Ana içeriğe geç
MacBook Pro 16" 2019 Battery Replacement
Neye ihtiyacın var
  1. MacBook Pro 16" 2019 Battery Replacement, Disable Auto Boot: adım 1, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disable Auto Boot: adım 1, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement, Disable Auto Boot: adım 1, 3 resimden 3.
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
    Is this step necessary? I can’t perform this step as I am attempting to repair water damage and need to remove logic board & most likely replace the battery.
    Macrepair SF - Yanıt
    @mac_medic You definitely don’t want the power coming on while the board is wet. In your case, I think powering on the machine to disable Auto Boot would do more damage than it prevents. I agree, skip this step and be prepared to disconnect the battery quickly if the laptop automatically powers on. Good luck!
    Jeff Suovanen -
    Thats right! You don't want power running while working on your logic board.
    Dan -
    This did not work when running High Sierra.
    Kyle B - Yanıt
    Tried this on a 2018 MBP 13” Touchbar (there’s no iFixit guide for this model yet). Need to replace a broken screen.
    Luckily I managed to connect to an external screen (Cmd-Down Brightness to switch displays) and enter above command. Seems to work, but there’s another problem with this model - it powers up as soon as any key is pressed……. ffs <gnashes teeth>
    Cool_Breeze - Yanıt
    I unscrew the battery first and wrap electrical tape over the logic board battery connector before attempting any repairs to the board. Haven’t had any problems yet and I’ve worked on about 10 of these models already. Also when you open the bottom case use a suction cup at the bottom and pull up then run a plastic spudger along the edges to disconnect the clips. Also only use a plastic spudger on the board. Saw a youtube video from a repair shop and he did not disconnect the power and used all metal tools during the entire process of removing the board. His last step was to disconnect the battery terminal.
    Brian - Yanıt
    Is this step necessary if my mac can turn on? Battery fully dead(
    Nursat b - Yanıt
    BEFORE YOU START: The included torx head stripped off before I was done (and you might need an additional T4) so stop now and go buy a good one. Also they fail to warn you above to get some blue threadlocker ahead of time.
    Jason Sherron - Yanıt
    This command did not work for me and I read that sometime in later 2020 Apple stopped this command from working…any ideas on a work around?
    Patrick Machacek - Yanıt
    Not able to do that with damaged screen
    richardjgreen - Yanıt
    If you have a damaged screen you can still use a converter from thunderbolt (USB 3) to HDMI and plug your Macbook Pro to your TV as monitor display. Just make sure to chose the right Source (HDMI IN) in your TV. I did it and to make it work I unplug and plug again in my Macbook and so I could disable the Auto boot
    Roberto Sanchez Bustos -
    Hi. This does not work on 2018 13” MacBook Pro with Touch Bar. I did exactly this to disable auto boot. But when I check by using nvram -p it says: auto-boot true. Am I doing something incorrectly? I did everything step by step. Copied and pasted the sudo command, pressed enter and then entered my password. I have Big Sur 11.1 installed. Is there any other way since I need to replace the screen. Thank you. Adrian
    Adrian Vizik - Yanıt
    Hi everyone. This is also a little pointless if you can’t see anything on the screen, and you don’t have a display adapter to USB C to display it. I agree with Brian about removing the back and disconnecting the battery cable before you even think about opening the lid of the MacBook. Applying the insulation tape is also a handy little tip that just makes sure there is no way to discharge from either the board or battery.
    Roberto Enrieu - Yanıt
    running `nvram -p | grep 'AutoBoot'` in terminal verifies that it was accepted
    result: `AutoBoot %00`
    Marek Polák - Yanıt
    Running Big Sur 11.6.7 on a 2019 16" MBP, it's "auto-boot". So it's: nvram -p | grep 'auto-boot' to display the current state, the default is true - and then to change it, sudo nvram auto-boot=false which turns it off.
    Ed Mechem -
    This step is completely unnecessary if you follow the guide to disconnect the battery properly. Just put some tape between the battery and logic board connection to prevent it from accidentally touching and therefore powering on the laptop.
    Grant Ormsby - Yanıt
    It took me a few tries to make this command work, as I was able to copy and paste the command into Terminal, but could not type in my laptop’s password. I finally typed my password into a text document, copied it (command C), and then pasted it into Terminal and it worked.
    tommy404 - Yanıt
    I didn’t do this. Mine never auto-booted before I replaced the battery. Now it does.
    hatuxka - Yanıt
    BEFORE YOU DO ANYTHING - CHECK THE BATTERY!
    I-fixit sent me a bad battery, which I didn’t realize until it was already install. They sent me a new one, but I wasted hours uninstalling and reinstalled.
    Get a volt meter and measure the voltage on the output of the battery pack. If it reads 0 V, SEND IT BACK. It should read over 2 V.
    bcardanha - Yanıt
    I've just received my replacement battery and it reads 0,042V between the two main connectors. Do you think it's dead?
    peter sussex -
    When I did this from Terminal.app within Recovery Mode, the “sudo” was not recognized but I could invoke it without the sudo part. It seems to have been accepted when looking at “nvram -p”
    johann beda - Yanıt
    When in Recovery Mode, you already have superuser powers. So you don't need to prefix commands with the sudo command to invoke them with root privileges; you already have them. Do a pwd (print working directory) after opening Terminal in Recovery Mode, and you'll see that you're in the root user's directory.
    Ed Mechem -
    I received the battery kit for my 2018 MacBook Pro and as per the above comment from bcardanha - Oct 12, 2021, I checked the voltage on the pads marked + and - . It was zero volts so I panicked a bit.
    I sent a message on the iFixiT Facebook page and I got no reply. I finally found the customer service email for Ifixit Europe and sent them an email voicing my concern as I was not keen to work for couple of hours just to discover that the battery is faulty. I had an almost instant reply on the email (kudos to them) and they adviced me to go ahead and install the new battery as the voltage measured when battery is not connected is not relevant.
    I took a leap of faith and after two hours… the new battery showed 50% charge and everything seems to be working just fine. I am happy it worked.
    Mircea Comanici - Yanıt
    After removing the old battery and installing the new battery I powered up the MBP before screwing the bottom on. I discovered the my keyboard would not function. It took a few hours of investigation and frustration that I discovered the track pad power ribbon had become partially dislodged from the trackpad. I was able to see that this through the little machined slot where the battery sat. I had to remove the trackpad to reinsert the power ribbon back into the connector in the trackpad. after reassembling and reinstalling the battery etc the keyboard worked. Just food for thought if your run into the keyboard issue.
    Ed Mease - Yanıt
    This should be the default. IMO I tell you to power on - not the lid.
    G Sena - Yanıt
    Est ce que cela fonctionne sur un macbook pro 2017 sans touchbar ?
    maël muzelet - Yanıt
    Bonjour Maël, oui, ce tutoriel concerne "les MacBook Pro 2016 (et plus récents) et les MacBook Retina 12" 2017 (et plus récents)"
    Claire Miesch -
    Excellent instructions. I was able to follow and install the new screen. I recommend that you get a good set of tools before you begin. I started with an inexpensive repair kit bought online. The Penta and torx bits failed. I bought an IFIXIT kit with quality bits and I was able to do everything I needed.
    Tom Markham - Yanıt
    If you're not running an admin account the sudo command won't work (which honestly, you should not be running admin). Rather than logging in to your admin amount via the OS, in the terminal type "login [admin username]," then the password and you'll be able to do the sudo command as described above. Once you're complete, type "logout [admin username]" and you'll be good to go. Obviously replace [admin username] with whatever the account name for your admin user is.
    arichard2401 - Yanıt
    For those unable to complete this step because the screen is too damaged I recommend leaving your macbook on until the battery dies.
    Nicholas R Licato - Yanıt
    Just replaced my 2018 15" MBP battery. Running Sonoma.
    I found no way to disable AutoBoot (The status can be checked in the Power section of system report).
    Anyway, i left my battery completely drain before opening the MBP, and had no issues during the process.
    Cédric Bontems - Yanıt
    After sending this command in terminal when I checked what happens if I now open the lid, instead the screen lit slightly up (still black) then a battery symbol showing the charging state showed up.
    Now, after replacement of the battery, this is all I get to see.
    No reset of NVRAM nor PRAM helped.
    Currently the new battery charges (58% atm) and it feels like it‘s mocking me.
    webrockers - Yanıt
    I suspected the keyboard or TouchID sensor wouldn’t work, so I went on and checked every connector.
    I missed connecting the left TouchID sensor from step 31.
    webrockers -
    Read the comments section at the bottom of the article before proceeding with the repair. It is unnecessary to remove the logic board. I actually removed the 45mm plastic bar to enable the cables to slip out then in. It is only there to frustrate repairers!
    Jack - Yanıt
  2. MacBook Pro 16" 2019 Battery Replacement, Remove lower case screws: adım 2, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Remove lower case screws: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
    • Four 3.7 mm screws
    • Two 7.3 mm screws
    • Note how the screws come out at a slight angle—you must reinstall them the same way.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. MacBook Pro 16" 2019 Battery Replacement, Unclip lower case: adım 3, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Unclip lower case: adım 3, 2 resimden 2.
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle just enough to open a small gap under the lower case.
  4. MacBook Pro 16" 2019 Battery Replacement: adım 4, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 4, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 4, 3 resimden 3.
    • Slide the corner of an opening pick into the gap you just created underneath the lower case.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
    I recommend being careful while sliding as you can scratch the speaker. The actual clip is about halfway up the side, whereas the speaker is closer to the front (further from the hinge). So stay very shallow with just the tip of the pick until you get halfway up the side.
    Eric Gauderman - Yanıt
  5. MacBook Pro 16" 2019 Battery Replacement: adım 5, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 5, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 5, 3 resimden 3.
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
    Same advice that I gave for the other side — be careful not to scratch the speaker which is close to the bottom. Keep the pick shallow until you get halfway up the side.
  6. MacBook Pro 16" 2019 Battery Replacement: adım 6, 1 resimden 1.
    • Lift the front edge of the lower case (the side opposite the display hinge) enough to slide your fingertips underneath and get a good grip on it.
    • Two additional hidden clips near the middle of the cover should pop free at this point, if they haven't already.
    • Don't lift more than an inch or so, and don't try to remove the lower case yet.
  7. MacBook Pro 16" 2019 Battery Replacement: adım 7, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 7, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 7, 3 resimden 3.
    • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
    This was made a lot easier by using a lever in the hinge area in combination with pulling. The amount of force required was more than the grip I could get on the metal allowed for my macbook.
    James Andariese - Yanıt
    Thank you for this comment! 🙏
    For me it was the same way, wasn't able to get enough grip to pull sufficiently - but gently levering near the hinge with a spudger to "push" the bottom panel away worked well!
    BavarianBamboo -
    There is no pulling required. Use an opening pick or a spudger at the hinge area to gently and easily nudge the bottom panel off the clips. It should be effortless.
    Marc Jacobson - Yanıt
    If you do pull on the bottom case be careful of where you place the hand supporting the Mac, otherwise you'll make a blood sacrifice to the Mac gods! I placed my other hand too close to the feet on the bottom case and while removing it, the sharp edge of the bottom case sliced into my thumb.
    o355 - Yanıt
  8. MacBook Pro 16" 2019 Battery Replacement, Remove lower case: adım 8, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Remove lower case: adım 8, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement, Remove lower case: adım 8, 3 resimden 3.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  9. MacBook Pro 16" 2019 Battery Replacement, Remove battery board sticker: adım 9, 1 resimden 1.
    • Peel up and remove the insulating sticker covering the battery board, on the edge of the logic board nearest the battery.
    • If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
  10. MacBook Pro 16" 2019 Battery Replacement: adım 10, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 10, 2 resimden 2.
    • Peel back any tape covering the battery board data cable connector.
  11. MacBook Pro 16" 2019 Battery Replacement, Disconnect battery board data cable: adım 11, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disconnect battery board data cable: adım 11, 2 resimden 2.
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  12. MacBook Pro 16" 2019 Battery Replacement: adım 12, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 12, 2 resimden 2.
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
    • Slide parallel to the logic board. Don't pull up.
    들어올려서 떨어지면 어떻게 해야하나요…ㅠㅠ
    obbamanse87 - Yanıt
    Anyone know where i can get a replacement connector mine looks like it was damaged. one side of the contacts is not fully gold
    Konstantinos Kalogeras - Yanıt
  13. MacBook Pro 16" 2019 Battery Replacement: adım 13, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 13, 2 resimden 2.
    • Pry up and disconnect the locking flap on the connector at the opposite end of the battery board data cable.
    Be very careful - the locking flap is very easy to break.
    Vaughan - Yanıt
    I’ve seen versions of this battery board that the cable goes around and to the back of the board, so this step is not always necesary.
    Carlos Morales - Yanıt
  14. MacBook Pro 16" 2019 Battery Replacement, Remove battery board data cable: adım 14, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Remove battery board data cable: adım 14, 2 resimden 2.
    • Slide the battery board data cable out of its socket on the battery board, and remove it completely.
    • Take care not to reinstall this cable backwards or upside-down.
    Putting a mark on the cable will be helpful when reinstalling so you don't put it backwards or upside down.
    maccentric - Yanıt
    This isn't necessary for many repairs, such as the Screen Replacement. I just lift the cable out of the way enough to do the next few steps and leave it attached.
    maccentric - Yanıt
  15. MacBook Pro 16" 2019 Battery Replacement, Disconnect the battery: adım 15, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disconnect the battery: adım 15, 2 resimden 2.
    • Use a T5 Torx driver to remove the 6.7 mm pancake screw securing the battery power connector.
  16. MacBook Pro 16" 2019 Battery Replacement: adım 16, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 16, 2 resimden 2.
    • Use a spudger to lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough to keep it separated from its socket while you work. If it accidentally makes contact, it could damage your MacBook Pro.
  17. MacBook Pro 16" 2019 Battery Replacement, Remove trackpad cable connector bracket: adım 17, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Remove trackpad cable connector bracket: adım 17, 2 resimden 2.
    • Use a T3 Torx driver to remove the two 1.8 mm screws securing the cover bracket for the keyboard and trackpad cable connectors.
    • Remove the bracket.
    R u sure about the 1.8mm length?
    Ifixit are you measuring the thread only ?
    kilter - Yanıt
    We measure the full length of the screw — if you find an error, let us know!
    Carsten Frauenheim -
  18. MacBook Pro 16" 2019 Battery Replacement, Disconnect trackpad cable: adım 18, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disconnect trackpad cable: adım 18, 2 resimden 2.
    • Use a spudger to disconnect the trackpad cable by prying its connector straight up from the logic board.
  19. MacBook Pro 16" 2019 Battery Replacement: adım 19, 1 resimden 1.
    • Apply mild heat to the trackpad ribbon cable to soften the adhesive securing it to the battery.
    • You can use an iOpener, hair dryer, or heat gun, but be careful not to overheat the battery. The cable should be warm, but not too hot to touch.
  20. MacBook Pro 16" 2019 Battery Replacement: adım 20, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 20, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 20, 3 resimden 3.
    • Carefully peel the trackpad cable up off the battery, and push it out of the way.
    • Don't crease or tear the cable. If you have trouble, don't force it—apply more heat and try again.
  21. MacBook Pro 16" 2019 Battery Replacement, Remove the trackpad assembly screws: adım 21, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Remove the trackpad assembly screws: adım 21, 2 resimden 2.
    • Use a T5 Torx driver to remove the 13 screws securing the trackpad assembly:
    • Nine 5.8 mm screws
    • Four 4.9 mm screws
    • These screws all look similar—be careful not to mix them up.
    • Adding a little blue threadlocker to the screw threads during reassembly can help prevent the screws from working themselves loose over time.
    • Install the screws loosely at first, and then check the trackpad alignment before tightening them down.
  22. MacBook Pro 16" 2019 Battery Replacement, Remove the trackpad: adım 22, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Remove the trackpad: adım 22, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement, Remove the trackpad: adım 22, 3 resimden 3.
    • Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
    • Carefully feed the trackpad's ribbon cable through its slot in the chassis.
  23. MacBook Pro 16" 2019 Battery Replacement: adım 23, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 23, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 23, 3 resimden 3.
    • As you remove the trackpad assembly, be very careful not to lose the nine small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
    • Remove the trackpad assembly.
    They are NOT kidding about those little washers. They practically leap off of the trackpad!
    krwright - Yanıt
  24. MacBook Pro 16" 2019 Battery Replacement, Disconnect the display board: adım 24, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disconnect the display board: adım 24, 2 resimden 2.
    • Use a T3 Torx driver to remove the two 3.5 mm screws securing the cover on the display board flex cable.
    • Remove the display board flex cover.
    If you're familiar with repairing, you do not need to do a complete tear down, you can skip from here to step 63 and just loosen (or you can remove) the Three 3.3 mm T3 Torx screws (red) and the T5 screw (Yellow)below the left fan and slightly lift the logic board enough to slide out the battery board cable from under the logic board.
    Gregg Stanley - Yanıt
  25. MacBook Pro 16" 2019 Battery Replacement: adım 25, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 25, 2 resimden 2.
    • Using a T3 Torx driver, remove the two 1.6 mm screws securing the bracket for the display board cable connector.
    • Remove the display board cable connector bracket.
  26. MacBook Pro 16" 2019 Battery Replacement: adım 26, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 26, 2 resimden 2.
    • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
  27. MacBook Pro 16" 2019 Battery Replacement, Remove the hinge covers: adım 27, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Remove the hinge covers: adım 27, 2 resimden 2.
    • Use a T3 Torx driver to remove the four 2.0 mm screws from the hinge covers (two screws on each side).
    Ces vis là sont des Torx T3
    Amaury - Yanıt
    Bonjour @amaury29177 Merci de remarque. Vous avez l'œil ! J'ai corrigé l'erreur. iFixit étant un wiki, je vous invite à faire la correction de votre côté s'il vous arrive de trouver une autre erreur :) Excellente journée et merci encore !
    Claire Miesch -
    Bonjour @claire17, merci de la correction et du conseil, je ferais ça la prochaine fois :) Excellente journée également
    Amaury -
  28. MacBook Pro 16" 2019 Battery Replacement: adım 28, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 28, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 28, 3 resimden 3.
    • Remove the two hinge covers.
  29. MacBook Pro 16" 2019 Battery Replacement, Disconnect Touch ID and headphone jack cable connectors: adım 29, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disconnect Touch ID and headphone jack cable connectors: adım 29, 2 resimden 2.
    • Use a T3 Torx driver to remove the two 2.4 mm screws securing the cover bracket for the Touch ID and headphone jack cable connectors.
    There are threads in this T8 for the subsequent T3 screw
    Kerby Rankin - Yanıt
  30. MacBook Pro 16" 2019 Battery Replacement: adım 30, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 30, 2 resimden 2.
    • Disconnect the headphone jack flex connector by prying it straight up from the logic board.
  31. MacBook Pro 16" 2019 Battery Replacement: adım 31, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 31, 2 resimden 2.
    • Disconnect the power button and Touch ID sensor by prying its connector straight up from the logic board.
    • These two small connectors have a tendency to get caught underneath the logic board during reinstallation, so double check they're correctly positioned before screwing down the logic board.
  32. MacBook Pro 16" 2019 Battery Replacement, Disconnect Touch Bar and lid angle sensor connectors: adım 32, 1 resimden 1.
    • Using a T3 Torx driver, remove the two 1.5 mm screws securing the cover bracket for the Touch Bar digitizer and lid angle sensor connectors.
    Deze foto is 180 graden gedraaid. Het is bij het rechter scharnier.
    Frans - Yanıt
  33. MacBook Pro 16" 2019 Battery Replacement: adım 33, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 33, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 33, 3 resimden 3.
    • Using your tweezers, slide the bracket toward the side edge of the MacBook Pro until it clears the slotted retaining tab on the logic board.
    Would have really preferred you knot change the orientation of the MacBook in this and the following step from the previously established orientation.
    krwright - Yanıt
  34. MacBook Pro 16" 2019 Battery Replacement: adım 34, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 34, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 34, 3 resimden 3.
    • Disconnect the lid angle sensor cable by prying it straight up from the logic board.
    • Disconnect the Touch Bar digitizer cable by prying it straight up from the logic board.
  35. MacBook Pro 16" 2019 Battery Replacement, Disconnect the Touch Bar display connector: adım 35, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disconnect the Touch Bar display connector: adım 35, 2 resimden 2.
    • Use a T3 Torx driver to remove the two 1.9 mm screws securing the bracket for the Touch Bar display cable connector.
  36. MacBook Pro 16" 2019 Battery Replacement: adım 36, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 36, 2 resimden 2.
    • Disconnect the Touch Bar display cable by prying its connector straight up from the logic board.
  37. MacBook Pro 16" 2019 Battery Replacement, Disconnect the Thunderbolt cables: adım 37, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disconnect the Thunderbolt cables: adım 37, 2 resimden 2.
    • Using a T3 Torx Driver:
    • Remove the two 1.3 mm screws securing the Thunderbolt flex cable cover on the left.
    • Remove two more 1.3 mm screws from the Thunderbolt cable cover on the right.
  38. MacBook Pro 16" 2019 Battery Replacement: adım 38, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 38, 2 resimden 2.
    • Remove the cover brackets from both Thunderbolt cable sockets.
  39. MacBook Pro 16" 2019 Battery Replacement: adım 39, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 39, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 39, 3 resimden 3.
    • Use a spudger to disconnect the left-side Thunderbolt flex cable by prying it straight up from the logic board.
    • Pry from the inside edge, nearest the fan.
    • Gently push the flex cable connector off to the side so it doesn't interfere with logic board removal.
  40. MacBook Pro 16" 2019 Battery Replacement: adım 40, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 40, 2 resimden 2.
    • Repeat to disconnect the Thunderbolt flex cable connector on the opposite side.
    • Carefully push the flex cable connector aside so there's clearance for the logic board to come out without snagging.
  41. MacBook Pro 16" 2019 Battery Replacement, Disconnect the keyboard cable: adım 41, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disconnect the keyboard cable: adım 41, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement, Disconnect the keyboard cable: adım 41, 3 resimden 3.
    • Peel back the tape covering the keyboard cable connector.
  42. MacBook Pro 16" 2019 Battery Replacement: adım 42, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 42, 2 resimden 2.
    • Use a spudger to gently pry straight up on the long locking flap on the ZIF connector for the keyboard cable.
    • Because this ZIF connector is so long, the locking flap is fragile. Be careful and pry up slowly and in the middle so it doesn't snap.
  43. MacBook Pro 16" 2019 Battery Replacement: adım 43, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 43, 2 resimden 2.
    • Disconnect the keyboard cable by sliding it out from its socket on the logic board.
    • Pull in the direction of the cable.
    • If possible, pull on the tape attached to the cable, rather than the cable itself, to reduce the risk of damage.
  44. MacBook Pro 16" 2019 Battery Replacement, Disconnect the left speaker: adım 44, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disconnect the left speaker: adım 44, 2 resimden 2.
    • Peel back any tape covering the left speaker cable connector.
  45. MacBook Pro 16" 2019 Battery Replacement: adım 45, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 45, 2 resimden 2.
    • Open the locking flap on the left speaker cable's ZIF connector by prying it straight up from the logic board.
  46. MacBook Pro 16" 2019 Battery Replacement: adım 46, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 46, 2 resimden 2.
    • Disconnect the left speaker by pulling its cable away from the logic board until it releases from its socket.
  47. MacBook Pro 16" 2019 Battery Replacement, Disconnect the right speaker: adım 47, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disconnect the right speaker: adım 47, 2 resimden 2.
    • Peel back any tape covering the right speaker cable connector.
  48. MacBook Pro 16" 2019 Battery Replacement: adım 48, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 48, 2 resimden 2.
    • Open the locking flap on the right speaker cable's ZIF connector by prying it straight up from the logic board.
  49. MacBook Pro 16" 2019 Battery Replacement: adım 49, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 49, 2 resimden 2.
    • Disconnect the right speaker by pulling its cable away from the logic board until it releases from its socket.
  50. MacBook Pro 16" 2019 Battery Replacement, Disconnect the keyboard backlight: adım 50, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disconnect the keyboard backlight: adım 50, 2 resimden 2.
    • Peel back any tape covering the first keyboard backlight cable connector.
    my model doesnt have this.
    Anton Mostovoy - Yanıt
  51. MacBook Pro 16" 2019 Battery Replacement: adım 51, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 51, 2 resimden 2.
    • Open the locking flap on the keyboard backlight's ZIF connector by prying it straight up from the logic board.
    Use a toothpick to roll under ribbon to release from logic board.
  52. MacBook Pro 16" 2019 Battery Replacement: adım 52, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 52, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 52, 3 resimden 3.
    • Disconnect the keyboard backlight by pulling its cable away from the logic board until it releases from its socket.
    • Move the cable away from its connector so it can more easily clear the logic board during removal.
  53. MacBook Pro 16" 2019 Battery Replacement, Disconnect the right fan: adım 53, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disconnect the right fan: adım 53, 2 resimden 2.
    • Peel back any tape covering the right fan connector.
  54. MacBook Pro 16" 2019 Battery Replacement: adım 54, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 54, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 54, 3 resimden 3.
    • Open the locking flap on the right fan's ZIF connector by prying it straight up from the logic board.
    • Disconnect the right fan by pulling its cable away from the logic board until it releases from its socket.
  55. MacBook Pro 16" 2019 Battery Replacement, Disconnect the left fan: adım 55, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disconnect the left fan: adım 55, 2 resimden 2.
    • Peel back any tape covering the left fan connector.
  56. MacBook Pro 16" 2019 Battery Replacement: adım 56, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 56, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 56, 3 resimden 3.
    • Open the locking flap on the left fan's ZIF connector by prying it straight up from the logic board.
    • Disconnect the left fan by pulling its cable away from the logic board until it releases from its socket.
  57. MacBook Pro 16" 2019 Battery Replacement, Disconnect the other keyboard backlight: adım 57, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disconnect the other keyboard backlight: adım 57, 2 resimden 2.
    • Peel back any tape covering the other keyboard backlight connector.
  58. MacBook Pro 16" 2019 Battery Replacement: adım 58, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 58, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 58, 3 resimden 3.
  59. MacBook Pro 16" 2019 Battery Replacement, Disconnect the microphone array: adım 59, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disconnect the microphone array: adım 59, 2 resimden 2.
    • Peel back any tape covering the microphone array connector.
  60. MacBook Pro 16" 2019 Battery Replacement: adım 60, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 60, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 60, 3 resimden 3.
    • Open the locking flap on the microphone array's ZIF connector by prying it straight up from the logic board.
    • Disconnect the microphone array by pulling its cable away from the logic board until it releases from its socket.
  61. MacBook Pro 16" 2019 Battery Replacement, Disconnect the antenna bundle: adım 61, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Disconnect the antenna bundle: adım 61, 2 resimden 2.
    • Use a T5 Torx driver to remove the single 2.9 mm screw securing the antenna cable bundle.
  62. MacBook Pro 16" 2019 Battery Replacement: adım 62, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 62, 2 resimden 2.
    • Disconnect all three antenna cables by prying each one straight up from its socket.
    • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
    • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
    One tip to make logic board removal and replacement easier, is to carefully tape all the flexes back out of the way. This makes it a lot easier, trust me. Paul Daniels of FlexBV fame taught me this https://pldaniels.com/flexbv/ See photo of taped back flexes here https://i.imgur.com/eriX0KV.jpg
    Peter Newman - Yanıt
  63. MacBook Pro 16" 2019 Battery Replacement, Remove the logic board screws: adım 63, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Remove the logic board screws: adım 63, 2 resimden 2.
    • Remove all eleven screws securing the logic board assembly:
    • Three 3.3 mm T3 Torx screws
    • Two 3.6 mm T5 Torx screws
    • Four 2.9 mm T5 Torx screws
    • One 4.0 mm T8 Torx screw
    • One 4.0 mm T8 Torx screw (large head)
    • During reassembly, install these screws only loosely. Adjust the board position if necessary until all the connectors line up, and then tighten the screws.
  64. MacBook Pro 16" 2019 Battery Replacement, Remove the logic board: adım 64, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement, Remove the logic board: adım 64, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement, Remove the logic board: adım 64, 3 resimden 3.
    • Peel up (but don't remove) the rubber vibration damping strip from the adhesive holding it to the fan.
    • If needed, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive and make the dampers easier to separate.
    • Repeat for the other adhesive strip on the opposite fan.
  65. MacBook Pro 16" 2019 Battery Replacement: adım 65, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 65, 2 resimden 2.
    • The logic board assembly is a tight fit, but you can make it easier to remove by inserting a spudger under the left edge and levering it up slightly.
    • There should be no resistance as you remove the logic board. Check all cables carefully and hold them out of the way if needed so they don't snag on the board.
  66. MacBook Pro 16" 2019 Battery Replacement: adım 66, 1 resimden 1.
    • Lifting from the left side, remove the logic board.
  67. MacBook Pro 16" 2019 Battery Replacement: adım 67, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 67, 2 resimden 2.
    • When reinstalling the logic board assembly:
    • Feed the antenna cable bundle through the gap between the logic board and heat sink, and make sure it lines up correctly as you lower the board into place.
    • Verify that no cables get trapped under the board as you install it. Check each of the fifteen marked locations carefully.
    So easy to refit the logic board with all the flexes taped back out of the way. The only way to go IMO https://i.imgur.com/1fiRGhe.jpg
    Peter Newman -
  68. MacBook Pro 16" 2019 Battery Replacement, Battery: adım 68, 1 resimden 1.
    • Use a T5 Torx driver to remove the 5.1 mm screw securing the battery board.
  69. MacBook Pro 16" 2019 Battery Replacement: adım 69, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 69, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 69, 3 resimden 3.
    • The liquid adhesive remover provided in your kit can damage the antireflective coating on your MacBook Pro's display, as well as the plastic keyboard keys.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
    • Additionally, use painter's tape to seal off the area under the trackpad as best you can. Optionally, you may also layer an absorbent towel directly underneath the trackpad area to soak up any excess adhesive remover.
  70. MacBook Pro 16" 2019 Battery Replacement: adım 70, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 70, 2 resimden 2.
    • To control the flow of adhesive remover, raise the back edge (hinge side) of your MacBook Pro a few inches using a book or foam block.
  71. MacBook Pro 16" 2019 Battery Replacement: adım 71, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 71, 2 resimden 2.
    • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
  72. MacBook Pro 16" 2019 Battery Replacement: adım 72, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 72, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 72, 3 resimden 3.
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
  73. MacBook Pro 16" 2019 Battery Replacement: adım 73, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 73, 2 resimden 2.
    • Apply a few drops of adhesive remover underneath the two battery cells on the right, starting along the edge nearest the fan.
    • You don't need to use very much. The small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
  74. MacBook Pro 16" 2019 Battery Replacement: adım 74, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 74, 2 resimden 2.
    • Add a few more drops of adhesive remover in between the two battery cells on the right, so that it flows down underneath the lower battery cell.
    • Wait about two minutes for the liquid adhesive remover to penetrate and weaken the battery adhesive before you proceed to the next step.
  75. MacBook Pro 16" 2019 Battery Replacement: adım 75, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 75, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 75, 3 resimden 3.
    Plastic Cards
    $2.99
    • After a couple minutes, insert one corner of a plastic card underneath the battery, starting from the lower edge of the bottom, right-most cell.
    • This shouldn't require much force. If you have trouble, apply more adhesive remover and give it 2-3 additional minutes to penetrate.
    • Try not to deform the battery. A damaged or punctured battery can leak dangerous chemicals and/or catch fire.
    • Wiggle the card from side to side and slide it all the way underneath both battery cells.
    • Lift the cells to fully separate the adhesive, but don't try to remove them from your MacBook yet.
    • Leave the plastic card temporarily underneath the cells to prevent the adhesive from re-bonding as you proceed to the next step.
  76. MacBook Pro 16" 2019 Battery Replacement: adım 76, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 76, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 76, 3 resimden 3.
    • Switch to the left side of the MacBook Pro, and repeat the previous step to separate two more battery cells.
    • Leave the second plastic card in place temporarily.
  77. MacBook Pro 16" 2019 Battery Replacement: adım 77, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 77, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 77, 3 resimden 3.
    • Apply a few drops of adhesive remover along the top edges of the two center battery cells.
    • There are openings in the chassis underneath these two cells, which allow the adhesive remover to leak through and may prevent it from fully penetrating.
    • Be mindful of leaks, and apply more adhesive remover along the side edges if needed.
  78. MacBook Pro 16" 2019 Battery Replacement: adım 78, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 78, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 78, 3 resimden 3.
    • After a couple minutes, retrieve your first plastic card and insert one corner under the top edge of one of the center battery cells.
    • Wiggle it from side to side and slide it underneath the battery cell until all the adhesive separates.
    • If you have trouble, don't use excessive force and don't deform the battery. Apply more adhesive remover and try again, or skip down two steps for an alternate method.
  79. MacBook Pro 16" 2019 Battery Replacement: adım 79, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 79, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 79, 3 resimden 3.
    • Retrieve your second plastic card and repeat the previous step to separate the remaining center battery cell.
  80. MacBook Pro 16" 2019 Battery Replacement: adım 80, 1 resimden 1.
    • If you had trouble getting the card underneath any of the battery cells, try working a piece of floss or wire underneath the battery cell and pull it side-to-side in a sawing motion to separate the adhesive.
    • Wear thick gloves or wrap the floss around a couple of driver handles so as not to hurt your fingers.
  81. MacBook Pro 16" 2019 Battery Replacement: adım 81, 2 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 81, 2 resimden 2.
    • Lift and remove the battery.
    • Before installing a new battery, remove all remaining adhesive from the MacBook Pro's case.
    • Peel off any large strips of adhesive using tweezers or gloved fingers.
    • Scrape away any remaining chunks of adhesive with a plastic tool, and clean the underlying areas with adhesive remover or isopropyl alcohol. Wipe in one direction (not back and forth) until the chassis is clean and ready for your new battery.
    • This can take quite a bit of work, so be patient.
  82. MacBook Pro 16" 2019 Battery Replacement: adım 82, 3 resimden 1. MacBook Pro 16" 2019 Battery Replacement: adım 82, 3 resimden 2. MacBook Pro 16" 2019 Battery Replacement: adım 82, 3 resimden 3.
    Tesa 61395 Tape
    $12.99
    • Double-check the fit and alignment of your new battery before sticking it down.
    • If your battery came with adhesive pre-installed on the bottom, flip it over and carefully peel away the liner to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to keep your battery in place.
    • Carefully position the battery and set it into place.
    • Press and hold each cell firmly for 5-10 seconds to secure it to the lower case.
Sonuç
Repair didn’t go as planned? Ask our Answers community for troubleshooting help.
64 farklı kişi bu kılavuzu tamamladı.
Carsten Frauenheim
136.836 İtibar
371 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
120 Üyeler
19.660 adet Kılavuz yazıldı
46Kılavuz Yorumları
Holy cow that is a lot of steps
T J - Yanıt
Amazing. This is truly thorough, and as soon as this battery starts to fail, will come back here. Nice work documenting a whole assembly line.
antoniogonzalo - Yanıt
If I want to replace my fans, it looks like I can follow this guide to step 66 and then just figure it out from there? Is there a guide somewhere on this? Thanks!
Matt - Yanıt
You can do as you wrote for replacing only the fan. Ther’s nothing more to know about it.
Daniele Carminati -
I see that the MacBook Pro 13 logic board remains in place in iFixit battery replacement guide. Is there any reason why in the MacBook Pro 16 the logic board cannot remain in place while removing and reinstalling the battery?
andremengatti - Yanıt
Yes, there are two battery cables running under the logic board, clearly visible at step 68. No way to put the battery back with the logic board in place.
I recently did the 15” 2017 Macbook Pro battery replacement and that seemed more difficult than this one due to the speaker connectors. In my opinion, this 16” replacement can be marked as Moderate.
Cristian Caprar -
Because the battery connector is underneath the logic board here.
Peter H -
it’s not just iFixit guide,different types of MacBooks have different ways of fixing them.
azam -
No, the battery is not trapped under the logic board. Moreover, that connector is under the logic board, but not blocked from sliding out by screws. The only reason would be to prevent the logic board from getting dissolved by the adhesive remover. Also, if you nudge the connector up with your finger, you can slide the entire battery out. If you only pry at the battery and don't intend to use any alcohol or adhesive remover, you don't need to remove the board.
Matthew Yang -
Great guide! Wow! Definitely not for the faint of heart! Thanks Carsten!
timberwilde - Yanıt
This is definitely a difficulty repair. I caused some damage to the speaker, likely while trying to get the battery out. (Luckily, that will be a very simple repair)
I definitely recommend double checking that you have all right screwdrivers, scrapers/spudgers, adhesive dissolvers, screw locker and a tray with lots of compartments to keep everything organized. I have done multiple complex repairs of mac laptops in the past including screen replacements, logic board replaceements and other battery replacements and this was the most difficult. I am very glad future generations included pull tabs for the adhesive.
owenbrewer4 - Yanıt
Indeed, the speakers have strong magnets, and require t be very careful with any metal parts getting close to them.
A note should be added in this tutotial, very easy to get in trouble.
Adrien Haage -
Thanks for the guide!
FWIW I skipped about half the steps, and used spudgers to angle the motherboard up, in order to remove the battery. I'll list the steps I followed below:
1-21
27-29
35-36
41-49
53-54
61
63
68
I use 99% isopropyl alcohol, and an ifixit plastic card to cut through the battery adhesive. TBH that was the most time-consuming part, because I like to let the alcohol melt the adhesive a bit before cutting, in order to minimize the amount of pressure I have to apply.
The reason I skipped a lot of steps is to minimize risk, and also to save time. Thankfully the battery ribbons were easy to slide underneath the board, once the board was angled up a bit.
Menelik Seth - Yanıt
What a nightmare... There's no way this wasn't done in purpose.
2 years in and the battery's already dead. That's insane.
James Bissick - Yanıt
This took longer than expected due to the logic board removal, but wasn’t too difficult and everything went to plan.
Note that you need to be REALLY careful with the ZIF connector latches like on the battery board and logic board, they are very fragile and I had to re-attach the latch for one of them.
Leo Best - Yanıt
OMG!! I did not know that the process to change out the battery on the 2019 MBP was so intense. My old 2009 MBP was "cake walk" compared to this. Thanks for the HOW TO
Michael Lucas - Yanıt
For Step 16:
What does "damage" mean in this case? I have one of these that I was attempting to clean, so I lifted the battery power connector up, but I can't swear it didn't make contact. When I was trying to lay it down flat I thought it would stay flat until I put the screw in, but it popped back up a short way. I then held it down & put the screw it - now my MBP isn't powering on. Did this damage the logic board?
AppleGamingSE - Yanıt
Nevermind my prior; took it to a local shop & they said it has liquid damage on logic board. Sending back to seller.
AppleGamingSE -
Does this battery replacement guide also apply for the 2020 model or is it the guide for the 2021 model one needs to follow?
Sven - Yanıt
Woo hoo! Just finished. I don’t know who could do this battery repair on the quicker side of that range—mine took over 5 hours. Granted, I also redid the thermal paste on my CPU and my GPU. In addition, the old battery was really stuck in there, so that took extra time. Nonetheless, now I have more experience and, no need to buy a new computer ! Thanks, iFixIt !
Peter - Yanıt
Carsten did an excellent job in providing the correct information to do the job. But let us ALL NOT FORGET, this convoluted way of replacing a battery (something that would be considered a common and ordinary everyday routine need) is Apple's good faith attempt at preventing the everyday consumer from replacing their own battery in their own device. Take for example myself when it takes 80+ steps to change a battery, and provided I were wealthy, I'd have someone replace the battery for me. Not everyone is wealthy or similarly situated. Make sure you don't forget to encourage your elected officials in the U.S. Congress to vote to allow us Americans our right to repair our devices ourselves without long, drawn out, encumbering, and convoluted ways of doing it. Can you imagine how blinded in the night we would be if we had to go through all this just to change the batteries in our flashlights? We're no longer in the dark ages. I for one, am not prepared to go back even if Apple likes it or not.
Martin Dixon - Yanıt
Is there a way to replace the battery without removing everything? I can just slide the big battery out of my Dell Latitude E6500 and pop another one in. However, can I replace the battery in my 2019 MBP 16" without having to remove everything?
Matthew Yang - Yanıt
Unfortunately no. That's how it needs to be done.
Comparing a 2008 Dell Latitude to a 2019 macbook pro and expecting the repair process to be about the same difficulty, is actually outrageous.
The Dell Latitude E6500 is a brick. It doesn't require all the components to be compact and organised in such a complex way. It's no surprise that with thinner and more modern architecture the hardware is more difficult to repair.
Andrew -
The repair guide is awesome. Unfortunately, replacing the battery didn't bring the machine back to life. Sadness!
But the repair guide was great. I felt very confident throughout.
Ken C. - Yanıt
Same with me. Did you figure out what was wrong with your machine? Replacing the battery was my best guess at what was wrong with my machine and now I'm stuck. Hopefully you had some luck diagnosing your issue?
Josef A -
Excellent guide
If I replace the battery, why coconut tool said that the manufacture date is 2013-03-18, is that normal?
Jaime Larios - Yanıt
It's crazy how this version of the 16 inch Macbook Pro requires this many steps. Thank you for the time and patience collate this in-depth guide!
Zhen - Yanıt
So I just completed the whole sequence and everything went fine, really really well done Carsten! Only thing that went wrong is minor but still annoying: it seems I broke the left keyboard backlight cable. What to do in such a case?
Yann Coppier - Yanıt
Little extra onfo: I can't seem to find that part anywhere, and I can see the ribbon is slightly ripped in its angle, which must have happened when I put the logic board back in place. I can live without it, but it is strange having a keyboard lit only on one side... so any hint will be appreciated.
Yann Coppier -
Yann,
Thank you for the kind words! Unfortunately, the keyboard, keyboard backlight, and their cables are integral to the laptop's upper case.
So thankful for this guide. Was able to resurrect an old unit that was collecting dust. Knew issue had to be the battery. Yes, a lot of steps; though, followed closely, you will succeed!!
rwsims77008 - Yanıt
3hours, with precaution and coffee time. All step are not so complicate. The unique attention is for the batterie removal. And cleaning step. So thanks for this tutorial.
Christophe PAYET - Yanıt
Really thank you Carsten for this majestic guide, but shame on Apple for doing this job. I spent like 8 hours for doing everything (I know, I'm quite slow) and I even punctured the old battery while using the plastic card. I was a nightmare.
Hopefully, we will have easy-to-replace batteries by 2027 thanks to the European Union.
Special thanks to the Italian translators too, Grazie!
Gianluca Iuliano - Yanıt
Do you seriously have to disconnect everything from power before removing the battery or can you just disconnect the battery and replace it with a new one? That just seems excessive.
But if their is a reason, I’d love to know
William Williams - Yanıt
Is there any way to test if I'm having a battery issue? Can I boot the computer if I disconnect the battery? Currently the computer is completely dead and gives no sign of life what ever I do.
Isak Dunér - Yanıt
As everyone else commented - excellent guide. I got through everything, powered it up, and everything seemed great. At this point it was late and I went to bed. The next morning, after logging in, the screen went black - never to power up again. The battery data cable showed some signs of overheating. Everything looked aligned, oriented correctly, etc. I must have had the cable slightly rotated in the socket or something. Not sure it is worth retrying with another battery data cable. Anyone else have a similar issue?
Scott Adams - Yanıt
Tedious tedious tedious. The screws are smaller than a strand of hair, so take extra care.
This guide also didn't exactly match my mac, it might've been a different model year, since I was missing various cables and screws to remove. Still very helpful nonetheless, and yeah it takes a long time.
Battery ribbon cable = extremely fragile
Mason Methot - Yanıt
My battery replacement went well, works great but now it can be heard clunking around on the inside.
Drew Thompson - Yanıt
does the part include the adhesive remover or do I have to purchase it separately?
Johann Easton - Yanıt
Adhesive remover is included, but you might prefer lighter fuel. This is working equally well and may be not as poisonous as the included toluene
– besides, in reminds me of the time when I had a Zippo (c:
Klaus Finke -
Explication très concise et facile. Suivre. Très beau travail. Merci au contributeur.
Didielus - Yanıt
Thanks for the guide.
Reynaldo Santos - Yanıt
There are 7 or 8 different sizes of T3 screws. Aside from the larger few the others are completely interchangeable, which I found out after accidentally knocking over my carefully laid out grid. Ridiculously over-engineered. The Juicero of laptops.
PSQuerty - Yanıt
Just finished. Two days. One day out, one day back in. The macbook booted up and is back in business.
I had to use the trick mentioned in the comments to tape the flexies back to get the logic board back in.
I'll count this battery replacement as an example of peak Apple user hostility.
David Johnston - Yanıt
How long to charge the new battery before it can boot up?
I’m not getting any signs of life.
some jerk - Yanıt
New batteries come's with a factory charge. It should boot up the moment you press power. HTH.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 111
Son 7 gün: 1,047
Son 30 gün: 5,666
Her zaman: 168,169
