OWC Aura Pro X SSD
  • OWC Aura Pro X SSD
OWC Aura Pro X SSD
$169,99
$169,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ürün Detayı
Açıklama
Açıklama
Replace or upgrade the PCIe solid-state drive in a variety of Macs.
Requires Mac OS High Sierra 10.13 or later.
Make your factory installed Apple PCIe SSD into an external SSD drive with an OWC Envoy Pro External Enclosure. Transfer data to your new internal SSD and/or keep the original drive as added external storage. The OWC Envoy enclosure is specifically designed for use only with the factory SSD found installed in the Mac models listed in compatibility. Do not attempt to install or use an OWC Aura SSD as external storage in an Envoy enclosure. This may damage the Aura drive, the Envoy enclosure, or both.
Not
Upgrade to macOS 10.13 or later, prior to Aura Pro X installation. MacOS 10.13 and later versions include an EFI (firmware) update that adds support for the Aura Pro X to the host computer. If you do not first update the host firmware by installing macOS 10.13 or later onto the existing SSD, the Aura Pro X will not function properly once installed.
Uyumluluk
Mac Mini Late 2014
1.4 GHz (Dual i5)
2.6 GHz (Dual i5)
2.8 GHz (Dual i5)
3.0 GHz (Dual i7)
Mac Pro Late 2013
2.7 GHz (12 Core)
3.0 GHz (8 Core)
3.5 GHz (6 Core)
3.7 GHz (Quad Core)
MacBook Air 11" Early 2014
1.4 GHz
1.7 GHz
MacBook Air 11" Early 2015
1.6 GHz
2.2 GHz
MacBook Air 11" Mid 2013
1.3 GHz
1.7 GHz
MacBook Air 13" Early 2014
1.4 GHz
1.7 GHz
MacBook Air 13" Early 2015
1.6 GHz
2.2 GHz
MacBook Air 13" Early 2017
1.8 GHz
2.2 GHz
MacBook Air 13" Mid 2013
1.3 GHz
1.7 GHz
MacBook Pro 13" Retina Display Early 2015
2.7 GHz
2.9 GHz
3.1 GHz
MacBook Pro 13" Retina Display Late 2013
2.4 GHz
2.6 GHz
2.8 GHz
MacBook Pro 13" Retina Display Mid 2014
2.6 GHz
2.8 GHz
3.0 GHz
MacBook Pro 15" Retina Display Late 2013
2.0 GHz (Integrated Graphics)
2.3 GHz (Dual Graphics)
2.3 GHz (Integrated Graphics)
2.6 GHz (Dual Graphics)
2.6 GHz (Integrated Graphics)
MacBook Pro 15" Retina Display Mid 2014
2.2 GHz (Integrated Graphics)
2.5 GHz (Dual Graphics)
2.5 GHz (Integrated Graphics)
2.8 GHz (Dual Graphics)
2.8 GHz (Integrated Graphics)
MacBook Pro 15" Retina Display Mid 2015
12 cihaz daha göster
Müşteri Yorumları
