Ana içeriğe geç
MacBook Air 2022 (M2) Battery Replacement
Spencer Day
Spencer Day ve 2 diğer katkıda bulunanlar
En son February 26, 2025 tarihinde güncellendi
1 - 2 saat
Orta
Öne Çıkan Kılavuzlar
Use this guide to replace the battery in your MacBook Air 2022 (M2).
This repair requires replacement battery adhesive.
Note: This laptop uses a combination of standard Torx and Torx Plus (IP) screws. In the case that you don't have all the necessary Torx Plus drivers, you can use standard Torx drivers instead. If you do, make sure to use constant, downward force to avoid stripping.
  1. MacBook Air 2022 (M2) Battery Replacement, Prepare your Macbook Air for disassembly: adım 1, 3 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Prepare your Macbook Air for disassembly: adım 1, 3 resimden 2. MacBook Air 2022 (M2) Battery Replacement, Prepare your Macbook Air for disassembly: adım 1, 3 resimden 3.
    • Before you begin, discharge your battery below 25%, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power off your MacBook Air and unplug all cables.
    • Close the display and flip the laptop upside down. Keep the lid closed until you've physically disconnected the battery.
  2. MacBook Air 2022 (M2) Battery Replacement, Unfasten the lower case: adım 2, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Unfasten the lower case: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    FixMat
    $36.95
    • Use a P5 Pentalobe driver to remove the four 6.4 mm screws securing the lower case:
    • Two screws with a short threaded portion near the hinges
    • Two screws with a long threaded portion near the front of the MacBook
  3. MacBook Air 2022 (M2) Battery Replacement, Insert an opening pick: adım 3, 3 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Insert an opening pick: adım 3, 3 resimden 2. MacBook Air 2022 (M2) Battery Replacement, Insert an opening pick: adım 3, 3 resimden 3.
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle with strong, steady force to create a small gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. MacBook Air 2022 (M2) Battery Replacement, Release the snapping clips: adım 4, 3 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Release the snapping clips: adım 4, 3 resimden 2. MacBook Air 2022 (M2) Battery Replacement, Release the snapping clips: adım 4, 3 resimden 3.
    • During the next two steps you'll feel and hear four snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next clip.
  5. MacBook Air 2022 (M2) Battery Replacement: adım 5, 3 resimden 1. MacBook Air 2022 (M2) Battery Replacement: adım 5, 3 resimden 2. MacBook Air 2022 (M2) Battery Replacement: adım 5, 3 resimden 3.
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the two remaining snapping clips.
  6. MacBook Air 2022 (M2) Battery Replacement, Release the sliding tabs: adım 6, 3 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Release the sliding tabs: adım 6, 3 resimden 2. MacBook Air 2022 (M2) Battery Replacement, Release the sliding tabs: adım 6, 3 resimden 3.
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
    It's obvious once you know how, but I think that stating the direction of force you apply to the lower case (towards the front) to separate the sliding tabs would be helpful.
    Thank you for the great instructions!
    Tatsuya Takahashi - Yanıt
    The back tabs are meant to slide down towards the track pad. Do not pull up on the back tabs
    nick mulvaine - Yanıt
    Using the iFixit opening tool from the toolkit and applying a moderate amount of force between the edge of the lower case and the inner lip of the main body (not the hinge!) worked better for me.
    Zach - Yanıt
  7. MacBook Air 2022 (M2) Battery Replacement, Remove the lower case: adım 7, 3 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Remove the lower case: adım 7, 3 resimden 2. MacBook Air 2022 (M2) Battery Replacement, Remove the lower case: adım 7, 3 resimden 3.
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the four snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
    I'd bet that if iFixit was to source upgraded replacement lower case 'feet' with a material like nearly any earlier macbook air or pros had--less hard and slippery--they'd sell a lot of them. I'd buy several sets. The OEM feet are horrible and not very 'Apple' in quality.
    Walt Keyes - Yanıt
  8. MacBook Air 2022 (M2) Battery Replacement, Remove the battery connector cover: adım 8, 1 resimden 1.
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the battery connector cover.
  9. MacBook Air 2022 (M2) Battery Replacement: adım 9, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement: adım 9, 2 resimden 2.
    • Remove the battery connector cover.
  10. MacBook Air 2022 (M2) Battery Replacement, Disconnect the battery: adım 10, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Disconnect the battery: adım 10, 2 resimden 2.
    • Use an opening pick to pry up and disconnect the battery press connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  11. MacBook Air 2022 (M2) Battery Replacement, Unfasten the trackpad cable cover: adım 11, 1 resimden 1.
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the trackpad cable cover.
  12. MacBook Air 2022 (M2) Battery Replacement, Access the trackpad press connector: adım 12, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Access the trackpad press connector: adım 12, 2 resimden 2.
    • Use a spudger or your fingers to move the trackpad cable cover out of the way so you can access the press connector underneath.
  13. MacBook Air 2022 (M2) Battery Replacement, Disconnect the trackpad cable: adım 13, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Disconnect the trackpad cable: adım 13, 2 resimden 2.
    • Use the pointed end of a spudger to pry up and disconnect the trackpad cable press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  14. MacBook Air 2022 (M2) Battery Replacement, Remove the display cable cover foam: adım 14, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Remove the display cable cover foam: adım 14, 2 resimden 2.
    • Peel up and remove the foam pad from the lower display cable cover to reveal a hidden screw.
  15. MacBook Air 2022 (M2) Battery Replacement, Remove the cable covers: adım 15, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Remove the cable covers: adım 15, 2 resimden 2.
    • Use a T3 Torx driver to remove the fourteen 1.5 mm screws securing the various cable covers.
  16. MacBook Air 2022 (M2) Battery Replacement: adım 16, 3 resimden 1. MacBook Air 2022 (M2) Battery Replacement: adım 16, 3 resimden 2. MacBook Air 2022 (M2) Battery Replacement: adım 16, 3 resimden 3.
    • Use tweezers or your fingers to remove the six cable covers.
    In step 16 (see here https://i.imgur.com/jbmTEsg.png) there are three screws retaining the inboard LCD connector cover. There is a piece of tape covering the centre screw, and it had me stumped for a minute (I am not vwery smart, am I 😂)
    Peter Newman - Yanıt
  17. MacBook Air 2022 (M2) Battery Replacement: adım 17, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement: adım 17, 2 resimden 2.
    • Remove the four screws securing the upper display cable cover:
    • Two 2.5 mm P2 Pentalobe screws
    • Two 2.5 mm 3IP Torx Plus screws
    • During reassembly, the Pentalobe screws must thread into their holes on the plastic securing bracket.
  18. MacBook Air 2022 (M2) Battery Replacement: adım 18, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement: adım 18, 2 resimden 2.
    • Remove the upper display cable cover and plastic securing bracket.
    • During reassembly, make sure that the upper lip of the metal cable cover slots into the plastic bracket.
  19. MacBook Air 2022 (M2) Battery Replacement, Disconnect the logic board connectors: adım 19, 3 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Disconnect the logic board connectors: adım 19, 3 resimden 2. MacBook Air 2022 (M2) Battery Replacement, Disconnect the logic board connectors: adım 19, 3 resimden 3.
    • Use the pointed end of a spudger to pry up and disconnect both display cable press connectors.
  20. MacBook Air 2022 (M2) Battery Replacement: adım 20, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement: adım 20, 2 resimden 2.
    • Disconnect the microphone array press connector, directly to the left of the display cable.
    Does anybody know what this connects too?
    Is it part of the Holy Display Trinity (LCD LVDS, Backlight & Camera) or is this something else?
    OmeletteBaguette - Yanıt
    Hi! Thank you for the comment. This is the microphone array connector. The guide has been updated!
    Spencer Day -
  21. MacBook Air 2022 (M2) Battery Replacement: adım 21, 3 resimden 1. MacBook Air 2022 (M2) Battery Replacement: adım 21, 3 resimden 2. MacBook Air 2022 (M2) Battery Replacement: adım 21, 3 resimden 3.
    • Disconnect the left and right speaker press connectors.
  22. MacBook Air 2022 (M2) Battery Replacement: adım 22, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement: adım 22, 2 resimden 2.
    • Insert the flat end of a spudger between the the interconnect cable and the screw post.
    • Pry up and disconnect the interconnect cable.
  23. MacBook Air 2022 (M2) Battery Replacement: adım 23, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement: adım 23, 2 resimden 2.
    • Disconnect the MagSafe port press connector.
  24. MacBook Air 2022 (M2) Battery Replacement: adım 24, 3 resimden 1. MacBook Air 2022 (M2) Battery Replacement: adım 24, 3 resimden 2. MacBook Air 2022 (M2) Battery Replacement: adım 24, 3 resimden 3.
    • Disconnect both Thunderbolt port press connectors.
  25. MacBook Air 2022 (M2) Battery Replacement: adım 25, 3 resimden 1. MacBook Air 2022 (M2) Battery Replacement: adım 25, 3 resimden 2. MacBook Air 2022 (M2) Battery Replacement: adım 25, 3 resimden 3.
    • Use a pair of tweezers to grip the first antenna connector, as close to its base as possible.
    • Lift straight up to disconnect the cable.
    • The antenna connectors on the logic board are very fragile. When disconnecting the cables, pull straight up—don’t bend them to the side.
    • Repeat for the second antenna cable.
    • To reattach antenna connectors like these, align the connector over its socket and press down with the flat end of a spudger. The connector should snap into place. This can be tricky and may take a few tries.
  26. MacBook Air 2022 (M2) Battery Replacement, Unfasten the logic board: adım 26, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Unfasten the logic board: adım 26, 2 resimden 2.
    • Remove the nine screws securing the logic board:
    • Three 3.8 mm T5 Torx screws
    • One 3.6 mm T5 Torx screw
    • Two 3.4 mm T5 Torx screws
    • One 3.1 mm T5 Torx screw
    • Two 2.7 mm 3IP Torx Plus screws
  27. MacBook Air 2022 (M2) Battery Replacement, Remove the logic board: adım 27, 3 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Remove the logic board: adım 27, 3 resimden 2. MacBook Air 2022 (M2) Battery Replacement, Remove the logic board: adım 27, 3 resimden 3.
    • The logic board and its cover are connected and remove as one assembly.
    • The cover extends out from the logic board's left edge and bends easily. Don't pull the board up from this side.
    • Grip the right side of the logic board and slide it towards the trackpad until it clears the overhangs near the speakers.
    • Remove the logic board.
  28. MacBook Air 2022 (M2) Battery Replacement, Check cables during reassembly: adım 28, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Check cables during reassembly: adım 28, 2 resimden 2.
    • When you reinstall the logic board, verify that no cables get trapped under the board as you lower it into place. Check each of the seven locations carefully:
    • Right speaker cable
    • Trackpad cable
    • Display cables and microphone array cable
    • Antenna cables
    • Battery cable
    • Left speaker cable
    • USB-C and MagSafe cables
    Need to include the microphone array cable from Step 20 ;)
    Jeff Suovanen - Yanıt
  29. MacBook Air 2022 (M2) Battery Replacement, Reposition the trackpad cable: adım 29, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Reposition the trackpad cable: adım 29, 2 resimden 2.
    • Reposition the trackpad cable over the bottom edge of the MacBook so it's out of the way of the battery.
  30. MacBook Air 2022 (M2) Battery Replacement, Detach the battery cable: adım 30, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Detach the battery cable: adım 30, 2 resimden 2.
    • A small amount of adhesive secures the right side of the battery cable to the frame.
    • Lift and detach the battery cable from the frame.
  31. MacBook Air 2022 (M2) Battery Replacement, Unfasten the battery tray: adım 31, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Unfasten the battery tray: adım 31, 2 resimden 2.
    • Use a 4IP Torx Plus driver to remove the two 4.5 mm screws securing the upper edges of the battery tray.
    • Use a 3IP Torx Plus driver to remove the four screws securing the center of the battery tray.
  32. MacBook Air 2022 (M2) Battery Replacement, Adhesive strip information: adım 32, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Adhesive strip information: adım 32, 2 resimden 2.
    • The MacBook's battery cells are attached to a metal tray as a complete assembly. This tray is secured to the frame by eight stretch-release adhesive strips:
    • Four on the bottom left corner
    • Four on the bottom right corner
  33. MacBook Air 2022 (M2) Battery Replacement, Remove the stretch release adhesive: adım 33, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Remove the stretch release adhesive: adım 33, 2 resimden 2.
    • Use a pair of tweezers to peel up the black pull tab on one of the stretch-release adhesive strips until you can grip it with your fingers.
    • Pull the strip out from under the battery at a shallow angle. Go very slow and use steady force, giving the strip plenty of time to stretch and unstick itself from under the battery tray.
    • You may have to re-grip the adhesive closer to the laptop and continue pulling multiple times—the adhesive will stretch a lot.
    • Pull the adhesive strip until it’s completely freed from underneath the battery tray.
    • Repeat for the seven remaining adhesive strips.
  34. MacBook Air 2022 (M2) Battery Replacement, Apply isopropyl alcohol: adım 34, 1 resimden 1.
    • If you removed all the stretch-release adhesive, congratulations! You can skip the next two steps. If any strips broke and the battery is still stuck in place, follow the next two steps to remove the remaining adhesive.
    • Apply a few drops of high concentration (greater than 90%) isopropyl alcohol between the edge of the frame and the battery where any adhesive strips remain.
    • Wait one minute for the isopropyl alcohol to soften the adhesive.
  35. MacBook Air 2022 (M2) Battery Replacement: adım 35, 3 resimden 1. MacBook Air 2022 (M2) Battery Replacement: adım 35, 3 resimden 2. MacBook Air 2022 (M2) Battery Replacement: adım 35, 3 resimden 3.
    Plastic Cards
    $2.99
    • Make sure your plastic card is underneath the battery tray, and not between the battery and the tray. Don’t attempt to remove the battery cells from the metal tray.
    • Insert a plastic card underneath the battery's metal tray.
    • Push the plastic card underneath the metal tray and slide it back and forth to slice the remaining adhesive. You may need to lift the battery cell to reach the adhesive.
    • If you're struggling to remove the remaining adhesive, apply more isopropyl alcohol and try again.
  36. MacBook Air 2022 (M2) Battery Replacement, Remove the battery: adım 36, 2 resimden 1. MacBook Air 2022 (M2) Battery Replacement, Remove the battery: adım 36, 2 resimden 2.
    Stretch Release Battery Adhesive
    $3.99
    • Remove the battery assembly.
    • Remove any remaining adhesive strips with tweezers or your fingers.
    • Clean up the adhesive residue with a few drops of isopropyl alcohol and a lint-free or microfiber cloth.
    • Before removing any adhesive liners, place the battery in its recess and make sure it fits.
    • If your replacement battery comes with adhesive, remove the plastic liners and firmly press each cell into place.
    • If your replacement battery doesn't come with adhesive, secure it with stretch-release adhesive.
    • Alternatively, you may use strong double-sided tape such as Tesa Tape to secure the battery.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
For optimal performance, calibrate your newly installed battery after completing this guide.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
13 farklı kişi bu kılavuzu tamamladı.
Spencer Day
104.591 İtibar
740 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.845 adet Kılavuz yazıldı
9Kılavuz Yorumları
Is is really necessary to remove the motherboard?
Looking at all the photos, it seems to me like the battery should be clear for removal after disconnecting it and the trackpad cable, leaving the motherboard (and all of its other connectors) in-place. So what am I missing here?
shamino - Yanıt
Hi! The logic board is removed first because the battery cable runs underneath it and is adhered to the frame.
Spencer Day -
It is not necessary to remove the motherboard. The battery cable runs underneath the logicboard, but is not adhere to it. You can slide it out once the battery is loose.
just1ed -
I lost the screws to my battery cover. Is there any way to replace them? Should i tape the cover on for now? Please help!
dumb yung and broke - Yanıt
Can someone verify this and see if it does really need to e removed?
"It is not necessary to remove the motherboard. The battery cable runs underneath the logicboard, but is not adhere to it. You can slide it out once the battery is loose."
Ryan Zmuda - Yanıt
Wrong, the cable is partially stuck underneath the logicboard
J FaDaWay (FaDaWay) -
Where can I buy the battery in a reliable place?
Jose Luis - Yanıt
Benim Macbook açılmıyor, şarja takıyorum ekran açılıyor ama tuşu algılamıyor, power tuşuna bastığımda ise ekran kendini kapatıyor. Bu sorun neden olabilir?
Yunuss - Yanıt
Replaced battery in macbook air 2022 and it still won't charge. It recognised the battery and ran until it went flat but wouldn't charge via magsafe or usb C. Pretty disappointing, it might be because the battery isn't official Apple and the logic board is programmed or maybe there is some other issue, just such little diagnostics. Also you do NOT need to remove the logic board, that is Apple's official procedure though. Just use a plastic spatula to slightly lift where the battery ribbon cable runs underneath and release the small adhesive on the battery then slide it out.
Combat x Computers - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 91
Son 7 gün: 633
Son 30 gün: 2,532
Her zaman: 47,834
