Ana içeriğe geç
Steam Deck Front Shell Replacement
Neye ihtiyacın var
  1. Steam Deck Front Shell Replacement, Prepare your Steam Deck for disassembly: adım 1, 3 resimden 1. Steam Deck Front Shell Replacement, Prepare your Steam Deck for disassembly: adım 1, 3 resimden 2. Steam Deck Front Shell Replacement, Prepare your Steam Deck for disassembly: adım 1, 3 resimden 3.
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
    FixBot'a Sor
    Yorum Ekle
  2. Steam Deck Front Shell Replacement, Remove the back cover screws: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    FixMat
    $36.95
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four coarse thread 9.5 mm-long screws
    • Four fine thread 5.8 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
    FixBot'a Sor
    Yorum Ekle
  3. Steam Deck Front Shell Replacement, Unclip the back cover: adım 3, 2 resimden 1. Steam Deck Front Shell Replacement, Unclip the back cover: adım 3, 2 resimden 2.
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
    FixBot'a Sor
    Yorum Ekle
  4. Steam Deck Front Shell Replacement, Remove the back cover: adım 4, 3 resimden 1. Steam Deck Front Shell Replacement, Remove the back cover: adım 4, 3 resimden 2. Steam Deck Front Shell Replacement, Remove the back cover: adım 4, 3 resimden 3.
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
    FixBot'a Sor
    Yorum Ekle
  5. Steam Deck Front Shell Replacement, Uncover the hidden shield screw: adım 5, 2 resimden 1. Steam Deck Front Shell Replacement, Uncover the hidden shield screw: adım 5, 2 resimden 2.
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
    FixBot'a Sor
    Yorum Ekle
  6. Steam Deck Front Shell Replacement, Remove the shield screws: adım 6, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the shield screws: adım 6, 2 resimden 2.
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
    FixBot'a Sor
    Yorum Ekle
  7. Steam Deck Front Shell Replacement, Remove the shield: adım 7, 3 resimden 1. Steam Deck Front Shell Replacement, Remove the shield: adım 7, 3 resimden 2. Steam Deck Front Shell Replacement, Remove the shield: adım 7, 3 resimden 3.
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
    FixBot'a Sor
    Yorum Ekle
  8. Steam Deck Front Shell Replacement, Disconnect the battery: adım 8, 3 resimden 1. Steam Deck Front Shell Replacement, Disconnect the battery: adım 8, 3 resimden 2. Steam Deck Front Shell Replacement, Disconnect the battery: adım 8, 3 resimden 3.
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
    FixBot'a Sor
    Yorum Ekle
  9. Steam Deck Front Shell Replacement, Unclip the left trigger: adım 9, 2 resimden 1. Steam Deck Front Shell Replacement, Unclip the left trigger: adım 9, 2 resimden 2.
    • The left trigger will be on your right-hand side when working on the Steam Deck, as it's laying upside down.
    • The Steam Deck's triggers clip into place on two pegs on the trigger bracket, which doubles as the hinge.
    • Place the flat end of a spudger onto the inside edge of the trigger's left clip.
    • Pivot the trigger clip out, away, and up from the peg to unlatch it.
    • During reassembly, latch the outermost peg first. Once in place, push down on the trigger to latch the innermost peg, producing an audible "click" sound.
    • Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
    FixBot'a Sor
    Yorum Ekle
  10. Steam Deck Front Shell Replacement, Remove the left trigger: adım 10, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the left trigger: adım 10, 2 resimden 2.
    • Remove the left trigger.
    • Take care to not lose the trigger spring. It press-fits onto a peg on the trigger's underside.
    FixBot'a Sor
    Yorum Ekle
  11. Steam Deck Front Shell Replacement, Remove the trigger bracket screws: adım 11, 1 resimden 1.
    • Use a Phillips driver to remove the three 5.2 mm screws securing the left trigger bracket.
    FixBot'a Sor
    Yorum Ekle
  12. Steam Deck Front Shell Replacement, Remove the trigger bracket: adım 12, 1 resimden 1.
    • Remove the left trigger bracket.
    • Replacement triggers require calibration to work as expected. To calibrate new triggers, follow this calibration guide.
    FixBot'a Sor
    Yorum Ekle
  13. Steam Deck Front Shell Replacement, Disconnect the left thumbstick: adım 13, 3 resimden 1. Steam Deck Front Shell Replacement, Disconnect the left thumbstick: adım 13, 3 resimden 2. Steam Deck Front Shell Replacement, Disconnect the left thumbstick: adım 13, 3 resimden 3.
    • Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
    • Use a pair of tweezers to slide the cable out of its connector.
    • Grip the cable by the blue pull tab, not by the cable itself.
    FixBot'a Sor
    Yorum Ekle
  14. Steam Deck Front Shell Replacement, Remove the thumbstick screws: adım 14, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the thumbstick screws: adım 14, 2 resimden 2.
    • Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
    • During reassembly, you may need to hold the Steam Deck off of the work surface so it isn't resting on the new thumbstick while you tighten down the screws.
    FixBot'a Sor
    Yorum Ekle
  15. Steam Deck Front Shell Replacement, Remove the left thumbstick: adım 15, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the left thumbstick: adım 15, 2 resimden 2.
    • Remove the left thumbstick.
    FixBot'a Sor
    Yorum Ekle
  16. Steam Deck Front Shell Replacement, Disconnect the interconnect cable: adım 16, 3 resimden 1. Steam Deck Front Shell Replacement, Disconnect the interconnect cable: adım 16, 3 resimden 2. Steam Deck Front Shell Replacement, Disconnect the interconnect cable: adım 16, 3 resimden 3.
    • Use the pointed end of a spudger to lift up the small locking flap on the button board interconnect cable's ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  17. Steam Deck Front Shell Replacement, Disconnect the remaining button board cables: adım 17, 3 resimden 1. Steam Deck Front Shell Replacement, Disconnect the remaining button board cables: adım 17, 3 resimden 2. Steam Deck Front Shell Replacement, Disconnect the remaining button board cables: adım 17, 3 resimden 3.
    • If any connectors are covered with tape, use a pair of tweezers to remove it.
    • Use the pointed end of a spudger to lift up the small locking flaps on the rest of the button board ZIF connectors. Use a pair of tweezers to slide the cables out of their connectors:
    • Disconnect the D-pad cable.
    • Disconnect the touchpad board cable.
    • Disconnect the touchpad cable.
    FixBot'a Sor
    Yorum Ekle
  18. Steam Deck Front Shell Replacement, Disconnect the left haptics: adım 18, 3 resimden 1. Steam Deck Front Shell Replacement, Disconnect the left haptics: adım 18, 3 resimden 2. Steam Deck Front Shell Replacement, Disconnect the left haptics: adım 18, 3 resimden 3.
    • Exercise caution when lifting this connector—pry up on the connector itself, not its housing.
    • Use the pointed end of a spudger to lift up on the haptics cable to disconnect it.
    • Alternatively, you can leave the haptics connected to the button board and flip the board up and over the edge of the shell and out of the way.
    FixBot'a Sor
    Yorum Ekle
  19. Steam Deck Front Shell Replacement, Remove the button board screws: adım 19, 1 resimden 1.
    • Use a Phillips driver to disconnect the four screws securing the left button board:
    • Three 5.2 mm screws
    • One 3.9 mm screw
    FixBot'a Sor
    Yorum Ekle
  20. Steam Deck Front Shell Replacement, Remove the button board: adım 20, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the button board: adım 20, 2 resimden 2.
    • Remove the left button board.
    • Keep track of the Steam button and its membrane, as once the left button board is removed, they're no longer secured in place.
    FixBot'a Sor
    Yorum Ekle
  21. Steam Deck Front Shell Replacement, Remove the touchpad board screws: adım 21, 1 resimden 1.
    • Use a Phillips driver to remove the four 4.7 mm screws securing the touchpad board.
    FixBot'a Sor
    Yorum Ekle
  22. Steam Deck Front Shell Replacement, Remove the touchpad board: adım 22, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the touchpad board: adım 22, 2 resimden 2.
    • Remove the touchpad board.
    FixBot'a Sor
    Yorum Ekle
  23. Steam Deck Front Shell Replacement, Remove the touchpad screws: adım 23, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the touchpad screws: adım 23, 2 resimden 2.
    • Use a Phillips driver to remove the four 4.7 mm screws securing the touchpad.
    • You may need to temporarily remove the Steam button membrane for easier access to the bottom left screw.
    • Each of the touchpad's four mounting corners have a locating peg. During reassembly, ensure each is properly seated.
    FixBot'a Sor
    Yorum Ekle
  24. Steam Deck Front Shell Replacement, Remove the left touchpad: adım 24, 3 resimden 1. Steam Deck Front Shell Replacement, Remove the left touchpad: adım 24, 3 resimden 2. Steam Deck Front Shell Replacement, Remove the left touchpad: adım 24, 3 resimden 3.
    • The touchpad's springs are very delicate and are precisely positioned. If bent, the touchpad may rattle or not work as intended.
    • From the front of the Steam Deck, use your finger to push the left touchpad partway through the front shell to unseat it.
    • Lift the touchpad out from underneath the overhanging section of the midframe.
    • Remove the touchpad.
    FixBot'a Sor
    Yorum Ekle
  25. Steam Deck Front Shell Replacement, Unclip the right trigger: adım 25, 2 resimden 1. Steam Deck Front Shell Replacement, Unclip the right trigger: adım 25, 2 resimden 2.
    • The right trigger will be on your left-hand side when working on the Steam Deck, as it's laying upside down.
    • Place the flat end of a spudger onto the inside edge of the trigger's right clip.
    FixBot'a Sor
    Yorum Ekle
  26. Steam Deck Front Shell Replacement, Remove the right trigger: adım 26, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the right trigger: adım 26, 2 resimden 2.
    • Remove the right trigger.
    FixBot'a Sor
    Yorum Ekle
  27. Steam Deck Front Shell Replacement, Remove the trigger bracket screws: adım 27, 1 resimden 1.
    • Use a Phillips driver to remove the three 5.2 mm screws securing the right trigger bracket.
    FixBot'a Sor
    Yorum Ekle
  28. Steam Deck Front Shell Replacement, Remove the trigger bracket: adım 28, 1 resimden 1.
    • Remove the right trigger bracket.
    FixBot'a Sor
    Yorum Ekle
  29. Steam Deck Front Shell Replacement, Disconnect the right thumbstick: adım 29, 3 resimden 1. Steam Deck Front Shell Replacement, Disconnect the right thumbstick: adım 29, 3 resimden 2. Steam Deck Front Shell Replacement, Disconnect the right thumbstick: adım 29, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
  30. Steam Deck Front Shell Replacement, Remove the thumbstick screws: adım 30, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the thumbstick screws: adım 30, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  31. Steam Deck Front Shell Replacement, Remove the right thumbstick: adım 31, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the right thumbstick: adım 31, 2 resimden 2.
    • Remove the right thumbstick.
    FixBot'a Sor
    Yorum Ekle
  32. Steam Deck Front Shell Replacement, Disconnect the button board cable: adım 32, 3 resimden 1. Steam Deck Front Shell Replacement, Disconnect the button board cable: adım 32, 3 resimden 2. Steam Deck Front Shell Replacement, Disconnect the button board cable: adım 32, 3 resimden 3.
    • Use the pointed end of a spudger to lift up the small locking flap on the button board cable's ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  33. Steam Deck Front Shell Replacement, Disconnect the interconnect cable: adım 33, 3 resimden 1. Steam Deck Front Shell Replacement, Disconnect the interconnect cable: adım 33, 3 resimden 2. Steam Deck Front Shell Replacement, Disconnect the interconnect cable: adım 33, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
  34. Steam Deck Front Shell Replacement, Disconnect the remaining button board cables: adım 34, 3 resimden 1. Steam Deck Front Shell Replacement, Disconnect the remaining button board cables: adım 34, 3 resimden 2. Steam Deck Front Shell Replacement, Disconnect the remaining button board cables: adım 34, 3 resimden 3.
    • Disconnect the action buttons cable.
    FixBot'a Sor
    Yorum Ekle
  35. Steam Deck Front Shell Replacement, Disconnect the right haptics: adım 35, 3 resimden 1. Steam Deck Front Shell Replacement, Disconnect the right haptics: adım 35, 3 resimden 2. Steam Deck Front Shell Replacement, Disconnect the right haptics: adım 35, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
  36. Steam Deck Front Shell Replacement, Remove the button board screws: adım 36, 1 resimden 1.
    • Use a Phillips driver to disconnect the four screws securing the right button board:
    • One 3.9 mm screw
    FixBot'a Sor
    Yorum Ekle
  37. Steam Deck Front Shell Replacement, Remove the button board: adım 37, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the button board: adım 37, 2 resimden 2.
    • Remove the right button board.
    • Keep track of the quick access button and its membrane, as once the right button board is removed, they're no longer secured in place.
    FixBot'a Sor
    Yorum Ekle
  38. Steam Deck Front Shell Replacement, Remove the touchpad board screws: adım 38, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  39. Steam Deck Front Shell Replacement, Remove the touchpad board: adım 39, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the touchpad board: adım 39, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  40. Steam Deck Front Shell Replacement, Remove the touchpad screws: adım 40, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the touchpad screws: adım 40, 2 resimden 2.
    • You may need to temporarily remove the quick access button membrane for easier access to the bottom right screw.
    FixBot'a Sor
    Yorum Ekle
  41. Steam Deck Front Shell Replacement, Remove the right touchpad: adım 41, 3 resimden 1. Steam Deck Front Shell Replacement, Remove the right touchpad: adım 41, 3 resimden 2. Steam Deck Front Shell Replacement, Remove the right touchpad: adım 41, 3 resimden 3.
    • From the front of the Steam Deck, use your finger to push the right touchpad partway through the front shell to unseat it.
    FixBot'a Sor
    Yorum Ekle
  42. Steam Deck Front Shell Replacement, Remove the quick access button membrane: adım 42, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the quick access button membrane: adım 42, 2 resimden 2.
    • Use a pair of tweezers to remove the quick access button membrane.
    FixBot'a Sor
    Yorum Ekle
  43. Steam Deck Front Shell Replacement, Remove the quick access button: adım 43, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the quick access button: adım 43, 2 resimden 2.
    • Use a pair of tweezers to remove the quick access button.
    FixBot'a Sor
    Yorum Ekle
  44. Steam Deck Front Shell Replacement, Remove the Steam button membrane: adım 44, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the Steam button membrane: adım 44, 2 resimden 2.
    • Use a pair of tweezers to remove the Steam button membrane.
    FixBot'a Sor
    Yorum Ekle
  45. Steam Deck Front Shell Replacement, Remove the Steam button: adım 45, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the Steam button: adım 45, 2 resimden 2.
    • Use a pair of tweezers to remove the Steam button.
    FixBot'a Sor
    Yorum Ekle
  46. Steam Deck Front Shell Replacement, Remove the SSD screw: adım 46, 1 resimden 1.
    • Use a Phillips driver to remove the 3.4 mm screw securing the SSD.
    FixBot'a Sor
    Yorum Ekle
  47. Steam Deck Front Shell Replacement, Remove the SSD: adım 47, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the SSD: adım 47, 2 resimden 2.
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the end of the SSD and pull it away from its M.2 board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
    FixBot'a Sor
    Yorum Ekle
  48. Steam Deck Front Shell Replacement, Remove the heatsink sticker: adım 48, 3 resimden 1. Steam Deck Front Shell Replacement, Remove the heatsink sticker: adım 48, 3 resimden 2. Steam Deck Front Shell Replacement, Remove the heatsink sticker: adım 48, 3 resimden 3.
    • Use a pair of tweezers to remove the sticker from the top edge of the fan.
    • If possible, try not to rip or tear this sticker so it can be reused. Use a little bit of heat if necessary to soften the adhesive.
    FixBot'a Sor
    Yorum Ekle
  49. Steam Deck Front Shell Replacement, Remove the heatsink screws: adım 49, 1 resimden 1.
    • Use a Phillips driver to loosen and remove the two screws securing the heatsink to the motherboard:
    • One captive 3.5 mm screw
    • One 3.4 mm screw
    • No, your eyes don't deceive you! The third heatsink screw was removed earlier in the disassembly: it doubles as the hidden board shield screw.
    FixBot'a Sor
    Yorum Ekle
  50. Steam Deck Front Shell Replacement, Remove the heatsink: adım 50, 3 resimden 1. Steam Deck Front Shell Replacement, Remove the heatsink: adım 50, 3 resimden 2. Steam Deck Front Shell Replacement, Remove the heatsink: adım 50, 3 resimden 3.
    • Lift and remove the heatsink.
    • Before reinstalling the heatsink, follow this guide to clean the heatsink and APU and reapply thermal paste.
    FixBot'a Sor
    Yorum Ekle
  51. Steam Deck Front Shell Replacement, Disconnect the fan: adım 51, 2 resimden 1. Steam Deck Front Shell Replacement, Disconnect the fan: adım 51, 2 resimden 2.
    • Use a pair of tweezers to grip the edges of the fan connector and pull up to disconnect it from the motherboard.
    • Pull the fan cable by its connector, not the wires themselves.
    FixBot'a Sor
    Yorum Ekle
  52. Steam Deck Front Shell Replacement, Remove the fan screws: adım 52, 1 resimden 1.
    • Use a Phillips driver to remove the two 3.7 mm screws securing the fan.
    • The other two fan screws were removed earlier in the disassembly: they double as two back cover screws.
    FixBot'a Sor
    Yorum Ekle
  53. Steam Deck Front Shell Replacement, Remove the fan: adım 53, 1 resimden 1.
    • Remove the fan.
    FixBot'a Sor
    Yorum Ekle
  54. Steam Deck Front Shell Replacement, Disconnect the speakers: adım 54, 2 resimden 1. Steam Deck Front Shell Replacement, Disconnect the speakers: adım 54, 2 resimden 2.
    • Use a pair of tweezers to grip the edges of the speaker connector and pull up to disconnect it from the motherboard.
    • Pull the speaker cable by its connector, not the wires themselves.
    FixBot'a Sor
    Yorum Ekle
  55. Steam Deck Front Shell Replacement, Remove the Wi-Fi shield tape: adım 55, 3 resimden 1. Steam Deck Front Shell Replacement, Remove the Wi-Fi shield tape: adım 55, 3 resimden 2. Steam Deck Front Shell Replacement, Remove the Wi-Fi shield tape: adım 55, 3 resimden 3.
    • Use a pair of tweezers to peel up and remove the Wi-Fi shield tape.
    FixBot'a Sor
    Yorum Ekle
  56. Steam Deck Front Shell Replacement, Disconnect the Wi-Fi: adım 56, 3 resimden 1. Steam Deck Front Shell Replacement, Disconnect the Wi-Fi: adım 56, 3 resimden 2. Steam Deck Front Shell Replacement, Disconnect the Wi-Fi: adım 56, 3 resimden 3.
    • Use a pair of tweezers to grip the antenna connector close to its base.
    • Pull straight up to disconnect the cable.
    • Repeat for the second antenna cable.
    • During reassembly, ensure that both antenna cables are reconnected at their appropriate connectors. The labels on the cables match the markings on the Wi-Fi module.
    • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
    FixBot'a Sor
    Yorum Ekle
  57. Steam Deck Front Shell Replacement, Disconnect the display: adım 57, 3 resimden 1. Steam Deck Front Shell Replacement, Disconnect the display: adım 57, 3 resimden 2. Steam Deck Front Shell Replacement, Disconnect the display: adım 57, 3 resimden 3.
    • Use the pointed end of a spudger to lift up the small locking flap on the display cable's ZIF connector.
    • Grip the cable by the pull tab, not by the cable itself.
    FixBot'a Sor
    Yorum Ekle
  58. Steam Deck Front Shell Replacement, Disconnect the audio cable: adım 58, 2 resimden 1. Steam Deck Front Shell Replacement, Disconnect the audio cable: adım 58, 2 resimden 2.
    • Use the pointed end of a spudger to lift up the small locking flap on the audio cable's ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  59. Steam Deck Front Shell Replacement: adım 59, 2 resimden 1. Steam Deck Front Shell Replacement: adım 59, 2 resimden 2.
    • Grip the cable by its pull tab, not by the cable itself.
    FixBot'a Sor
    Yorum Ekle
  60. Steam Deck Front Shell Replacement: adım 60, 3 resimden 1. Steam Deck Front Shell Replacement: adım 60, 3 resimden 2. Steam Deck Front Shell Replacement: adım 60, 3 resimden 3.
    • Carefully peel the audio cable off of the battery.
    • The audio cable is secured to the battery with some light adhesive.
    • If the adhesive is stubborn, don't force the cable. Lightly heat the audio cable using an iOpener or a hair dryer to soften the adhesive.
    FixBot'a Sor
    Yorum Ekle
  61. Steam Deck Front Shell Replacement, Remove the motherboard screws: adım 61, 1 resimden 1.
    • Use a Phillips driver to remove the three 3.7 mm screws securing the motherboard.
    FixBot'a Sor
    Yorum Ekle
  62. Steam Deck Front Shell Replacement, Remove the motherboard: adım 62, 3 resimden 1. Steam Deck Front Shell Replacement, Remove the motherboard: adım 62, 3 resimden 2. Steam Deck Front Shell Replacement, Remove the motherboard: adım 62, 3 resimden 3.
    • Remove the motherboard.
    • The audio and button board cables attach to the underside of the motherboard with ZIF connectors.
    FixBot'a Sor
    Yorum Ekle
  63. Steam Deck Front Shell Replacement, Disconnect the mic cable: adım 63, 3 resimden 1. Steam Deck Front Shell Replacement, Disconnect the mic cable: adım 63, 3 resimden 2. Steam Deck Front Shell Replacement, Disconnect the mic cable: adım 63, 3 resimden 3.
    • Use the pointed end of a spudger to lift up on the mic cable's white locking tab.
    • You should feel a small tactile bump once the connector unlocks.
    • Use a pair of tweezers to pull the mic cable up and out of its connector.
    • With the connector properly unlocked, the mic cable should slide out with little to no resistance.
    • During reassembly, ensure that the locking tab is in its unlocked, lifted position before reinserting the mic cable. Press down on the tab to lock the cable in place.
    FixBot'a Sor
    Yorum Ekle
  64. Steam Deck Front Shell Replacement, Remove the audio board screws: adım 64, 1 resimden 1.
    • Use a Phillips driver to remove the two 3.7 mm screws securing the audio board.
    FixBot'a Sor
    Yorum Ekle
  65. Steam Deck Front Shell Replacement, Remove the audio board: adım 65, 3 resimden 1. Steam Deck Front Shell Replacement, Remove the audio board: adım 65, 3 resimden 2. Steam Deck Front Shell Replacement, Remove the audio board: adım 65, 3 resimden 3.
    • Use a pair of tweezers to grip the audio board by the headphone jack.
    • Pivot the board up and out of its recess to remove it.
    FixBot'a Sor
    Yorum Ekle
  66. Steam Deck Front Shell Replacement, Isolate the speaker wire: adım 66, 1 resimden 1.
    • Use a pair of tweezers to peel up the tape bundling the speaker wire to the Wi-Fi antenna cables.
    FixBot'a Sor
    Yorum Ekle
  67. Steam Deck Front Shell Replacement: adım 67, 3 resimden 1. Steam Deck Front Shell Replacement: adım 67, 3 resimden 2. Steam Deck Front Shell Replacement: adım 67, 3 resimden 3.
    • Use a pair of tweezers to peel up the various strips of black tape routing the speaker wire along the bottom edge of the chassis.
    FixBot'a Sor
    Yorum Ekle
  68. Steam Deck Front Shell Replacement, Remove the right speaker: adım 68, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the right speaker: adım 68, 2 resimden 2.
    • Insert the flat end of a spudger between the right speaker and the frame.
    • Pivot the spudger up to separate the speaker from the light adhesive securing it against the front shell.
    • If the adhesive is stubborn, don't force the speaker out. Lightly heat it using an iOpener or a hair dryer to soften the adhesive underneath.
    FixBot'a Sor
    Yorum Ekle
  69. Steam Deck Front Shell Replacement: adım 69, 2 resimden 1. Steam Deck Front Shell Replacement: adım 69, 2 resimden 2.
    • Use a pair of tweezers to grip and remove the right speaker from its cavity.
    FixBot'a Sor
    Yorum Ekle
  70. Steam Deck Front Shell Replacement, Remove the left speaker: adım 70, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the left speaker: adım 70, 2 resimden 2.
    • Insert the flat end of a spudger between the left speaker and the frame.
    FixBot'a Sor
    Yorum Ekle
  71. Steam Deck Front Shell Replacement: adım 71, 2 resimden 1. Steam Deck Front Shell Replacement: adım 71, 2 resimden 2.
    • Use a pair of tweezers to grip and remove the left speaker from its cavity.
    FixBot'a Sor
    Yorum Ekle
  72. Steam Deck Front Shell Replacement, Remove the speakers: adım 72, 1 resimden 1.
    • Remove the tethered right and left speakers.
    FixBot'a Sor
    Yorum Ekle
  73. Steam Deck Front Shell Replacement, Uncover the display connector: adım 73, 2 resimden 1. Steam Deck Front Shell Replacement, Uncover the display connector: adım 73, 2 resimden 2.
    • Use a pair of tweezers to peel back the sticker covering the display connector.
    FixBot'a Sor
    Yorum Ekle
  74. Steam Deck Front Shell Replacement, Disconnect the display: adım 74, 3 resimden 1. Steam Deck Front Shell Replacement, Disconnect the display: adım 74, 3 resimden 2. Steam Deck Front Shell Replacement, Disconnect the display: adım 74, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
  75. Steam Deck Front Shell Replacement, Heat the display adhesive: adım 75, 1 resimden 1.
    • Prepare an iOpener and apply it to the top edge of the display for one minute.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the Steam Deck—displays and internal batteries are both susceptible to heat damage.
    FixBot'a Sor
    Yorum Ekle
  76. Steam Deck Front Shell Replacement, Insert an opening pick: adım 76, 3 resimden 1. Steam Deck Front Shell Replacement, Insert an opening pick: adım 76, 3 resimden 2. Steam Deck Front Shell Replacement, Insert an opening pick: adım 76, 3 resimden 3.
    • Apply a suction cup to the top left corner of the display by pressing down on it to create suction, as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken glass.
    • Pull up on the suction cup with strong, steady force to create a gap between the display and the frame.
    • Insert the point of an opening pick into the gap.
    • Don't insert the pick more than 1/8 of an inch (~3 mm) or you risk damaging the display panel, ambient light sensor, or fragile cable underneath.
    FixBot'a Sor
    Yorum Ekle
  77. Steam Deck Front Shell Replacement, Begin to slice the adhesive: adım 77, 3 resimden 1. Steam Deck Front Shell Replacement, Begin to slice the adhesive: adım 77, 3 resimden 2. Steam Deck Front Shell Replacement, Begin to slice the adhesive: adım 77, 3 resimden 3.
    • Slide the opening pick no more than 3 mm deep across the top edge to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  78. Steam Deck Front Shell Replacement, Heat the display adhesive: adım 78, 1 resimden 1.
    • Heat the right edge of the display for one minute.
    FixBot'a Sor
    Yorum Ekle
  79. Steam Deck Front Shell Replacement, Slice the right side adhesive: adım 79, 3 resimden 1. Steam Deck Front Shell Replacement, Slice the right side adhesive: adım 79, 3 resimden 2. Steam Deck Front Shell Replacement, Slice the right side adhesive: adım 79, 3 resimden 3.
    • Slide the opening pick down the right edge to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  80. Steam Deck Front Shell Replacement, Heat the display adhesive: adım 80, 1 resimden 1.
    • Heat the bottom edge of the display for one minute.
    FixBot'a Sor
    Yorum Ekle
  81. Steam Deck Front Shell Replacement, Slice the bottom side adhesive: adım 81, 3 resimden 1. Steam Deck Front Shell Replacement, Slice the bottom side adhesive: adım 81, 3 resimden 2. Steam Deck Front Shell Replacement, Slice the bottom side adhesive: adım 81, 3 resimden 3.
    • Slide the opening pick across the bottom edge to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  82. Steam Deck Front Shell Replacement, Heat the display adhesive: adım 82, 1 resimden 1.
    • Heat the left edge of the display for one minute.
    • Slide the opening pick across the left edge to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  83. Steam Deck Front Shell Replacement, Lift up the display: adım 83, 3 resimden 1. Steam Deck Front Shell Replacement, Lift up the display: adım 83, 3 resimden 2. Steam Deck Front Shell Replacement, Lift up the display: adım 83, 3 resimden 3.
    • Once you have sliced around the perimeter of the display, carefully lift the right edge up, opening it like a book.
    • Remove the display.
    • During reassembly, if you’d like to install new display adhesive strips, follow these steps after removing your old adhesive strips from your current display.
    FixBot'a Sor
    Yorum Ekle
  84. Steam Deck Front Shell Replacement, Remove the bumper screws: adım 84, 1 resimden 1.
    • Use a Phillips driver to remove the two 5.2 mm screws securing the left bumper assembly.
    FixBot'a Sor
    Yorum Ekle
  85. Steam Deck Front Shell Replacement, Remove the left bumper assembly: adım 85, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the left bumper assembly: adım 85, 2 resimden 2.
    • Remove the left bumper assembly.
    FixBot'a Sor
    Yorum Ekle
  86. Steam Deck Front Shell Replacement, Remove the bumper screws: adım 86, 1 resimden 1.
    • Use a Phillips driver to remove the two 5.2 mm screws securing the right bumper assembly.
    FixBot'a Sor
    Yorum Ekle
  87. Steam Deck Front Shell Replacement, Remove the right bumper assembly: adım 87, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the right bumper assembly: adım 87, 2 resimden 2.
    • Remove the right bumper assembly.
    FixBot'a Sor
    Yorum Ekle
  88. Steam Deck Front Shell Replacement, Remove the D-pad membrane: adım 88, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the D-pad membrane: adım 88, 2 resimden 2.
    • Use a pair of tweezers to remove the D-pad membrane.
    FixBot'a Sor
    Yorum Ekle
  89. Steam Deck Front Shell Replacement, Remove the D-pad: adım 89, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the D-pad: adım 89, 2 resimden 2.
    • Use a pair of tweezers to remove the D-pad.
    • During reassembly, align the D-pad button such that the short side is facing towards the Steam Deck's outer edge.
    FixBot'a Sor
    Yorum Ekle
  90. Steam Deck Front Shell Replacement, Remove the action buttons membrane: adım 90, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the action buttons membrane: adım 90, 2 resimden 2.
    • Use a pair of tweezers to remove the action buttons membrane.
    FixBot'a Sor
    Yorum Ekle
  91. Steam Deck Front Shell Replacement, Remove the action buttons: adım 91, 3 resimden 1. Steam Deck Front Shell Replacement, Remove the action buttons: adım 91, 3 resimden 2. Steam Deck Front Shell Replacement, Remove the action buttons: adım 91, 3 resimden 3.
    • Use a pair of tweezers to remove the four action buttons, A, B, X, and Y.
    • During reassembly, don't worry! The buttons are keyed—they can only be reinstalled in one orientation.
    FixBot'a Sor
    Yorum Ekle
  92. Steam Deck Front Shell Replacement, Remove the view button: adım 92, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the view button: adım 92, 2 resimden 2.
    • Use a pair of tweezers to remove the view button.
    FixBot'a Sor
    Yorum Ekle
  93. Steam Deck Front Shell Replacement, Remove the menu button: adım 93, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the menu button: adım 93, 2 resimden 2.
    • Use a pair of tweezers to remove the menu button.
    FixBot'a Sor
    Yorum Ekle
  94. Steam Deck Front Shell Replacement, Remove the front midframe screws: adım 94, 1 resimden 1.
    • Use a Phillips driver to remove the six 2.3 mm screws securing the midframe to the front shell, located on the front side.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different Phillips driver if the screws won't come out.
    FixBot'a Sor
    Yorum Ekle
  95. Steam Deck Front Shell Replacement, Remove the rear midframe screws: adım 95, 1 resimden 1.
    • Use a Phillips driver to remove the four 5.2 mm screws securing the midframe to the front shell.
    FixBot'a Sor
    Yorum Ekle
  96. Steam Deck Front Shell Replacement, Remove the midframe: adım 96, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the midframe: adım 96, 2 resimden 2.
    • Remove the midframe.
    FixBot'a Sor
    Yorum Ekle
  97. Steam Deck Front Shell Replacement: adım 97, 2 resimden 1. Steam Deck Front Shell Replacement: adım 97, 2 resimden 2.
    • Use the pointed end of a spudger to lift the rubber flap to the left of the volume buttons up and out of its plastic clip.
    FixBot'a Sor
    Yorum Ekle
  98. Steam Deck Front Shell Replacement, Remove the volume buttons: adım 98, 3 resimden 1. Steam Deck Front Shell Replacement, Remove the volume buttons: adım 98, 3 resimden 2. Steam Deck Front Shell Replacement, Remove the volume buttons: adım 98, 3 resimden 3.
    • Use a pair of tweezers to remove the volume buttons by pulling them up and away from the front shell.
    FixBot'a Sor
    Yorum Ekle
  99. Steam Deck Front Shell Replacement: adım 99, 2 resimden 1. Steam Deck Front Shell Replacement: adım 99, 2 resimden 2.
    • Use the pointed end of a spudger to lift the rubber flap to the right of the power button up and out of its plastic clip.
    FixBot'a Sor
    Yorum Ekle
  100. Steam Deck Front Shell Replacement, Remove the power button: adım 100, 3 resimden 1. Steam Deck Front Shell Replacement, Remove the power button: adım 100, 3 resimden 2. Steam Deck Front Shell Replacement, Remove the power button: adım 100, 3 resimden 3.
    • Use the pointed end of a spudger to lift the rubber flap to the left of the power button up and out of its plastic clip.
    • Remove the power button.
    FixBot'a Sor
    Yorum Ekle
  101. Steam Deck Front Shell Replacement: adım 101, 2 resimden 1. Steam Deck Front Shell Replacement: adım 101, 2 resimden 2.
    • Insert the flat end of a spudger under the left end of the mic cable and pry upwards to peel it up from the front shell.
    • The mic cable is secured to the front shell with some light adhesive.
    • If the adhesive is stubborn, don't force the cable. Lightly heat the mic cable using an iOpener or a hair dryer to soften the adhesive.
    FixBot'a Sor
    Yorum Ekle
  102. Steam Deck Front Shell Replacement: adım 102, 3 resimden 1. Steam Deck Front Shell Replacement: adım 102, 3 resimden 2. Steam Deck Front Shell Replacement: adım 102, 3 resimden 3.
    • Insert the flat end of a spudger under the right end of the mic cable and pry upwards to peel it up from the front shell.
    FixBot'a Sor
    Yorum Ekle
  103. Steam Deck Front Shell Replacement, Remove the mic cable: adım 103, 2 resimden 1. Steam Deck Front Shell Replacement, Remove the mic cable: adım 103, 2 resimden 2.
    • Remove the mic cable from the front shell.
    • Only the front shell remains.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
24 farklı kişi bu kılavuzu tamamladı.
Carsten Frauenheim
167.735 İtibar
439 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
32.272 adet Kılavuz yazıldı
20Kılavuz Yorumları
maybe I don’t need an Atomic Purple replacement shell…
Jon - Yanıt Paylaş
Hahaha. Same
Rob - Yanıt Paylaş
Same, wouldn't have minded a sweet water dipped or translucent outer shell. Bring back that mad catz/third party aesthetic.
Ichi Yamamoto - Yanıt Paylaş
I wanted to replace my old shell with a new one cause it got scratches... well, now I feel the scratches ain't that ugly.
Milo Zhao - Yanıt Paylaş
Seems to me like a "Welp...I guess if I ever break the screen and have to replace it, that's when I'll get an atomic purple shell...
reginalb124 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 25
Son 7 gün: 192
Son 30 gün: 1,018
Her zaman: 69,866
