimden 2. Google Pixel 7 Battery Replacement, Screen removal information: adım 2, 3 resimden 3.
    • The screen of the Google Pixel 7 is held in place by a safety frame of plastic clips and adhesive.
    • During the removal procedure, make sure to insert your opening picks under the safety frame to avoid separating it from the screen.
    • Only insert the pick up to ~3.5 mm during the removal procedure to avoid damaging the internals and to avoid interfering with the plastic clips.
    • There are several plastic clips around the whole screen. In case your opening pick gets blocked during the screen removal procedure it means you inserted your pick too deep underneath the screen.
    I accidentally removed the screen from the safety frame. Thankfully, this wasn't a big issue since my screen was broken anyway. In that case, you can still easily pop up the frame, and carefully remove the remaining glue with some pliers afterward.
    Max - Yanıt
    "During the removal procedure, make sure to insert your opening picks in the right position"
    But then don't share what that position is, or even how to start.
    Great way to start the guide. Fills me with so much confidence in doing a $150 repair.
    Off tonyoutube to find someone who did q better job at a guide.
    HA Halleman - Yanıt
    Hi there! I apologize that the instructions were not clear. I have updated the guide to clarify where the right place to insert the opening picks.
    Alex Diaz-Kokaisl -
  3. Google Pixel 7 Battery Replacement, Anti-Clamp instructions: adım 3, 3 resimden 1. Google Pixel 7 Battery Replacement, Anti-Clamp instructions: adım 3, 3 resimden 2. Google Pixel 7 Battery Replacement, Anti-Clamp instructions: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. Google Pixel 7 Battery Replacement: adım 4, 3 resimden 1. Google Pixel 7 Battery Replacement: adım 4, 3 resimden 2. Google Pixel 7 Battery Replacement: adım 4, 3 resimden 3.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. Google Pixel 7 Battery Replacement: adım 5, 3 resimden 1. Google Pixel 7 Battery Replacement: adım 5, 3 resimden 2. Google Pixel 7 Battery Replacement: adım 5, 3 resimden 3.
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. Google Pixel 7 Battery Replacement, Loosen the display adhesive: adım 6, 1 resimden 1.
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
    This guide is a bit all over the place. Most of the previous pictures show the iOpener being placed on the left side first (with the device having the camera facing upwards)
    However this pictures shows placing the iOpener on the right side. Does it matter? Is there a best practice side to pry first?
    Zachary (Zach) - Yanıt
    I left my iOpener on the phone for a out 5 or more minutes, but the bag should have been hotter I think (I put it in the microwave about 35 seconds, 30 is recommended starting amount). I highly suggest making sure the phone is well heated before taking the screen off because I think that is the only way to make the adhesive easier to get off. I spent probably 30-45 minutes just scraping off adhesive with the tweezers.
    Samuel Y - Yanıt
  7. Google Pixel 7 Battery Replacement, Insert an opening pick: adım 7, 3 resimden 1. Google Pixel 7 Battery Replacement, Insert an opening pick: adım 7, 3 resimden 2. Google Pixel 7 Battery Replacement, Insert an opening pick: adım 7, 3 resimden 3.
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the bottom edge and try again.
    • Insert an opening pick into the gap.
    If you're having trouble getting the first pick in, try a different hand position than what is shown. Grip the suction cup's handle with your index finger, and keep your thumb and middle finger on either side of the screen. Choose a forgiving surface underneath in case you slip. Then hold firmly and keep it stable (no need to really push down). Just be prying it open deliberately and evenly. Then take your pick and use gentle prodding, experimenting with your angle and pressure, feel around. That should be all you need to get in.
    Orin Zebest - Yanıt
  8. Google Pixel 7 Battery Replacement, Prevent damage to your phone: adım 8, 2 resimden 1. Google Pixel 7 Battery Replacement, Prevent damage to your phone: adım 8, 2 resimden 2.
    • To avoid damaging your phone, don't insert your pick more than ~2.5 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
  9. Google Pixel 7 Battery Replacement, Slice the bottom edge adhesive: adım 9, 2 resimden 1. Google Pixel 7 Battery Replacement, Slice the bottom edge adhesive: adım 9, 2 resimden 2.
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  10. Google Pixel 7 Battery Replacement: adım 10, 2 resimden 1. Google Pixel 7 Battery Replacement: adım 10, 2 resimden 2.
    • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
  11. Google Pixel 7 Battery Replacement, Release the left clips: adım 11, 3 resimden 1. Google Pixel 7 Battery Replacement, Release the left clips: adım 11, 3 resimden 2. Google Pixel 7 Battery Replacement, Release the left clips: adım 11, 3 resimden 3.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive and to release the plastic clips.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  12. Google Pixel 7 Battery Replacement, Slice the top edge adhesive: adım 12, 3 resimden 1. Google Pixel 7 Battery Replacement, Slice the top edge adhesive: adım 12, 3 resimden 2. Google Pixel 7 Battery Replacement, Slice the top edge adhesive: adım 12, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2.5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    This is the only slice that makes me nervous. Never had a problem, but yeah... extra care because of the camera.
    Orin Zebest - Yanıt
  13. Google Pixel 7 Battery Replacement, Release the right clips: adım 13, 3 resimden 1. Google Pixel 7 Battery Replacement, Release the right clips: adım 13, 3 resimden 2. Google Pixel 7 Battery Replacement, Release the right clips: adım 13, 3 resimden 3.
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive and release the right plastic clips.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly by a flex cable.
  14. Google Pixel 7 Battery Replacement, Open up the phone assembly: adım 14, 3 resimden 1. Google Pixel 7 Battery Replacement, Open up the phone assembly: adım 14, 3 resimden 2. Google Pixel 7 Battery Replacement, Open up the phone assembly: adım 14, 3 resimden 3.
    • Lift the right edge of the screen up and towards the left side of the device, like opening a book.
    • Don't twist the screen or move it too far away from the frame to avoid straining or damaging the flex cable.
    • Rest the screen upside down and parallel to the frame before continuing.
    The adhesive still sticking to the screen might trip you up... don't let it pull the screen in weird ways. Just pick that stuff off and the screen sits perfectly next to the phone, as pictured.
    Orin Zebest - Yanıt
  15. Google Pixel 7 Battery Replacement, Release the display cable bracket: adım 15, 2 resimden 1. Google Pixel 7 Battery Replacement, Release the display cable bracket: adım 15, 2 resimden 2.
    • The display cable bracket sits tightly and requires some force to release it.
    • Insert one arm of a pair of tweezers into the opening at the upper end of the display cable bracket.
    • Push the bracket inwards and pry up to release it.
    The way this piece is wedged in there can be a difficult to imagine, so you may need to apply force at a different angle than you expect. I bent mine a few times, but just bent it back into shape with no issue.
    Orin Zebest - Yanıt
    This was a pain to get out! Felt like I was going to rip the whole cable out. But it popped out eventually.
    Alex Thengvall - Yanıt
  16. Google Pixel 7 Battery Replacement, Remove the display cable bracket: adım 16, 2 resimden 1. Google Pixel 7 Battery Replacement, Remove the display cable bracket: adım 16, 2 resimden 2.
    • Use a pair of tweezers to remove the display cable bracket by pulling it from underneath the midframe and in direction of the cameras.
    I forgot to replace this the first time. It's not a dealbreaker (phone works fine without it), but if you ever open your phone again you must be super-extra careful -- nothing is securing the connection.
    Orin Zebest - Yanıt
    I bent the top of the bracket backwards by accident, but it released easier this way. Then I just bent the bracket back before putting it back.
    Also, make sure you add the adhesive before plugging the new screen in.
    Samuel Y - Yanıt
  17. Google Pixel 7 Battery Replacement, Disconnect the display cable: adım 17, 2 resimden 1. Google Pixel 7 Battery Replacement, Disconnect the display cable: adım 17, 2 resimden 2.
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Getting the press connector aligned properly is a very fiddly task and impossible without a light touch and several tries. My only advice is to take a break if you get frustrated. There's no 'click' or anything to help you notice that you've got it right. But when you do, it'll just... fit. And you'll probably think, "wait I did it? oh, not as hard as it sounded. just took awhile."
    Orin Zebest - Yanıt
    Beware! I tried using the forceps instead of my finger and I ended up tearing into the ribbon cable. So be careful and use your finger if possible. I wouldn't use a sharp tool like I did. There are a couple Youtube videos that probably can help if you search "pixel 7 screen replacement". Sadly I didn't do that first.
    Alex Thengvall -
    Be careful not to hit any circuitry or jumpers in the process. They are so tiny that I did and now sound doesn't work on my bottom speaker. There's a YouTube video on this topic. Take your time!
    Louie Popov - Yanıt
  18. Google Pixel 7 Battery Replacement, Screen information: adım 18, 1 resimden 1.
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  19. Google Pixel 7 Battery Replacement, Separate the screen: adım 19, 1 resimden 1.
    • Separate the screen from the phone.
    • During reassembly:
    • Check that all screws are tightened and there are no loose parts.
    • Reconnect the screen and test your phone to make sure it works. Power it back down and continue reassembly.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide if you're using a pre-cut adhesive card.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
  20. Google Pixel 7 Battery Replacement, Remove the black silicone pad: adım 20, 3 resimden 1. Google Pixel 7 Battery Replacement, Remove the black silicone pad: adım 20, 3 resimden 2. Google Pixel 7 Battery Replacement, Remove the black silicone pad: adım 20, 3 resimden 3.
    • Take care not to puncture or bend the battery with your tool in the following steps—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Use a pair of tweezers to peel the black silicone pad off the battery and midframe.
    For me, some of the graphite foil also came up with the silicone pad. be careful
    Shantanu Wanivadekar - Yanıt
  21. Google Pixel 7 Battery Replacement, Peel off the upper graphite foil: adım 21, 3 resimden 1. Google Pixel 7 Battery Replacement, Peel off the upper graphite foil: adım 21, 3 resimden 2. Google Pixel 7 Battery Replacement, Peel off the upper graphite foil: adım 21, 3 resimden 3.
    • Use a pair of tweezers to carefully peel the upper graphite foil off the battery and midframe.
    • If you're having a hard time peeling off the foil, apply a heated iOpener to the foil for two minutes to loosen its adhesive.
    For me, an upper layer of graphite foil came up, leaving a silver-ish graphite layer still stuck on top my battery and other assembly. It took a lot of time to clear all of that. Do heat it properly before removing it. Also using the pointy tweezers just tore the foil over and over again. IG I don't know how to use them properly
  22. Google Pixel 7 Battery Replacement, Peel off the lower graphite foil: adım 22, 3 resimden 1. Google Pixel 7 Battery Replacement, Peel off the lower graphite foil: adım 22, 3 resimden 2. Google Pixel 7 Battery Replacement, Peel off the lower graphite foil: adım 22, 3 resimden 3.
    • Use a pair of tweezers to carefully peel the lower graphite foil off the battery and midframe.
  23. Google Pixel 7 Battery Replacement, Unfasten the loudspeaker screws: adım 23, 2 resimden 1. Google Pixel 7 Battery Replacement, Unfasten the loudspeaker screws: adım 23, 2 resimden 2.
    • Use a Torx T3 screwdriver to remove the three 5.1 mm-long screws securing the loudspeaker.
  24. Google Pixel 7 Battery Replacement, Remove the loudspeaker: adım 24, 2 resimden 1. Google Pixel 7 Battery Replacement, Remove the loudspeaker: adım 24, 2 resimden 2.
    • Use a pair of tweezers to lift the loudspeaker out of its recess and remove it.
  25. Google Pixel 7 Battery Replacement, Unfasten the midframe screws: adım 25, 2 resimden 1. Google Pixel 7 Battery Replacement, Unfasten the midframe screws: adım 25, 2 resimden 2.
    • Use a Torx T3 screwdriver to remove the nine 5.1 mm-long screws securing the midframe.
  26. Google Pixel 7 Battery Replacement, Remove the midframe: adım 26, 3 resimden 1. Google Pixel 7 Battery Replacement, Remove the midframe: adım 26, 3 resimden 2. Google Pixel 7 Battery Replacement, Remove the midframe: adım 26, 3 resimden 3.
    • Use a pair of tweezers to remove the midframe.
    • During reassembly check the condition of the thermal pad. If it's damaged, remove the pad, clean the area with high-concentration (greater than 90%) isopropyl alcohol and a microfiber or lint-free cloth, and apply a new thermal pad.
  27. Google Pixel 7 Battery Replacement, Disconnect the battery cable: adım 27, 2 resimden 1. Google Pixel 7 Battery Replacement, Disconnect the battery cable: adım 27, 2 resimden 2.
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  28. Google Pixel 7 Battery Replacement, Heat the battery's adhesive: adım 28, 1 resimden 1.
    • Apply a heated iOpener to the back of the device to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
  29. Google Pixel 7 Battery Replacement, Separate the battery pull tabs: adım 29, 3 resimden 1. Google Pixel 7 Battery Replacement, Separate the battery pull tabs: adım 29, 3 resimden 2. Google Pixel 7 Battery Replacement, Separate the battery pull tabs: adım 29, 3 resimden 3.
    • Use tweezers, or your fingers, to peel the plastic pull tabs away from the battery.
  30. Google Pixel 7 Battery Replacement, Separate the battery's adhesive: adım 30, 3 resimden 1. Google Pixel 7 Battery Replacement, Separate the battery's adhesive: adım 30, 3 resimden 2. Google Pixel 7 Battery Replacement, Separate the battery's adhesive: adım 30, 3 resimden 3.
    • Pull the tabs back and forth in a sawing motion up the length of the battery to separate the adhesive underneath.
    • Work slowly. It's easy to lose your grip and accidentally pull the tab up from under the battery.
    • If you're having difficulty separating the adhesive, apply more heat and wait for the adhesive to loosen.
    • If you lose or tear the release strip, follow the next step for an alternative battery removal method.
  31. Google Pixel 7 Battery Replacement, How to remove a stuck battery: adım 31, 3 resimden 1. Google Pixel 7 Battery Replacement, How to remove a stuck battery: adım 31, 3 resimden 2. Google Pixel 7 Battery Replacement, How to remove a stuck battery: adım 31, 3 resimden 3.
    • Follow this step if you couldn't loosen the battery using the battery release strip.
    • Apply a few drops of high concentration (90% or higher) isopropyl alcohol into the gap at the top edge of the battery.
    • Don't apply too much alcohol, or you'll loosen the NFC antenna and charging coil underneath the battery.
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use the flat end of a spudger or an opening pick to gently lift the top edge of the battery until you can grab it with your fingers.
    • Don't use excessive force on the battery. Slow, consistent pressure is all that's required to free it from the frame.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
  32. Google Pixel 7 Battery Replacement, Remove the battery: adım 32, 3 resimden 1. Google Pixel 7 Battery Replacement, Remove the battery: adım 32, 3 resimden 2. Google Pixel 7 Battery Replacement, Remove the battery: adım 32, 3 resimden 3.
    • Tilt the battery out of the device to separate the rest of the adhesive.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • To secure the replacement battery:
    • Apply pre-cut adhesive adhesive or double-sided tape to the battery well at the places where the old adhesive was located, not directly onto the battery.
    • Temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it's seated.
    • Make sure that the battery sits in the center of the battery well and there's an even gap around the battery.
    • Press the new battery firmly into place.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
For optimal performance, calibrate your newly installed battery after completing this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 7 answers community for help.
23 farklı kişi bu kılavuzu tamamladı.
232.026 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.829 adet Kılavuz yazıldı
5Kılavuz Yorumları
I assume the IP68 rating is gone after this. Is there a way to bring it back?
Albert - Yanıt
Top Anleitung vielen Dank dafür. Schön viel Bilder und gut erklärt worauf man achten muss.
Benedikt - Yanıt
Just completed a Pixel 7 battery replacement using this very detailed guide.
Here are my key takeaways:
Screen Handling: Protect the front camera lens and camera cavity in the screen from dust/fingerprints post-removal. Store the screen assembly face-up in a clean container to prevent dust.
Battery Flex Cable: Replacement batteries may have longer flex cables than the OEM. Probably also have to follow how it's bent.
Bloated Battery/Frame Separation: If the battery swelling has caused frame separation, find an alternate entry point to avoid further damage. For re-adhering the screen plastic frame, B7000 or E7000 adhesive works well, use sparingly and clean excess.
Battery Removal: The most challenging aspect of this repair is definitely removing the original, often strongly adhered battery.
Ranjeet Joshi - Yanıt
worst replacement repair i ever had to do. removing adhesive, removing the SUPERGLUED battery. had limited tools to my disposal (only the kit). $@$* took me hours but it's finally done. thank you for the guide.
bruh - Yanıt
Tolle Anleitung!
Die Batterie ließ sich allerdings nur mit schwerem Gerät (einer kleinen Kombizange aus dem Werkzeugkoffer) und ordentlich Hitze entfernen. Ohne diese Hilfsmittel ist dem Kleber nicht beizukommen.
Jan B. - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 135
Son 7 gün: 1,047
Son 30 gün: 3,763
Her zaman: 66,565
