Ana içeriğe geç
Microsoft Surface Laptop 3 13.5" Battery Replacement
Neye ihtiyacın var
  1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Flip the laptop over: adım 1, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Flip the laptop over: adım 1, 2 resimden 2.
    • Flip the laptop over and place it on your work surface, feet facing up.
  2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Removal tip: adım 2, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Removal tip: adım 2, 2 resimden 2.
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
  3. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the rear feet: adım 3, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the rear feet: adım 3, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the rear feet: adım 3, 3 resimden 3.
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
  4. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the front feet: adım 4, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the front feet: adım 4, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the front feet: adım 4, 3 resimden 3.
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
  5. Microsoft Surface Laptop 3 13.5" Battery Replacement, Reassembly tip: adım 5, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Reassembly tip: adım 5, 2 resimden 2.
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
  6. Microsoft Surface Laptop 3 13.5" Battery Replacement, Reassembly tip: adım 6, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Reassembly tip: adım 6, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Reassembly tip: adım 6, 3 resimden 3.
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
  7. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the upper case screws: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Use a T5 Torx driver to remove the four 3 mm screws in the foot cavities securing the upper case to the device.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
    • During reassembly, don't over-tighten these screws—they strip easily.
  8. Microsoft Surface Laptop 3 13.5" Battery Replacement, Open the display: adım 8, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Open the display: adım 8, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Open the display: adım 8, 3 resimden 3.
    • Flip the device over.
    • Open the display as far as it will go.
  9. Microsoft Surface Laptop 3 13.5" Battery Replacement, Lift up the upper case: adım 9, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Lift up the upper case: adım 9, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Lift up the upper case: adım 9, 3 resimden 3.
    • The upper case is secured in place by magnets.
    • Grip the top edge of upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case just yet, as it's still connected to the rest of the laptop.
    • Lift the front edge of the upper case up and away from the laptop, taking care to not strain the keyboard and touchpad ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the display could cause damage to the display as it closes.
  10. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the ribbon cable: adım 10, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the ribbon cable: adım 10, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the ribbon cable: adım 10, 3 resimden 3.
    • The keyboard and touchpad ribbon cable is secured in place by a magnet connector.
    • On some models, this connector is surrounded by black tape.
    • Insert the flat end of a spudger underneath one edge of the ribbon cable connector, and pry up to release it.
    • Remove the ribbon cable from the motherboard.
  11. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the upper case: adım 11, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the upper case: adım 11, 2 resimden 2.
    • Remove the upper case.
    • Set the upper case onto a clean surface, keyboard-side down.
    • Ensure the ribbon cable lays flat, and isn't twisted or stressed.
  12. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the SSD screw: adım 12, 1 resimden 1.
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • Removing the SSD also functions as a battery disconnect and should be performed before all major repairs.
  13. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the SSD: adım 13, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the SSD: adım 13, 2 resimden 2.
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the end of the SSD and pull it away from its board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
  14. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the tape: adım 14, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the tape: adım 14, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the tape: adım 14, 3 resimden 3.
    • Use a pair of tweezers to remove the two pieces of black tape covering the bottom left and bottom right corners of the motherboard.
    • During reassembly, reapply the tape if it's sticky enough to be reused.
  15. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the heatsink shield: adım 15, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the heatsink shield: adım 15, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the heatsink shield: adım 15, 3 resimden 3.
    • Insert the tip of one arm of a sharp pair of tweezers into one of the holes near the top left corner of the heatsink shield.
    • Pull upwards to release the top left corner of the shield.
    • This may require a considerable amount of force, but try not to deform the shield too much—you'll need to reinstall it during reassembly.
  16. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 16, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 16, 2 resimden 2.
    • Repeat the previous step's procedure to release the top right corner of the heatsink shield.
  17. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 17, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 17, 2 resimden 2.
    • Continue along the heatsink's top edge, inserting a tweezer arm into the shield holes and prying upwards on each one as you go.
  18. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 18, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 18, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 18, 3 resimden 3.
    • Once the top edge is loose, use your fingers to grip the top of the shield and pull it up and away from the heatsink to release the remainder of the shield.
    • Try not to deform the shield too much—you'll need to reinstall it during reassembly.
    • Completely remove the heatsink shield.
  19. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the cooling fan: adım 19, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the cooling fan: adım 19, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the cooling fan: adım 19, 3 resimden 3.
    • Use the pointed end of a spudger to flip up the locking flap on the fan cable's ZIF connector.
    • Use a pair of tweezers to pull the fan cable straight out of the connector.
  20. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the heatsink screws: adım 20, 1 resimden 1.
    • Use a T3 Torx driver to remove the nine screws securing the heatsink:
    • One 2.5 mm screw
    • Three 2.0 mm screws
    • One 3.0 mm screw
    • Two 4.1 mm screws
    • Two 3.4 mm screws
  21. Microsoft Surface Laptop 3 13.5" Battery Replacement, Reassembly tip: adım 21, 1 resimden 1.
    • Align the heatsink with the centering peg on the motherboard.
    • Tighten the four CPU tension screws in an "X" pattern.
  22. Microsoft Surface Laptop 3 13.5" Battery Replacement, Clear the alignment peg: adım 22, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Clear the alignment peg: adım 22, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Clear the alignment peg: adım 22, 3 resimden 3.
    • Use the tip of your finger to lift the far right edge of the heatsink up and off of the small alignment peg near the right side of the fan on the lower case.
    • Once the heatsink has cleared the peg, lightly pull the right edge towards the front of the device.
  23. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the heatsink: adım 23, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the heatsink: adım 23, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the heatsink: adım 23, 3 resimden 3.
    • Remove the heatsink.
    • If the heatsink feels stuck to the CPU, gently wiggle it side-to-side to separate it from the thermal paste holding it down.
    • Don't pull on the heatsink too hard; the heat pipes are susceptible to creasing.
  24. Microsoft Surface Laptop 3 13.5" Battery Replacement, Reapply thermal paste: adım 24, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Reapply thermal paste: adım 24, 2 resimden 2.
    • Before reinstalling the heatsink, follow this guide to clean the heatsink and CPU and reapply thermal paste.
  25. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the motherboard shields: adım 25, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the motherboard shields: adım 25, 2 resimden 2.
    • Some motherboard screws are located under two of the metal shields, both of which need to be removed.
    • Use an opening tool to pry up an edge of the metal shield covering the right side of the motherboard.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
    • Work your way around the perimeter of the shield, prying up intermittently, until you can remove it completely.
    • Remove the shield.
  26. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 26, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 26, 2 resimden 2.
    • Repeat the previous step to remove the second shield from the left side of the motherboard, closest to the CPU.
  27. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the right speaker: adım 27, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the right speaker: adım 27, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the right speaker: adım 27, 3 resimden 3.
    • Use the pointed end of a spudger to lift and disconnect the right speaker wire from its connector on the motherboard.
  28. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the Surface Connect port: adım 28, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the Surface Connect port: adım 28, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the Surface Connect port: adım 28, 3 resimden 3.
    • Use an opening tool to flip open the gold locking arm on the Surface Connect port's motherboard connector.
  29. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 29, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 29, 2 resimden 2.
    • Grip the Surface Connect port cable and pull it away from its connector to remove it.
  30. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the left speaker: adım 30, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the left speaker: adım 30, 2 resimden 2.
    • Use the pointed end of a spudger to lift and disconnect the left speaker wire from its connector on the motherboard.
  31. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the display connector shields: adım 31, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the display connector shields: adım 31, 2 resimden 2.
    • Use an opening tool to pry up the black shield covering the right bank of display connectors.
    • Repeat at different points around the shield until it becomes loose.
  32. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 32, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 32, 2 resimden 2.
    • Repeat the previous step to remove the remaining shield from the left bank of display connectors.
  33. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the display cables: adım 33, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the display cables: adım 33, 2 resimden 2.
    • Use the flat end of a spudger to pry the first display cable up and out of its socket on the motherboard to disconnect it.
  34. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 34, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 34, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 34, 3 resimden 3.
    • Disconnect the three remaining display connectors.
  35. Microsoft Surface Laptop 3 13.5" Battery Replacement, Reassembly tip: adım 35, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Reassembly tip: adım 35, 2 resimden 2.
    • During reassembly, use the flat end of a spudger to gently push the display cables back into their cavity in the lower case.
  36. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the antenna cable: adım 36, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the antenna cable: adım 36, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Disconnect the antenna cable: adım 36, 3 resimden 3.
    • Use a pair of tweezers to grip the antenna cable close to its base.
    • Pull straight up to disconnect the cable.
  37. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the motherboard bracket: adım 37, 1 resimden 1.
    • Use a T3 Torx driver to remove the two 3 mm screws securing the motherboard bracket.
  38. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 38, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 38, 2 resimden 2.
    • Use a pair of tweezers to remove the motherboard bracket.
  39. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the motherboard screws: adım 39, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the motherboard screws: adım 39, 2 resimden 2.
    • Use a T3 Torx driver to remove the six 2 mm screws securing the motherboard.
    • Optionally, to simplify motherboard removal, use a T3 Torx driver to remove the three screws securing the port bracket, then remove the bracket.
  40. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the motherboard: adım 40, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the motherboard: adım 40, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the motherboard: adım 40, 3 resimden 3.
    • Use your fingers to lift and remove the motherboard.
    • If the motherboard feels stuck, slide the motherboard to the right so the I/O ports clear their cutouts on the chassis.
    • Ensure the two screwpost braces underneath the motherboard don't get lost during removal.
  41. Microsoft Surface Laptop 3 13.5" Battery Replacement, Check cables during reassembly: adım 41, 1 resimden 1.
    • When you reinstall the motherboard, verify that no cables get trapped under the board as you lower it into place. Check each of the five locations carefully:
    • Four display cables
    • Antenna cable
    • Left speaker cable
    • Surface Connect cable
    • Right speaker cable
  42. Microsoft Surface Laptop 3 13.5" Battery Replacement, Loosen the battery contact cable adhesive: adım 42, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Loosen the battery contact cable adhesive: adım 42, 2 resimden 2.
    • Heat an iOpener and lay it on top of the battery contact cable for about a minute, in order to soften the adhesive securing it to the case.
    • If you don't have an iOpener, use a hair dryer to warm up the cable instead.
  43. Microsoft Surface Laptop 3 13.5" Battery Replacement, Separate the battery contact cable: adım 43, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Separate the battery contact cable: adım 43, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Separate the battery contact cable: adım 43, 3 resimden 3.
    • Slide an opening pick underneath the battery contact cable to separate it from the case.
    • If the adhesive is stubborn, don't force the pick. Lightly reheat the cable and try again.
    • During reassembly, note that the contact cable is centered in place with both a screwpost and an alignment peg.
  44. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the battery screws: adım 44, 1 resimden 1.
    • Use a T3 Torx driver to remove the six 2.7 mm screws securing the battery to the case.
  45. Microsoft Surface Laptop 3 13.5" Battery Replacement, Loosen the battery adhesive: adım 45, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Loosen the battery adhesive: adım 45, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Loosen the battery adhesive: adım 45, 3 resimden 3.
    • Apply adhesive remover or high-concentration (90% or higher) isopropyl alcohol to the top edges of all three battery cell groups.
    • If you are using adhesive remover, follow these preparation steps first.
    • Wait 2–3 minutes for the adhesive remover to penetrate and soften the adhesive before you proceed to the next step.
  46. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 46, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 46, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 46, 3 resimden 3.
    Plastic Cards
    $2.99
    • Take care not to puncture or bend the battery with your tools—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Slide a plastic card underneath the far left battery cell group to slice through the adhesive holding it to the case.
    • If you encounter significant resistance at any point during this procedure, pause and apply more adhesive remover. Wait for it to soak into the adhesive, and try again.
    • Wiggle the card from side to side as you insert it under the battery cells to fully separate all adhesive holding them in place.
    • Leave the plastic card temporarily underneath the cell to prevent it from re-adhering while you continue.
  47. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 47, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 47, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 47, 3 resimden 3.
    • Slide a second plastic card underneath the middle battery cell group to slice through the adhesive holding it to the case.
  48. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 48, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 48, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement: adım 48, 3 resimden 3.
    • Slide the card out from under the middle cell group.
    • Leave the card that's underneath the left group in place for now.
    • Slide the plastic card underneath the far right battery cell group to slice through the adhesive holding it to the case.
    • Leave the plastic card temporarily underneath the right cell group to prevent it from re-adhering while you continue.
  49. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the battery: adım 49, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the battery: adım 49, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Battery Replacement, Remove the battery: adım 49, 3 resimden 3.
    Tesa 61395 Tape
    $12.99
    • Use both plastic cards to lift the entire battery assembly up and away from the case.
    • If the battery still feels adhered to the case, reapply adhesive remover and use the plastic cards in problem areas to make sure all three cell groups are fully separated from the case.
    • Remove the battery.
    • During reassembly, double-check the fit and alignment of your new battery before sticking it down.
    • If your battery came with adhesive pre-installed on the bottom, flip it over and carefully peel away the liner to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to keep your battery in place.
    • Carefully position the battery and set it into place. Press and hold each cell group firmly for 5–10 seconds to secure it to the lower case.
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
10 farklı kişi bu kılavuzu tamamladı.
Carsten Frauenheim
136.384 İtibar
371 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.605 adet Kılavuz yazıldı
5 Yorum
Thank you for showing how difficult it is to repair these devices. If it were my personal device, I’d give the task a shot. Instead, this is for work and I have to go with an option other than Surface as I have to be able to repair devices when the battery or other components fail instead of having to replace the entire device.
Little Rich - Yanıt
Wow that is so difficult. I am getting 2-3 hrs battery life. I have done a lot of DIY repairs but this look downright outrageous.
Jonathon Waldes - Yanıt
That was super tedious... but this guide made it possible thank you very much!
Kyle Lepkowski - Yanıt
Here's a question I have, what happens if you don't replace the heat shields on the motherboard? It seems like no matter how careful I tried to be the only real way to get these things off is to almost destroy the pins that are holding them in place so how bad is it for thermals if they're not replaced?
Alex Hooper - Yanıt
Without them the device might not function properly in some cases. These are not heat shields, they are used for electromagnetic interference shielding. I was able to get them off by using a very small flat head screwdriver, just be careful not to tear the PCB. Hardest part was to remove the battery itself. Even with some nail polish remover, had to lightly bend the cells. :(
ernestc -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 33
Son 7 gün: 205
Son 30 gün: 1,027
Her zaman: 36,576
